在windows 11上安装了Ubuntu 22.04,安装了RTL8188GU的驱动,出现了Wi-Fi 图标,但是无线连接连不上,一直在转圈,提示Connection failed。 Activation of network connection failed
lsusb
hman13@hman13-E500:~$ lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 012: ID 0bda:b711 Realtek Semiconductor Corp. RTL8188GU 802.11n WLAN Adapter (After Modeswitch)
Bus 001 Device 003: ID 093a:2510 Pixart Imaging, Inc. Optical Mouse
Bus 001 Device 002: ID 0c45:760b Microdia USB Keyboard
lspci
hman13@hman13-E500:~$ lspci
00:00.0 Host bridge: Intel Corporation Device 9b73 (rev 03)
00:02.0 VGA compatible controller: Intel Corporation Device 9ba8 (rev 03)
00:08.0 System peripheral: Intel Corporation Xeon E3-1200 v5/v6 / E3-1500 v5 / 6th/7th/8th Gen Core Processor Gaussian Mixture Model
00:14.0 USB controller: Intel Corporation Comet Lake PCH-V USB Controller
00:14.2 Signal processing controller: Intel Corporation Comet Lake PCH-V Thermal Subsystem
00:15.0 Signal processing controller: Intel Corporation Device a3e0
00:15.1 Signal processing controller: Intel Corporation Device a3e1
00:16.0 Communication controller: Intel Corporation Comet Lake PCH-V HECI Controller
00:17.0 SATA controller: Intel Corporation 400 Series Chipset Family SATA AHCI Controller
00:1c.0 PCI bridge: Intel Corporation Device a395 (rev f0)
00:1c.6 PCI bridge: Intel Corporation Device a396 (rev f0)
00:1f.0 ISA bridge: Intel Corporation B460 Chipset LPC/eSPI Controller
00:1f.2 Memory controller: Intel Corporation Memory controller
00:1f.3 Audio device: Intel Corporation Comet Lake PCH-V cAVS
00:1f.4 SMBus: Intel Corporation Comet Lake PCH-V SMBus Host Controller
01:00.0 PCI bridge: Integrated Technology Express, Inc. IT8893E PCIe to PCI Bridge (rev 41)
03:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
sudo lshw -C network
hman13@hman13-E500:~$ sudo lshw -C network
[sudo] password for hman13:
*-network
physical id: 0
bus info: pci@0000:03:00.0
logical name: enp3s0
version: 15
serial: 1c:69:7a:76:86:19
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=5.15.0-52-generic duplex=full firmware=rtl8168h-2_0.0.2 02/26/15 ip=192.168.1.123 latency=0 link=yes multicast=yes port=twisted pair speed=100Mbit/s
resources: irq:18 ioport:3000(size=256) memory:b1004000-b1004fff memory:b1000000-b1003fff
*-network
physical id: 6
bus info: usb@1:9
logical name: wlx502b73d97fcc
serial: 50:2b:73:d9:7f:cc
capabilities: ethernet physical wireless
configuration: broadcast=yes driver=rtl8710bu driverversion=5.15.0-52-generic multicast=yes wireless=unassociated
Ubuntu 22.04无线连接连不上,一直在转圈
- 系统: Windows 11
Re: Ubuntu 22.04无线连接连不上,一直在转圈
用dmesg看具体是什么错
- 系统: Windows 11
dmesg输出下列内容,看不懂。超出字数限制了,这是第一部分
hman13@hman13-E500:~$ sudo dmesg
[ 0.000000] microcode: microcode updated early to revision 0xf0, date = 2021-11-15
[ 0.000000] Linux version 5.15.0-52-generic (buildd@lcy02-amd64-032) (gcc (Ubuntu 11.2.0-19ubuntu1) 11.2.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #58-Ubuntu SMP Thu Oct 13 08:03:55 UTC 2022 (Ubuntu 5.15.0-52.58-generic 5.15.60)
[ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-5.15.0-52-generic root=UUID=877b6128-a41a-47ee-8def-efeb6c0c8892 ro quiet splash vt.handoff=7
[ 0.000000] KERNEL supported cpus:
[ 0.000000] Intel GenuineIntel
[ 0.000000] AMD AuthenticAMD
[ 0.000000] Hygon HygonGenuine
[ 0.000000] Centaur CentaurHauls
[ 0.000000] zhaoxin Shanghai
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x008: 'MPX bounds registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x010: 'MPX CSR'
[ 0.000000] x86/fpu: xstate_offset[3]: 576, xstate_sizes[3]: 64
[ 0.000000] x86/fpu: xstate_offset[4]: 640, xstate_sizes[4]: 64
[ 0.000000] x86/fpu: Enabled xstate features 0x1b, context size is 704 bytes, using 'compacted' format.
[ 0.000000] signal: max sigframe size: 2032
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000005dfff] usable
[ 0.000000] BIOS-e820: [mem 0x000000000005e000-0x000000000005efff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000000005f000-0x000000000009ffff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000000a0000-0x00000000000fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x000000003fffffff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000040000000-0x00000000403fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000040400000-0x0000000094f28fff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000094f29000-0x0000000094f29fff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x0000000094f2a000-0x0000000094f4ffff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000094f50000-0x0000000094f50fff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000094f51000-0x0000000097eadfff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000097eae000-0x00000000991e3fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000991e4000-0x0000000099313fff] ACPI data
[ 0.000000] BIOS-e820: [mem 0x0000000099314000-0x000000009975ffff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x0000000099760000-0x0000000099ffdfff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000099ffe000-0x0000000099ffefff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000099fff000-0x000000009f7fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000e0000000-0x00000000efffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fe000000-0x00000000fe010fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000015f7fffff] usable
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] e820: update [mem 0x9411b018-0x9412c857] usable ==> usable
[ 0.000000] extended physical RAM map:
[ 0.000000] reserve setup_data: [mem 0x0000000000000000-0x000000000005dfff] usable
[ 0.000000] reserve setup_data: [mem 0x000000000005e000-0x000000000005efff] reserved
[ 0.000000] reserve setup_data: [mem 0x000000000005f000-0x000000000009ffff] usable
[ 0.000000] reserve setup_data: [mem 0x00000000000a0000-0x00000000000fffff] reserved
[ 0.000000] reserve setup_data: [mem 0x0000000000100000-0x000000003fffffff] usable
[ 0.000000] reserve setup_data: [mem 0x0000000040000000-0x00000000403fffff] reserved
[ 0.000000] reserve setup_data: [mem 0x0000000040400000-0x000000009411b017] usable
[ 0.000000] reserve setup_data: [mem 0x000000009411b018-0x000000009412c857] usable
[ 0.000000] reserve setup_data: [mem 0x000000009412c858-0x0000000094f28fff] usable
[ 0.000000] reserve setup_data: [mem 0x0000000094f29000-0x0000000094f29fff] ACPI NVS
[ 0.000000] reserve setup_data: [mem 0x0000000094f2a000-0x0000000094f4ffff] usable
[ 0.000000] reserve setup_data: [mem 0x0000000094f50000-0x0000000094f50fff] reserved
[ 0.000000] reserve setup_data: [mem 0x0000000094f51000-0x0000000097eadfff] usable
[ 0.000000] reserve setup_data: [mem 0x0000000097eae000-0x00000000991e3fff] reserved
[ 0.000000] reserve setup_data: [mem 0x00000000991e4000-0x0000000099313fff] ACPI data
[ 0.000000] reserve setup_data: [mem 0x0000000099314000-0x000000009975ffff] ACPI NVS
[ 0.000000] reserve setup_data: [mem 0x0000000099760000-0x0000000099ffdfff] reserved
[ 0.000000] reserve setup_data: [mem 0x0000000099ffe000-0x0000000099ffefff] usable
[ 0.000000] reserve setup_data: [mem 0x0000000099fff000-0x000000009f7fffff] reserved
[ 0.000000] reserve setup_data: [mem 0x00000000e0000000-0x00000000efffffff] reserved
[ 0.000000] reserve setup_data: [mem 0x00000000fe000000-0x00000000fe010fff] reserved
[ 0.000000] reserve setup_data: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[ 0.000000] reserve setup_data: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[ 0.000000] reserve setup_data: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[ 0.000000] reserve setup_data: [mem 0x0000000100000000-0x000000015f7fffff] usable
[ 0.000000] efi: EFI v2.70 by American Megatrends
[ 0.000000] efi: ACPI=0x99313000 ACPI 2.0=0x99313014 TPMFinalLog=0x9970e000 SMBIOS=0x99bbe000 SMBIOS 3.0=0x99bbd000 MEMATTR=0x94134018 ESRT=0x96a75218 MOKvar=0x94139000 RNG=0x99be6698 TPMEventLog=0x9412d018
[ 0.000000] efi: seeding entropy pool
[ 0.000000] random: crng init done
[ 0.000000] secureboot: Secure boot disabled
[ 0.000000] SMBIOS 3.2.0 present.
[ 0.000000] DMI: TSINGHUA TONGFANG COMPUTER E500/B460-N2(ED), BIOS E001NJ3 06/17/2020
[ 0.000000] tsc: Detected 4000.000 MHz processor
[ 0.000000] tsc: Detected 3999.984 MHz TSC
[ 0.000018] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.000020] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.000028] last_pfn = 0x15f800 max_arch_pfn = 0x400000000
[ 0.000178] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
[ 0.000917] last_pfn = 0x99fff max_arch_pfn = 0x400000000
[ 0.006569] found SMP MP-table at [mem 0x000fcd70-0x000fcd7f]
[ 0.006579] esrt: Reserving ESRT space from 0x0000000096a75218 to 0x0000000096a75250.
