冒昧问一下armbian无法进入桌面
Ubuntu各种衍生版本
lihaha28
系统: ubuntu
冒昧问一下armbian无法进入桌面
帖子 lihaha28 » 2022-07-17 19:21
有一个phicomm T1盒子,装了armbian到gdm登录界面输入密码之后进不去桌面,会返回登录界面,特来求助,下面把dmesg贴出来,感谢!
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000] Linux version 5.15.55-flippy-74+o (root@univm25) (Ubuntu clang version 14.0.0-1ubuntu1, Ubuntu LLD 14.0.0) #142 SMP PREEMPT Sat Jul 16 02:15:09 CST 2022
[    0.000000] Machine model: Amlogic Meson GXM (S912) Q201 Development Board
[    0.000000] efi: UEFI not found.
[    0.000000] Reserved memory: created CMA memory pool at 0x0000000063400000, size 256 MiB
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000000000000-0x0000000077ffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000000000-0x0000000000ffffff]
[    0.000000]   node   0: [mem 0x0000000001000000-0x0000000004ffffff]
[    0.000000]   node   0: [mem 0x0000000005000000-0x00000000072fffff]
[    0.000000]   node   0: [mem 0x0000000007300000-0x000000000fffffff]
[    0.000000]   node   0: [mem 0x0000000010000000-0x00000000101fffff]
[    0.000000]   node   0: [mem 0x0000000010200000-0x0000000077ffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x0000000077ffffff]
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv0.2 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] percpu: Embedded 19 pages/cpu s37720 r8192 d31912 u77824
[    0.000000] pcpu-alloc: s37720 r8192 d31912 u77824 alloc=19*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5 [0] 6 [0] 7
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: detected: ARM erratum 845719
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 483840
[    0.000000] Kernel command line: root=UUID=3edfda7b-e43d-45b1-b01b-1f2f96993e8f rootflags=data=writeback rw rootfstype=ext4 console=ttyAML0,115200n8 console=tty0 no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1 mac=68:DB:54:5D:D8:42
[    0.000000] Unknown kernel command line parameters "cgroup_enable=memory cgroup_memory=1 mac=68:DB:54:5D:D8:42", will be passed to user space.
[    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] Memory: 1580236K/1966080K available (15104K kernel code, 2720K rwdata, 5928K rodata, 1984K init, 886K bss, 123700K reserved, 262144K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] 	Trampoline variant of Tasks RCU enabled.
[    0.000000] 	Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] Root IRQ handler: gic_handle_irq
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] irq_meson_gpio: 110 to 8 gpio interrupt mux initialized
[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000000] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.000563] Console: colour dummy device 80x25
[    0.000967] printk: console [tty0] enabled
[    0.001034] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[    0.001059] pid_max: default: 32768 minimum: 301
[    0.001302] LSM: Security Framework initializing
[    0.001390] SELinux:  Initializing.
[    0.001648] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    0.001675] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    0.004281] rcu: Hierarchical SRCU implementation.
[    0.005511] EFI services will not be available.
[    0.006160] smp: Bringing up secondary CPUs ...
[    0.006907] Detected VIPT I-cache on CPU1
[    0.006978] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.007729] Detected VIPT I-cache on CPU2
[    0.007782] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[    0.008500] Detected VIPT I-cache on CPU3
[    0.008551] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[    0.009273] Detected VIPT I-cache on CPU4
[    0.009341] CPU4: Booted secondary processor 0x0000000100 [0x410fd034]
[    0.010074] Detected VIPT I-cache on CPU5
[    0.010105] CPU5: Booted secondary processor 0x0000000101 [0x410fd034]
[    0.010777] Detected VIPT I-cache on CPU6
[    0.010808] CPU6: Booted secondary processor 0x0000000102 [0x410fd034]
[    0.011500] Detected VIPT I-cache on CPU7
[    0.011531] CPU7: Booted secondary processor 0x0000000103 [0x410fd034]
[    0.011628] smp: Brought up 1 node, 8 CPUs
[    0.011762] SMP: Total of 8 processors activated.
[    0.011774] CPU features: detected: 32-bit EL0 Support
[    0.011784] CPU features: detected: 32-bit EL1 Support
[    0.011797] CPU features: detected: CRC32 instructions
[    0.012890] CPU: All CPU(s) started at EL2
[    0.012942] alternatives: patching kernel code
[    0.015208] devtmpfs: initialized
[    0.023353] Registered cp15_barrier emulation handler
[    0.023393] Registered setend emulation handler
[    0.023562] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[    0.023595] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[    0.030081] prandom: seed boundary self test passed
[    0.031290] prandom: 100 self tests passed
[    0.054239] prandom32: self test passed (less than 6 bits correlated)
[    0.054294] pinctrl core: initialized pinctrl subsystem
[    0.054905] DMI not present or invalid.
