有没有人ax200 网卡在deepin 15.11上用起来的?
现在系统已升级了kernel 5.4.7,firmware也更新官网的了,但是现在情况是蓝牙可以使用了,但是无线还是没有反应:
sudo lshw -C network
*-network
product: Intel Corporation
vendor: Intel Corporation
physical id: 0
bus info: pci@0000:01:00.0
version: 1a
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix bus_master cap_list
configuration: driver=iwlwifi latency=0
resources: irq:16 memory:f7100000-f7103fff
rfkill list
0: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
lsmod |grep iw
iwlmvm 380928 0
mac80211 843776 1 iwlmvm
iwlwifi 331776 1 iwlmvm
cfg80211 704512 3 iwlmvm,iwlwifi,mac80211
dmesg iwlwifi相关
[ 3.966292] Intel(R) Wireless WiFi driver for Linux
[ 3.966293] Copyright(c) 2003- 2015 Intel Corporation
[ 3.966352] iwlwifi 0000:01:00.0: enabling device (0000 -> 0002)
[ 3.970661] iwlwifi 0000:01:00.0: Direct firmware load for iwlwifi-cc-a0-50.ucode failed with error -2
[ 3.976689] Adding 16777212k swap on /dev/nvme0n1p2. Priority:-2 extents:1 across:16777212k SSFS
[ 3.976979] iwlwifi 0000:01:00.0: Direct firmware load for iwlwifi-cc-a0-49.ucode failed with error -2
[ 3.986411] iwlwifi 0000:01:00.0: TLV_FW_FSEQ_VERSION: FSEQ Version: 43.2.23.17
[ 3.986413] iwlwifi 0000:01:00.0: Found debug destination: EXTERNAL_DRAM
[ 3.986414] iwlwifi 0000:01:00.0: Found debug configuration: 0
[ 3.986668] iwlwifi 0000:01:00.0: loaded firmware version 48.13675109.0 op_mode iwlmvm
[ 4.021266] Error: Driver 'pcspkr' is already registered, aborting...
[ 4.038945] snd_hda_intel 0000:00:1f.3: enabling device (0000 -> 0002)
[ 4.042555] snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[ 4.044753] iwlwifi 0000:01:00.0: Detected Intel(R) Wi-Fi 6 AX200 160MHz, REV=0x340
[ 4.055984] iwlwifi 0000:01:00.0: Applying debug destination EXTERNAL_DRAM
[ 4.056642] iwlwifi 0000:01:00.0: Allocated 0x00400000 bytes for firmware monitor.
[ 5.088664] iwlwifi 0000:01:00.0: Collecting data: trigger 15 fired.
[ 5.088765] iwlwifi 0000:01:00.0: Start IWL Error Log Dump:
[ 5.097716] iwlwifi 0000:01:00.0: Status: 0x00000000, count: 6
[ 5.100136] iwlwifi 0000:01:00.0: Loaded firmware version: 48.13675109.0
[ 5.102905] iwlwifi 0000:01:00.0: 0x00000071 | NMI_INTERRUPT_UMAC_FATAL
[ 5.104962] iwlwifi 0000:01:00.0: 0x0020A2F0 | trm_hw_status0
[ 5.107594] iwlwifi 0000:01:00.0: 0x00000000 | trm_hw_status1
[ 5.107595] iwlwifi 0000:01:00.0: 0x004F8E2C | branchlink2
[ 5.107596] iwlwifi 0000:01:00.0: 0x004E4FF4 | interruptlink1
[ 5.107596] iwlwifi 0000:01:00.0: 0x004E4FF4 | interruptlink2
[ 5.107597] iwlwifi 0000:01:00.0: 0x004F3DA0 | data1
[ 5.107598] iwlwifi 0000:01:00.0: 0x00001000 | data2
[ 5.107598] iwlwifi 0000:01:00.0: 0xF0000000 | data3
[ 5.107599] iwlwifi 0000:01:00.0: 0x00000000 | beacon time
[ 5.107599] iwlwifi 0000:01:00.0: 0x00009114 | tsf low
[ 5.107600] iwlwifi 0000:01:00.0: 0x00000000 | tsf hi
[ 5.107600] iwlwifi 0000:01:00.0: 0x00000000 | time gp1
[ 5.107601] iwlwifi 0000:01:00.0: 0x0000F20A | time gp2
[ 5.107601] iwlwifi 0000:01:00.0: 0x00000001 | uCode revision type
[ 5.107602] iwlwifi 0000:01:00.0: 0x00000030 | uCode version major
[ 5.107602] iwlwifi 0000:01:00.0: 0x13675109 | uCode version minor
[ 5.107603] iwlwifi 0000:01:00.0: 0x00000340 | hw version
