Ubuntu22.04运行VMWare16.2报错Unable to install all modules.
qhxia
系统: ubuntu22.04
帖子 qhxia » 2022-05-17 23:21
具体日志如下:
2022-05-17T14:53:07.987Z In(05) host-4407 Log for VMware Workstation pid=4407 version=16.2.0 build=build-18760230 option=Release
2022-05-17T14:53:07.987Z In(05) host-4407 The host is 64-bit.
2022-05-17T14:53:07.987Z In(05) host-4407 Host codepage=UTF-8 encoding=UTF-8
2022-05-17T14:53:07.987Z In(05) host-4407 Host is Linux 5.15.0-32-generic Ubuntu 22.04 LTS Ubuntu 22.04 LTS 22.04
2022-05-17T14:53:07.987Z In(05) host-4407 Host offset from UTC is +08:00.
2022-05-17T14:53:07.987Z In(05) host-4407 DictionaryLoad: Cannot open file "/usr/lib/vmware/settings": 没有那个文件或目录.
2022-05-17T14:53:07.987Z In(05) host-4407 [msg.dictionary.load.openFailed] Cannot open file "/usr/lib/vmware/settings": 没有那个文件或目录.
2022-05-17T14:53:07.987Z In(05) host-4407 PREF Optional preferences file not found at /usr/lib/vmware/settings. Using default values.
2022-05-17T14:53:07.987Z In(05) host-4407 DictionaryLoad: Cannot open file "/home/xqh/.vmware/config": 没有那个文件或目录.
2022-05-17T14:53:07.987Z In(05) host-4407 [msg.dictionary.load.openFailed] Cannot open file "/home/xqh/.vmware/config": 没有那个文件或目录.
2022-05-17T14:53:07.987Z In(05) host-4407 PREF Optional preferences file not found at /home/xqh/.vmware/config. Using default values.
2022-05-17T14:53:08.046Z Wa(03) host-4407 Logging to /tmp/vmware-xqh/vmware-4407.log
2022-05-17T14:53:08.053Z In(05) host-4407 Obtaining info using the running kernel.
2022-05-17T14:53:08.053Z In(05) host-4407 Created new pathsHash.
2022-05-17T14:53:08.053Z In(05) host-4407 Setting header path for 5.15.0-32-generic to "/lib/modules/5.15.0-32-generic/build/include".
2022-05-17T14:53:08.053Z In(05) host-4407 Validating path "/lib/modules/5.15.0-32-generic/build/include" for kernel release "5.15.0-32-generic".
2022-05-17T14:53:08.103Z In(05) host-4407 Failed to find /lib/modules/5.15.0-32-generic/build/include/linux/version.h
2022-05-17T14:53:08.103Z In(05) host-4407 /lib/modules/5.15.0-32-generic/build/include/linux/version.h not found, looking for generated/uapi/linux/version.h instead.
2022-05-17T14:53:08.103Z In(05) host-4407 using /usr/bin/gcc-11 for preprocess check
2022-05-17T14:53:08.131Z In(05) host-4407 Preprocessed UTS_RELEASE, got value "5.15.0-32-generic".
2022-05-17T14:53:08.131Z In(05) host-4407 The header path "/lib/modules/5.15.0-32-generic/build/include" for the kernel "5.15.0-32-generic" is valid. Whoohoo!
2022-05-17T14:53:08.264Z In(05) host-4407 found symbol version file /lib/modules/5.15.0-32-generic/build/Module.symvers
2022-05-17T14:53:08.264Z In(05) host-4407 Reading symbol versions from /lib/modules/5.15.0-32-generic/build/Module.symvers.
2022-05-17T14:53:08.279Z In(05) host-4407 Read 26217 symbol versions
2022-05-17T14:53:08.279Z In(05) host-4407 Reading in info for the vmmon module.
2022-05-17T14:53:08.279Z In(05) host-4407 Reading in info for the vmnet module.
2022-05-17T14:53:08.279Z In(05) host-4407 Invoking modinfo on "vmmon".