[    0.055401] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.057865] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
[    0.058333] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.058589] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.058682] audit: initializing netlink subsys (disabled)
[    0.058952] audit: type=2000 audit(0.056:1): state=initialized audit_enabled=0 res=1
[    0.060016] thermal_sys: Registered thermal governor 'step_wise'
[    0.060402] cpuidle: using governor ladder
[    0.060611] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.060828] ASID allocator initialised with 65536 entries
[    0.061011] Serial: AMBA PL011 UART driver
[    0.079801] platform c883a000.hdmi-tx: Fixing up cyclic dependency with d0100000.vpu
[    0.084345] platform cvbs-connector: Fixing up cyclic dependency with d0100000.vpu
[    0.084619] platform hdmi-connector: Fixing up cyclic dependency with c883a000.hdmi-tx
[    0.093529] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.093558] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    0.093573] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.093587] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    1.781186] cryptd: max_cpu_qlen set to 1000
[    1.785460] "cryptomgr_test" (118) uses obsolete ecb(arc4) skcipher
[    1.800605] alg: No test for 842 (842-generic)
[    1.800766] alg: No test for 842 (842-scomp)
[    1.909110] DRBG: Continuing without Jitter RNG
[    1.993437] raid6: neonx8   gen()  2229 MB/s
[    2.050202] raid6: neonx8   xor()  1605 MB/s
[    2.106976] raid6: neonx4   gen()  2219 MB/s
[    2.163725] raid6: neonx4   xor()  1541 MB/s
[    2.220495] raid6: neonx2   gen()  2043 MB/s
[    2.277258] raid6: neonx2   xor()  1434 MB/s
[    2.334033] raid6: neonx1   gen()  1662 MB/s
[    2.390817] raid6: neonx1   xor()  1178 MB/s
[    2.447558] raid6: int64x8  gen()  1506 MB/s
[    2.504311] raid6: int64x8  xor()   802 MB/s
[    2.561082] raid6: int64x4  gen()  1553 MB/s
[    2.617832] raid6: int64x4  xor()   823 MB/s
[    2.674604] raid6: int64x2  gen()  1389 MB/s
[    2.731365] raid6: int64x2  xor()   740 MB/s
[    2.788132] raid6: int64x1  gen()  1169 MB/s
[    2.844882] raid6: int64x1  xor()   582 MB/s
[    2.844894] raid6: using algorithm neonx8 gen() 2229 MB/s
[    2.844906] raid6: .... xor() 1605 MB/s, rmw enabled
[    2.844917] raid6: using neon recovery algorithm
[    2.845140] fbcon: Taking over console
[    2.845178] ACPI: Interpreter disabled.
[    2.847411] iommu: Default domain type: Translated
[    2.847440] iommu: DMA domain TLB invalidation policy: strict mode
[    2.847861] vgaarb: loaded
[    2.848435] SCSI subsystem initialized
[    2.848677] usbcore: registered new interface driver usbfs
[    2.848737] usbcore: registered new interface driver hub
[    2.848792] usbcore: registered new device driver usb
[    2.849302] mc: Linux media interface: v0.10
[    2.849337] videodev: Linux video capture interface: v2.00
[    2.849636] EDAC MC: Ver: 3.0.0
[    2.850730] Advanced Linux Sound Architecture Driver Initialized.
[    2.852148] clocksource: Switched to clocksource arch_sys_counter
[    2.852472] VFS: Disk quotas dquot_6.6.0
[    2.852561] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    2.852731] FS-Cache: Loaded
[    2.853248] pnp: PnP ACPI: disabled
[    2.860936] NET: Registered PF_INET protocol family
[    2.861145] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    2.862468] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
[    2.862525] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    2.862604] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    2.862740] TCP bind hash table entries: 16384 (order: 6, 262144 bytes, linear)
[    2.862974] TCP: Hash tables configured (established 16384 bind 16384)
[    2.863264] MPTCP token hash table entries: 2048 (order: 3, 49152 bytes, linear)
[    2.863365] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
[    2.863421] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
[    2.863663] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    2.863702] NET: Registered PF_XDP protocol family
[    2.863725] PCI: CLS 0 bytes, default 64
[    2.864052] Trying to unpack rootfs image as initramfs...
