postgres@my:~/Python-3.5.10$[b] pkg-config --modversion gtk+-2.0[/b]
Package gtk+-2.0 was not found in the pkg-config search path.
Perhaps you should add the directory containing `gtk+-2.0.pc'
to the PKG_CONFIG_PATH environment variable
No package 'gtk+-2.0' found
postgres@my:~/Python-3.5.10$ [b]pkg-config --modversion glib-2.0[/b]
Package glib-2.0 was not found in the pkg-config search path.
Perhaps you should add the directory containing `glib-2.0.pc'
No package 'glib-2.0' found
pkg-config --list-all grep gtk
adwaita-icon-theme gnome-icon-theme - A collection of icons used as the basis for GNOME themes
applewmproto AppleWMProto - AppleWM extension headers
bash-completion bash-completion - programmable completion for the bash shell
bigreqsproto BigReqsProto - BigReqs extension headers
compositeproto CompositeExt - Composite extension headers
damageproto DamageProto - Damage extension headers
dbus-1 dbus - Free desktop message bus
dmxproto DMXProto - DMX extension headers
dpmsproto DPMSProto - DPMS extension headers
dri2proto DRI2Proto - DRI2 extension headers
dri3proto DRI3Proto - DRI3 extension headers
expat expat - expat XML parser
fixesproto FixesProto - X Fixes extension headers
fontconfig Fontconfig - Font configuration and customization library
fontsproto FontsProto - Fonts extension headers
fontutil FontUtil - Font utilities dirs
form form - ncurses 6.3 add-on library
formw formw - ncurses 6.3 add-on library
freetype2 FreeType 2 - A free, high-quality, and portable font engine.
gcalc-2 libgcalc - GNOME Calculator Libray
gci-1 libgcalc - GNOME Calculator Libray GTK Interface
geoclue-2.0 Geoclue - The Geoinformation Service
glproto GLProto - GL extension headers
grilo-plugins-0.3 Grilo Framework Plugins - Plugins for the Grilo Framework
ibus-table IBus-Table - Table Based Input Method Framework for Intelligent Input Bus for Linux / Unix OS
inputproto InputProto - Input extension headers
iso-codes iso-codes - ISO country, language, script and currency codes and translations
kbproto KBProto - KB extension headers
libbrotlicommon libbrotlicommon - Brotli common dictionary library
libbrotlidec libbrotlidec - Brotli decoder library
libbrotlienc libbrotlienc - Brotli encoder library
libcrypt libxcrypt - Extended crypt library for DES, MD5, Blowfish and others
libcrypto OpenSSL-libcrypto - OpenSSL cryptography library
libffi libffi - Library supporting Foreign Function Interfaces
liblzma liblzma - General purpose data compression library
libnsl libnsl - Library containing NIS functions using TI-RPC (IPv6 enabled)
libpainter libpainter - Library for manipulating memory bitmaps.
libpcap libpcap - Platform-independent network traffic capture library
libpng libpng - Loads and saves PNG files
libpng16 libpng - Loads and saves PNG files
libssl OpenSSL-libssl - Secure Sockets Layer and cryptography libraries
libtirpc libtirpc - Transport Independent RPC Library
libxcrypt libxcrypt - Extended crypt library for DES, MD5, Blowfish and others
menu menu - ncurses 6.3 add-on library
menuw menuw - ncurses 6.3 add-on library
mobile-broadband-provider-info mobile-broadband-provider-info - Mobile Broadband Service Provider Information Database
ncurses ncurses - ncurses 6.3 library
ncurses++ ncurses++ - ncurses 6.3 add-on library
ncurses++w ncurses++w - ncurses 6.3 add-on library
ncursesw ncursesw - ncurses 6.3 library
openssl OpenSSL - Secure Sockets Layer and cryptography libraries and tools
panel panel - ncurses 6.3 add-on library
panelw panelw - ncurses 6.3 add-on library
poppler-data poppler-data - Encoding files for use with poppler
presentproto PresentProto - Present extension headers
pthread-stubs pthread stubs - Meta package for pthread symbols - defaults to heavyweight ones if the C runtime does not provide lightweight ones.
python-3.10 Python - Build a C extension for Python
python-3.10-embed Python - Embed Python into an application
python3 Python - Build a C extension for Python
python3-embed Python - Embed Python into an application
randrproto RandrProto - Randr extension headers
readline Readline - Gnu Readline library for command line editing
recordproto RecordProto - Record extension headers
renderproto RenderProto - Render extension headers
resourceproto ResourceProto - Resource extension headers
rfxcodec rfxcodec - Fast jpeg2000 codec compatible with MS RDP servers and xrdp
scrnsaverproto ScrnSaverProto - ScrnSaver extension headers
shared-mime-info shared-mime-info - Freedesktop common MIME database
sqlite3 SQLite - SQL database engine
systemd systemd - systemd System and Service Manager
tcl Tool Command Language - Tcl is a powerful, easy-to-learn dynamic programming language, suitable for a wide range of uses.
tcl8.6 Tool Command Language - Tcl is a powerful, easy-to-learn dynamic programming language, suitable for a wide range of uses.
tic tic - ncurses 6.3 add-on library
tinfo tinfo - ncurses 6.3 terminal interface library
tk The Tk Toolkit - Tk is a cross-platform graphical user interface toolkit, the standard GUI not only for Tcl, but for many other dynamic languages as well.
tk8.6 The Tk Toolkit - Tk is a cross-platform graphical user interface toolkit, the standard GUI not only for Tcl, but for many other dynamic languages as well.
udev udev - udev
uuid uuid - Universally unique id library
videoproto VideoProto - Video extension headers
x11 X11 - X Library
xau Xau - X authorization file management libary
xbitmaps X bitmaps - Bitmaps that are shared between X applications
xcb XCB - X-protocol C Binding
xcmiscproto XCMiscProto - XCMisc extension headers
xdmcp Xdmcp - X Display Manager Control Protocol library
xext Xext - Misc X Extension Library
xextproto XExtProto - XExt extension headers
xf86bigfontproto XF86BigFontProto - XF86BigFont extension headers
xf86dgaproto XF86DGAProto - XF86DGA extension headers
xf86driproto XF86DRIProto - XF86DRI extension headers
xf86vidmodeproto XF86VidModeProto - XF86VidMode extension headers
xft Xft - X FreeType library
xineramaproto XineramaProto - Xinerama extension headers
xkbcomp xkbcomp - XKB keymap compiler
xkeyboard-config XKeyboardConfig - X Keyboard configuration data
xorg-sgml-doctools xorg-sgml-doctools - Stylesheets and entities for X.Org documentation
xorg-wacom xorg-wacom - X.Org Wacom Tablet driver.
xpm Xpm - X Pixmap Library
xproto Xproto - Xproto headers
xrdp xrdp - An open source Remote Desktop Protocol (RDP) server
xrender Xrender - X Render Library
xscrnsaver XScrnSaver - The XScrnSaver Library
xtrans XTrans - Abstract network code for X
yelp-xsl yelp-xsl - Yelp XSLT Stylesheets
zlib zlib - zlib compression library
postgres@my:~/Python-3.5.10$ dpkg -s libgtk-3-0|grep '^Version'
Version: 3.24.33-1ubuntu2
postgres@my:~/Python-3.5.10$ dpkg -s libgtk-3-0|grep '^Version' | cut -d' ' -f2-
3.24.33-1ubuntu2
postgres@servers:~/Python-3.5.10$ env | grep gtk
postgres@my:~/Python-3.5.10$ dpkg-query -W libgtk-3-bin
libgtk-3-bin 3.24.33-1ubuntu2