2022-05-17T14:53:08.281Z In(05) host-4407 "/sbin/modinfo" exited with status 256.
2022-05-17T14:53:08.281Z In(05) host-4407 Invoking modinfo on "vmnet".
2022-05-17T14:53:08.283Z In(05) host-4407 "/sbin/modinfo" exited with status 256.
2022-05-17T14:53:08.293Z In(05) host-4407 to be installed: vmmon status: 0
2022-05-17T14:53:08.293Z In(05) host-4407 to be installed: vmnet status: 0
2022-05-17T14:53:08.306Z In(05) host-4407 Obtaining info using the running kernel.
2022-05-17T14:53:08.306Z In(05) host-4407 Setting header path for 5.15.0-32-generic to "/lib/modules/5.15.0-32-generic/build/include".
2022-05-17T14:53:08.306Z In(05) host-4407 Validating path "/lib/modules/5.15.0-32-generic/build/include" for kernel release "5.15.0-32-generic".
2022-05-17T14:53:08.306Z In(05) host-4407 Failed to find /lib/modules/5.15.0-32-generic/build/include/linux/version.h
2022-05-17T14:53:08.306Z In(05) host-4407 /lib/modules/5.15.0-32-generic/build/include/linux/version.h not found, looking for generated/uapi/linux/version.h instead.
2022-05-17T14:53:08.306Z In(05) host-4407 using /usr/bin/gcc-11 for preprocess check
2022-05-17T14:53:08.310Z In(05) host-4407 Preprocessed UTS_RELEASE, got value "5.15.0-32-generic".
2022-05-17T14:53:08.310Z In(05) host-4407 The header path "/lib/modules/5.15.0-32-generic/build/include" for the kernel "5.15.0-32-generic" is valid. Whoohoo!
2022-05-17T14:53:08.432Z In(05) host-4407 found symbol version file /lib/modules/5.15.0-32-generic/build/Module.symvers
2022-05-17T14:53:08.432Z In(05) host-4407 Reading symbol versions from /lib/modules/5.15.0-32-generic/build/Module.symvers.
2022-05-17T14:53:08.444Z In(05) host-4407 Read 26217 symbol versions
2022-05-17T14:53:08.448Z In(05) host-4407 Kernel header path retrieved from FileEntry: /lib/modules/5.15.0-32-generic/build/include
2022-05-17T14:53:08.448Z In(05) host-4407 Update kernel header path to /lib/modules/5.15.0-32-generic/build/include
2022-05-17T14:53:08.448Z In(05) host-4407 Validating path "/lib/modules/5.15.0-32-generic/build/include" for kernel release "5.15.0-32-generic".
2022-05-17T14:53:08.448Z In(05) host-4407 Failed to find /lib/modules/5.15.0-32-generic/build/include/linux/version.h
2022-05-17T14:53:08.448Z In(05) host-4407 /lib/modules/5.15.0-32-generic/build/include/linux/version.h not found, looking for generated/uapi/linux/version.h instead.
2022-05-17T14:53:08.448Z In(05) host-4407 using /usr/bin/gcc-11 for preprocess check
2022-05-17T14:53:08.451Z In(05) host-4407 Preprocessed UTS_RELEASE, got value "5.15.0-32-generic".
2022-05-17T14:53:08.451Z In(05) host-4407 The header path "/lib/modules/5.15.0-32-generic/build/include" for the kernel "5.15.0-32-generic" is valid. Whoohoo!
2022-05-17T14:53:08.452Z In(05) host-4407 Found compiler at "/usr/bin/gcc"
2022-05-17T14:53:08.453Z In(05) host-4407 Got gcc version "11".
2022-05-17T14:53:08.453Z In(05) host-4407 The GCC version matches the kernel GCC minor version like a glove.
2022-05-17T14:53:08.454Z In(05) host-4407 Got gcc version "11".
2022-05-17T14:53:08.454Z In(05) host-4407 The GCC version matches the kernel GCC minor version like a glove.
