kubuntu22.04 audacity无法打开
Longhao.Chen
系统: Debian,KUbuntu
帖子 Longhao.Chen » 2022-07-31 17:26
如果使用apt安装的版本,在命令行打开,一直显示
(audacity:13567): Pango-CRITICAL **: 15:17:51.179: pango_font_description_set_size: assertion 'size >= 0' failed
如果直接从github上下载或使用 snap 版本,则输出以下信息后卡死
/bin/bash: warning: setlocale: LC_ALL: cannot change locale (zh_CN.UTF-8)
Testing for explicit PulseAudio choice...
Testing for ALSA permissions...
Gtk-Message: 17:24:28.250: Failed to load module "colorreload-gtk-module"
Gtk-Message: 17:24:28.250: Failed to load module "window-decorations-gtk-module"
...use PulseAudio this time and ask next time.
(process:77071): Gdk-CRITICAL **: 17:24:31.245: IA__gdk_screen_get_root_window: assertion 'GDK_IS_SCREEN (screen)' failed
(process:77071): Gdk-CRITICAL **: 17:24:31.245: _gdk_pixmap_new: assertion '(drawable != NULL) || (depth != -1)' failed
/root/.conan/data/wxwidgets/3.1.3.1-audacity/_/_/build/e419d9154337f54ac2c5cc53c5142e9073a52daa/source_subfolder/src/gtk/bitmap.cpp(827): assert ""IsOk()"" failed in ConvertToImage(): invalid bitmap
/root/.conan/data/wxwidgets/3.1.3.1-audacity/_/_/build/e419d9154337f54ac2c5cc53c5142e9073a52daa/source_subfolder/src/common/image.cpp(2172): assert ""IsOk()"" failed in SetMaskColour(): invalid image
/root/.conan/data/wxwidgets/3.1.3.1-audacity/_/_/build/e419d9154337f54ac2c5cc53c5142e9073a52daa/source_subfolder/src/common/image.cpp(2223): assert ""IsOk()"" failed in SetMask(): invalid image
/root/.conan/data/wxwidgets/3.1.3.1-audacity/_/_/build/e419d9154337f54ac2c5cc53c5142e9073a52daa/source_subfolder/src/common/image.cpp(1853): assert ""IsOk()"" failed in GetWidth(): invalid image
/root/.conan/data/wxwidgets/3.1.3.1-audacity/_/_/build/e419d9154337f54ac2c5cc53c5142e9073a52daa/source_subfolder/src/common/image.cpp(1860): assert ""IsOk()"" failed in GetHeight(): invalid image
/root/.conan/data/wxwidgets/3.1.3.1-audacity/_/_/build/e419d9154337f54ac2c5cc53c5142e9073a52daa/source_subfolder/src/common/image.cpp(2112): assert ""IsOk()"" failed in GetAlpha(): invalid image
/root/.conan/data/wxwidgets/3.1.3.1-audacity/_/_/build/e419d9154337f54ac2c5cc53c5142e9073a52daa/source_subfolder/src/common/image.cpp(2232): assert ""IsOk()"" failed in HasMask(): invalid image
/root/.conan/data/wxwidgets/3.1.3.1-audacity/_/_/build/e419d9154337f54ac2c5cc53c5142e9073a52daa/source_subfolder/src/common/image.cpp(1986): assert ""IsOk()"" failed in GetData(): invalid image
(process:77071): GdkPixbuf-CRITICAL **: 17:24:31.245: gdk_pixbuf_new_from_data: assertion 'data != NULL' failed