[    2.876735] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[    2.877258] kvm [1]: IPA Size Limit: 40 bits
[    2.878341] kvm [1]: vgic interrupt IRQ9
[    2.878607] kvm [1]: Hyp mode initialized successfully
[    3.437486] Freeing initrd memory: 7888K
[    3.664646] Initialise system trusted keyrings
[    3.664916] workingset: timestamp_bits=46 max_order=19 bucket_order=0
[    3.671996] zbud: loaded
[    3.674182] fuse: init (API version 7.34)
[    3.674712] SGI XFS with ACLs, security attributes, quota, no debug enabled
[    3.714866] NET: Registered PF_ALG protocol family
[    3.775336] xor: measuring software checksum speed
[    3.780169]    8regs           :  2051 MB/sec
[    3.783573]    32regs          :  2908 MB/sec
[    3.788159]    arm64_neon      :  2154 MB/sec
[    3.788172] xor: using function: 32regs (2908 MB/sec)
[    3.788189] Key type asymmetric registered
[    3.788200] Asymmetric key parser 'x509' registered
[    3.788311] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[    3.788523] io scheduler mq-deadline registered
[    3.788538] io scheduler kyber registered
[    3.788726] io scheduler bfq registered
[    3.814303] soc soc0: Amlogic Meson GXM (S912) Revision 22:a (82:2) Detected
[    3.816689] Serial: 8250/16550 driver, 5 ports, IRQ sharing enabled
[    3.818779] Serial: AMBA driver
[    3.819233] c81004c0.serial: ttyAML0 at MMIO 0xc81004c0 (irq = 22, base_baud = 1500000) is a meson_uart
[    4.866392] printk: console [ttyAML0] enabled
[    4.880394] brd: module loaded
[    4.884898] loop: module loaded
[    4.891992] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    4.892928] ehci-pci: EHCI PCI platform driver
[    4.897363] ehci-platform: EHCI generic platform driver
[    4.903082] usbcore: registered new interface driver cdc_wdm
[    4.908130] usbcore: registered new interface driver usb-storage
[    4.914583] mousedev: PS/2 mouse device common for all mice
[    4.920555] SPI driver rmi4_spi has no spi_device_id for syna,rmi4-spi
[    4.926805] meson-vrtc c81000a8.rtc: registered as rtc0
[    4.931234] meson-vrtc c81000a8.rtc: setting system clock to 1970-01-01T00:00:04 UTC (4)
[    4.939789] i2c_dev: i2c /dev entries driver
[    4.945807] Registered IR keymap rc-cec
[    4.947379] rc rc0: meson_ao_cec as /devices/platform/soc/c8100000.bus/c8100100.cec/rc/rc0
[    4.955611] input: meson_ao_cec as /devices/platform/soc/c8100000.bus/c8100100.cec/rc/rc0/input0
[    4.967747] Synopsys Designware Multimedia Card Interface Driver
[    4.971542] meson-gx-mmc d0072000.mmc: Got CD GPIO
[    4.971967] meson-gx-mmc d0074000.mmc: allocated mmc-pwrseq
[    4.972851] meson-sm: secure-monitor enabled
[    4.974647] gxl-crypto c883e000.crypto: will run requests pump with realtime priority
[    4.974778] gxl-crypto c883e000.crypto: will run requests pump with realtime priority
[    4.980995] hid: raw HID events driver (C) Jiri Kosina
[    5.005630] usbcore: registered new interface driver usbhid
[    5.010752] usbhid: USB HID core driver
[    5.014968] platform-mhu c883c404.mailbox: Platform MHU Mailbox registered
[    5.028449] Initializing XFRM netlink socket
[    5.028833] gpio irq setup: hwirq: 0x3A irqfirst: 0x34 irqlast: 0x3A pin[48]
[    5.029128] NET: Registered PF_INET6 protocol family
[    5.034642] genirq: Setting trigger mode 3 for irq 41 failed (meson_gpio_irq_set_type+0x0/0x140)
[    5.078353] Segment Routing with IPv6
[    5.078401] RPL Segment Routing with IPv6
[    5.080491] In-situ OAM (IOAM) with IPv6
[    5.084447] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    5.093540] bpfilter: Loaded bpfilter_umh pid 328
[    5.094845] NET: Registered PF_PACKET protocol family
[    5.099918] NET: Registered PF_KEY protocol family
[    5.104697] 8021q: 802.1Q VLAN Support v1.8
[    5.109191] registered taskstats version 1
[    5.112812] Loading compiled-in X.509 certificates
[    5.122758] zswap: loaded using pool zstd/zbud
[    5.123482] Key type ._fscrypt registered
[    5.125858] Key type .fscrypt registered
[    5.129722] Key type fscrypt-provisioning registered
[    5.135833] Btrfs loaded, crc32c=crc32c-generic, zoned=no, fsverity=no
[    5.157855] mmc2: new HS200 MMC card at address 0001
[    5.158994] mmcblk2: mmc2:0001 AJNB4R 14.6 GiB
[    5.164333] mmcblk2boot0: mmc2:0001 AJNB4R 4.00 MiB
[    5.168495] mmcblk2boot1: mmc2:0001 AJNB4R 4.00 MiB
[    5.173182] mmcblk2rpmb: mmc2:0001 AJNB4R 4.00 MiB, chardev (240:0)
[    5.174381] meson-drm d0100000.vpu: Queued 3 outputs on vpu
[    5.212203] meson-dw-hdmi c883a000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
[    5.216988] meson-dw-hdmi c883a000.hdmi-tx: registered DesignWare HDMI I2C bus driver
[    5.225137] meson-drm d0100000.vpu: bound c883a000.hdmi-tx (ops meson_dw_hdmi_ops)
[    5.232531] [drm] Initialized meson 1.0.0 20161109 for d0100000.vpu on minor 0
[    5.350576] [drm] kms: can't enable cloning when we probably wanted to.