2022-05-17T14:53:08.455Z In(05) host-4407 Trying to find a suitable PBM set for kernel "5.15.0-32-generic".
2022-05-17T14:53:08.455Z In(05) host-4407 No matching PBM set was found for kernel "5.15.0-32-generic".
2022-05-17T14:53:08.455Z In(05) host-4407 The GCC version matches the kernel GCC minor version like a glove.
2022-05-17T14:53:08.455Z In(05) host-4407 Validating path "/lib/modules/5.15.0-32-generic/build/include" for kernel release "5.15.0-32-generic".
2022-05-17T14:53:08.455Z In(05) host-4407 Failed to find /lib/modules/5.15.0-32-generic/build/include/linux/version.h
2022-05-17T14:53:08.455Z In(05) host-4407 /lib/modules/5.15.0-32-generic/build/include/linux/version.h not found, looking for generated/uapi/linux/version.h instead.
2022-05-17T14:53:08.455Z In(05) host-4407 using /usr/bin/gcc-11 for preprocess check
2022-05-17T14:53:08.458Z In(05) host-4407 Preprocessed UTS_RELEASE, got value "5.15.0-32-generic".
2022-05-17T14:53:08.458Z In(05) host-4407 The header path "/lib/modules/5.15.0-32-generic/build/include" for the kernel "5.15.0-32-generic" is valid. Whoohoo!
2022-05-17T14:53:10.759Z In(05) host-4407 The GCC version matches the kernel GCC minor version like a glove.
2022-05-17T14:53:10.759Z In(05) host-4407 Validating path "/lib/modules/5.15.0-32-generic/build/include" for kernel release "5.15.0-32-generic".
2022-05-17T14:53:10.759Z In(05) host-4407 Failed to find /lib/modules/5.15.0-32-generic/build/include/linux/version.h
2022-05-17T14:53:10.759Z In(05) host-4407 /lib/modules/5.15.0-32-generic/build/include/linux/version.h not found, looking for generated/uapi/linux/version.h instead.
2022-05-17T14:53:10.759Z In(05) host-4407 using /usr/bin/gcc-11 for preprocess check
2022-05-17T14:53:10.770Z In(05) host-4407 Preprocessed UTS_RELEASE, got value "5.15.0-32-generic".
2022-05-17T14:53:10.770Z In(05) host-4407 The header path "/lib/modules/5.15.0-32-generic/build/include" for the kernel "5.15.0-32-generic" is valid. Whoohoo!
2022-05-17T14:53:10.771Z In(05) host-4407 Using temp dir "/tmp".
2022-05-17T14:53:17.744Z In(05) host-4407 Stopping VMware services:
2022-05-17T14:53:17.744Z In(05) host-4407 VMware Authentication Daemon[71G done
2022-05-17T14:53:17.744Z In(05) host-4407 Virtual machine monitor[71G done
2022-05-17T14:53:17.744Z In(05) host-4407 make: 进入目录“/tmp/modconfig-iIlLDm/vmmon-only”
2022-05-17T14:53:17.744Z In(05) host-4407 /usr/bin/make -C /lib/modules/5.15.0-32-generic/build/include/.. M=$PWD SRCROOT=$PWD/. \
2022-05-17T14:53:17.744Z In(05) host-4407 MODULEBUILDDIR= modules
2022-05-17T14:53:17.744Z In(05) host-4407 make[1]: 进入目录“/usr/src/linux-headers-5.15.0-32-generic”
2022-05-17T14:53:17.744Z In(05) host-4407 CC [M] /tmp/modconfig-iIlLDm/vmmon-only/linux/driver.o