[ 0.006583] e820: update [mem 0x96a75000-0x96a75fff] usable ==> reserved
[ 0.006596] e820: update [mem 0x94139000-0x94139fff] usable ==> reserved
[ 0.006616] Using GB pages for direct mapping
[ 0.006986] secureboot: Secure boot disabled
[ 0.006987] RAMDISK: [mem 0x3c39b000-0x3fffdfff]
[ 0.006992] ACPI: Early table checksum verification disabled
[ 0.006994] ACPI: RSDP 0x0000000099313014 000024 (v02 THTFPC)
[ 0.006997] ACPI: XSDT 0x0000000099312728 0000D4 (v01 THTFPC TONGFANG 01072009 AMI 01000013)
[ 0.007002] ACPI: FACP 0x000000009930D000 000114 (v06 THTFPC TONGFANG 01072009 AMI 00010013)
[ 0.007006] ACPI: DSDT 0x00000000992D7000 035D6F (v02 THTFPC TONGFANG 01072009 INTL 20160527)
[ 0.007008] ACPI: FACS 0x000000009975F000 000040
[ 0.007010] ACPI: MCFG 0x0000000099311000 00003C (v01 THTFPC TONGFANG 01072009 MSFT 00000097)
[ 0.007013] ACPI: SSDT 0x000000009930E000 0020AD (v02 CpuRef CpuSsdt 00003000 INTL 20160527)
[ 0.007015] ACPI: FIDT 0x00000000992D6000 00009C (v01 THTFPC TONGFANG 01072009 AMI 00010013)
[ 0.007018] ACPI: MSDM 0x00000000992D5000 000055 (v03 THTFPC TONGFANG 01072009 AMI 01000013)
[ 0.007020] ACPI: SSDT 0x00000000992D1000 0031FA (v02 SaSsdt SaSsdt 00003000 INTL 20160527)
[ 0.007022] ACPI: HPET 0x00000000992D0000 000038 (v01 THTFPC TONGFANG 01072009 AMI 01000013)
[ 0.007025] ACPI: SSDT 0x00000000992CE000 00147B (v02 THTFPC Ther_Rvp 00001000 INTL 20160527)
[ 0.007027] ACPI: SSDT 0x00000000992CA000 00323D (v02 INTEL xh_cmvd4 00000000 INTL 20160527)
[ 0.007029] ACPI: NHLT 0x00000000992C9000 00002D (v00 THTFPC TONGFANG 01072009 AMI 01000013)
[ 0.007032] ACPI: LPIT 0x00000000992C8000 000094 (v01 THTFPC TONGFANG 01072009 AMI 01000013)
[ 0.007034] ACPI: SSDT 0x00000000992C4000 002720 (v02 THTFPC PtidDevc 00001000 INTL 20160527)
[ 0.007036] ACPI: SSDT 0x00000000992C1000 0025B2 (v02 THTFPC TbtTypeC 00000000 INTL 20160527)
[ 0.007039] ACPI: DBGP 0x00000000992C0000 000034 (v01 THTFPC TONGFANG 01072009 AMI 01000013)
[ 0.007041] ACPI: DBG2 0x00000000992BF000 000054 (v00 THTFPC TONGFANG 01072009 AMI 01000013)
[ 0.007043] ACPI: SSDT 0x00000000992BD000 001B67 (v02 THTFPC UsbCTabl 00001000 INTL 20160527)
[ 0.007046] ACPI: DMAR 0x00000000992BC000 0000A8 (v01 INTEL EDK2 00000002 01000013)
[ 0.007048] ACPI: BGRT 0x00000000992BB000 000038 (v01 THTFPC TONGFANG 01072009 AMI 00010013)
[ 0.007050] ACPI: TPM2 0x00000000992BA000 00004C (v04 THTFPC TONGFANG 00000001 AMI 00000000)
[ 0.007053] ACPI: WSMT 0x00000000992C7000 000028 (v01 THTFPC TONGFANG 01072009 AMI 00010013)
[ 0.007055] ACPI: APIC 0x00000000992B9000 000084 (v04 THTFPC TONGFANG 01072009 AMI 00010013)
[ 0.007057] ACPI: FPDT 0x00000000992B8000 000044 (v01 THTFPC CML 01072009 AMI 01000013)
[ 0.007059] ACPI: Reserving FACP table memory at [mem 0x9930d000-0x9930d113]
[ 0.007060] ACPI: Reserving DSDT table memory at [mem 0x992d7000-0x9930cd6e]
[ 0.007061] ACPI: Reserving FACS table memory at [mem 0x9975f000-0x9975f03f]
[ 0.007062] ACPI: Reserving MCFG table memory at [mem 0x99311000-0x9931103b]
[ 0.007063] ACPI: Reserving SSDT table memory at [mem 0x9930e000-0x993100ac]
[ 0.007064] ACPI: Reserving FIDT table memory at [mem 0x992d6000-0x992d609b]
[ 0.007064] ACPI: Reserving MSDM table memory at [mem 0x992d5000-0x992d5054]
[ 0.007065] ACPI: Reserving SSDT table memory at [mem 0x992d1000-0x992d41f9]
[ 0.007066] ACPI: Reserving HPET table memory at [mem 0x992d0000-0x992d0037]
[ 0.007067] ACPI: Reserving SSDT table memory at [mem 0x992ce000-0x992cf47a]
[ 0.007067] ACPI: Reserving SSDT table memory at [mem 0x992ca000-0x992cd23c]
[ 0.007068] ACPI: Reserving NHLT table memory at [mem 0x992c9000-0x992c902c]
[ 0.007069] ACPI: Reserving LPIT table memory at [mem 0x992c8000-0x992c8093]
[ 0.007070] ACPI: Reserving SSDT table memory at [mem 0x992c4000-0x992c671f]
[ 0.007070] ACPI: Reserving SSDT table memory at [mem 0x992c1000-0x992c35b1]
[ 0.007071] ACPI: Reserving DBGP table memory at [mem 0x992c0000-0x992c0033]
[ 0.007072] ACPI: Reserving DBG2 table memory at [mem 0x992bf000-0x992bf053]
[ 0.007073] ACPI: Reserving SSDT table memory at [mem 0x992bd000-0x992beb66]
[ 0.007074] ACPI: Reserving DMAR table memory at [mem 0x992bc000-0x992bc0a7]
[ 0.007074] ACPI: Reserving BGRT table memory at [mem 0x992bb000-0x992bb037]
[ 0.007075] ACPI: Reserving TPM2 table memory at [mem 0x992ba000-0x992ba04b]
[ 0.007076] ACPI: Reserving WSMT table memory at [mem 0x992c7000-0x992c7027]
[ 0.007077] ACPI: Reserving APIC table memory at [mem 0x992b9000-0x992b9083]
[ 0.007077] ACPI: Reserving FPDT table memory at [mem 0x992b8000-0x992b8043]
[ 0.007388] No NUMA configuration found
[ 0.007388] Faking a node at [mem 0x0000000000000000-0x000000015f7fffff]
[ 0.007396] NODE_DATA(0) allocated [mem 0x15f7d6000-0x15f7fffff]
[ 0.007649] Zone ranges:
[ 0.007650] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ 0.007651] DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
[ 0.007652] Normal [mem 0x0000000100000000-0x000000015f7fffff]
[ 0.007654] Device empty
[ 0.007655] Movable zone start for each node
[ 0.007657] Early memory node ranges
[ 0.007657] node 0: [mem 0x0000000000001000-0x000000000005dfff]
[ 0.007658] node 0: [mem 0x000000000005f000-0x000000000009ffff]
[ 0.007659] node 0: [mem 0x0000000000100000-0x000000003fffffff]
[ 0.007660] node 0: [mem 0x0000000040400000-0x0000000094f28fff]
[ 0.007661] node 0: [mem 0x0000000094f2a000-0x0000000094f4ffff]
[ 0.007661] node 0: [mem 0x0000000094f51000-0x0000000097eadfff]
[ 0.007662] node 0: [mem 0x0000000099ffe000-0x0000000099ffefff]
[ 0.007662] node 0: [mem 0x0000000100000000-0x000000015f7fffff]
[ 0.007664] Initmem setup node 0 [mem 0x0000000000001000-0x000000015f7fffff]
[ 0.007667] On node 0, zone DMA: 1 pages in unavailable ranges
[ 0.007668] On node 0, zone DMA: 1 pages in unavailable ranges
[ 0.007690] On node 0, zone DMA: 96 pages in unavailable ranges
[ 0.012645] On node 0, zone DMA32: 1024 pages in unavailable ranges
[ 0.012646] On node 0, zone DMA32: 1 pages in unavailable ranges
[ 0.012743] On node 0, zone DMA32: 1 pages in unavailable ranges
[ 0.012838] On node 0, zone DMA32: 8528 pages in unavailable ranges
[ 0.016409] On node 0, zone Normal: 24577 pages in unavailable ranges
[ 0.016432] On node 0, zone Normal: 2048 pages in unavailable ranges
[ 0.016441] Reserving Intel graphics memory at [mem 0x9b800000-0x9f7fffff]
[ 0.016831] ACPI: PM-Timer IO Port: 0x1808
[ 0.016836] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[ 0.016837] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
[ 0.016838] ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
[ 0.016838] ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
[ 0.016864] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-119
[ 0.016867] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.016868] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.016871] ACPI: Using ACPI (MADT) for SMP configuration information
[ 0.016872] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[ 0.016878] e820: update [mem 0x93fd0000-0x940bffff] usable ==> reserved
[ 0.016889] TSC deadline timer available
[ 0.016890] smpboot: Allowing 4 CPUs, 0 hotplug CPUs
[ 0.016909] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
[ 0.016911] PM: hibernation: Registered nosave memory: [mem 0x0005e000-0x0005efff]
[ 0.016913] PM: hibernation: Registered nosave memory: [mem 0x000a0000-0x000fffff]
[ 0.016914] PM: hibernation: Registered nosave memory: [mem 0x40000000-0x403fffff]
[ 0.016916] PM: hibernation: Registered nosave memory: [mem 0x93fd0000-0x940bffff]
[ 0.016917] PM: hibernation: Registered nosave memory: [mem 0x9411b000-0x9411bfff]
[ 0.016919] PM: hibernation: Registered nosave memory: [mem 0x9412c000-0x9412cfff]
[ 0.016920] PM: hibernation: Registered nosave memory: [mem 0x94139000-0x94139fff]
[ 0.016922] PM: hibernation: Registered nosave memory: [mem 0x94f29000-0x94f29fff]
[ 0.016923] PM: hibernation: Registered nosave memory: [mem 0x94f50000-0x94f50fff]
[ 0.016925] PM: hibernation: Registered nosave memory: [mem 0x96a75000-0x96a75fff]
[ 0.016926] PM: hibernation: Registered nosave memory: [mem 0x97eae000-0x991e3fff]
[ 0.016927] PM: hibernation: Registered nosave memory: [mem 0x991e4000-0x99313fff]
[ 0.016928] PM: hibernation: Registered nosave memory: [mem 0x99314000-0x9975ffff]
[ 0.016928] PM: hibernation: Registered nosave memory: [mem 0x99760000-0x99ffdfff]
[ 0.016930] PM: hibernation: Registered nosave memory: [mem 0x99fff000-0x9f7fffff]
[ 0.016930] PM: hibernation: Registered nosave memory: [mem 0x9f800000-0xdfffffff]
[ 0.016931] PM: hibernation: Registered nosave memory: [mem 0xe0000000-0xefffffff]
[ 0.016932] PM: hibernation: Registered nosave memory: [mem 0xf0000000-0xfdffffff]
[ 0.016932] PM: hibernation: Registered nosave memory: [mem 0xfe000000-0xfe010fff]
[ 0.016933] PM: hibernation: Registered nosave memory: [mem 0xfe011000-0xfebfffff]
[ 0.016933] PM: hibernation: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
[ 0.016934] PM: hibernation: Registered nosave memory: [mem 0xfec01000-0xfedfffff]
[ 0.016935] PM: hibernation: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
[ 0.016935] PM: hibernation: Registered nosave memory: [mem 0xfee01000-0xfeffffff]
[ 0.016936] PM: hibernation: Registered nosave memory: [mem 0xff000000-0xffffffff]
[ 0.016937] [mem 0x9f800000-0xdfffffff] available for PCI devices
[ 0.016938] Booting paravirtualized kernel on bare hardware
[ 0.016940] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645519600211568 ns
[ 0.016946] setup_percpu: NR_CPUS:8192 nr_cpumask_bits:4 nr_cpu_ids:4 nr_node_ids:1
[ 0.017106] percpu: Embedded 60 pages/cpu s208896 r8192 d28672 u524288
[ 0.017112] pcpu-alloc: s208896 r8192 d28672 u524288 alloc=1*2097152
[ 0.017114] pcpu-alloc: [0] 0 1 2 3
[ 0.017139] Built 1 zonelists, mobility grouping on. Total pages: 996322
[ 0.017140] Policy zone: Normal
[ 0.017142] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.15.0-52-generic root=UUID=877b6128-a41a-47ee-8def-efeb6c0c8892 ro quiet splash vt.handoff=7
[ 0.017204] Unknown kernel command line parameters "splash BOOT_IMAGE=/boot/vmlinuz-5.15.0-52-generic", will be passed to user space.
[ 0.017399] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.017513] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.017554] mem auto-init: stack:off, heap alloc:on, heap free:off
[ 0.039642] Memory: 3729240K/4049196K available (16393K kernel code, 4378K rwdata, 10812K rodata, 3228K init, 6572K bss, 319696K reserved, 0K cma-reserved)
[ 0.039738] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.039759] ftrace: allocating 50499 entries in 198 pages
[ 0.059423] ftrace: allocated 198 pages with 4 groups
[ 0.059509] rcu: Hierarchical RCU implementation.
[ 0.059510] rcu: RCU restricting CPUs from NR_CPUS=8192 to nr_cpu_ids=4.
[ 0.059512] Rude variant of Tasks RCU enabled.
[ 0.059512] Tracing variant of Tasks RCU enabled.
[ 0.059513] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.059513] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.062571] NR_IRQS: 524544, nr_irqs: 1024, preallocated irqs: 16
[ 0.062906] Console: colour dummy device 80x25
[ 0.062920] printk: console [tty0] enabled
[ 0.062935] ACPI: Core revision 20210730
[ 0.063147] hpet: HPET dysfunctional in PC10. Force disabled.
