huangsijun17
- 系统: WinUbuntuArchRocky
帖子
由 huangsijun17 » 2024-03-22 14:28
1. 偶见apt装包时提示缺少依赖,但使用apt install命令可以安装该依赖。似乎是没有循环搜索依赖?
2. 在chroot到一个离线的Ubuntu根目录后,如何优雅得使用apt安装?我这似乎apt update命令都跑不了了。
在线系统Ubuntu 18.04 X86,离线系统Ubuntu 18.04 ARMv7(32位)
chroot时的命令如下:
sudo chroot rootfs\
/usr/bin/env -i \
HOME=/root \
TERM="$TERM" \
PS1='\u:\w\$ ' \
PATH=/bin:/usr/bin:/sbin:/usr/sbin \
/bin/bash --login +h
登录时防机器人的问题真TM难。
我试了不下10次。答案包括:
20.04
20.04.3
LTS
18.04
16.04
等等等等
帖子
由 astolia » 2024-03-22 15:27
huangsijun17 写了: ↑2024-03-22 14:28
你这“apt装包”是具体用的哪个命令?
你这都跨架构了,你做了在x86上直接执行arm程序的相关准备工作了吗?
huangsijun17
帖子
由 huangsijun17 » 2024-03-22 15:53
astolia 写了: ↑2024-03-22 15:27
你这“apt装包”是具体用的哪个命令?
root@bf7f99a1af7d:/# apt install git gnupg flex bison gperf build-essential zip curl libc6-dev libncurses5-dev x11proto-core-dev libx11-dev libreadline6-dev libgl1-mesa-glx libgl1-mesa-dev g++-multilib tofrodos python-markdown libxml2-utils xsltproc zlib1g-dev gawk gcc g++ make bash-completion net-tools inetutils-ping vim openssh-server binutils ifupdown pax-utils gcc-arm-linux-gnueabihf g++-arm-linux-gnueabihf qemu-user-staticReading package lists... Done
Building dependency tree
Note, selecting 'libreadline-dev' instead of 'libreadline6-dev'
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
g++-arm-linux-gnueabihf : Depends: g++-7-arm-linux-gnueabihf (>= 7.4.0-1~) but it is not going to be installed
gcc-arm-linux-gnueabihf : Depends: gcc-7-arm-linux-gnueabihf (>= 7.4.0-1~) but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
root@bf7f99a1af7d:/# apt install g++-7-arm-linux-gnueabihf gcc-7-arm-linux-gnueabihf
The following additional packages will be installed:
binutils-arm-linux-gnueabihf binutils-common cpp-7-arm-linux-gnueabihf gcc-7-arm-linux-gnueabihf-base
gcc-7-cross-base gcc-8-cross-base libasan4-armhf-cross libatomic1-armhf-cross libc6-armhf-cross
libc6-dev-armhf-cross libcc1-0 libcilkrts5-armhf-cross libgcc-7-dev-armhf-cross libgcc1-armhf-cross
libgomp1-armhf-cross libisl19 libmpc3 libmpfr6 libstdc++-7-dev-armhf-cross libstdc++6-armhf-cross
libubsan0-armhf-cross linux-libc-dev-armhf-cross
Suggested packages:
binutils-doc gcc-7-locales g++-7-multilib-arm-linux-gnueabihf gcc-7-doc libstdc++6-7-dbg-armhf-cross
gcc-7-multilib-arm-linux-gnueabihf libgcc1-dbg-armhf-cross libgomp1-dbg-armhf-cross
libitm1-dbg-armhf-cross libatomic1-dbg-armhf-cross libasan4-dbg-armhf-cross liblsan0-dbg-armhf-cross
libtsan0-dbg-armhf-cross libubsan0-dbg-armhf-cross libcilkrts5-dbg-armhf-cross libmpx2-dbg-armhf-cross
libquadmath0-dbg-armhf-cross
binutils-arm-linux-gnueabihf binutils-common cpp-7-arm-linux-gnueabihf g++-7-arm-linux-gnueabihf
gcc-7-arm-linux-gnueabihf gcc-7-arm-linux-gnueabihf-base gcc-7-cross-base gcc-8-cross-base
libasan4-armhf-cross libatomic1-armhf-cross libc6-armhf-cross libc6-dev-armhf-cross libcc1-0
libcilkrts5-armhf-cross libgcc-7-dev-armhf-cross libgcc1-armhf-cross libgomp1-armhf-cross libisl19 libmpc3
libmpfr6 libstdc++-7-dev-armhf-cross libstdc++6-armhf-cross libubsan0-armhf-cross
0 upgraded, 24 newly installed, 0 to remove and 1 not upgraded.
Need to get 31.0 MB of archives.
After this operation, 108 MB of additional disk space will be used.