2022-05-17T14:53:17.744Z In(05) host-4407 CC [M] /tmp/modconfig-iIlLDm/vmmon-only/linux/driverLog.o
2022-05-17T14:53:17.744Z In(05) host-4407 CC [M] /tmp/modconfig-iIlLDm/vmmon-only/linux/hostif.o
2022-05-17T14:53:17.744Z In(05) host-4407 CC [M] /tmp/modconfig-iIlLDm/vmmon-only/common/apic.o
2022-05-17T14:53:17.744Z In(05) host-4407 CC [M] /tmp/modconfig-iIlLDm/vmmon-only/common/comport.o
2022-05-17T14:53:17.744Z In(05) host-4407 CC [M] /tmp/modconfig-iIlLDm/vmmon-only/common/cpuid.o
2022-05-17T14:53:17.744Z In(05) host-4407 CC [M] /tmp/modconfig-iIlLDm/vmmon-only/common/crosspage.o
2022-05-17T14:53:17.744Z In(05) host-4407 CC [M] /tmp/modconfig-iIlLDm/vmmon-only/common/memtrack.o
2022-05-17T14:53:17.744Z In(05) host-4407 CC [M] /tmp/modconfig-iIlLDm/vmmon-only/common/moduleloop.o
2022-05-17T14:53:17.744Z In(05) host-4407 CC [M] /tmp/modconfig-iIlLDm/vmmon-only/common/phystrack.o
2022-05-17T14:53:17.744Z In(05) host-4407 CC [M] /tmp/modconfig-iIlLDm/vmmon-only/common/sharedAreaVmmon.o
2022-05-17T14:53:17.744Z In(05) host-4407 CC [M] /tmp/modconfig-iIlLDm/vmmon-only/common/statVarsVmmon.o
2022-05-17T14:53:17.744Z In(05) host-4407 CC [M] /tmp/modconfig-iIlLDm/vmmon-only/common/task.o
2022-05-17T14:53:17.744Z In(05) host-4407 CC [M] /tmp/modconfig-iIlLDm/vmmon-only/common/vmx86.o
2022-05-17T14:53:17.744Z In(05) host-4407 CC [M] /tmp/modconfig-iIlLDm/vmmon-only/bootstrap/bootstrap.o
2022-05-17T14:53:17.744Z In(05) host-4407 CC [M] /tmp/modconfig-iIlLDm/vmmon-only/bootstrap/monLoader.o
2022-05-17T14:53:17.744Z In(05) host-4407 CC [M] /tmp/modconfig-iIlLDm/vmmon-only/bootstrap/monLoaderVmmon.o
2022-05-17T14:53:17.744Z In(05) host-4407 CC [M] /tmp/modconfig-iIlLDm/vmmon-only/bootstrap/vmmblob.o
2022-05-17T14:53:17.744Z In(05) host-4407 make[1]: 离开目录“/usr/src/linux-headers-5.15.0-32-generic”
2022-05-17T14:53:17.744Z In(05) host-4407 make: 离开目录“/tmp/modconfig-iIlLDm/vmmon-only”
2022-05-17T14:53:17.744Z In(05) host-4407 make: 进入目录“/tmp/modconfig-iIlLDm/vmnet-only”
2022-05-17T14:53:17.744Z In(05) host-4407 CC [M] /tmp/modconfig-iIlLDm/vmnet-only/driver.o
2022-05-17T14:53:17.744Z In(05) host-4407 CC [M] /tmp/modconfig-iIlLDm/vmnet-only/hub.o
2022-05-17T14:53:17.744Z In(05) host-4407 CC [M] /tmp/modconfig-iIlLDm/vmnet-only/userif.o
2022-05-17T14:53:17.744Z In(05) host-4407 CC [M] /tmp/modconfig-iIlLDm/vmnet-only/netif.o
2022-05-17T14:53:17.744Z In(05) host-4407 CC [M] /tmp/modconfig-iIlLDm/vmnet-only/bridge.o
2022-05-17T14:53:17.744Z In(05) host-4407 CC [M] /tmp/modconfig-iIlLDm/vmnet-only/procfs.o
2022-05-17T14:53:17.744Z In(05) host-4407 CC [M] /tmp/modconfig-iIlLDm/vmnet-only/smac_compat.o
2022-05-17T14:53:17.744Z In(05) host-4407 CC [M] /tmp/modconfig-iIlLDm/vmnet-only/smac.o