[    5.517557] Console: switching to colour frame buffer device 240x67
[    5.561565] meson-drm d0100000.vpu: [drm] fb0: mesondrmfb frame buffer device
[    5.571152] meson8b-dwmac c9410000.ethernet: IRQ eth_wake_irq not found
[    5.575215] meson8b-dwmac c9410000.ethernet: IRQ eth_lpi not found
[    5.581488] meson8b-dwmac c9410000.ethernet: PTP uses main clock
[    5.588502] meson8b-dwmac c9410000.ethernet: User ID: 0x11, Synopsys ID: 0x37
[    5.594353] meson8b-dwmac c9410000.ethernet: 	DWMAC1000
[    5.599520] meson8b-dwmac c9410000.ethernet: DMA HW capability register supported
[    5.606936] meson8b-dwmac c9410000.ethernet: RX Checksum Offload Engine supported
[    5.614352] meson8b-dwmac c9410000.ethernet: COE Type 2
[    5.619527] meson8b-dwmac c9410000.ethernet: TX Checksum insertion supported
[    5.626513] meson8b-dwmac c9410000.ethernet: Wake-Up On Lan supported
[    5.632896] meson8b-dwmac c9410000.ethernet: Normal descriptors
[    5.638761] meson8b-dwmac c9410000.ethernet: Ring mode enabled
[    5.644539] meson8b-dwmac c9410000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[    5.655764] dwc3-meson-g12a d0078080.usb: USB2 ports: 3
[    5.657643] dwc3-meson-g12a d0078080.usb: USB3 ports: 0
[    5.668430] dwc2 c9100000.usb: supply vusb_d not found, using dummy regulator
[    5.670343] dwc2 c9100000.usb: supply vusb_a not found, using dummy regulator
[    5.677463] dwc2 c9100000.usb: EPs: 7, dedicated fifos, 712 entries in SPRAM
[    5.686734] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller
[    5.689852] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 1
[    5.697369] xhci-hcd xhci-hcd.3.auto: hcc params 0x0228f664 hci version 0x100 quirks 0x0000000002010010
[    5.706579] xhci-hcd xhci-hcd.3.auto: irq 43, io mem 0xc9000000
[    5.712874] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[    5.720564] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    5.727720] usb usb1: Product: xHCI Host Controller
[    5.732549] usb usb1: Manufacturer: Linux 5.15.55-flippy-74+o xhci-hcd
[    5.739018] usb usb1: SerialNumber: xhci-hcd.3.auto
[    5.744505] hub 1-0:1.0: USB hub found
[    5.747616] hub 1-0:1.0: 3 ports detected
[    5.752079] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller
[    5.757214] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 2
[    5.764566] xhci-hcd xhci-hcd.3.auto: Host supports USB 3.0 SuperSpeed
[    5.771103] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    5.779324] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15
[    5.787234] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    5.794391] usb usb2: Product: xHCI Host Controller
[    5.799220] usb usb2: Manufacturer: Linux 5.15.55-flippy-74+o xhci-hcd
[    5.805690] usb usb2: SerialNumber: xhci-hcd.3.auto
[    5.811151] hub 2-0:1.0: USB hub found
[    5.814267] hub 2-0:1.0: config failed, hub doesn't have any ports! (err -19)
[    5.824600] scpi_protocol scpi: SCP Protocol legacy pre-1.0 firmware
[    5.864782] meson-gx-mmc d0070000.mmc: allocated mmc-pwrseq
[    5.880372] ALSA device list:
[    5.886042]   No soundcards found.
[    5.898211] Freeing unused kernel memory: 1984K
[    5.919102] Run /init as init process
[    5.927737]   with arguments:
[    5.927748]     /init
[    5.927753]   with environment:
[    5.927757]     HOME=/
[    5.927761]     TERM=linux
[    5.927766]     cgroup_enable=memory
[    5.927771]     cgroup_memory=1
[    5.927776]     mac=68:DB:54:5D:D8:42
[    6.008910] usb 1-2: new high-speed USB device number 2 using xhci-hcd
[    6.015815] mmc0: new high speed SDIO card at address 0001
[    6.167000] usb 1-2: New USB device found, idVendor=2109, idProduct=2815, bcdDevice= 7.04
[    6.175786] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    6.183488] usb 1-2: Product: USB2.0 Hub
[    6.189819] usb 1-2: Manufacturer: VIA Labs, Inc.