[ 0.063148] APIC: Switch to symmetric I/O mode setup
[ 0.063150] DMAR: Host address width 39
[ 0.063151] DMAR: DRHD base: 0x000000fed90000 flags: 0x0
[ 0.063155] DMAR: dmar0: reg_base_addr fed90000 ver 1:0 cap 1c0000c40660462 ecap 19e2ff0505e
[ 0.063157] DMAR: DRHD base: 0x000000fed91000 flags: 0x1
[ 0.063159] DMAR: dmar1: reg_base_addr fed91000 ver 1:0 cap d2008c40660462 ecap f050da
[ 0.063161] DMAR: RMRR base: 0x0000009994e000 end: 0x00000099b97fff
[ 0.063162] DMAR: RMRR base: 0x0000009b000000 end: 0x0000009f7fffff
[ 0.063164] DMAR-IR: IOAPIC id 2 under DRHD base 0xfed91000 IOMMU 1
[ 0.063165] DMAR-IR: HPET id 0 under DRHD base 0xfed91000
[ 0.063166] DMAR-IR: Queued invalidation will be enabled to support x2apic and Intr-remapping.
[ 0.248873] DMAR-IR: Enabled IRQ remapping in x2apic mode
[ 0.248874] x2apic enabled
[ 0.248889] Switched APIC routing to cluster x2apic.
[ 0.252749] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x73509d9fa88, max_idle_ns: 881590914879 ns
[ 0.252760] Calibrating delay loop (skipped), value calculated using timer frequency.. 7999.96 BogoMIPS (lpj=15999936)
[ 0.252762] pid_max: default: 32768 minimum: 301
[ 0.255097] LSM: Security Framework initializing
[ 0.255105] landlock: Up and running.
[ 0.255105] Yama: becoming mindful.
[ 0.255123] AppArmor: AppArmor initialized
[ 0.255154] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.255163] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.255348] x86/cpu: SGX disabled by BIOS.
[ 0.255354] CPU0: Thermal monitoring enabled (TM1)
[ 0.255385] process: using mwait in idle threads
[ 0.255387] Last level iTLB entries: 4KB 64, 2MB 8, 4MB 8
[ 0.255387] Last level dTLB entries: 4KB 64, 2MB 0, 4MB 0, 1GB 4
[ 0.255390] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[ 0.255392] Spectre V2 : Mitigation: Enhanced IBRS
[ 0.255392] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[ 0.255393] Spectre V2 : Spectre v2 / PBRSB-eIBRS: Retire a single CALL on VMEXIT
[ 0.255393] RETBleed: Mitigation: Enhanced IBRS
[ 0.255394] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[ 0.255395] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
[ 0.255398] MMIO Stale Data: Mitigation: Clear CPU buffers
[ 0.255399] SRBDS: Mitigation: Microcode
[ 0.256757] Freeing SMP alternatives memory: 40K
[ 0.256757] smpboot: Estimated ratio of average max frequency by base frequency (times 1024): 1024
[ 0.256757] smpboot: CPU0: Intel(R) Pentium(R) Gold G6400 CPU @ 4.00GHz (family: 0x6, model: 0xa5, stepping: 0x3)
[ 0.256757] Performance Events: PEBS fmt3+, Skylake events, 32-deep LBR, full-width counters, Intel PMU driver.
[ 0.256757] ... version: 4
[ 0.256757] ... bit width: 48
[ 0.256757] ... generic registers: 4
[ 0.256757] ... value mask: 0000ffffffffffff
[ 0.256757] ... max period: 00007fffffffffff
[ 0.256757] ... fixed-purpose events: 3
[ 0.256757] ... event mask: 000000070000000f
[ 0.256757] rcu: Hierarchical SRCU implementation.
[ 0.256757] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[ 0.256757] smp: Bringing up secondary CPUs ...
[ 0.256757] x86: Booting SMP configuration:
[ 0.256757] .... node #0, CPUs: #1 #2
[ 0.256757] MMIO Stale Data CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/ ... _data.html for more details.
[ 0.256757] #3
[ 0.256757] smp: Brought up 1 node, 4 CPUs
[ 0.256757] smpboot: Max logical packages: 1
[ 0.256757] smpboot: Total of 4 processors activated (31999.87 BogoMIPS)
[ 0.256883] devtmpfs: initialized
[ 0.256883] x86/mm: Memory block size: 128MB
[ 0.256997] ACPI: PM: Registering ACPI NVS region [mem 0x94f29000-0x94f29fff] (4096 bytes)
[ 0.256997] ACPI: PM: Registering ACPI NVS region [mem 0x99314000-0x9975ffff] (4505600 bytes)
[ 0.256997] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.256997] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.256997] pinctrl core: initialized pinctrl subsystem
[ 0.257038] PM: RTC time: 06:21:38, date: 2022-10-23
[ 0.257113] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.257188] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[ 0.257209] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.257231] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.257236] audit: initializing netlink subsys (disabled)
[ 0.257240] audit: type=2000 audit(1666506098.004:1): state=initialized audit_enabled=0 res=1
[ 0.257240] thermal_sys: Registered thermal governor 'fair_share'
[ 0.257240] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.257240] thermal_sys: Registered thermal governor 'step_wise'
[ 0.257240] thermal_sys: Registered thermal governor 'user_space'
[ 0.257240] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.257240] EISA bus registered
[ 0.257240] cpuidle: using governor ladder
[ 0.257240] cpuidle: using governor menu
[ 0.257240] ACPI: bus type PCI registered
[ 0.257240] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.257240] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.257240] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in E820
[ 0.257240] PCI: Using configuration type 1 for base access
[ 0.257240] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[ 0.257550] Kprobes globally optimized
[ 0.257552] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.257552] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.257552] fbcon: Taking over console
[ 0.257552] ACPI: Added _OSI(Module Device)
[ 0.257552] ACPI: Added _OSI(Processor Device)
[ 0.257552] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.257552] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.257552] ACPI: Added _OSI(Linux-Dell-Video)
[ 0.257552] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[ 0.257552] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[ 0.309894] ACPI: 8 ACPI AML tables successfully acquired and loaded
[ 0.313458] ACPI: Dynamic OEM Table Load:
[ 0.313458] ACPI: SSDT 0xFFFF8C7EC1071800 0000FC (v02 PmRef Cpu0Psd 00003000 INTL 20160527)
[ 0.313795] ACPI: \_SB_.PR00: _OSC native thermal LVT Acked
[ 0.315149] ACPI: Dynamic OEM Table Load:
[ 0.315154] ACPI: SSDT 0xFFFF8C7EC11B0800 000400 (v02 PmRef Cpu0Cst 00003001 INTL 20160527)
[ 0.315998] ACPI: Dynamic OEM Table Load:
[ 0.316003] ACPI: SSDT 0xFFFF8C7EC0C86800 00072E (v02 PmRef Cpu0Ist 00003000 INTL 20160527)
[ 0.317915] ACPI: Dynamic OEM Table Load:
[ 0.317920] ACPI: SSDT 0xFFFF8C7EC0C81800 000778 (v02 PmRef ApIst 00003000 INTL 20160527)
[ 0.318867] ACPI: Dynamic OEM Table Load:
[ 0.318871] ACPI: SSDT 0xFFFF8C7EC11B3800 0003D7 (v02 PmRef ApHwp 00003000 INTL 20160527)
[ 0.319795] ACPI: Dynamic OEM Table Load:
[ 0.319800] ACPI: SSDT 0xFFFF8C7EC0C88000 000D22 (v02 PmRef ApPsd 00003000 INTL 20160527)
[ 0.321292] ACPI: Dynamic OEM Table Load:
[ 0.321296] ACPI: SSDT 0xFFFF8C7EC11B3C00 0003CA (v02 PmRef ApCst 00003000 INTL 20160527)
[ 0.324611] ACPI: Interpreter enabled
[ 0.324639] ACPI: PM: (supports S0 S3 S4 S5)
[ 0.324640] ACPI: Using IOAPIC for interrupt routing
[ 0.324667] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.324668] PCI: Using E820 reservations for host bridge windows
[ 0.325733] ACPI: Enabled 8 GPEs in block 00 to 7F
[ 0.336534] ACPI: PM: Power Resource [V0PR]
[ 0.336706] ACPI: PM: Power Resource [V1PR]
[ 0.336876] ACPI: PM: Power Resource [V2PR]
[ 0.341056] ACPI: PM: Power Resource [FN00]
[ 0.341113] ACPI: PM: Power Resource [FN01]
[ 0.341170] ACPI: PM: Power Resource [FN02]
[ 0.341226] ACPI: PM: Power Resource [FN03]
[ 0.341282] ACPI: PM: Power Resource [FN04]
[ 0.341657] ACPI: PM: Power Resource [PIN]
[ 0.342059] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-fe])
[ 0.342064] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[ 0.343682] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug SHPCHotplug PME AER PCIeCapability LTR DPC]
[ 0.344430] PCI host bridge to bus 0000:00
[ 0.344432] pci_bus 0000:00: root bus resource [bus 00-fe]
[ 0.344434] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
[ 0.344435] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 0.344436] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[ 0.344436] pci_bus 0000:00: root bus resource [mem 0x9f800000-0xdfffffff window]
[ 0.344437] pci_bus 0000:00: root bus resource [mem 0xfc800000-0xfe7fffff window]
[ 0.344561] pci 0000:00:00.0: [8086:9b73] type 00 class 0x060000
[ 0.344856] pci 0000:00:02.0: [8086:9ba8] type 00 class 0x030000
[ 0.344862] pci 0000:00:02.0: reg 0x10: [mem 0xb0000000-0xb0ffffff 64bit]
[ 0.344866] pci 0000:00:02.0: reg 0x18: [mem 0xa0000000-0xafffffff 64bit pref]
[ 0.344868] pci 0000:00:02.0: reg 0x20: [io 0x4000-0x403f]
[ 0.344878] pci 0000:00:02.0: BAR 2: assigned to efifb
[ 0.344880] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[ 0.345078] pci 0000:00:08.0: [8086:1911] type 00 class 0x088000
[ 0.345085] pci 0000:00:08.0: reg 0x10: [mem 0xb1131000-0xb1131fff 64bit]
[ 0.345374] pci 0000:00:14.0: [8086:a3af] type 00 class 0x0c0330
[ 0.345400] pci 0000:00:14.0: reg 0x10: [mem 0xb1110000-0xb111ffff 64bit]
[ 0.345495] pci 0000:00:14.0: PME# supported from D3hot D3cold
[ 0.346205] pci 0000:00:14.2: [8086:a3b1] type 00 class 0x118000
[ 0.346229] pci 0000:00:14.2: reg 0x10: [mem 0xb1130000-0xb1130fff 64bit]
[ 0.346698] pci 0000:00:15.0: [8086:a3e0] type 00 class 0x118000
[ 0.346920] pci 0000:00:15.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 0.348205] pci 0000:00:15.1: [8086:a3e1] type 00 class 0x118000
[ 0.348427] pci 0000:00:15.1: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 0.349593] pci 0000:00:16.0: [8086:a3ba] type 00 class 0x078000
[ 0.349618] pci 0000:00:16.0: reg 0x10: [mem 0xb112d000-0xb112dfff 64bit]
[ 0.349699] pci 0000:00:16.0: PME# supported from D3hot
[ 0.350208] pci 0000:00:17.0: [8086:a382] type 00 class 0x010601
[ 0.350230] pci 0000:00:17.0: reg 0x10: [mem 0xb1128000-0xb1129fff]
[ 0.350241] pci 0000:00:17.0: reg 0x14: [mem 0xb112c000-0xb112c0ff]
[ 0.350252] pci 0000:00:17.0: reg 0x18: [io 0x4090-0x4097]
[ 0.350263] pci 0000:00:17.0: reg 0x1c: [io 0x4080-0x4083]
[ 0.350274] pci 0000:00:17.0: reg 0x20: [io 0x4060-0x407f]
[ 0.350285] pci 0000:00:17.0: reg 0x24: [mem 0xb112b000-0xb112b7ff]
[ 0.350344] pci 0000:00:17.0: PME# supported from D3hot
[ 0.350559] pci 0000:00:1c.0: [8086:a395] type 01 class 0x060400
[ 0.350692] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.351246] pci 0000:00:1c.6: [8086:a396] type 01 class 0x060400
[ 0.351379] pci 0000:00:1c.6: PME# supported from D0 D3hot D3cold
[ 0.351915] pci 0000:00:1f.0: [8086:a3c8] type 00 class 0x060100
[ 0.352319] pci 0000:00:1f.2: [8086:a3a1] type 00 class 0x058000
[ 0.352336] pci 0000:00:1f.2: reg 0x10: [mem 0xb1124000-0xb1127fff]
[ 0.352701] pci 0000:00:1f.3: [8086:a3f0] type 00 class 0x040300
[ 0.352726] pci 0000:00:1f.3: reg 0x10: [mem 0xb1120000-0xb1123fff 64bit]
[ 0.352755] pci 0000:00:1f.3: reg 0x20: [mem 0xb1100000-0xb110ffff 64bit]
[ 0.352805] pci 0000:00:1f.3: PME# supported from D3hot D3cold
[ 0.353771] pci 0000:00:1f.4: [8086:a3a3] type 00 class 0x0c0500
[ 0.353832] pci 0000:00:1f.4: reg 0x10: [mem 0xb112a000-0xb112a0ff 64bit]
[ 0.353901] pci 0000:00:1f.4: reg 0x20: [io 0xefa0-0xefbf]
[ 0.354241] pci 0000:01:00.0: [1283:8893] type 01 class 0x060401
[ 0.354367] pci 0000:01:00.0: supports D1 D2
[ 0.354368] pci 0000:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.354424] pci 0000:00:1c.0: PCI bridge to [bus 01-02]
[ 0.354473] pci_bus 0000:02: extended config space not accessible
[ 0.354574] pci 0000:01:00.0: PCI bridge to [bus 02] (subtractive decode)
[ 0.354708] pci 0000:03:00.0: [10ec:8168] type 00 class 0x020000
[ 0.354730] pci 0000:03:00.0: reg 0x10: [io 0x3000-0x30ff]
[ 0.354758] pci 0000:03:00.0: reg 0x18: [mem 0xb1004000-0xb1004fff 64bit]
[ 0.354775] pci 0000:03:00.0: reg 0x20: [mem 0xb1000000-0xb1003fff 64bit]
[ 0.354899] pci 0000:03:00.0: supports D1 D2
[ 0.354900] pci 0000:03:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.355051] pci 0000:00:1c.6: PCI bridge to [bus 03]
[ 0.355055] pci 0000:00:1c.6: bridge window [io 0x3000-0x3fff]
[ 0.355059] pci 0000:00:1c.6: bridge window [mem 0xb1000000-0xb10fffff]
[ 0.357605] ACPI: PCI: Interrupt link LNKA configured for IRQ 0
[ 0.357682] ACPI: PCI: Interrupt link LNKB configured for IRQ 1
[ 0.357755] ACPI: PCI: Interrupt link LNKC configured for IRQ 0
[ 0.357827] ACPI: PCI: Interrupt link LNKD configured for IRQ 0
[ 0.357899] ACPI: PCI: Interrupt link LNKE configured for IRQ 0
[ 0.357970] ACPI: PCI: Interrupt link LNKF configured for IRQ 0
[ 0.358042] ACPI: PCI: Interrupt link LNKG configured for IRQ 0
[ 0.358114] ACPI: PCI: Interrupt link LNKH configured for IRQ 0
[ 0.362194] iommu: Default domain type: Translated
[ 0.362194] iommu: DMA domain TLB invalidation policy: lazy mode
[ 0.362194] SCSI subsystem initialized
[ 0.362194] libata version 3.00 loaded.