2022-05-17T14:53:17.744Z In(05) host-4407 CC [M] /tmp/modconfig-iIlLDm/vmnet-only/vnetEvent.o
2022-05-17T14:53:17.744Z In(05) host-4407 CC [M] /tmp/modconfig-iIlLDm/vmnet-only/vnetUserListener.o
2022-05-17T14:53:17.744Z In(05) host-4407 LD [M] /tmp/modconfig-iIlLDm/vmnet-only/vmnet.o
2022-05-17T14:53:17.744Z In(05) host-4407 MODPOST /tmp/modconfig-iIlLDm/vmnet-only/Module.symvers
2022-05-17T14:53:17.744Z In(05) host-4407 CC [M] /tmp/modconfig-iIlLDm/vmnet-only/vmnet.mod.o
2022-05-17T14:53:17.744Z In(05) host-4407 LD [M] /tmp/modconfig-iIlLDm/vmnet-only/vmnet.ko
2022-05-17T14:53:17.744Z In(05) host-4407 BTF [M] /tmp/modconfig-iIlLDm/vmnet-only/vmnet.ko
2022-05-17T14:53:17.744Z In(05) host-4407 /usr/bin/make -C $PWD SRCROOT=$PWD/. \
2022-05-17T14:53:17.744Z In(05) host-4407 MODULEBUILDDIR= postbuild
2022-05-17T14:53:17.744Z In(05) host-4407 make[1]: 进入目录“/tmp/modconfig-iIlLDm/vmnet-only”
2022-05-17T14:53:17.744Z In(05) host-4407 make[1]: “postbuild”已是最新。
2022-05-17T14:53:17.744Z In(05) host-4407 make[1]: 离开目录“/tmp/modconfig-iIlLDm/vmnet-only”
2022-05-17T14:53:17.744Z In(05) host-4407 cp -f vmnet.ko ./../vmnet.o
2022-05-17T14:53:17.744Z In(05) host-4407 make: 离开目录“/tmp/modconfig-iIlLDm/vmnet-only”
2022-05-17T14:53:17.744Z In(05) host-4407 [AppLoader] Use shipped Linux kernel AIO access library.
2022-05-17T14:53:17.744Z In(05) host-4407 An up-to-date "libaio" or "libaio1" package from your system is preferred.
2022-05-17T14:53:17.744Z In(05) host-4407 [AppLoader] GLib does not have GSettings support.
2022-05-17T14:53:17.744Z In(05) host-4407 Using kernel build system.
2022-05-17T14:53:17.744Z In(05) host-4407 /tmp/modconfig-iIlLDm/vmmon-only/common/phystrack.o: warning: objtool: PhysTrack_Free() falls through to next function PhysTrack_Add()
2022-05-17T14:53:17.744Z In(05) host-4407 /tmp/modconfig-iIlLDm/vmmon-only/common/phystrack.o: warning: objtool: PhysTrack_Add() falls through to next function PhysTrack_Remove()
2022-05-17T14:53:17.744Z In(05) host-4407 /tmp/modconfig-iIlLDm/vmmon-only/common/phystrack.o: warning: objtool: PhysTrack_Remove() falls through to next function PhysTrack_Test()
2022-05-17T14:53:17.744Z In(05) host-4407 In file included from /tmp/modconfig-iIlLDm/vmmon-only/common/vmx86.h:32,
2022-05-17T14:53:17.744Z In(05) host-4407 from /tmp/modconfig-iIlLDm/vmmon-only/common/moduleloop.c:34:
2022-05-17T14:53:17.744Z In(05) host-4407 /tmp/modconfig-iIlLDm/vmmon-only/./include/x86msr.h:122: warning: "MSR_TEST_CTRL" redefined
2022-05-17T14:53:17.744Z In(05) host-4407 122 | #define MSR_TEST_CTRL 0x33
2022-05-17T14:53:17.744Z In(05) host-4407 |
2022-05-17T14:53:17.744Z In(05) host-4407 In file included from ./arch/x86/include/asm/nospec-branch.h:12,