Do you want to continue? [Y/n]
Get:1 http://archive.ubuntu.com/ubuntu bionic-updates/main amd64 binutils-common amd64 2.30-21ubuntu1~18.04.9 [197 kB]
(略)
Processing triggers for libc-bin (2.27-3ubuntu1.6) ...
g++-multilib : Depends: gcc-multilib (>= 4:7.4.0-1ubuntu2.3) but it is not going to be installed
root@bf7f99a1af7d:/# apt install gcc-multilib Reading package lists... Done
The following packages were automatically installed and are no longer required:
binutils-arm-linux-gnueabihf cpp-7-arm-linux-gnueabihf gcc-7-arm-linux-gnueabihf-base gcc-7-cross-base
gcc-8-cross-base libasan4-armhf-cross libatomic1-armhf-cross libc6-armhf-cross libc6-dev-armhf-cross
libstdc++-7-dev-armhf-cross libstdc++6-armhf-cross libubsan0-armhf-cross linux-libc-dev-armhf-cross
Use 'apt autoremove' to remove them.
binutils binutils-x86-64-linux-gnu cpp cpp-7 gcc gcc-7 gcc-7-base gcc-7-multilib lib32asan4 lib32atomic1
lib32cilkrts5 lib32gcc-7-dev lib32gcc1 lib32gomp1 lib32itm1 lib32mpx2 lib32quadmath0 lib32stdc++6
lib32ubsan0 libasan4 libatomic1 libbinutils libc-dev-bin libc6-dev libc6-dev-i386 libc6-dev-x32 libc6-i386
libc6-x32 libcilkrts5 libgcc-7-dev libgomp1 libitm1 liblsan0 libmpx2 libquadmath0 libtsan0 libubsan0
libx32asan4 libx32atomic1 libx32cilkrts5 libx32gcc-7-dev libx32gcc1 libx32gomp1 libx32itm1 libx32quadmath0
libx32stdc++6 libx32ubsan0 linux-libc-dev manpages manpages-dev
Suggested packages:
binutils-doc cpp-doc gcc-7-locales make autoconf automake libtool flex bison gdb gcc-doc gcc-7-doc
libgcc1-dbg libgomp1-dbg libitm1-dbg libatomic1-dbg libasan4-dbg liblsan0-dbg libtsan0-dbg libubsan0-dbg
libcilkrts5-dbg libmpx2-dbg libquadmath0-dbg glibc-doc man-browser
The following packages will be REMOVED:
binutils binutils-x86-64-linux-gnu cpp cpp-7 gcc gcc-7 gcc-7-base gcc-7-multilib gcc-multilib lib32asan4
lib32atomic1 lib32cilkrts5 lib32gcc-7-dev lib32gcc1 lib32gomp1 lib32itm1 lib32mpx2 lib32quadmath0
lib32stdc++6 lib32ubsan0 libasan4 libatomic1 libbinutils libc-dev-bin libc6-dev libc6-dev-i386
libc6-dev-x32 libc6-i386 libc6-x32 libcilkrts5 libgcc-7-dev libgomp1 libitm1 liblsan0 libmpx2 libquadmath0
libtsan0 libubsan0 libx32asan4 libx32atomic1 libx32cilkrts5 libx32gcc-7-dev libx32gcc1 libx32gomp1
libx32itm1 libx32quadmath0 libx32stdc++6 libx32ubsan0 linux-libc-dev manpages manpages-dev
0 upgraded, 51 newly installed, 2 to remove and 1 not upgraded.
Need to get 47.1 MB of archives.
After this operation, 149 MB of additional disk space will be used.
(略)
这三个包,就是不会自动安装的,但可以手动安装。不知为何。
我是给ARM的嵌入设备根tar包镜像加依赖,上面的apt命令是安我编译成img用的SDK的依赖。
登录时防机器人的问题真TM难。
我试了不下10次。答案包括:
20.04
20.04.3
LTS
18.04
16.04
等等等等
帖子
由 astolia » 2024-03-22 16:32
你沒看你命令的輸出?
huangsijun17 写了: ↑2024-03-22 15:53
(中略)
(后略)
gcc-multilib和g{cc,++}{,-7}-arm-linux-gnueabihf相互冲突,g++-multilib又依赖gcc-multilib。你把它们放到同一个install后面肯定没法满足依赖关系啊
huangsijun17
帖子
由 huangsijun17 » 2024-03-22 16:34
astolia 写了: ↑2024-03-22 16:32
你沒看你命令的輸出?
(中略)
(后略)
apt的安装命令是厂商给的,我没细看……
登录时防机器人的问题真TM难。
我试了不下10次。答案包括:
20.04
20.04.3
LTS
18.04
16.04
等等等等
雪风FFR31D系
帖子
由 雪风FFR31D系 » 2024-03-31 13:00
现在ubuntu的在线安装方式也太多了,apt-get和 apt 这两个到底有什么区别,我到现在也没弄懂
帖子
由 astolia » 2024-04-02 9:38
雪风FFR31D系 写了: ↑2024-03-31 13:00
自行运行man apt,阅读DESCRIPTION部分