[ 0.362194] pci 0000:00:02.0: vgaarb: setting as boot VGA device
[ 0.362194] pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[ 0.362194] pci 0000:00:02.0: vgaarb: bridge control possible
[ 0.362194] vgaarb: loaded
[ 0.362194] ACPI: bus type USB registered
[ 0.362194] usbcore: registered new interface driver usbfs
[ 0.362194] usbcore: registered new interface driver hub
[ 0.362194] usbcore: registered new device driver usb
[ 0.362194] pps_core: LinuxPPS API ver. 1 registered
[ 0.362194] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.362194] PTP clock support registered
[ 0.362194] EDAC MC: Ver: 3.0.0
[ 0.362194] Registered efivars operations
[ 0.362194] NetLabel: Initializing
[ 0.362194] NetLabel: domain hash size = 128
[ 0.362194] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.362194] NetLabel: unlabeled traffic allowed by default
[ 0.362194] PCI: Using ACPI for IRQ routing
[ 0.392611] PCI: pci_cache_line_size set to 64 bytes
[ 0.392714] e820: reserve RAM buffer [mem 0x0005e000-0x0005ffff]
[ 0.392716] e820: reserve RAM buffer [mem 0x93fd0000-0x93ffffff]
[ 0.392717] e820: reserve RAM buffer [mem 0x9411b018-0x97ffffff]
[ 0.392718] e820: reserve RAM buffer [mem 0x94139000-0x97ffffff]
[ 0.392718] e820: reserve RAM buffer [mem 0x94f29000-0x97ffffff]
[ 0.392719] e820: reserve RAM buffer [mem 0x94f50000-0x97ffffff]
[ 0.392720] e820: reserve RAM buffer [mem 0x96a75000-0x97ffffff]
[ 0.392720] e820: reserve RAM buffer [mem 0x97eae000-0x97ffffff]
[ 0.392721] e820: reserve RAM buffer [mem 0x99fff000-0x9bffffff]
[ 0.392722] e820: reserve RAM buffer [mem 0x15f800000-0x15fffffff]
[ 0.393521] clocksource: Switched to clocksource tsc-early
[ 0.398727] VFS: Disk quotas dquot_6.6.0
[ 0.398743] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.398854] AppArmor: AppArmor Filesystem Enabled
[ 0.398896] pnp: PnP ACPI init
[ 0.399031] system 00:00: [mem 0x40000000-0x403fffff] has been reserved
[ 0.399323] system 00:01: [io 0x0a00-0x0a0f] has been reserved
[ 0.399326] system 00:01: [io 0x0a10-0x0a1f] has been reserved
[ 0.399328] system 00:01: [io 0x0a20-0x0a2f] has been reserved
[ 0.399919] pnp 00:02: [dma 3]
[ 0.400509] pnp 00:03: [dma 0 disabled]
[ 0.400941] pnp 00:04: [dma 0 disabled]
[ 0.401084] system 00:05: [io 0x0680-0x069f] has been reserved
[ 0.401087] system 00:05: [io 0x164e-0x164f] has been reserved
[ 0.401209] system 00:06: [io 0x1854-0x1857] has been reserved
[ 0.401349] system 00:07: [mem 0xfd000000-0xfdabffff] has been reserved
[ 0.401352] system 00:07: [mem 0xfdad0000-0xfdadffff] has been reserved
[ 0.401353] system 00:07: [mem 0xfdb00000-0xfdffffff] has been reserved
[ 0.401355] system 00:07: [mem 0xfe000000-0xfe01ffff] could not be reserved
[ 0.401357] system 00:07: [mem 0xfe036000-0xfe03bfff] has been reserved
[ 0.401359] system 00:07: [mem 0xfe03d000-0xfe3fffff] has been reserved
[ 0.401361] system 00:07: [mem 0xfe410000-0xfe7fffff] has been reserved
[ 0.401650] system 00:08: [io 0x2000-0x20fe] has been reserved
[ 0.402345] system 00:09: [mem 0xfed10000-0xfed17fff] has been reserved
[ 0.402347] system 00:09: [mem 0xfed18000-0xfed18fff] has been reserved
[ 0.402349] system 00:09: [mem 0xfed19000-0xfed19fff] has been reserved
[ 0.402351] system 00:09: [mem 0xe0000000-0xefffffff] has been reserved
[ 0.402353] system 00:09: [mem 0xfed20000-0xfed3ffff] has been reserved
[ 0.402355] system 00:09: [mem 0xfed90000-0xfed93fff] could not be reserved
[ 0.402356] system 00:09: [mem 0xfed45000-0xfed8ffff] has been reserved
[ 0.402358] system 00:09: [mem 0xfee00000-0xfeefffff] could not be reserved
[ 0.402752] system 00:0a: [mem 0xfe038000-0xfe038fff] has been reserved
[ 0.403198] pnp: PnP ACPI: found 11 devices
[ 0.408376] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.408410] NET: Registered PF_INET protocol family
[ 0.408456] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.408893] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[ 0.408914] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.408937] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.408984] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
[ 0.409006] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.409042] MPTCP token hash table entries: 4096 (order: 4, 98304 bytes, linear)
[ 0.409056] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 0.409064] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 0.409087] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.409090] NET: Registered PF_XDP protocol family
[ 0.409104] clipped [mem size 0x00020000 64bit] to [mem size 0xfffffffffffc0000 64bit] for e820 entry [mem 0x000a0000-0x000fffff]
[ 0.409108] pci 0000:00:15.0: BAR 0: assigned [mem 0x9f800000-0x9f800fff 64bit]
[ 0.409206] clipped [mem size 0x00020000 64bit] to [mem size 0xfffffffffffc0000 64bit] for e820 entry [mem 0x000a0000-0x000fffff]
[ 0.409209] pci 0000:00:15.1: BAR 0: assigned [mem 0x9f801000-0x9f801fff 64bit]
[ 0.409305] pci 0000:01:00.0: PCI bridge to [bus 02]
[ 0.409323] pci 0000:00:1c.0: PCI bridge to [bus 01-02]
[ 0.409337] pci 0000:00:1c.6: PCI bridge to [bus 03]
[ 0.409339] pci 0000:00:1c.6: bridge window [io 0x3000-0x3fff]
[ 0.409344] pci 0000:00:1c.6: bridge window [mem 0xb1000000-0xb10fffff]
[ 0.409354] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
[ 0.409356] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
[ 0.409357] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[ 0.409358] pci_bus 0000:00: resource 7 [mem 0x9f800000-0xdfffffff window]
[ 0.409358] pci_bus 0000:00: resource 8 [mem 0xfc800000-0xfe7fffff window]
[ 0.409360] pci_bus 0000:03: resource 0 [io 0x3000-0x3fff]
[ 0.409360] pci_bus 0000:03: resource 1 [mem 0xb1000000-0xb10fffff]
[ 0.409584] PCI: CLS 64 bytes, default 64
[ 0.409612] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 0.409613] software IO TLB: mapped [mem 0x000000008f5f4000-0x00000000935f4000] (64MB)
[ 0.409642] Trying to unpack rootfs image as initramfs...
[ 0.416911] platform rtc_cmos: registered platform RTC device (no PNP device found)
[ 0.417287] Initialise system trusted keyrings
[ 0.417306] Key type blacklist registered
[ 0.417334] workingset: timestamp_bits=36 max_order=20 bucket_order=0
[ 0.418522] zbud: loaded
[ 0.418738] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.418843] fuse: init (API version 7.34)
[ 0.418947] integrity: Platform Keyring initialized
[ 0.424506] Key type asymmetric registered
[ 0.424508] Asymmetric key parser 'x509' registered
[ 0.424531] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[ 0.424555] io scheduler mq-deadline registered
[ 0.424967] pcieport 0000:00:1c.0: PME: Signaling with IRQ 122
[ 0.425023] pcieport 0000:00:1c.0: AER: enabled with IRQ 122
[ 0.425280] pcieport 0000:00:1c.6: PME: Signaling with IRQ 123
[ 0.425328] pcieport 0000:00:1c.6: AER: enabled with IRQ 123
[ 0.425431] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 0.425798] Monitor-Mwait will be used to enter C-1 state
[ 0.425802] Monitor-Mwait will be used to enter C-2 state
[ 0.425804] Monitor-Mwait will be used to enter C-3 state
[ 0.425806] ACPI: \_SB_.PR00: Found 3 idle states
[ 0.426095] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input0
[ 0.426114] ACPI: button: Sleep Button [SLPB]
[ 0.426142] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
[ 0.426157] ACPI: button: Power Button [PWRB]
[ 0.426184] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
[ 0.426208] ACPI: button: Power Button [PWRF]
[ 0.426364] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PR00._CPC], AE_NOT_FOUND (20210730/psargs-330)
[ 0.426375] No Local Variables are initialized for Method [_CPC]
[ 0.426377] No Arguments are initialized for method [_CPC]
[ 0.426378] ACPI Error: Aborting method \_SB.PR01._CPC due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
[ 0.426423] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PR00._CPC], AE_NOT_FOUND (20210730/psargs-330)
[ 0.426430] No Local Variables are initialized for Method [_CPC]
[ 0.426431] No Arguments are initialized for method [_CPC]
[ 0.426433] ACPI Error: Aborting method \_SB.PR02._CPC due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
[ 0.426477] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PR00._CPC], AE_NOT_FOUND (20210730/psargs-330)
[ 0.426485] No Local Variables are initialized for Method [_CPC]
[ 0.426486] No Arguments are initialized for method [_CPC]
[ 0.426488] ACPI Error: Aborting method \_SB.PR03._CPC due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
[ 0.427052] thermal LNXTHERM:00: registered as thermal_zone0
[ 0.427054] ACPI: thermal: Thermal Zone [TZ00] (28 C)
[ 0.427240] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[ 0.448411] 00:03: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
[ 0.470870] 00:04: ttyS1 at I/O 0x2f8 (irq = 3, base_baud = 115200) is a 16550A
[ 0.473388] hpet_acpi_add: no address or irqs in _CRS
[ 0.473439] Linux agpgart interface v0.103
[ 0.482538] loop: module loaded
[ 0.482765] tun: Universal TUN/TAP device driver, 1.6
[ 0.482782] PPP generic driver version 2.4.2
[ 0.482817] VFIO - User Level meta-driver version: 0.3
[ 0.482893] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.482895] ehci-pci: EHCI PCI platform driver
[ 0.482902] ehci-platform: EHCI generic platform driver
[ 0.482908] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.482909] ohci-pci: OHCI PCI platform driver
[ 0.482915] ohci-platform: OHCI generic platform driver
[ 0.482920] uhci_hcd: USB Universal Host Controller Interface driver
[ 0.482950] i8042: PNP: No PS/2 controller found.