2022-05-17T14:53:17.744Z In(05) host-4407 from ./arch/x86/include/asm/irqflags.h:9,
2022-05-17T14:53:17.744Z In(05) host-4407 from ./include/linux/irqflags.h:16,
2022-05-17T14:53:17.744Z In(05) host-4407 from ./include/linux/rcupdate.h:26,
2022-05-17T14:53:17.744Z In(05) host-4407 from ./include/linux/rculist.h:11,
2022-05-17T14:53:17.744Z In(05) host-4407 from ./include/linux/pid.h:5,
2022-05-17T14:53:17.744Z In(05) host-4407 from ./include/linux/sched.h:14,
2022-05-17T14:53:17.744Z In(05) host-4407 from /tmp/modconfig-iIlLDm/vmmon-only/common/moduleloop.c:31:
2022-05-17T14:53:17.744Z In(05) host-4407 ./arch/x86/include/asm/msr-index.h:44: note: this is the location of the previous definition
2022-05-17T14:53:17.744Z In(05) host-4407 44 | #define MSR_TEST_CTRL 0x00000033
2022-05-17T14:53:17.744Z In(05) host-4407 /tmp/modconfig-iIlLDm/vmmon-only/./include/x86msr.h:123: warning: "MSR_TEST_CTRL_SPLIT_LOCK_DETECT" redefined
2022-05-17T14:53:17.744Z In(05) host-4407 123 | #define MSR_TEST_CTRL_SPLIT_LOCK_DETECT (1ULL << 29)
2022-05-17T14:53:17.744Z In(05) host-4407 ./arch/x86/include/asm/msr-index.h:46: note: this is the location of the previous definition
2022-05-17T14:53:17.744Z In(05) host-4407 46 | #define MSR_TEST_CTRL_SPLIT_LOCK_DETECT BIT(MSR_TEST_CTRL_SPLIT_LOCK_DETECT_BIT)
2022-05-17T14:53:17.744Z In(05) host-4407 /tmp/modconfig-iIlLDm/vmmon-only/./include/x86msr.h:150: warning: "MSR_MISC_FEATURES_ENABLES" redefined
2022-05-17T14:53:17.744Z In(05) host-4407 150 | #define MSR_MISC_FEATURES_ENABLES 0x140
2022-05-17T14:53:17.744Z In(05) host-4407 ./arch/x86/include/asm/msr-index.h:781: note: this is the location of the previous definition
2022-05-17T14:53:17.744Z In(05) host-4407 781 | #define MSR_MISC_FEATURES_ENABLES 0x00000140
2022-05-17T14:53:17.744Z In(05) host-4407 /tmp/modconfig-iIlLDm/vmmon-only/./include/x86msr.h:588: warning: "MSR_K7_HWCR_SMMLOCK" redefined
2022-05-17T14:53:17.744Z In(05) host-4407 588 | #define MSR_K7_HWCR_SMMLOCK 0x00000001ULL // Lock SMM environment
2022-05-17T14:53:17.744Z In(05) host-4407 ./arch/x86/include/asm/msr-index.h:581: note: this is the location of the previous definition
2022-05-17T14:53:17.744Z In(05) host-4407 581 | #define MSR_K7_HWCR_SMMLOCK BIT_ULL(MSR_K7_HWCR_SMMLOCK_BIT)
2022-05-17T14:53:17.744Z In(05) host-4407 /tmp/modconfig-iIlLDm/vmmon-only/./include/x86msr.h:795: warning: "MSR_TSX_FORCE_ABORT" redefined
2022-05-17T14:53:17.744Z In(05) host-4407 795 | #define MSR_TSX_FORCE_ABORT 0x0000010f
2022-05-17T14:53:17.744Z In(05) host-4407 ./arch/x86/include/asm/msr-index.h:790: note: this is the location of the previous definition
2022-05-17T14:53:17.744Z In(05) host-4407 790 | #define MSR_TSX_FORCE_ABORT 0x0000010F