[    6.251509] hub 1-2:1.0: USB hub found
[    6.257965] hub 1-2:1.0: 4 ports detected
[    7.032342] usb 1-2.2: new full-speed USB device number 3 using xhci-hcd
[    7.238606] usb 1-2.2: New USB device found, idVendor=046d, idProduct=c53f, bcdDevice=44.01
[    7.302087] usb 1-2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    7.327939] usb 1-2.2: Product: USB Receiver
[    7.351820] usb 1-2.2: Manufacturer: Logitech
[    7.474696] input: Logitech USB Receiver as /devices/platform/soc/d0078080.usb/c9000000.usb/xhci-hcd.3.auto/usb1/1-2/1-2.2/1-2.2:1.0/0003:046D:C53F.0001/input/input1
[    7.569134] hid-generic 0003:046D:C53F.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-xhci-hcd.3.auto-2.2/input0
[    7.612304] input: Logitech USB Receiver Mouse as /devices/platform/soc/d0078080.usb/c9000000.usb/xhci-hcd.3.auto/usb1/1-2/1-2.2/1-2.2:1.1/0003:046D:C53F.0002/input/input2
[    7.650489] input: Logitech USB Receiver Consumer Control as /devices/platform/soc/d0078080.usb/c9000000.usb/xhci-hcd.3.auto/usb1/1-2/1-2.2/1-2.2:1.1/0003:046D:C53F.0002/input/input3
[    7.729560] input: Logitech USB Receiver System Control as /devices/platform/soc/d0078080.usb/c9000000.usb/xhci-hcd.3.auto/usb1/1-2/1-2.2/1-2.2:1.1/0003:046D:C53F.0002/input/input4
[    7.755696] hid-generic 0003:046D:C53F.0002: input,hiddev96,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-xhci-hcd.3.auto-2.2/input1
[    7.760426] hid-generic 0003:046D:C53F.0003: hiddev97,hidraw2: USB HID v1.11 Device [Logitech USB Receiver] on usb-xhci-hcd.3.auto-2.2/input2
[    7.882185] usb 1-2.3: new full-speed USB device number 4 using xhci-hcd
[    7.909034] logitech-djreceiver 0003:046D:C53F.0001: hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-xhci-hcd.3.auto-2.2/input0
[    8.044932] usb 1-2.3: New USB device found, idVendor=09da, idProduct=2403, bcdDevice= 1.26
[    8.127076] usb 1-2.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    8.160758] usb 1-2.3: Product: 2.4G Device
[    8.176806] usb 1-2.3: Manufacturer: COMPANY
[    8.266210] logitech-djreceiver 0003:046D:C53F.0002: hiddev96,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-xhci-hcd.3.auto-2.2/input1
[    8.274676] input: COMPANY 2.4G Device as /devices/platform/soc/d0078080.usb/c9000000.usb/xhci-hcd.3.auto/usb1/1-2/1-2.3/1-2.3:1.0/0003:09DA:2403.0004/input/input6
[    8.370754] logitech-djreceiver 0003:046D:C53F.0003: hiddev97,hidraw2: USB HID v1.11 Device [Logitech USB Receiver] on usb-xhci-hcd.3.auto-2.2/input2
[    8.410989] hid-generic 0003:09DA:2403.0004: input,hidraw3: USB HID v1.11 Keyboard [COMPANY 2.4G Device] on usb-xhci-hcd.3.auto-2.3/input0
[    8.449655] input: COMPANY 2.4G Device Mouse as /devices/platform/soc/d0078080.usb/c9000000.usb/xhci-hcd.3.auto/usb1/1-2/1-2.3/1-2.3:1.1/0003:09DA:2403.0005/input/input7
[    8.473462] logitech-djreceiver 0003:046D:C53F.0003: device of type eQUAD Lightspeed 1.1 (0x0d) connected on slot 1
[    8.478478] input: COMPANY 2.4G Device Keyboard as /devices/platform/soc/d0078080.usb/c9000000.usb/xhci-hcd.3.auto/usb1/1-2/1-2.3/1-2.3:1.1/0003:09DA:2403.0005/input/input8
[    8.587101] input: Logitech Wireless Mouse PID:4074 Keyboard as /devices/platform/soc/d0078080.usb/c9000000.usb/xhci-hcd.3.auto/usb1/1-2/1-2.2/1-2.2:1.2/0003:046D:C53F.0003/0003:046D:4074.0006/input/input10
[    8.705976] input: COMPANY 2.4G Device as /devices/platform/soc/d0078080.usb/c9000000.usb/xhci-hcd.3.auto/usb1/1-2/1-2.3/1-2.3:1.1/0003:09DA:2403.0005/input/input9
[    8.707429] input: Logitech Wireless Mouse PID:4074 Mouse as /devices/platform/soc/d0078080.usb/c9000000.usb/xhci-hcd.3.auto/usb1/1-2/1-2.2/1-2.2:1.2/0003:046D:C53F.0003/0003:046D:4074.0006/input/input11
[    8.725226] hid-generic 0003:09DA:2403.0005: input,hiddev98,hidraw4: USB HID v1.11 Mouse [COMPANY 2.4G Device] on usb-xhci-hcd.3.auto-2.3/input1
[    8.757758] hid-generic 0003:046D:4074.0006: input,hidraw5: USB HID v1.11 Keyboard [Logitech Wireless Mouse PID:4074] on usb-xhci-hcd.3.auto-2.2/input2:1
[    8.918950] usb 1-2.4: new high-speed USB device number 5 using xhci-hcd
[    9.002818] input: Logitech G304 as /devices/platform/soc/d0078080.usb/c9000000.usb/xhci-hcd.3.auto/usb1/1-2/1-2.2/1-2.2:1.2/0003:046D:C53F.0003/0003:046D:4074.0006/input/input15
[    9.047908] logitech-hidpp-device 0003:046D:4074.0006: input,hidraw5: USB HID v1.11 Keyboard [Logitech G304] on usb-xhci-hcd.3.auto-2.2/input2:1
[    9.117257] usb 1-2.4: New USB device found, idVendor=090c, idProduct=2000, bcdDevice=11.00
[    9.164013] usb 1-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    9.187484] usb 1-2.4: Product: Flash Disk
[    9.209102] usb 1-2.4: Manufacturer: USB
[    9.222314] usb-storage 1-2.4:1.0: USB Mass Storage device detected
[    9.267373] scsi host0: usb-storage 1-2.4:1.0
[   10.369157] scsi 0:0:0:0: Direct-Access     USB      Flash Disk       1100 PQ: 0 ANSI: 6
[   10.417440] sd 0:0:0:0: [sda] 61736960 512-byte logical blocks: (31.6 GB/29.4 GiB)
[   10.476436] sd 0:0:0:0: [sda] Write Protect is off
[   10.519599] sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00
[   10.520567] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[   10.551999]  sda: sda1 sda2
[   10.578593] sd 0:0:0:0: [sda] Attached SCSI removable disk
[   11.233341] EXT4-fs (sda2): mounted filesystem with writeback data mode. Opts: data=writeback. Quota mode: none.
