我先装了gcc,然后嫌自带的源太慢,就改用了163的源,结果安装g++时遇到问题了,如下:
dyn@DELL:/etc/apt$ sudo apt-get install g++
sudo: unable to resolve host DELL
Reading package lists... Done
Building dependency tree
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
g++ : Depends: g++-4.8 (>= 4.8.2-5~) but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
dyn@DELL:/etc/apt$ sudo apt-get install g++-4.8
g++-4.8 : Depends: gcc-4.8-base (= 4.8.4-2ubuntu1~14.04) but 4.8.4-2ubuntu1~14.04.3 is to be installed
Depends: gcc-4.8 (= 4.8.4-2ubuntu1~14.04) but 4.8.4-2ubuntu1~14.04.3 is to be installed
Depends: libstdc++-4.8-dev (= 4.8.4-2ubuntu1~14.04) but it is not going to be installed
在win10的wsl下安装g++时遇到问题
- 系统: Linux Mint 13
Re: 在win10的wsl下安装g++时遇到问题
163的源现在已经废了,大半年都没跟官方同步过了。建议用阿里云的 http://mirrors.aliyun.com/ubuntu/
- 系统: Linux Mint 13
多谢!astolia 写了:163的源现在已经废了,大半年都没跟官方同步过了。建议用阿里云的 http://mirrors.aliyun.com/ubuntu/
后来证实确实是163源的问题,改用ubuntu中国官方源就好了。