[ 0.482984] mousedev: PS/2 mouse device common for all mice
[ 0.483079] rtc_cmos rtc_cmos: RTC can wake from S4
[ 0.483656] rtc_cmos rtc_cmos: registered as rtc0
[ 0.483783] rtc_cmos rtc_cmos: setting system clock to 2022-10-23T06:21:38 UTC (1666506098)
[ 0.483797] rtc_cmos rtc_cmos: alarms up to one month, y3k, 114 bytes nvram
[ 0.483803] i2c_dev: i2c /dev entries driver
[ 0.483962] device-mapper: core: CONFIG_IMA_DISABLE_HTABLE is disabled. Duplicate IMA measurements will not be recorded in the IMA log.
[ 0.483986] device-mapper: uevent: version 1.0.3
[ 0.484023] device-mapper: ioctl: 4.45.0-ioctl (2021-03-22) initialised: dm-devel@redhat.com
[ 0.484040] platform eisa.0: Probing EISA bus 0
[ 0.484042] platform eisa.0: EISA: Cannot allocate resource for mainboard
[ 0.484044] platform eisa.0: Cannot allocate resource for EISA slot 1
[ 0.484045] platform eisa.0: Cannot allocate resource for EISA slot 2
[ 0.484046] platform eisa.0: Cannot allocate resource for EISA slot 3
[ 0.484048] platform eisa.0: Cannot allocate resource for EISA slot 4
[ 0.484049] platform eisa.0: Cannot allocate resource for EISA slot 5
[ 0.484050] platform eisa.0: Cannot allocate resource for EISA slot 6
[ 0.484051] platform eisa.0: Cannot allocate resource for EISA slot 7
[ 0.484052] platform eisa.0: Cannot allocate resource for EISA slot 8
[ 0.484053] platform eisa.0: EISA: Detected 0 cards
[ 0.484056] intel_pstate: Intel P-state driver initializing
[ 0.484144] intel_pstate: HWP enabled
[ 0.484218] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.484237] efifb: probing for efifb
[ 0.484256] efifb: showing boot graphics
[ 0.486250] efifb: framebuffer at 0xa0000000, using 8100k, total 8100k
[ 0.486252] efifb: mode is 1920x1080x32, linelength=7680, pages=1
[ 0.486254] efifb: scrolling: redraw
[ 0.486255] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ 0.486334] Console: switching to colour frame buffer device 240x67
[ 0.490857] fb0: EFI VGA frame buffer device
[ 0.490867] EFI Variables Facility v0.08 2004-May-17
[ 0.496439] resource sanity check: requesting [mem 0xfdffe800-0xfe0007ff], which spans more than pnp 00:07 [mem 0xfdb00000-0xfdffffff]
[ 0.496445] caller pmc_core_probe+0xb3/0x250 mapping multiple BARs
[ 0.496463] intel_pmc_core INT33A1:00: initialized
[ 0.496549] drop_monitor: Initializing network drop monitor service
[ 0.496684] NET: Registered PF_INET6 protocol family
[ 0.679506] Freeing initrd memory: 61836K
[ 0.682909] Segment Routing with IPv6
[ 0.682919] In-situ OAM (IOAM) with IPv6
[ 0.682937] NET: Registered PF_PACKET protocol family
[ 0.682959] Key type dns_resolver registered
[ 0.683135] microcode: sig=0xa0653, pf=0x2, revision=0xf0
[ 0.683161] microcode: Microcode Update Driver: v2.2.
[ 0.683173] IPI shorthand broadcast: enabled
[ 0.683179] sched_clock: Marking stable (493271414, 189885712)->(705027807, -21870681)
[ 0.683267] registered taskstats version 1
[ 0.683293] Loading compiled-in X.509 certificates
[ 0.683707] Loaded X.509 cert 'Build time autogenerated kernel key: f4250c069446d374e20697dfdb8caf1b5de3eae8'
[ 0.684076] Loaded X.509 cert 'Canonical Ltd. Live Patch Signing: 14df34d1a87cf37625abec039ef2bf521249b969'
[ 0.684440] Loaded X.509 cert 'Canonical Ltd. Kernel Module Signing: 88f752e560a1e0737e31163a466ad7b70a850c19'
[ 0.684440] blacklist: Loading compiled-in revocation X.509 certificates
[ 0.684450] Loaded X.509 cert 'Canonical Ltd. Secure Boot Signing: 61482aa2830d0ab2ad5af10b7250da9033ddcef0'
[ 0.684530] zswap: loaded using pool lzo/zbud
[ 0.684626] Key type ._fscrypt registered
[ 0.684627] Key type .fscrypt registered
[ 0.684627] Key type fscrypt-provisioning registered
[ 0.684690] Key type trusted registered
[ 0.686258] Key type encrypted registered
[ 0.686261] AppArmor: AppArmor sha1 policy hashing enabled
[ 0.686787] integrity: Loading X.509 certificate: UEFI:MokListRT (MOKvar table)
[ 0.686953] integrity: Loaded X.509 cert 'Canonical Ltd. Master Certificate Authority: ad91990bc22ab1f517048c23b6655a268e345a63'
[ 0.686956] Loading compiled-in module X.509 certificates
[ 0.687328] Loaded X.509 cert 'Build time autogenerated kernel key: f4250c069446d374e20697dfdb8caf1b5de3eae8'
[ 0.687329] ima: Allocated hash algorithm: sha1
[ 0.720831] ima: No architecture policies found
[ 0.720847] evm: Initialising EVM extended attributes:
[ 0.720848] evm: security.selinux
[ 0.720850] evm: security.SMACK64
[ 0.720851] evm: security.SMACK64EXEC
[ 0.720853] evm: security.SMACK64TRANSMUTE
[ 0.720854] evm: security.SMACK64MMAP
[ 0.720855] evm: security.apparmor
[ 0.720856] evm: security.ima
[ 0.720857] evm: security.capability
[ 0.720858] evm: HMAC attrs: 0x1
[ 0.721287] PM: Magic number: 10:211:368
[ 0.721579] RAS: Correctable Errors collector initialized.
[ 0.723338] Freeing unused decrypted memory: 2036K
[ 0.724095] Freeing unused kernel image (initmem) memory: 3228K
[ 0.748853] Write protecting the kernel read-only data: 30720k
[ 0.749669] Freeing unused kernel image (text/rodata gap) memory: 2036K
[ 0.750053] Freeing unused kernel image (rodata/data gap) memory: 1476K
[ 0.777982] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 0.777990] Run /init as init process
[ 0.777993] with arguments:
[ 0.777995] /init
[ 0.777996] splash
[ 0.777997] with environment:
[ 0.777999] HOME=/
[ 0.778000] TERM=linux
[ 0.778001] BOOT_IMAGE=/boot/vmlinuz-5.15.0-52-generic
[ 0.881079] acpi PNP0C14:01: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
[ 0.881370] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 0.881376] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
[ 0.882809] xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x100 quirks 0x0000000000109810
[ 0.883722] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 0.883726] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[ 0.883728] xhci_hcd 0000:00:14.0: Host supports USB 3.0 SuperSpeed
[ 0.883753] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[ 0.883756] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.883757] usb usb1: Product: xHCI Host Controller
[ 0.883759] usb usb1: Manufacturer: Linux 5.15.0-52-generic xhci-hcd
[ 0.883760] usb usb1: SerialNumber: 0000:00:14.0
[ 0.885434] hub 1-0:1.0: USB hub found
[ 0.885466] hub 1-0:1.0: 12 ports detected
[ 0.887178] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15
[ 0.887180] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.887181] usb usb2: Product: xHCI Host Controller
[ 0.887182] usb usb2: Manufacturer: Linux 5.15.0-52-generic xhci-hcd
[ 0.887183] usb usb2: SerialNumber: 0000:00:14.0
[ 0.888851] ahci 0000:00:17.0: version 3.0
[ 0.889139] hub 2-0:1.0: USB hub found
[ 0.889163] hub 2-0:1.0: 8 ports detected
[ 0.892040] i801_smbus 0000:00:1f.4: SPD Write Disable is set
[ 0.892079] i801_smbus 0000:00:1f.4: SMBus using PCI interrupt
[ 0.893263] i2c i2c-0: 1/2 memory slots populated (from DMI)
[ 0.893791] i2c i2c-0: Successfully instantiated SPD at 0x50
[ 0.898725] r8169 0000:03:00.0 eth0: RTL8168h/8111h, 1c:69:7a:76:86:19, XID 541, IRQ 126
[ 0.898730] r8169 0000:03:00.0 eth0: jumbo features [frames: 9194 bytes, tx checksumming: ko]
[ 0.899297] ahci 0000:00:17.0: AHCI 0001.0301 32 slots 5 ports 6 Gbps 0x3e impl SATA mode
[ 0.899300] ahci 0000:00:17.0: flags: 64bit ncq sntf pm led clo only pio slum part ems deso sadm sds apst
[ 0.900882] intel-lpss 0000:00:15.0: enabling device (0004 -> 0006)
[ 0.901474] idma64 idma64.0: Found Intel integrated DMA 64-bit
[ 0.923172] r8169 0000:03:00.0 enp3s0: renamed from eth0
[ 0.928831] intel-lpss 0000:00:15.1: enabling device (0004 -> 0006)
[ 0.929359] idma64 idma64.1: Found Intel integrated DMA 64-bit
[ 0.949535] scsi host0: ahci
[ 0.949725] scsi host1: ahci
[ 0.949974] scsi host2: ahci
[ 0.950087] scsi host3: ahci
[ 0.950302] scsi host4: ahci
[ 0.950427] scsi host5: ahci
[ 0.950499] ata1: DUMMY
[ 0.950517] ata2: SATA max UDMA/133 abar m2048@0xb112b000 port 0xb112b180 irq 125
[ 0.950520] ata3: SATA max UDMA/133 abar m2048@0xb112b000 port 0xb112b200 irq 125
[ 0.950523] ata4: SATA max UDMA/133 abar m2048@0xb112b000 port 0xb112b280 irq 125
[ 0.950526] ata5: SATA max UDMA/133 abar m2048@0xb112b000 port 0xb112b300 irq 125
[ 0.950529] ata6: SATA max UDMA/133 abar m2048@0xb112b000 port 0xb112b380 irq 125
[ 0.256757] #3
[ 0.777995] /init
[ 0.777996] splash
[ 0.777999] HOME=/
- 系统: Windows 11
接三楼,第二部分
[ 1.224813] usb 1-2: new low-speed USB device number 2 using xhci_hcd
[ 1.267635] ata5: SATA link down (SStatus 4 SControl 300)
[ 1.267687] ata4: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 1.267721] ata6: SATA link down (SStatus 4 SControl 300)
[ 1.267758] ata2: SATA link down (SStatus 4 SControl 300)
[ 1.267796] ata3: SATA link down (SStatus 4 SControl 300)
[ 1.268316] ata4.00: ATA-10: WDC WD10EZEX-08WN4A0, 02.01A02, max UDMA/100
[ 1.269313] ata4.00: 1953525168 sectors, multi 16: LBA48 NCQ (depth 32), AA
[ 1.269324] ata4.00: Features: NCQ-prio
[ 1.271288] ata4.00: configured for UDMA/100
[ 1.271557] scsi 3:0:0:0: Direct-Access ATA WDC WD10EZEX-08W 1A02 PQ: 0 ANSI: 5
[ 1.272217] sd 3:0:0:0: Attached scsi generic sg0 type 0
[ 1.272384] sd 3:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[ 1.272391] sd 3:0:0:0: [sda] 4096-byte physical blocks
[ 1.272436] sd 3:0:0:0: [sda] Write Protect is off
[ 1.272443] sd 3:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.272488] sd 3:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.339664] sda: sda1 sda2 sda3 sda4 sda5 sda6 sda7 sda8 sda9 sda10
[ 1.353204] sd 3:0:0:0: [sda] Attached SCSI disk
[ 1.383856] usb 1-2: New USB device found, idVendor=0c45, idProduct=760b, bcdDevice= 1.05
[ 1.383865] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.383869] usb 1-2: Product: USB Keyboard
[ 1.383871] usb 1-2: Manufacturer: SONiX
[ 1.432865] tsc: Refined TSC clocksource calibration: 4008.006 MHz
[ 1.432877] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x39c5e7ceb00, max_idle_ns: 440795385467 ns
[ 1.432911] clocksource: Switched to clocksource tsc
[ 1.512779] usb 1-3: new low-speed USB device number 3 using xhci_hcd