[   12.030477] systemd[1]: System time before build time, advancing clock.
[   12.174903] systemd[1]: systemd 247.3-7 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified)
[   12.221755] systemd[1]: Detected architecture arm64.
[   12.269553] systemd[1]: Set hostname to <armbian>.
[   13.300427] systemd[1]: Queued start job for default target Graphical Interface.
[   13.314163] random: systemd: uninitialized urandom read (16 bytes read)
[   13.328641] systemd[1]: Created slice system-getty.slice.
[   13.346684] random: systemd: uninitialized urandom read (16 bytes read)
[   13.358163] systemd[1]: Created slice system-modprobe.slice.
[   13.375714] random: systemd: uninitialized urandom read (16 bytes read)
[   13.387621] systemd[1]: Created slice system-serial\x2dgetty.slice.
[   13.407354] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[   13.426617] systemd[1]: Created slice User and Session Slice.
[   13.442932] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped.
[   13.458784] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[   13.478176] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[   13.498258] systemd[1]: Reached target Local Encrypted Volumes.
[   13.514815] systemd[1]: Reached target User and Group Name Lookups.
[   13.531316] systemd[1]: Reached target Paths.
[   13.546733] systemd[1]: Reached target Slices.
[   13.561573] systemd[1]: Reached target Swap.
[   13.575903] systemd[1]: Reached target System Time Set.
[   13.619259] systemd[1]: Listening on RPCbind Server Activation Socket.
[   13.634374] systemd[1]: Listening on Syslog Socket.
[   13.648429] systemd[1]: Listening on fsck to fsckd communication Socket.
[   13.662871] systemd[1]: Listening on initctl Compatibility Named Pipe.
[   13.677701] systemd[1]: Listening on Journal Audit Socket.
[   13.691288] systemd[1]: Listening on Journal Socket (/dev/log).
[   13.705425] systemd[1]: Listening on Journal Socket.
[   13.720695] systemd[1]: Listening on udev Control Socket.
[   13.734205] systemd[1]: Listening on udev Kernel Socket.
[   13.752538] systemd[1]: Mounting Huge Pages File System...
[   13.768662] systemd[1]: Mounting POSIX Message Queue File System...
[   13.785697] systemd[1]: Mounting NFSD configuration filesystem...
[   13.801875] systemd[1]: Mounting RPC Pipe File System...
[   13.818318] systemd[1]: Mounting Kernel Debug File System...
[   13.830937] systemd[1]: Condition check resulted in Kernel Trace File System being skipped.
[   13.839862] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
[   13.854500] systemd[1]: Starting Restore / save the current clock...
[   13.863294] RPC: Registered named UNIX socket transport module.
[   13.863313] RPC: Registered udp transport module.
[   13.863322] RPC: Registered tcp transport module.
[   13.863330] RPC: Registered tcp NFSv4.1 backchannel transport module.
[   13.898583] systemd[1]: Starting Set the console keyboard layout...
[   13.915557] systemd[1]: Starting Create list of static device nodes for the current kernel...
[   13.934986] systemd[1]: Starting Load Kernel Module configfs...
[   13.951271] systemd[1]: Starting Load Kernel Module drm...
[   13.963043] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[   13.976965] systemd[1]: Starting Load Kernel Module fuse...
[   13.995795] systemd[1]: Started Nameserver information manager.
[   14.008511] systemd[1]: Reached target Network (Pre).
[   14.026284] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[   14.043635] systemd[1]: Starting Load Kernel Modules...
[   14.058453] systemd[1]: Starting Remount Root and Kernel File Systems...
[   14.075588] systemd[1]: Starting Coldplug All udev Devices...
[   14.095754] systemd[1]: Mounted Huge Pages File System.
[   14.097500] EXT4-fs (sda2): re-mounted. Opts: errors=remount-ro. Quota mode: none.
[   14.121659] systemd[1]: Mounted POSIX Message Queue File System.
[   14.133478] systemd[1]: Mounted NFSD configuration filesystem.
[   14.145048] systemd[1]: Mounted RPC Pipe File System.
[   14.156493] systemd[1]: Mounted Kernel Debug File System.
[   14.169120] systemd[1]: Finished Restore / save the current clock.
[   14.182311] systemd[1]: Finished Create list of static device nodes for the current kernel.
[   14.198645] systemd[1]: modprobe@configfs.service: Succeeded.
[   14.207245] systemd[1]: Finished Load Kernel Module configfs.
[   14.221406] systemd[1]: modprobe@drm.service: Succeeded.
[   14.228694] systemd[1]: Finished Load Kernel Module drm.
[   14.243458] systemd[1]: modprobe@fuse.service: Succeeded.
[   14.251308] systemd[1]: Finished Load Kernel Module fuse.
