我是在windows10下安装的WSL子系统,然后安装openfoam,按照openfoam官网上的编译指导过程安装完之后,进行测试,出现以下信息:
Basic setup :
OpenFOAM: OpenFOAM-v2112
ThirdParty: ThirdParty-v2112
Shell: bash
Host: LAPTOP-BE4H11SV
OS: Linux version 4.4.0-18362-Microsoft
Main OpenFOAM env variables :
Environment FileOrDirectory Valid Crit
$WM_PROJECT_USER_DIR /home/zjl/OpenFOAM/zjl-v2112 yes no
$WM_THIRD_PARTY_DIR /home/zjl/OpenFOAM/ThirdParty-v2112 yes maybe
$WM_PROJECT_SITE [env variable unset] no
OpenFOAM env variables in PATH :
Environment FileOrDirectory Valid Path Crit
$WM_PROJECT_DIR /home/zjl/OpenFOAM/OpenFOAM-v2112 yes yes yes
$FOAM_APPBIN ...12/platforms/linux64GccDPInt32Opt/bin no yes
$FOAM_SITE_APPBIN ...12/platforms/linux64GccDPInt32Opt/bin no no
$FOAM_USER_APPBIN ...12/platforms/linux64GccDPInt32Opt/bin no no
$WM_DIR /home/zjl/OpenFOAM/OpenFOAM-v2112/wmake yes yes often
OpenFOAM env variables in LD_LIBRARY_PATH :
$FOAM_LIBBIN ...12/platforms/linux64GccDPInt32Opt/lib no yes
$FOAM_SITE_LIBBIN ...12/platforms/linux64GccDPInt32Opt/lib no no
$FOAM_USER_LIBBIN ...12/platforms/linux64GccDPInt32Opt/lib no no
$FOAM_EXT_LIBBIN ...v2112/platforms/linux64GccDPInt32/lib no maybe
$MPI_ARCH_PATH /usr yes no yes
Software Components
Software Version Location
flex *** not installed ***
make *** not installed ***
wmake *** not installed ***
unknown c compiler for Gcc
unknown cxx compiler for Gcc
icoFoam *** not installed ***
CRITICAL ERROR
Summary
The system test evoked 2 fatal error(s).
The foam installation contains 1 critical error(s).
Review the output for warning messages and consult
the installation guide for troubleshooting.
Done
最后summary中显示的2个致命错误,是不是宣告了我openfoam没安装成功呀?
CFD小白,求大神帮忙看一下到底是哪个地方出了问题!!!
小白求教:OpenFOAM安装完成后,测试时出现2个fatal errors
- 系统: Linux version 4.4.0
Re: 小白求教:OpenFOAM安装完成后,测试时出现2个fatal errors
所以你安装gcc和make等必要的包了吗?Software Components
CRITICAL ERROR
感谢你的回答,gcc和make都安装了的,我今天又重头按照openfoam官网上的安装顺序再装了一遍,又可以运行了。onlylove 写了: ↑2022-06-05 8:37所以你安装gcc和make等必要的包了吗?Software Components
CRITICAL ERROR