2022-05-17T14:53:17.744Z In(05) host-4407 In file included from ./arch/x86/include/asm/processor.h:5,
2022-05-17T14:53:17.744Z In(05) host-4407 from ./arch/x86/include/asm/cpufeature.h:5,
2022-05-17T14:53:17.744Z In(05) host-4407 from ./arch/x86/include/asm/thread_info.h:53,
2022-05-17T14:53:17.744Z In(05) host-4407 from ./include/linux/thread_info.h:60,
2022-05-17T14:53:17.744Z In(05) host-4407 from ./arch/x86/include/asm/preempt.h:7,
2022-05-17T14:53:17.744Z In(05) host-4407 from ./include/linux/preempt.h:78,
2022-05-17T14:53:17.744Z In(05) host-4407 from ./include/linux/spinlock.h:55,
2022-05-17T14:53:17.744Z In(05) host-4407 from ./arch/x86/include/asm/mmu.h:5,
2022-05-17T14:53:17.744Z In(05) host-4407 from ./arch/x86/include/asm/desc.h:7,
2022-05-17T14:53:17.744Z In(05) host-4407 from /tmp/modconfig-iIlLDm/vmmon-only/common/task.c:72:
2022-05-17T14:53:17.744Z In(05) host-4407 ./arch/x86/include/asm/processor-flags.h:39: warning: "CR3_PCID_MASK" redefined
2022-05-17T14:53:17.744Z In(05) host-4407 39 | #define CR3_PCID_MASK 0xFFFull
2022-05-17T14:53:17.744Z In(05) host-4407 In file included from /tmp/modconfig-iIlLDm/vmmon-only/./include/vm_asm_x86.h:41,
2022-05-17T14:53:17.744Z In(05) host-4407 from /tmp/modconfig-iIlLDm/vmmon-only/./include/vm_asm.h:44,
2022-05-17T14:53:17.744Z In(05) host-4407 from /tmp/modconfig-iIlLDm/vmmon-only/common/task.c:52:
2022-05-17T14:53:17.744Z In(05) host-4407 /tmp/modconfig-iIlLDm/vmmon-only/./include/x86_basic_defs.h:78: note: this is the location of the previous definition
2022-05-17T14:53:17.744Z In(05) host-4407 78 | #define CR3_PCID_MASK 0xFFF
2022-05-17T14:53:17.744Z In(05) host-4407 from ./arch/x86/include/asm/paravirt_types.h:40,
2022-05-17T14:53:17.744Z In(05) host-4407 from ./arch/x86/include/asm/ptrace.h:97,
2022-05-17T14:53:17.744Z In(05) host-4407 from ./arch/x86/include/asm/math_emu.h:5,
2022-05-17T14:53:17.744Z In(05) host-4407 from ./arch/x86/include/asm/processor.h:13,
2022-05-17T14:53:17.744Z In(05) host-4407 ./arch/x86/include/asm/msr-index.h:44: warning: "MSR_TEST_CTRL" redefined
2022-05-17T14:53:17.744Z In(05) host-4407 from /tmp/modconfig-iIlLDm/vmmon-only/common/task.c:50:
2022-05-17T14:53:17.744Z In(05) host-4407 /tmp/modconfig-iIlLDm/vmmon-only/./include/x86msr.h:122: note: this is the location of the previous definition
2022-05-17T14:53:17.744Z In(05) host-4407 ./arch/x86/include/asm/msr-index.h:46: warning: "MSR_TEST_CTRL_SPLIT_LOCK_DETECT" redefined
2022-05-17T14:53:17.744Z In(05) host-4407 /tmp/modconfig-iIlLDm/vmmon-only/./include/x86msr.h:123: note: this is the location of the previous definition
2022-05-17T14:53:17.744Z In(05) host-4407 ./arch/x86/include/asm/msr-index.h:581: warning: "MSR_K7_HWCR_SMMLOCK" redefined