[ 5.107603] iwlwifi 0000:01:00.0: 0x18C89000 | board version
[ 5.107604] iwlwifi 0000:01:00.0: 0x8002FF03 | hcmd
[ 5.107604] iwlwifi 0000:01:00.0: 0x20028000 | isr0
[ 5.107605] iwlwifi 0000:01:00.0: 0x00000000 | isr1
[ 5.107605] iwlwifi 0000:01:00.0: 0x08F00002 | isr2
[ 5.107606] iwlwifi 0000:01:00.0: 0x00C0000C | isr3
[ 5.107606] iwlwifi 0000:01:00.0: 0x00000000 | isr4
[ 5.107607] iwlwifi 0000:01:00.0: 0x00000000 | last cmd Id
[ 5.107607] iwlwifi 0000:01:00.0: 0x004F3DA0 | wait_event
[ 5.107608] iwlwifi 0000:01:00.0: 0x00000000 | l2p_control
[ 5.107608] iwlwifi 0000:01:00.0: 0x00000020 | l2p_duration
[ 5.107609] iwlwifi 0000:01:00.0: 0x00000000 | l2p_mhvalid
[ 5.107609] iwlwifi 0000:01:00.0: 0x00000000 | l2p_addr_match
[ 5.107610] iwlwifi 0000:01:00.0: 0x00000009 | lmpm_pmg_sel
[ 5.107610] iwlwifi 0000:01:00.0: 0x00000000 | timestamp
[ 5.107611] iwlwifi 0000:01:00.0: 0x0000F81C | flow_handler
[ 5.107636] iwlwifi 0000:01:00.0: Start IWL Error Log Dump:
[ 5.192134] iwlwifi 0000:01:00.0: Status: 0x00000000, count: 7
[ 5.192137] iwlwifi 0000:01:00.0: 0x20100222 | ADVANCED_SYSASSERT
[ 5.192138] iwlwifi 0000:01:00.0: 0x00000000 | umac branchlink1
[ 5.192139] iwlwifi 0000:01:00.0: 0xC008CC3C | umac branchlink2
[ 5.192140] iwlwifi 0000:01:00.0: 0xC0087662 | umac interruptlink1
[ 5.192141] iwlwifi 0000:01:00.0: 0x00000000 | umac interruptlink2
[ 5.192142] iwlwifi 0000:01:00.0: 0xDEADBEEF | umac data1
[ 5.192143] iwlwifi 0000:01:00.0: 0xDEADBEEF | umac data2
[ 5.192144] iwlwifi 0000:01:00.0: 0xDEADBEEF | umac data3
[ 5.192145] iwlwifi 0000:01:00.0: 0x00000030 | umac major
[ 5.192146] iwlwifi 0000:01:00.0: 0x13675109 | umac minor
[ 5.192147] iwlwifi 0000:01:00.0: 0x0000F1FE | frame pointer
[ 5.192148] iwlwifi 0000:01:00.0: 0xC0886B00 | stack pointer
[ 5.192150] iwlwifi 0000:01:00.0: 0x0000FFFF | last host cmd
[ 5.192151] iwlwifi 0000:01:00.0: 0x00000000 | isr status reg
[ 5.192158] iwlwifi 0000:01:00.0: Fseq Registers:
[ 5.192161] iwlwifi 0000:01:00.0: 0xE0000101 | FSEQ_ERROR_CODE
[ 5.192164] iwlwifi 0000:01:00.0: 0x00290006 | FSEQ_TOP_INIT_VERSION
[ 5.192167] iwlwifi 0000:01:00.0: 0x80050008 | FSEQ_CNVIO_INIT_VERSION
[ 5.192170] iwlwifi 0000:01:00.0: 0x0000A503 | FSEQ_OTP_VERSION
[ 5.192173] iwlwifi 0000:01:00.0: 0x80000003 | FSEQ_TOP_CONTENT_VERSION
[ 5.192176] iwlwifi 0000:01:00.0: 0x4552414E | FSEQ_ALIVE_TOKEN
[ 5.243139] iwlwifi 0000:01:00.0: 0x00100530 | FSEQ_CNVI_ID
[ 5.243142] iwlwifi 0000:01:00.0: 0x00000532 | FSEQ_CNVR_ID
[ 5.243144] iwlwifi 0000:01:00.0: 0x00100530 | CNVI_AUX_MISC_CHIP
[ 5.243148] iwlwifi 0000:01:00.0: 0x00000532 | CNVR_AUX_MISC_CHIP
[ 5.243153] iwlwifi 0000:01:00.0: 0x05B0905B | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[ 5.243157] iwlwifi 0000:01:00.0: 0x0000025B | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[ 5.243193] iwlwifi 0000:01:00.0: SecBoot CPU1 Status: 0x5ff9, CPU2 Status: 0x3
[ 5.251473] iwlwifi 0000:01:00.0: Failed to start RT ucode: -110
[ 5.252430] iwlwifi 0000:01:00.0: Firmware not running - cannot dump error
[ 5.264747] iwlwifi 0000:01:00.0: Failed to run INIT ucode: -110
看dmesg前面ax200识别出来了,但驱动加载有failed,iwlwifi-cc-a0-49.ucode,iwlwifi-cc-a0-50.ucode是什么?网上没查询到,官网的fireware是iwlwifi-cc-a0-46.ucode已经下载最新版本了。
有高手能帮忙解答下么?
