蓝牙耳机闪断
CPU/显卡/打印机/USB设备等硬件问题
百草谷居士
系统: Mint21.1/Deepin20.8
蓝牙耳机闪断
帖子 百草谷居士 » 2023-06-01 9:09
有一周了吧,蓝牙耳机连接后,迅速断开。
这个问题只出现在 Mint 系统,在 深度系统 上是正常的?
何解?
onlylove
Re: 蓝牙耳机闪断
帖子 onlylove » 2023-06-01 11:02
如果说,让你提供蓝牙相关的日志,你知道怎么做吗?
比方dmesg和syslog,系统服务什么的
百草谷居士
Re: 蓝牙耳机闪断
帖子 百草谷居士 » 2023-06-01 12:06
dmesg 的输出:
[ 8.717777] spl: loading out-of-tree module taints kernel.
[ 8.726760] znvpair: module license 'CDDL' taints kernel.
[ 8.726764] Disabling lock debugging due to kernel taint
[ 9.012674] ZFS: Loaded module v2.1.5-1ubuntu6, ZFS pool version 5000, ZFS filesystem version 5
[ 10.077084] audit: type=1400 audit(1685592149.187:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-xpdfimport" pid=1032 comm="apparmor_parser"
[ 10.077116] audit: type=1400 audit(1685592149.187:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-senddoc" pid=1030 comm="apparmor_parser"
[ 10.077257] audit: type=1400 audit(1685592149.187:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=1023 comm="apparmor_parser"
[ 10.077323] audit: type=1400 audit(1685592149.187:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=1024 comm="apparmor_parser"
[ 10.077326] audit: type=1400 audit(1685592149.187:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=1024 comm="apparmor_parser"
[ 10.077343] audit: type=1400 audit(1685592149.187:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-oosplash" pid=1029 comm="apparmor_parser"
[ 10.077539] audit: type=1400 audit(1685592149.191:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/man" pid=1026 comm="apparmor_parser"
[ 10.077542] audit: type=1400 audit(1685592149.191:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_filter" pid=1026 comm="apparmor_parser"
[ 10.077544] audit: type=1400 audit(1685592149.191:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_groff" pid=1026 comm="apparmor_parser"
[ 10.077949] audit: type=1400 audit(1685592149.191:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/cups-browsed" pid=1033 comm="apparmor_parser"
[ 10.157507] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 10.157510] Bluetooth: BNEP filters: protocol multicast
[ 10.157515] Bluetooth: BNEP socket layer initialized
[ 10.162105] NET: Registered PF_ALG protocol family
[ 10.229542] RTL8226B_RTL8221B 2.5Gbps PHY r8169-0-300:00: attached PHY driver (mii_bus:phy_addr=r8169-0-300:00, irq=MAC)
[ 10.416765] vboxdrv: module verification failed: signature and/or required key missing - tainting kernel
[ 10.423991] vboxdrv: Found 16 processor cores/threads
[ 10.445628] vboxdrv: TSC mode is Invariant, tentative frequency 2496000239 Hz
[ 10.445630] vboxdrv: Successfully loaded version 7.0.4 r154605 (interface 0x00330004)
[ 10.445680] r8169 0000:03:00.0 enp3s0: Link is Down
[ 10.648320] VBoxNetFlt: Successfully started.
[ 10.649598] VBoxNetAdp: Successfully started.
[ 13.231264] r8169 0000:03:00.0 enp3s0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 13.231273] IPv6: ADDRCONF(NETDEV_CHANGE): enp3s0: link becomes ready
[ 14.360412] Bluetooth: RFCOMM TTY layer initialized
[ 14.360418] Bluetooth: RFCOMM socket layer initialized
[ 14.360422] Bluetooth: RFCOMM ver 1.11
[ 23.777379] BTRFS info (device sdb3): using free space tree
[ 23.777383] BTRFS info (device sdb3): has skinny extents
[ 23.842672] BTRFS info (device sdb3): enabling ssd optimizations
syslog 没有用过。
lihuiyuan_1988
Re: 蓝牙耳机闪断
帖子 lihuiyuan_1988 » 2023-06-04 22:34
我在linuxmint21上也遇到这个问题了,目前没有找到办法。但是你可以先把你上次连接过的蓝牙耳机删除掉,然后再搜索这个蓝牙耳机进行连接,还能正常使用。
每次断开后,再次使用都需要这么重复!
百草谷居士
Re: 蓝牙耳机闪断
帖子 百草谷居士 » 2023-06-05 8:57
应该是某次更新造成的问题的。也许会在某次更新后解决吧
百草谷居士
Re: 蓝牙耳机闪断
帖子 百草谷居士 » 2023-06-21 15:44
lihuiyuan_1988 写了: 2023-06-04 22:34 我在linuxmint21上也遇到这个问题了,目前没有找到办法。但是你可以先把你上次连接过的蓝牙耳机删除掉,然后再搜索这个蓝牙耳机进行连接,还能正常使用。
每次断开后,再次使用都需要这么重复!
在 ubuntu 22.04.1 下测试,也是一样的。这个问题你有解决方案吗?
lihuiyuan_1988
Re: 蓝牙耳机闪断
帖子 lihuiyuan_1988 » 2023-06-22 16:50
百草谷居士 写了: 2023-06-21 15:44
每次断开后,再次使用都需要这么重复!
目前没有找到解决方案,不是个例,反应这个问题的不少,应该是系统或blueman的一个bug