[ 1.664179] usb 1-3: New USB device found, idVendor=093a, idProduct=2510, bcdDevice= 1.00
[ 1.664188] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.664191] usb 1-3: Product: USB Optical Mouse
[ 1.664194] usb 1-3: Manufacturer: PixA琀
[ 1.796837] usb 1-9: new high-speed USB device number 4 using xhci_hcd
[ 1.945079] usb 1-9: New USB device found, idVendor=0bda, idProduct=1a2b, bcdDevice= 2.00
[ 1.945088] usb 1-9: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.945091] usb 1-9: Product: DISK
[ 1.945094] usb 1-9: Manufacturer: Realtek
[ 1.952553] usb-storage 1-9:1.0: USB Mass Storage device detected
[ 1.952646] scsi host6: usb-storage 1-9:1.0
[ 1.952711] usbcore: registered new interface driver usb-storage
[ 1.953721] hid: raw HID events driver (C) Jiri Kosina
[ 1.954317] usbcore: registered new interface driver uas
[ 1.962528] usbcore: registered new interface driver usbhid
[ 1.962530] usbhid: USB HID core driver
[ 1.963916] input: SONiX USB Keyboard as /devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.0/0003:0C45:760B.0001/input/input3
[ 2.021055] hid-generic 0003:0C45:760B.0001: input,hidraw0: USB HID v1.11 Keyboard [SONiX USB Keyboard] on usb-0000:00:14.0-2/input0
[ 2.021549] input: SONiX USB Keyboard Consumer Control as /devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.1/0003:0C45:760B.0002/input/input4
[ 2.081096] input: SONiX USB Keyboard System Control as /devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.1/0003:0C45:760B.0002/input/input5
[ 2.081415] hid-generic 0003:0C45:760B.0002: input,hidraw1: USB HID v1.11 Device [SONiX USB Keyboard] on usb-0000:00:14.0-2/input1
[ 2.081756] input: PixA琀 USB Optical Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.0/0003:093A:2510.0003/input/input6
[ 2.082015] hid-generic 0003:093A:2510.0003: input,hidraw2: USB HID v1.11 Mouse [PixA琀 USB Optical Mouse] on usb-0000:00:14.0-3/input0
[ 2.153479] input: SONiX USB Keyboard as /devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.0/0003:0C45:760B.0001/input/input7
[ 2.185154] usb 1-9: USB disconnect, device number 4
[ 2.213056] redragon 0003:0C45:760B.0001: input,hidraw0: USB HID v1.11 Keyboard [SONiX USB Keyboard] on usb-0000:00:14.0-2/input0
[ 2.301437] input: SONiX USB Keyboard as /devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.1/0003:0C45:760B.0002/input/input8
[ 2.361029] redragon 0003:0C45:760B.0002: input,hidraw1: USB HID v1.11 Device [SONiX USB Keyboard] on usb-0000:00:14.0-2/input1
[ 2.482561] EXT4-fs (sda9): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[ 2.580852] usb 1-9: new high-speed USB device number 5 using xhci_hcd
[ 2.729329] usb 1-9: New USB device found, idVendor=0bda, idProduct=1a2b, bcdDevice= 2.00
[ 2.729338] usb 1-9: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.729341] usb 1-9: Product: DISK
[ 2.729344] usb 1-9: Manufacturer: Realtek
[ 2.730540] usb-storage 1-9:1.0: USB Mass Storage device detected
[ 2.730840] scsi host6: usb-storage 1-9:1.0
[ 3.333224] systemd[1]: Inserted module 'autofs4'
[ 3.437788] systemd[1]: systemd 249.11-0ubuntu3.6 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY -P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[ 3.457018] systemd[1]: Detected architecture x86-64.
[ 3.481502] systemd[1]: Hostname set to <hman13-E500>.
[ 3.737220] scsi 6:0:0:0: CD-ROM Realtek USB Disk autorun 1.00 PQ: 0 ANSI: 0 CCS
[ 3.737940] sr 6:0:0:0: [sr0] scsi-1 drive
[ 3.737945] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 3.739530] sr 6:0:0:0: Attached scsi CD-ROM sr0
[ 3.739573] sr 6:0:0:0: Attached scsi generic sg1 type 5
[ 5.097387] systemd[1]: Queued start job for default target Graphical Interface.
[ 5.098436] systemd[1]: Created slice Slice /system/modprobe.
[ 5.098707] systemd[1]: Created slice Slice /system/systemd-fsck.
[ 5.098889] systemd[1]: Created slice User and Session Slice.
[ 5.098951] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 5.099097] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 5.099163] systemd[1]: Reached target User and Group Name Lookups.
[ 5.099182] systemd[1]: Reached target Remote File Systems.
[ 5.099195] systemd[1]: Reached target Slice Units.
[ 5.099222] systemd[1]: Reached target Local Verity Protected Volumes.
[ 5.099320] systemd[1]: Listening on Syslog Socket.
[ 5.099394] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 5.099439] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 5.099588] systemd[1]: Listening on Journal Audit Socket.
[ 5.099655] systemd[1]: Listening on Journal Socket (/dev/log).
[ 5.099734] systemd[1]: Listening on Journal Socket.
[ 5.099831] systemd[1]: Listening on udev Control Socket.
[ 5.099901] systemd[1]: Listening on udev Kernel Socket.
[ 5.100472] systemd[1]: Mounting Huge Pages File System...
[ 5.101077] systemd[1]: Mounting POSIX Message Queue File System...
[ 5.101736] systemd[1]: Mounting Kernel Debug File System...
[ 5.102310] systemd[1]: Mounting Kernel Trace File System...
[ 5.103413] systemd[1]: Starting Journal Service...
[ 5.104208] systemd[1]: Starting Set the console keyboard layout...
[ 5.105064] systemd[1]: Starting Create List of Static Device Nodes...
[ 5.105947] systemd[1]: Starting Load Kernel Module chromeos_pstore...
[ 5.106833] systemd[1]: Starting Load Kernel Module configfs...
[ 5.107785] systemd[1]: Starting Load Kernel Module drm...
[ 5.108653] systemd[1]: Starting Load Kernel Module efi_pstore...
[ 5.109603] systemd[1]: Starting Load Kernel Module fuse...
[ 5.110480] systemd[1]: Starting Load Kernel Module pstore_blk...
[ 5.111394] systemd[1]: Starting Load Kernel Module pstore_zone...
[ 5.112318] systemd[1]: Starting Load Kernel Module ramoops...
[ 5.112498] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 5.118663] systemd[1]: Starting Load Kernel Modules...
[ 5.119180] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 5.119716] systemd[1]: Starting Coldplug All udev Devices...
[ 5.131850] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[ 5.132235] systemd[1]: Finished Load Kernel Module configfs.
[ 5.133053] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[ 5.133397] systemd[1]: Finished Load Kernel Module fuse.
[ 5.135002] systemd[1]: Mounting FUSE Control File System...
[ 5.136424] systemd[1]: Mounting Kernel Configuration File System...
[ 5.144896] systemd[1]: Mounted Huge Pages File System.
[ 5.145100] systemd[1]: Mounted POSIX Message Queue File System.
[ 5.145277] systemd[1]: Mounted Kernel Debug File System.
[ 5.145433] systemd[1]: Mounted FUSE Control File System.
[ 5.145588] systemd[1]: Mounted Kernel Configuration File System.
[ 5.169981] systemd[1]: Mounted Kernel Trace File System.
[ 5.207303] systemd[1]: Finished Create List of Static Device Nodes.
[ 5.247573] EXT4-fs (sda9): re-mounted. Opts: errors=remount-ro. Quota mode: none.
[ 5.249813] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 5.251434] systemd[1]: Starting Load/Save Random Seed...
[ 5.252979] systemd[1]: Starting Create System Users...
[ 5.312454] systemd[1]: modprobe@drm.service: Deactivated successfully.
[ 5.312671] systemd[1]: Finished Load Kernel Module drm.
[ 5.330008] systemd[1]: modprobe@pstore_zone.service: Deactivated successfully.
[ 5.330144] systemd[1]: Finished Load Kernel Module pstore_zone.
[ 5.332404] systemd[1]: Finished Coldplug All udev Devices.
[ 5.335320] systemd[1]: modprobe@pstore_blk.service: Deactivated successfully.
[ 5.335439] systemd[1]: Finished Load Kernel Module pstore_blk.
[ 5.353951] systemd[1]: modprobe@chromeos_pstore.service: Deactivated successfully.
[ 5.354323] systemd[1]: Finished Load Kernel Module chromeos_pstore.
[ 5.383568] systemd[1]: modprobe@ramoops.service: Deactivated successfully.
[ 5.383934] systemd[1]: Finished Load Kernel Module ramoops.
[ 5.397175] pstore: Using crash dump compression: deflate
[ 5.397195] pstore: Registered efi as persistent store backend
[ 5.398143] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
[ 5.398435] systemd[1]: Finished Load Kernel Module efi_pstore.
[ 5.398593] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[ 5.419239] systemd[1]: Started Journal Service.
[ 5.421938] lp: driver loaded but no devices found
[ 5.423941] ppdev: user-space parallel port driver
[ 5.481330] systemd-journald[286]: Received client request to flush runtime journal.
[ 5.501129] parport_pc 00:02: reported by Plug and Play ACPI
[ 5.501253] parport0: PC-style at 0x378 (0x778), irq 5, dma 3 [PCSPP,TRISTATE,COMPAT,EPP,ECP,DMA]
[ 5.600994] lp0: using parport0 (interrupt-driven).
[ 5.695893] usb 1-9: USB disconnect, device number 5
[ 6.080852] usb 1-9: new high-speed USB device number 6 using xhci_hcd
[ 6.149333] loop0: detected capacity change from 0 to 8
[ 6.149451] loop1: detected capacity change from 0 to 126896
[ 6.229168] usb 1-9: New USB device found, idVendor=0bda, idProduct=1a2b, bcdDevice= 2.00
[ 6.229178] usb 1-9: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 6.229182] usb 1-9: Product: DISK
[ 6.229185] usb 1-9: Manufacturer: Realtek
[ 6.230673] usb-storage 1-9:1.0: USB Mass Storage device detected
[ 6.230995] scsi host6: usb-storage 1-9:1.0
[ 6.273840] loop2: detected capacity change from 0 to 129480
[ 6.281110] loop3: detected capacity change from 0 to 488424
[ 6.353101] loop4: detected capacity change from 0 to 487456
[ 6.436060] loop5: detected capacity change from 0 to 820832
[ 6.486103] loop6: detected capacity change from 0 to 709280
[ 6.511228] loop7: detected capacity change from 0 to 187776
[ 6.586936] loop8: detected capacity change from 0 to 93928
[ 6.599546] loop9: detected capacity change from 0 to 96176
[ 6.608544] loop10: detected capacity change from 0 to 98280
[ 6.618481] loop11: detected capacity change from 0 to 568
[ 7.256940] scsi 6:0:0:0: CD-ROM Realtek USB Disk autorun 1.00 PQ: 0 ANSI: 0 CCS
[ 7.257311] sr 6:0:0:0: [sr0] scsi-1 drive
[ 7.258546] sr 6:0:0:0: Attached scsi CD-ROM sr0
[ 7.258585] sr 6:0:0:0: Attached scsi generic sg1 type 5
[ 7.462981] ee1004 0-0050: 512 byte EE1004-compliant SPD EEPROM, read-only
[ 7.477356] Serial bus multi instantiate pseudo device driver INT3515:01: Instantiated 2 I2C devices.