[   14.270343] systemd[1]: Finished Load Kernel Modules.
[   14.283916] systemd[1]: Finished Remount Root and Kernel File Systems.
[   14.306978] systemd[1]: Mounting FUSE Control File System...
[   14.318727] random: systemd: uninitialized urandom read (16 bytes read)
[   14.328439] systemd[1]: Mounting Kernel Configuration File System...
[   14.340302] random: systemd: uninitialized urandom read (16 bytes read)
[   14.350121] systemd[1]: Starting pNFS block layout mapping daemon...
[   14.376223] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[   14.384777] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[   14.394124] random: systemd: uninitialized urandom read (16 bytes read)
[   14.404238] systemd[1]: Starting Load/Save Random Seed...
[   14.419327] systemd[1]: Starting Apply Kernel Variables...
[   14.434646] systemd[1]: Starting Create System Users...
[   14.451133] systemd[1]: Finished Set the console keyboard layout.
[   14.463728] systemd[1]: Mounted FUSE Control File System.
[   14.475693] systemd[1]: Mounted Kernel Configuration File System.
[   14.488351] systemd[1]: Started pNFS block layout mapping daemon.
[   14.501609] systemd[1]: Finished Create System Users.
[   14.516311] systemd[1]: Finished Apply Kernel Variables.
[   14.535954] systemd[1]: Starting Create Static Device Nodes in /dev...
[   14.565641] random: crng init done
[   14.570945] random: 40 urandom warning(s) missed due to ratelimiting
[   14.575208] systemd[1]: Finished Coldplug All udev Devices.
[   14.593669] systemd[1]: Starting Helper to synchronize boot up for ifupdown...
[   14.608322] systemd[1]: Finished Load/Save Random Seed.
[   14.620091] systemd[1]: Condition check resulted in First Boot Complete being skipped.
[   14.629704] systemd[1]: Finished Create Static Device Nodes in /dev.
[   14.641770] systemd[1]: Reached target Local File Systems (Pre).
[   14.658611] systemd[1]: Mounting /var/tmp...
[   14.676361] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[   14.693431] systemd[1]: Mounted /var/tmp.
[   14.910611] systemd[1]: Started Rule-based Manager for Device Events and Files.
[   15.151522] systemd[1]: Found device /dev/ttyAML0.
[   15.165580] Registered IR keymap rc-empty
[   15.173778] rc rc1: meson-ir as /devices/platform/soc/c8100000.bus/c8100580.ir/rc/rc1
[   15.183056] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned.
[   15.184899] rc rc1: lirc_dev: driver meson-ir registered at minor = 0, raw IR receiver, no transmitter
[   15.200485] systemd[1]: Reached target Hardware activated USB gadget.
[   15.205055] input: meson-ir as /devices/platform/soc/c8100000.bus/c8100580.ir/rc/rc1/input16
[   15.224637] meson-ir c8100580.ir: receiver initialized
[   15.225999] debugfs: Directory 'c1105400.audio-controller' with parent 'P230-Q200' already present!
[   15.226034] debugfs: Directory 'c1105400.audio-controller' with parent 'P230-Q200' already present!
[   15.230903] debugfs: File 'HDMITX Capture' in directory 'dapm' already present!
[   15.252440] panfrost d00c0000.gpu: clock rate = 24000000
[   15.279599] panfrost d00c0000.gpu: dev_pm_opp_set_regulators: no regulator (mali) found: -19
[   15.292392] panfrost d00c0000.gpu: mali-t820 id 0x820 major 0x1 minor 0x0 status 0x0
[   15.302320] panfrost d00c0000.gpu: features: 00000000,101e76ff, issues: 00000000,24040400
[   15.312579] panfrost d00c0000.gpu: Features: L2:0x07110206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002821 AS:0xff JS:0x7
[   15.326542] panfrost d00c0000.gpu: shader_present=0x7 l2_present=0x1
[   15.352821] [drm] Initialized panfrost 1.2.0 20180908 for d00c0000.gpu on minor 1
[   15.371006] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[   15.415372] sd 0:0:0:0: Attached scsi generic sg0 type 0
[   15.504618] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[   15.547728] [drm] kms: can't enable cloning when we probably wanted to.
[   15.581695] systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
[   15.602272] brcmfmac: F1 signature read @0x18000000=0x15264345
[   15.606369] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[   15.628775] brcmfmac mmc0:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.amlogic,q201.bin failed with error -2
[   15.657421] brcmfmac mmc0:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.amlogic,q201.txt failed with error -2
[   15.802524] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[   15.806402] systemd[1]: Found device Flash_Disk BOOT.
[   15.823480] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped.
[   15.837381] systemd[1]: Condition check resulted in Kernel Trace File System being skipped.
[   15.846511] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[   15.859746] systemd[1]: Starting File System Check on /dev/disk/by-label/BOOT...
[   15.872399] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Mar  1 2015 07:29:38 version 7.45.18 (r538002) FWID 01-6a2c8ad4
[   15.886180] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[   15.895211] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[   15.909670] systemd[1]: Started File System Check Daemon to report status.
[   15.943804] systemd[1]: Starting Load/Save RF Kill Switch Status...