(process:77071): Gdk-CRITICAL **: 17:24:31.245: IA__gdk_drawable_get_display: assertion 'GDK_IS_DRAWABLE (drawable)' failed
(process:77071): Gdk-CRITICAL **: 17:24:31.245: IA__gdk_cursor_new_from_pixbuf: assertion 'GDK_IS_DISPLAY (display)' failed
(process:77071): GLib-GObject-CRITICAL **: 17:24:31.245: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
请问以上问题是什么原因以及如何解决。
yq-ysy
来自: 广西(桂)南宁(邕)
Re: kubuntu22.04 audacity无法打开
帖子 yq-ysy » 2022-07-31 20:59
我用的是UbubtuStudio,从20.10版的某一天开始,audacity无法打开。
后来安装21.04版,刚安装好时,audacity是可以打开的,但过了一段时间(提示升级了几次)之后,又打不开了。
现在的替换方法是用AppImage版的audacity,可以正常打开。
下载地址: https://apprepo.de/appimage/audacity
Longhao.Chen
系统: Debian,KUbuntu
帖子 Longhao.Chen » 2022-07-31 22:00
这个方法能用,非常感谢。
只是现在界面是英文的,如果有办法改成中文就更好了
Longhao.Chen
系统: Debian,KUbuntu
帖子 Longhao.Chen » 2022-07-31 22:23
我这里好像还是不行,软件能够正常打开了,但导入一个音频文件就会卡死,出现
(audacity:5523): Pango-CRITICAL **: 22:21:05.298: pango_font_description_set_size: assertion 'size >= 0' failed
目前来看应该是显示波形那里的问题
帖子 qy117121 » 2022-08-01 8:48
试试这样启动 env LANG=C audacity &
帖子 qy117121 » 2022-08-01 8:53
https://bbs.archlinux.org/viewtopic.php?id=258730
搜到了这个帖子,看起来可能时因为字体配置的原因导致的
帖子 qy117121 » 2022-08-01 9:20
qy117121 写了: 2022-08-01 8:48 试试这样启动 env LANG=C audacity &
虚拟机测试了下,可以启动,当然就没有中文了
Longhao.Chen
系统: Debian,KUbuntu
帖子 Longhao.Chen » 2022-08-01 10:35
非常感谢,这个方法能用。
帖子 qy117121 » 2022-08-01 11:36
测试了下,虚拟机 安装ubuntu 22.04 gnome版本,然后安装KDE sudo apt install kde-standard kwin-addons language-pack-kde-zh-hans
安装audacity ,可以启动,重启,还是可以
安装kubuntu-desktop 重启,不能启动,出现 pango_font_description_set_size: assertion 'size >= 0' failed
卸载kubuntu-desktop 提示有一堆软件可以卸载,卸载后audacity可以启动了
但还是不知道是哪个软件包导致的
帖子 qy117121 » 2022-08-01 11:44
确定了,kubuntu-settings-desktop 导致的,卸载后就可以启动audacity
Longhao.Chen
系统: Debian,KUbuntu
帖子 Longhao.Chen » 2022-08-01 11:50
卸载 kubuntu-settings-desktop 完美解决,感谢你所付出的时间和精力。
我想学习一下你是怎么想到是KDE桌面的问题的?
帖子 qy117121 » 2022-08-01 11:56
Longhao.Chen 写了: 2022-08-01 11:50 我想学习一下你是怎么想到是KDE桌面的问题的?
我用的是一个衍生版的系统,也是KDE,但没有这个问题
台式机前段时间安装了linux mint 21 (基于22.04) 但是我是安装了KDE使用的,也没有这个问题
虽然都是KDE,但没有安装kubuntu-desktop 推荐的一大堆软件包,所以就怀疑kubuntu自带软件包的问题
虚拟机里试了下果然是kubuntu 软件包的问题
Longhao.Chen
系统: Debian,KUbuntu
帖子 Longhao.Chen » 2022-08-01 12:03
之前在Debian上用没有问题,我还以为是因为Debian上的软件包太旧的原因。
如果可以的话,最好与Kubuntu社区反映一下,为其他遇到类似问题的人节省时间。
大宝
帖子 大宝 » 2022-08-08 13:15
在下的可以启动,一切正常,QT界面感觉更好看一些,配合上 Viper4Linux,简直不要太好。
当然,后来又换为 20.04,觉得 22.04 不好用
mraandtux
系统: Kubuntu
帖子 mraandtux » 2022-12-10 11:46
如果直接从github上下载或使用 snap 版本,则······卡死
AppImage和Snap在Kubuntu均出现问题,5楼的解决方法也可以用于AppImage,命令稍微改改即可;本人早前用过Flatpak版(记得用Flatseal禁联网权限,Audacity卖给Muse Group还是令人不放心),运行没问题。