[ 7.557394] mei_me 0000:00:16.0: enabling device (0000 -> 0002)
[ 7.589129] RAPL PMU: API unit is 2^-32 Joules, 4 fixed counters, 655360 ms ovfl timer
[ 7.589132] RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
[ 7.589133] RAPL PMU: hw unit of domain package 2^-14 Joules
[ 7.589134] RAPL PMU: hw unit of domain dram 2^-14 Joules
[ 7.589135] RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
[ 7.891133] cryptd: max_cpu_qlen set to 1000
[ 8.545132] SSE version of gcm_enc/dec engaged.
[ 8.554105] snd_hda_intel 0000:00:1f.3: enabling device (0400 -> 0402)
[ 8.580779] Console: switching to colour dummy device 80x25
[ 8.580825] i915 0000:00:02.0: vgaarb: deactivate vga console
[ 8.583748] i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=io+mem:owns=io+mem
[ 8.584215] mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_component_ops [i915])
[ 8.611693] [drm] Initialized i915 1.6.0 20201103 for 0000:00:02.0 on minor 0
[ 8.618255] ACPI: video: Video Device [GFX0] (multi-head: yes rom: no post: no)
[ 8.619303] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input9
[ 8.619558] snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[ 8.749182] i915 0000:00:02.0: [drm] Finished loading DMC firmware i915/kbl_dmc_ver1_04.bin (v1.4)
[ 8.845505] fbcon: i915drmfb (fb0) is primary device
[ 8.882953] Console: switching to colour frame buffer device 240x67
[ 8.915786] i915 0000:00:02.0: [drm] fb0: i915drmfb frame buffer device
[ 9.016818] i2c_designware i2c_designware.1: controller timed out
[ 9.042453] i2c_designware i2c_designware.1: timeout in disabling adapter
[ 9.057407] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC892: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:line
[ 9.057411] snd_hda_codec_realtek hdaudioC0D0: speaker_outs=1 (0x15/0x0/0x0/0x0/0x0)
[ 9.057412] snd_hda_codec_realtek hdaudioC0D0: hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[ 9.057413] snd_hda_codec_realtek hdaudioC0D0: mono: mono_out=0x0
[ 9.057414] snd_hda_codec_realtek hdaudioC0D0: inputs:
[ 9.057415] snd_hda_codec_realtek hdaudioC0D0: Front Mic=0x19
[ 9.057416] snd_hda_codec_realtek hdaudioC0D0: Rear Mic=0x18
[ 9.057417] snd_hda_codec_realtek hdaudioC0D0: Line=0x1a
[ 9.063012] i2c_designware i2c_designware.1: timeout waiting for bus ready
[ 9.085356] input: HDA Intel PCH Front Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input10
[ 9.085417] input: HDA Intel PCH Rear Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input11
[ 9.085480] input: HDA Intel PCH Line as /devices/pci0000:00/0000:00:1f.3/sound/card0/input12
[ 9.085529] input: HDA Intel PCH Line Out as /devices/pci0000:00/0000:00:1f.3/sound/card0/input13
[ 9.085566] input: HDA Intel PCH Front Headphone as /devices/pci0000:00/0000:00:1f.3/sound/card0/input14
[ 9.085617] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input15
[ 9.085655] input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input16
[ 9.085699] input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input17
[ 9.085745] input: HDA Intel PCH HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input18
[ 9.085783] input: HDA Intel PCH HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input19
[ 9.122041] sr 6:0:0:0: [sr0] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 9.122049] sr 6:0:0:0: [sr0] tag#0 CDB: Read(10) 28 00 00 00 ff fc 00 00 02 00
[ 9.122051] blk_update_request: I/O error, dev sr0, sector 262128 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 0
[ 9.172936] sr 6:0:0:0: [sr0] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 9.172947] sr 6:0:0:0: [sr0] tag#0 CDB: Read(10) 28 00 00 00 ff fc 00 00 02 00
[ 9.172951] blk_update_request: I/O error, dev sr0, sector 262128 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 9.172962] Buffer I/O error on dev sr0, logical block 32766, async page read
[ 9.177986] sr 6:0:0:0: [sr0] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 9.177995] sr 6:0:0:0: [sr0] tag#0 CDB: Read(10) 28 00 00 00 04 00 00 00 02 00
[ 9.177998] blk_update_request: I/O error, dev sr0, sector 4096 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 0
[ 9.180042] intel_tcc_cooling: Programmable TCC Offset detected
[ 9.228968] sr 6:0:0:0: [sr0] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 9.228977] sr 6:0:0:0: [sr0] tag#0 CDB: Read(10) 28 00 00 00 04 00 00 00 02 00
[ 9.228980] blk_update_request: I/O error, dev sr0, sector 4096 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 9.228988] Buffer I/O error on dev sr0, logical block 512, async page read
[ 9.236876] intel_rapl_common: Found RAPL domain package
[ 9.236881] intel_rapl_common: Found RAPL domain core
[ 9.236884] intel_rapl_common: Found RAPL domain uncore
[ 9.236887] intel_rapl_common: Found RAPL domain dram
[ 9.273984] sr 6:0:0:0: [sr0] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 9.273995] sr 6:0:0:0: [sr0] tag#0 CDB: Read(10) 28 00 00 00 fe 80 00 00 3c 00
[ 9.273998] blk_update_request: I/O error, dev sr0, sector 260608 op 0x0:(READ) flags 0x80700 phys_seg 29 prio class 0
[ 9.328951] sr 6:0:0:0: [sr0] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 9.328961] sr 6:0:0:0: [sr0] tag#0 CDB: Read(10) 28 00 00 00 fe 80 00 00 02 00
[ 9.328964] blk_update_request: I/O error, dev sr0, sector 260608 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 9.328974] Buffer I/O error on dev sr0, logical block 32576, async page read
[ 9.392942] sr 6:0:0:0: [sr0] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 9.392947] sr 6:0:0:0: [sr0] tag#0 CDB: Read(10) 28 00 00 00 04 00 00 00 02 00
[ 9.392948] blk_update_request: I/O error, dev sr0, sector 4096 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 9.392990] Buffer I/O error on dev sr0, logical block 512, async page read
[ 9.393159] sr 6:0:0:0: [sr0] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 9.393161] sr 6:0:0:0: [sr0] tag#0 CDB: Read(10) 28 00 00 00 ff fa 00 00 02 00
[ 9.393162] blk_update_request: I/O error, dev sr0, sector 262120 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 0
[ 9.453009] sr 6:0:0:0: [sr0] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 9.453019] sr 6:0:0:0: [sr0] tag#0 CDB: Read(10) 28 00 00 00 ff fa 00 00 02 00
[ 9.453022] blk_update_request: I/O error, dev sr0, sector 262120 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 9.453107] Buffer I/O error on dev sr0, logical block 32765, async page read
[ 9.598868] sr 6:0:0:0: [sr0] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 9.598879] sr 6:0:0:0: [sr0] tag#0 CDB: Read(10) 28 00 00 00 ff fc 00 00 02 00
[ 9.598883] blk_update_request: I/O error, dev sr0, sector 262128 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 0
[ 9.601470] Adding 5999612k swap on /dev/sda8. Priority:-2 extents:1 across:5999612k FS
[ 9.656923] Buffer I/O error on dev sr0, logical block 32766, async page read
[ 9.724920] Buffer I/O error on dev sr0, logical block 512, async page read
[ 9.828931] Buffer I/O error on dev sr0, logical block 32576, async page read
[ 9.892897] Buffer I/O error on dev sr0, logical block 512, async page read
[ 9.949041] Buffer I/O error on dev sr0, logical block 32765, async page read
[ 10.302051] i2c_designware i2c_designware.1: timeout in disabling adapter
[ 11.414127] EXT4-fs (sda10): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[ 12.204639] audit: type=1400 audit(1666506110.213:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=668 comm="apparmor_parser"
[ 12.204646] audit: type=1400 audit(1666506110.213:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=668 comm="apparmor_parser"
[ 12.207424] audit: type=1400 audit(1666506110.217:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=667 comm="apparmor_parser"
[ 12.214270] audit: type=1400 audit(1666506110.225:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/man" pid=681 comm="apparmor_parser"
[ 12.214275] audit: type=1400 audit(1666506110.225:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_filter" pid=681 comm="apparmor_parser"
[ 12.214278] audit: type=1400 audit(1666506110.225:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_groff" pid=681 comm="apparmor_parser"
[ 12.291005] audit: type=1400 audit(1666506110.301:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-oosplash" pid=683 comm="apparmor_parser"
[ 12.295457] usb 1-9: USB disconnect, device number 6
[ 12.310396] audit: type=1400 audit(1666506110.321:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-senddoc" pid=684 comm="apparmor_parser"
[ 12.336186] audit: type=1400 audit(1666506110.345:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="tcpdump" pid=682 comm="apparmor_parser"
[ 12.353977] audit: type=1400 audit(1666506110.365:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-xpdfimport" pid=687 comm="apparmor_parser"
[ 12.756786] usb 1-9: new high-speed USB device number 7 using xhci_hcd
[ 12.905052] usb 1-9: New USB device found, idVendor=0bda, idProduct=1a2b, bcdDevice= 2.00
[ 12.905065] usb 1-9: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 12.905072] usb 1-9: Product: DISK
[ 12.905076] usb 1-9: Manufacturer: Realtek
[ 12.906567] usb-storage 1-9:1.0: USB Mass Storage device detected
[ 12.906845] scsi host6: usb-storage 1-9:1.0
[ 13.917058] scsi 6:0:0:0: CD-ROM Realtek USB Disk autorun 1.00 PQ: 0 ANSI: 0 CCS
[ 13.917607] sr 6:0:0:0: [sr0] scsi-1 drive
[ 13.919338] sr 6:0:0:0: Attached scsi CD-ROM sr0
[ 13.920135] sr 6:0:0:0: Attached scsi generic sg1 type 5
[ 14.132953] scsi_io_completion_action: 22 callbacks suppressed
[ 14.132966] sr 6:0:0:0: [sr0] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 14.132978] sr 6:0:0:0: [sr0] tag#0 CDB: Read(10) 28 00 00 00 fe 80 00 00 02 00
[ 14.132983] print_req_error: 22 callbacks suppressed
[ 14.132986] blk_update_request: I/O error, dev sr0, sector 260608 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 14.188940] sr 6:0:0:0: [sr0] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 14.188949] sr 6:0:0:0: [sr0] tag#0 CDB: Read(10) 28 00 00 00 04 00 00 00 02 00
[ 14.188952] blk_update_request: I/O error, dev sr0, sector 4096 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 14.188963] buffer_io_error: 8 callbacks suppressed
[ 14.188966] Buffer I/O error on dev sr0, logical block 512, async page read
[ 14.189143] sr 6:0:0:0: [sr0] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 14.189147] sr 6:0:0:0: [sr0] tag#0 CDB: Read(10) 28 00 00 00 ff fa 00 00 02 00
[ 14.189149] blk_update_request: I/O error, dev sr0, sector 262120 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 0
[ 14.240961] sr 6:0:0:0: [sr0] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 14.240969] sr 6:0:0:0: [sr0] tag#0 CDB: Read(10) 28 00 00 00 ff fa 00 00 02 00
[ 14.240972] blk_update_request: I/O error, dev sr0, sector 262120 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 14.240983] Buffer I/O error on dev sr0, logical block 32765, async page read
[ 14.313258] sr 6:0:0:0: [sr0] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 14.313267] sr 6:0:0:0: [sr0] tag#0 CDB: Read(10) 28 00 00 00 ff fc 00 00 02 00
[ 14.313270] blk_update_request: I/O error, dev sr0, sector 262128 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 0
[ 14.364939] sr 6:0:0:0: [sr0] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 14.364948] sr 6:0:0:0: [sr0] tag#0 CDB: Read(10) 28 00 00 00 ff fc 00 00 02 00
[ 14.364951] blk_update_request: I/O error, dev sr0, sector 262128 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 14.364962] Buffer I/O error on dev sr0, logical block 32766, async page read
[ 14.368820] sr 6:0:0:0: [sr0] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 14.368830] sr 6:0:0:0: [sr0] tag#0 CDB: Read(10) 28 00 00 00 04 00 00 00 02 00
[ 14.368834] blk_update_request: I/O error, dev sr0, sector 4096 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 0
[ 14.416920] sr 6:0:0:0: [sr0] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 14.416929] sr 6:0:0:0: [sr0] tag#0 CDB: Read(10) 28 00 00 00 04 00 00 00 02 00
[ 14.416932] blk_update_request: I/O error, dev sr0, sector 4096 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 14.416943] Buffer I/O error on dev sr0, logical block 512, async page read
[ 14.461102] sr 6:0:0:0: [sr0] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 14.461110] sr 6:0:0:0: [sr0] tag#0 CDB: Read(10) 28 00 00 00 fe 80 00 00 3c 00
[ 14.461113] blk_update_request: I/O error, dev sr0, sector 260608 op 0x0:(READ) flags 0x80700 phys_seg 2 prio class 0
[ 14.512922] sr 6:0:0:0: [sr0] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 14.512930] sr 6:0:0:0: [sr0] tag#0 CDB: Read(10) 28 00 00 00 fe 80 00 00 02 00
[ 14.512933] blk_update_request: I/O error, dev sr0, sector 260608 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 14.512944] Buffer I/O error on dev sr0, logical block 32576, async page read
[ 14.564934] Buffer I/O error on dev sr0, logical block 512, async page read
[ 14.616928] Buffer I/O error on dev sr0, logical block 32765, async page read
[ 16.481574] usb 1-9: USB disconnect, device number 7
[ 16.796811] usb 1-9: new high-speed USB device number 8 using xhci_hcd
[ 16.950000] usb 1-9: New USB device found, idVendor=0bda, idProduct=b711, bcdDevice= 2.00
[ 16.950007] usb 1-9: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 16.950011] usb 1-9: Product: 802.11n WLAN Adapter
[ 16.950013] usb 1-9: Manufacturer: Realtek
[ 16.950015] usb 1-9: SerialNumber: 00E04CB82101
[ 17.287400] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 17.288243] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 17.439925] 8188gu: loading out-of-tree module taints kernel.