谢谢~
deepin intel ax200无线网卡问题:蓝牙可用,无线没有
Re: deepin intel ax200无线网卡问题:蓝牙可用,无线没有
或者大家谁有:
两个文件可以共享下的么?试试是不是这2个文件的问题~
[email protected]
谢谢
[email protected]
谢谢
我也是这个网卡,同样的5.4.7内核,虽然同样会报两个固件加载失败,但还是能用。
我现在是用的ubuntu 20.04,以前用19.10的时候wifi也可以用
[ 3.127788] iwlwifi 0000:28:00.0: enabling device (0000 -> 0002)
[ 3.134509] iwlwifi 0000:28:00.0: Direct firmware load for iwlwifi-cc-a0-50.ucode failed with error -2
[ 3.134735] iwlwifi 0000:28:00.0: Direct firmware load for iwlwifi-cc-a0-49.ucode failed with error -2
[ 3.136267] iwlwifi 0000:28:00.0: TLV_FW_FSEQ_VERSION: FSEQ Version: 43.2.23.17
[ 3.136269] iwlwifi 0000:28:00.0: Found debug destination: EXTERNAL_DRAM
[ 3.136270] iwlwifi 0000:28:00.0: Found debug configuration: 0
[ 3.136496] iwlwifi 0000:28:00.0: loaded firmware version 48.4fa0041f.0 op_mode iwlmvm
[ 3.152967] iwlwifi 0000:28:00.0: Detected Intel(R) Wi-Fi 6 AX200 160MHz, REV=0x340
[ 3.163214] iwlwifi 0000:28:00.0: Applying debug destination EXTERNAL_DRAM
[ 3.163565] iwlwifi 0000:28:00.0: Allocated 0x00400000 bytes for firmware monitor.
[ 3.317486] iwlwifi 0000:28:00.0: base HW address: 38:00:XX:XX:XX:XX
[ 3.331770] iwlwifi 0000:28:00.0 wlo1: renamed from wlan0
[ 5.542120] iwlwifi 0000:28:00.0: Applying debug destination EXTERNAL_DRAM
[ 5.689675] iwlwifi 0000:28:00.0: FW already configured (0) - re-configuring
据这个 https://bugzilla.kernel.org/show_bug.cgi?id=204821#c5,原因是因为ax200内部PCI实现(至少在某些主板上)不支持X16的PCIE slot。有人在bios里手动设置成X1/X4就没问题了
- 系统: ubuntu20.04
我也遇到了一样的问题,内核是符合要求的,也将驱动复制到了/lib/firmware 但是还是不行,只能以普通驱动工作,速率很低astolia 写了: ↑2020-01-06 16:27 我也是这个网卡,同样的5.4.7内核,虽然同样会报两个固件加载失败,但还是能用。
我现在是用的ubuntu 20.04,以前用19.10的时候wifi也可以用代码: 全选
[ 3.127788] iwlwifi 0000:28:00.0: enabling device (0000 -> 0002) [ 3.134509] iwlwifi 0000:28:00.0: Direct firmware load for iwlwifi-cc-a0-50.ucode failed with error -2 [ 3.134735] iwlwifi 0000:28:00.0: Direct firmware load for iwlwifi-cc-a0-49.ucode failed with error -2 [ 3.136267] iwlwifi 0000:28:00.0: TLV_FW_FSEQ_VERSION: FSEQ Version: 43.2.23.17 [ 3.136269] iwlwifi 0000:28:00.0: Found debug destination: EXTERNAL_DRAM [ 3.136270] iwlwifi 0000:28:00.0: Found debug configuration: 0 [ 3.136496] iwlwifi 0000:28:00.0: loaded firmware version 48.4fa0041f.0 op_mode iwlmvm [ 3.152967] iwlwifi 0000:28:00.0: Detected Intel(R) Wi-Fi 6 AX200 160MHz, REV=0x340 [ 3.163214] iwlwifi 0000:28:00.0: Applying debug destination EXTERNAL_DRAM [ 3.163565] iwlwifi 0000:28:00.0: Allocated 0x00400000 bytes for firmware monitor. [ 3.317486] iwlwifi 0000:28:00.0: base HW address: 38:00:XX:XX:XX:XX [ 3.331770] iwlwifi 0000:28:00.0 wlo1: renamed from wlan0 [ 5.542120] iwlwifi 0000:28:00.0: Applying debug destination EXTERNAL_DRAM [ 5.689675] iwlwifi 0000:28:00.0: FW already configured (0) - re-configuring
联想14s遇到同样的问题, 求大佬指点下,一开始可以用,切换系统后再切回来,wifi就用不了了,bt可以用