2022-05-17T14:53:17.744Z In(05) host-4407 /tmp/modconfig-iIlLDm/vmmon-only/./include/x86msr.h:588: note: this is the location of the previous definition
2022-05-17T14:53:17.744Z In(05) host-4407 ./arch/x86/include/asm/msr-index.h:781: warning: "MSR_MISC_FEATURES_ENABLES" redefined
2022-05-17T14:53:17.744Z In(05) host-4407 /tmp/modconfig-iIlLDm/vmmon-only/./include/x86msr.h:150: note: this is the location of the previous definition
2022-05-17T14:53:17.744Z In(05) host-4407 ./arch/x86/include/asm/msr-index.h:790: warning: "MSR_TSX_FORCE_ABORT" redefined
2022-05-17T14:53:17.744Z In(05) host-4407 /tmp/modconfig-iIlLDm/vmmon-only/./include/x86msr.h:795: note: this is the location of the previous definition
2022-05-17T14:53:17.744Z In(05) host-4407 from /tmp/modconfig-iIlLDm/vmmon-only/common/vmx86.c:42:
2022-05-17T14:53:17.744Z In(05) host-4407 from /tmp/modconfig-iIlLDm/vmmon-only/common/vmx86.c:31:
2022-05-17T14:53:17.744Z In(05) host-4407 In file included from /tmp/modconfig-iIlLDm/vmmon-only/./common/vmx86.h:32,
2022-05-17T14:53:17.744Z In(05) host-4407 from /tmp/modconfig-iIlLDm/vmmon-only/linux/driver.h:32,
2022-05-17T14:53:17.744Z In(05) host-4407 from /tmp/modconfig-iIlLDm/vmmon-only/linux/hostif.c:59:
2022-05-17T14:53:17.744Z In(05) host-4407 from ./include/linux/binfmts.h:5,
2022-05-17T14:53:17.744Z In(05) host-4407 from /tmp/modconfig-iIlLDm/vmmon-only/linux/hostif.c:31:
2022-05-17T14:53:17.745Z In(05) host-4407 |
2022-05-17T14:53:17.745Z In(05) host-4407 In file included from /tmp/modconfig-iIlLDm/vmmon-only/./common/vmx86.h:32,
2022-05-17T14:53:17.745Z In(05) host-4407 from /tmp/modconfig-iIlLDm/vmmon-only/linux/driver.h:32,
2022-05-17T14:53:17.745Z In(05) host-4407 from /tmp/modconfig-iIlLDm/vmmon-only/linux/hostif.c:59:
2022-05-17T14:53:17.745Z In(05) host-4407 /tmp/modconfig-iIlLDm/vmmon-only/./include/x86msr.h:150: warning: "MSR_MISC_FEATURES_ENABLES" redefined
2022-05-17T14:53:17.745Z In(05) host-4407 Skipping BTF generation for /tmp/modconfig-iIlLDm/vmnet-only/vmnet.ko due to unavailability of vmlinux
2022-05-17T14:53:17.745Z In(05) host-4407 Unable to install all modules. See log for details.
Re: Ubuntu22.04运行VMWare16.2报错Unable to install all modules.
帖子 astolia » 2022-05-18 10:25
vmware对linux最新版的支持从来都是慢人一步。没有特殊需求的话,用virtualbox就好。
另外,你非要用vmware workstation的话,需要用第三方修改版的驱动
cd /usr/lib/vmware/modules/source
git clone https://github.com/mkubecek/vmware-host-modules
cd vmware-host-modules
git checkout workstation-16.2.3
make
tar -cf vmnet.tar vmnet-only
tar -cf vmmon.tar vmmon-only
mv vmnet.tar /usr/lib/vmware/modules/source/
mv vmmon.tar /usr/lib/vmware/modules/source/
vmware-modconfig --console --install-all
上面是针对最新版16.2.3的。
hai1212
系统: Ubuntu、WIN7、XP、WIN8
帖子 hai1212 » 2024-10-26 16:21
我16.2.5安装成功!可以用windows里的虚拟硬盘!!