[ 17.440892] 8188gu: module verification failed: signature and/or required key missing - tainting kernel
[ 17.465635] usbcore: registered new interface driver rtl8710bu
[ 17.532099] rtl8710bu 1-9:1.0 wlx502b73d97fcc: renamed from wlan0
[ 18.345156] kauditd_printk_skb: 36 callbacks suppressed
[ 18.345163] audit: type=1400 audit(1666506116.357:48): apparmor="DENIED" operation="capable" profile="/usr/sbin/cupsd" pid=866 comm="cupsd" capability=12 capname="net_admin"
[ 18.760839] Generic FE-GE Realtek PHY r8169-0-300:00: attached PHY driver (mii_bus:phy_addr=r8169-0-300:00, irq=MAC)
[ 18.960897] r8169 0000:03:00.0 enp3s0: Link is Down
[ 19.476289] [Warning] 8703B/8723D/8710B CCK should be 4bit LNA, ie. 0x950[11] = 1
[ 20.164529] loop12: detected capacity change from 0 to 8
[ 21.570855] IPv6: ADDRCONF(NETDEV_CHANGE): wlx502b73d97fcc: link becomes ready
[ 22.954659] audit: type=1400 audit(1666506120.965:49): apparmor="DENIED" operation="capable" profile="/usr/lib/snapd/snap-confine" pid=1010 comm="snap-confine" capability=12 capname="net_admin"
[ 22.954674] audit: type=1400 audit(1666506120.965:50): apparmor="DENIED" operation="capable" profile="/usr/lib/snapd/snap-confine" pid=1010 comm="snap-confine" capability=38 capname="perfmon"
[ 23.289602] audit: type=1400 audit(1666506121.301:51): apparmor="DENIED" operation="capable" profile="/usr/lib/snapd/snap-confine" pid=1010 comm="snap-confine" capability=4 capname="fsetid"
[ 30.727526] audit: type=1400 audit(1666506128.737:52): apparmor="DENIED" operation="capable" profile="/usr/lib/snapd/snap-confine" pid=1319 comm="snap-confine" capability=12 capname="net_admin"
[ 30.727534] audit: type=1400 audit(1666506128.737:53): apparmor="DENIED" operation="capable" profile="/usr/lib/snapd/snap-confine" pid=1319 comm="snap-confine" capability=38 capname="perfmon"
[ 31.411748] audit: type=1400 audit(1666506129.421:54): apparmor="DENIED" operation="capable" profile="/usr/lib/snapd/snap-confine" pid=1391 comm="snap-confine" capability=12 capname="net_admin"
[ 31.411755] audit: type=1400 audit(1666506129.421:55): apparmor="DENIED" operation="capable" profile="/usr/lib/snapd/snap-confine" pid=1391 comm="snap-confine" capability=38 capname="perfmon"
[ 31.853403] audit: type=1400 audit(1666506129.865:56): apparmor="DENIED" operation="capable" profile="/usr/lib/snapd/snap-confine" pid=1453 comm="snap-confine" capability=12 capname="net_admin"
[ 31.853414] audit: type=1400 audit(1666506129.865:57): apparmor="DENIED" operation="capable" profile="/usr/lib/snapd/snap-confine" pid=1453 comm="snap-confine" capability=38 capname="perfmon"
[ 32.302863] audit: type=1326 audit(1666506130.313:58): auid=1000 uid=1000 gid=1000 ses=2 subj=? pid=1521 comm="snapd-desktop-i" exe="/snap/snapd-desktop-integration/14/bin/snapd-desktop-integration" sig=0 arch=c000003e syscall=314 compat=0 ip=0x7f4305ed873d code=0x50000
[ 35.578049] audit: type=1400 audit(1666506133.589:59): apparmor="DENIED" operation="capable" profile="/usr/sbin/cups-browsed" pid=1134 comm="cups-browsed" capability=23 capname="sys_nice"
[ 36.964893] rfkill: input handler disabled
[ 37.646943] audit: type=1400 audit(1666506135.657:60): apparmor="DENIED" operation="capable" profile="/usr/lib/snapd/snap-confine" pid=1845 comm="snap-confine" capability=4 capname="fsetid"
[ 41.279176] audit: type=1326 audit(1666506139.289:61): auid=1000 uid=1000 gid=1000 ses=2 subj=? pid=1845 comm="snap-store" exe="/snap/snap-store/582/usr/bin/snap-store" sig=0 arch=c000003e syscall=314 compat=0 ip=0x7ffa5e4c473d code=0x50000
[ 46.932966] audit: type=1107 audit(1666506146.638:62): pid=751 uid=102 auid=4294967295 ses=4294967295 subj=? msg='apparmor="DENIED" operation="dbus_method_call" bus="system" path="/org/freedesktop/PolicyKit1/Authority" interface="org.freedesktop.DBus.Properties" member="GetAll" mask="send" name=":1.8" pid=1845 label="snap.snap-store.ubuntu-software" peer_pid=760 peer_label="unconfined"
exe="/usr/bin/dbus-daemon" sauid=102 hostname=? addr=? terminal=?'
[ 46.932975] audit: type=1420 audit(1666506146.638:63): subj_apparmor=unconfined
[ 46.933436] audit: type=1107 audit(1666506146.638:64): pid=751 uid=102 auid=4294967295 ses=4294967295 subj=? msg='apparmor="DENIED" operation="dbus_method_call" bus="system" path="/org/freedesktop/PolicyKit1/Authority" interface="org.freedesktop.PolicyKit1.Authority" member="CheckAuthorization" mask="send" name=":1.8" pid=1845 label="snap.snap-store.ubuntu-software" peer_pid=760 peer_label="unconfined"
[ 46.933442] audit: type=1420 audit(1666506146.638:65): subj_apparmor=unconfined
[ 46.935999] audit: type=1107 audit(1666506146.638:66): pid=751 uid=102 auid=4294967295 ses=4294967295 subj=? msg='apparmor="DENIED" operation="dbus_method_call" bus="system" path="/org/freedesktop/PolicyKit1/Authority" interface="org.freedesktop.DBus.Properties" member="GetAll" mask="send" name=":1.8" pid=1845 label="snap.snap-store.ubuntu-software" peer_pid=760 peer_label="unconfined"
[ 46.936007] audit: type=1420 audit(1666506146.638:67): subj_apparmor=unconfined
[ 46.936313] audit: type=1107 audit(1666506146.638:68): pid=751 uid=102 auid=4294967295 ses=4294967295 subj=? msg='apparmor="DENIED" operation="dbus_method_call" bus="system" path="/org/freedesktop/PolicyKit1/Authority" interface="org.freedesktop.PolicyKit1.Authority" member="CheckAuthorization" mask="send" name=":1.8" pid=1845 label="snap.snap-store.ubuntu-software" peer_pid=760 peer_label="unconfined"
[ 46.936319] audit: type=1420 audit(1666506146.638:69): subj_apparmor=unconfined
[ 48.394522] audit: type=1400 audit(1666506148.098:70): apparmor="DENIED" operation="open" profile="snap.snap-store.ubuntu-software" name="/etc/PackageKit/Vendor.conf" pid=1845 comm="snap-store" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
[ 49.218686] audit: type=1400 audit(1666506148.922:71): apparmor="DENIED" operation="open" profile="snap.snap-store.ubuntu-software" name="/etc/appstream.conf" pid=1845 comm="snap-store" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
[ 102.747604] audit: type=1400 audit(1666506202.449:72): apparmor="DENIED" operation="capable" profile="/usr/lib/snapd/snap-confine" pid=3082 comm="snap-confine" capability=4 capname="fsetid"
[ 103.041221] audit: type=1400 audit(1666506202.741:73): apparmor="DENIED" operation="mkdir" profile="snap-update-ns.firefox" name="/usr/share/cups/doc-root/" pid=3100 comm="5" requested_mask="c" denied_mask="c" fsuid=0 ouid=0
[ 103.059930] audit: type=1400 audit(1666506202.761:74): apparmor="DENIED" operation="mkdir" profile="snap-update-ns.firefox" name="/usr/share/gimp/2.0/" pid=3100 comm="5" requested_mask="c" denied_mask="c" fsuid=0 ouid=0
[ 103.060355] audit: type=1400 audit(1666506202.761:75): apparmor="DENIED" operation="mkdir" profile="snap-update-ns.firefox" name="/usr/share/libreoffice/help/" pid=3100 comm="5" requested_mask="c" denied_mask="c" fsuid=0 ouid=0
[ 103.060527] audit: type=1400 audit(1666506202.761:76): apparmor="DENIED" operation="open" profile="snap-update-ns.firefox" name="/var/lib/" pid=3100 comm="5" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
[ 105.983205] audit: type=1326 audit(1666506205.685:77): auid=1000 uid=1000 gid=1000 ses=2 subj=? pid=3082 comm="firefox" exe="/snap/firefox/1993/usr/lib/firefox/firefox" sig=0 arch=c000003e syscall=314 compat=0 ip=0x7f4d1972d73d code=0x50000
Re: Ubuntu 22.04无线连接连不上,一直在转圈
输出里面没有驱动或固件方面的错误,应该就是单纯的wifi连接设置问题。检查一下wifi连接的安全认证类型,看下明文密码输对没有。到无线路由器的设置页面确认一下
- 系统: Windows 11
开机时还是连不上,一直转圈,但是关机重新启动后就自动连上无线了