[   16.027992] systemd[1]: Finished File System Check on /dev/disk/by-label/BOOT.
[   16.048827] systemd[1]: Mounting /boot...
[   16.181377] usbcore: registered new interface driver brcmfmac
[   16.268710] systemd[1]: Started Load/Save RF Kill Switch Status.
[   16.362321] Bluetooth: Core ver 2.22
[   16.382365] Bluetooth: Starting self testing
[   16.412967] Bluetooth: ECDH test passed in 17767 usecs
[   16.431163] Bluetooth: SMP test passed in 9574 usecs
[   16.438728] Bluetooth: Finished self testing
[   16.445893] NET: Registered PF_BLUETOOTH protocol family
[   16.451654] Bluetooth: HCI device and connection manager initialized
[   16.458089] Bluetooth: HCI socket layer initialized
[   16.463851] Bluetooth: L2CAP socket layer initialized
[   16.465028] systemd[1]: Mounted /boot.
[   16.469631] Bluetooth: SCO socket layer initialized
[   16.488325] systemd[1]: Reached target Local File Systems.
[   16.509290] systemd[1]: Starting Armbian leds state...
[   16.527412] systemd[1]: Starting Armbian ZRAM config...
[   16.544387] systemd[1]: Starting Set console font and keymap...
[   16.560504] systemd[1]: Starting Preprocess NFS configuration...
[   16.572651] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
[   16.582556] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
[   16.595363] systemd[1]: Finished Helper to synchronize boot up for ifupdown.
[   16.610953] systemd[1]: Finished Armbian leds state.
[   16.624776] systemd[1]: Finished Set console font and keymap.
[   16.638612] systemd[1]: nfs-config.service: Succeeded.
[   16.645734] systemd[1]: Finished Preprocess NFS configuration.
[   16.663348] systemd[1]: Starting Raise network interfaces...
[   16.678881] systemd[1]: Starting NFSv4 ID-name mapping service...
[   16.691729] systemd[1]: Condition check resulted in RPC security service for NFS client and server being skipped.
[   16.702146] systemd[1]: Condition check resulted in RPC security service for NFS server being skipped.
[   16.711575] systemd[1]: Reached target NFS client services.
[   16.748587] systemd[1]: Started NFSv4 ID-name mapping service.
[   16.821314] zram: Added device: zram0
[   16.829711] zram: Added device: zram1
[   16.837834] zram: Added device: zram2
[   16.935210] zram0: detected capacity change from 0 to 1852256
[   16.972848] Adding 926124k swap on /dev/zram0.  Priority:5 extents:1 across:926124k SSFS
[   17.174642] zram1: detected capacity change from 0 to 102400
[   17.281032] zram2: detected capacity change from 0 to 1852256
[   17.282080] meson8b-dwmac c9410000.ethernet eth0: PHY [0.e40908ff:08] driver [Meson GXL Internal PHY] (irq=44)
[   17.336489] meson8b-dwmac c9410000.ethernet eth0: Register MEM_TYPE_PAGE_POOL RxQ-0
[   17.358831] meson8b-dwmac c9410000.ethernet eth0: No Safety Features support found
[   17.366619] meson8b-dwmac c9410000.ethernet eth0: PTP not supported by HW
[   17.373861] meson8b-dwmac c9410000.ethernet eth0: configuring for phy/rmii link mode
[   17.396550] EXT4-fs (zram2): mounted filesystem without journal. Opts: discard. Quota mode: none.
[   17.433277] systemd[1]: Finished Armbian ZRAM config.
[   17.457731] systemd[1]: Starting Armbian memory supported logging...
[   17.546299] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard. Quota mode: none.
[   17.555627] ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff)
[   21.282188] systemd[1]: systemd-rfkill.service: Succeeded.
[   22.998003] systemd[1]: Finished Armbian memory supported logging.
[   23.032907] systemd[1]: Starting Journal Service...
[   23.319737] systemd[1]: Started Journal Service.
[   23.370518] systemd-journald[852]: Received client request to flush runtime journal.
[   23.379748] systemd-journald[852]: File /var/log/journal/d162928a1ddf4980be05cc81234a55ef/system.journal corrupted or uncleanly shut down, renaming and replacing.
[   28.600762] NFSD: Using UMH upcall client tracking operations.
[   28.604433] NFSD: starting 90-second grace period (net f0000000)
[   34.605966] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[   34.645733] meson-gx-mmc d0070000.mmc: unaligned sg len 96 blksize 512, disabling descriptor DMA for transfer
[   42.512572] rfkill: input handler disabled
[  388.477364] logitech-hidpp-device 0003:046D:4074.0006: HID++ 4.2 device connected.
[  396.614497] systemd-journald[852]: File /var/log/journal/d162928a1ddf4980be05cc81234a55ef/user-1000.journal corrupted or uncleanly shut down, renaming and replacing.
[  397.001291] rfkill: input handler enabled
[  397.282585] rfkill: input handler disabled
[  399.362304] rfkill: input handler enabled
Re: 冒昧问一下armbian无法进入桌面
帖子 astolia » 2022-07-24 10:51
dmesg显示的是内核日志,你进不去桌面是用户态进程的问题,具体错误不会出现到内核日志里。用journalctl -b 0来看
