如何成功编译VIM支持lua
Vim、Emacs配置和使用
zfovly216
系统: windows 7
如何成功编译VIM支持lua
帖子 zfovly216 »
安装参考的帖子:http://www.jianshu.com/p/3e0c242310d3
已安装的依赖如下:
sudo apt-get install \
    python-dev \
    python3-dev \
    ruby-dev \
    liblua5.2-dev \
    liblua5.3-dev \
    libperl-dev \
    libtcl8.6 \
    libgnomeui-dev \
    libx11-dev \
    libxt-dev \
    libxpm-dev
使用的命令如下:
 $ ./configure \        [20:58:26]
    --prefix=/usr/local/ \
    --with-features=huge \
    --enable-multibyte \
    --enable-cscope=yes \
    --enable-perlinterp=yes \
    --enable-rubyinterp=yes \
    --with-ruby-command=/usr/bin/ruby \
    --enable-luainterp=yes \
    --enable-pythoninterp=yes \
    --enable-python3interp=yes \
    --enable-tclinterp=yes \
    --enable-gui=auto \
    --enable-gnome-check \
    --enable-sniff \
    --enable-xim \
    --enable-fontset \
    --with-x \
    --with-compiledby=$USER \
    --enable-fail-if-missing
提示报错如下:
checking --with-lua-prefix argument... no
checking LUA_PREFIX environment var... not set, default to /usr
checking --with-luajit... no
checking for lua... no
checking if lua.h can be found in /usr/include... no
checking if lua.h can be found in /usr/include/lua... no
configure: error: could not configure lua
实际lua.h的位置在/usr/include/lua5.3/或/usr/include/lua5.2/,就算把/usr/include/lua5.3复制为/usr/include/lua,成功找到lua.h,还是会继续报错:
checking if link with -L/usr/lib -llua is sane... no
于是不知道怎么办好了……
上次由 zfovly216 在 2016-08-09 13:56,总共编辑 1 次。
Re: 如何成功编译VIM支持lua
帖子 astolia »
直接安裝vim-nox/vim-gtk/vim-gtk3就有lua支持了
$ vim.nox --version | grep lua
+dialog_con      +lua             +rightleft       +windows
Linking: gcc   -L. -Wl,-Bsymbolic-functions -Wl,-z,relro -Wl,-z,now -fstack-protector -rdynamic -Wl,-export-dynamic -Wl,-E  -Wl,-Bsymbolic-functions -fPIE -pie -Wl,-z,relro -Wl,-z,now -Wl,--as-needed -o vim        -lm -ltinfo -lnsl  -lselinux  -lacl -lattr -lgpm -ldl  -L/usr/lib -llua5.2 -Wl,-E  -fstack-protector-strong -L/usr/local/lib  -L/usr/lib/x86_64-linux-gnu/perl/5.22/CORE -lperl -ldl -lm -lpthread -lcrypt  -L/usr/lib/python3.5/config-3.5m-x86_64-linux-gnu -lpython3.5m -lpthread -ldl -lutil -lm -L/usr/lib/x86_64-linux-gnu -ltcl8.6 -ldl -lz -lpthread -lieee -lm -lruby-2.3 -lpthread -lgmp -ldl -lcrypt -l
lilydjwg
系统: Arch Linux
Re: 如何成功编译VIM支持lua
帖子 lilydjwg »
如果你用最新的 Vim 源码还是报错,可以去提交一下 bug 报告。
当然,先看一下 config.log 确认一下确实是 Vim 的构建系统没有找到头/库文件,而不是别的什么问题。
zfovly216
系统: windows 7
Re: 如何成功编译VIM支持lua
帖子 zfovly216 »
astolia 写了:直接安裝vim-nox/vim-gtk/vim-gtk3就有lua支持了
很少用带GUI的VIM,而且自己编译想要什么支持都可以实现,某种程度更加方便点
zfovly216
系统: windows 7
Re: 如何成功编译VIM支持lua
帖子 zfovly216 »
lilydjwg 写了:如果你用最新的 Vim 源码还是报错,可以去提交一下 bug 报告。
源码足够新了
commit 7547a78446c1a3c04b36c0533f0f046188bd378b
Author: Bram Moolenaar <[email protected]>
Date:   Mon Aug 8 23:26:51 2016 +0200
    patch 7.4.2187
    Problem:    glob2regpat test fails on Windows.
    Solution:   Remove the checks that use backslashes.
的确是找不到头文件与库文件,上面也贴了
checking --enable-luainterp argument... yes
我发个issues问问
zfovly216
系统: windows 7
Re: 如何成功编译VIM支持lua
帖子 zfovly216 »
开发者也没有什么好办法,最后各种软链接解决了。
再问一下编译好带有python支持了(+python/dyn,+python3/dyn),为什么还会提示:Error: Required vim compiled with +python
lilydjwg
系统: Arch Linux
Re: 如何成功编译VIM支持lua
帖子 lilydjwg »
zfovly216 写了:
加载失败了?没有报错说加载失败什么的么?
zfovly216
系统: windows 7
Re: 如何成功编译VIM支持lua
帖子 zfovly216 »
lilydjwg 写了: 加载失败了?没有报错说加载失败什么的么?
查了一下是说如果vim要同时支持python和python3,那么只会在同一时间动态加载其中一个,不知道是根据什么来决定的,反正每次加载的都是python3,后来在编译的时候把python3的支持去掉了就好了
zfovly216
系统: windows 7
Re: 如何成功编译VIM支持lua
帖子 zfovly216 »
实际上正确的方法是安装lua5.2,而不仅仅是liblua5.2-dev,configure脚本会使用lua命令来检查lua的版本以及头文件和库文件的路径,会自动修正问题。
lilydjwg
系统: Arch Linux
Re: 如何成功编译VIM支持lua
帖子 lilydjwg »
zfovly216 写了:
是根据操作系统来决定的。Arch Linux 上的 Vim 可以同时支持 Python 2 和 3。Ubuntu 上的只能支持先被加载的那个,因为它的 Python 编译时没有加 --enable-shared。
lilydjwg
系统: Arch Linux
Re: 如何成功编译VIM支持lua
帖子 lilydjwg »
zfovly216 写了:
原来是这样……Arch Linux 用户从来没遇到过这种问题。
zfovly216
系统: windows 7
Re: 如何成功编译VIM支持lua
帖子 zfovly216 »
lilydjwg 写了:
zfovly216 写了:
是这样吗?我看vim的manual不是这么写得,貌似跟python与python3的符号表怎么的有关,导致同一时间只能加载一个。Arch上echo has('python')和echo has('python3')都是1么?
lilydjwg
系统: Arch Linux
Re: 如何成功编译VIM支持lua
帖子 lilydjwg »
我记得是这样的。
Arch 官方编译的我不太清楚。我的 vim-lily / gvim-lily 是两个都能同时加载的。曾经我也在 Ubuntu 上自行编译 Python 和 Vim 来同时支持过两者。
zfovly216
系统: windows 7
Re: 如何成功编译VIM支持lua
帖子 zfovly216 »
lilydjwg 写了:我记得是这样的。
厉害[emoji1303]
从我的 iPhone 发送,使用 Tapatalk
