durongze
帖子
由 durongze » 2021-08-29 23:28
menuentry 'Ubuntu, with Linux 5.11.22 (recovery mode)' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-5.11.22-recovery-7a913e8f-58fb-442f-9b20-4d3971ecaf7f' {
recordfail
load_video
insmod gzio
if [ x$grub_platform = xxen ]; then insmod xzio; insmod lzopio; fi
insmod part_gpt
insmod ext2
set root='hd0,gpt9'
if [ x$feature_platform_search_hint = xy ]; then
search --no-floppy --fs-uuid --set=root --hint-bios=hd0,gpt9 --hint-efi=hd0,gpt9 --hint-baremetal=ahci0,gpt9 7a913e8f-58fb-442f-9b20-4d3971ecaf7f
else
search --no-floppy --fs-uuid --set=root 7a913e8f-58fb-442f-9b20-4d3971ecaf7f
fi
echo '载入 Linux 5.11.22 ...'
linux /boot/vmlinuz-5.11.22 root=UUID=7a913e8f-58fb-442f-9b20-4d3971ecaf7f ro recovery dis_ucode_ldr
echo '载入初始化内存盘...'
initrd /boot/initrd.img-5.11.22
menuentry 'Ubuntu,Linux 5.11.0-31-generic' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-5.11.0-31-generic-advanced-7a913e8f-58fb-442f-9b20-4d3971ecaf7f' {
recordfail
load_video
gfxmode $linux_gfx_mode
insmod gzio
insmod part_gpt
insmod ext2
set root='hd0,gpt9'
else
fi
echo '载入 Linux 5.11.0-31-generic ...'
linux /boot/vmlinuz-5.11.0-31-generic root=UUID=7a913e8f-58fb-442f-9b20-4d3971ecaf7f ro quiet splash $vt_handoff
echo '载入初始化内存盘...'
initrd /boot/initrd.img-5.11.0-31-generic
5.11.0-31可以启动, 但是5.11.22启动就会报错,这个是咋回事呢?
帖子
由 astolia » 2021-08-30 11:15
编译缺了模块吧,对比一下两者的config文件
durongze
帖子
由 durongze » 2021-09-04 2:38
0.545098] ACPI: Lid Switch [LID0]
[ 0.545125] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input3
[ 0.545145] ACPI: Power Button [PWRF]
[ 0.546173] thermal LNXTHERM:00: registered as thermal_zone0
[ 0.546176] ACPI: Thermal Zone [TZ00] (28 C)
[ 0.546379] thermal LNXTHERM:01: registered as thermal_zone1
[ 0.546381] ACPI: Thermal Zone [TZ01] (30 C)
[ 0.546571] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[ 0.549153] Linux agpgart interface v0.103
[ 0.550835] tpm_crb MSFT0101:00: [Firmware Bug]: ACPI region does not cover the entire command/response buffer. [mem 0xfed40000-0xfed4087f flags 0x200] vs fed40080 f80
[ 0.550920] tpm_crb MSFT0101:00: [Firmware Bug]: ACPI region does not cover the entire command/response buffer. [mem 0xfed40000-0xfed4087f flags 0x200] vs fed40080 f80
[ 0.553997] battery: ACPI: Battery Slot [BAT0] (battery present)
[ 0.614109] loop: module loaded
[ 0.614419] libphy: Fixed MDIO Bus: probed
[ 0.614420] tun: Universal TUN/TAP device driver, 1.6
[ 0.614462] PPP generic driver version 2.4.2
[ 0.614548] VFIO - User Level meta-driver version: 0.3
[ 0.614661] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.614663] ehci-pci: EHCI PCI platform driver
durongze
帖子
由 durongze » 2021-09-04 2:39
[ 2.320443] usb 1-5: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.671751] scsi 2:0:0:0: Direct-Access WD My Passport 25E2 4005 PQ: 0 ANSI: 6
[ 2.672375] scsi 2:0:0:1: Enclosure WD SES Device 4005 PQ: 0 ANSI: 6
[ 2.674409] sd 2:0:0:0: Attached scsi generic sg1 type 0
[ 2.674846] sd 2:0:0:0: [sdb] Very big device. Trying to use READ CAPACITY(16).
[ 2.674900] scsi 2:0:0:1: Attached scsi generic sg2 type 13
[ 2.675106] sd 2:0:0:0: [sdb] 7813969920 512-byte logical blocks: (4.00 TB/3.64 TiB)
[ 2.675114] sd 2:0:0:0: [sdb] 4096-byte physical blocks
[ 2.675345] sd 2:0:0:0: [sdb] Write Protect is off
[ 2.675350] sd 2:0:0:0: [sdb] Mode Sense: 47 00 10 08
[ 2.675573] sd 2:0:0:0: [sdb] No Caching mode page found
[ 2.675656] sd 2:0:0:0: [sdb] Assuming drive cache: write through
[ 3.062741] sdb: sdb1 sdb2 sdb3
[ 3.063938] sd 2:0:0:0: [sdb] Attached SCSI disk
[ 3.287161] systemd[1]: Inserted module 'autofs4'
[ 3.384341] efivars: duplicate variable: DellDBARBootInfo-c2f1eaf5-2535-4042-a2d1-93ec4e31f5b2
[ 3.465861] systemd[1]: systemd 247.3-3ubuntu3.4 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
durongze
帖子
由 durongze » 2021-09-04 2:40
9.297769] Bluetooth: SCO socket layer initialized
[ 9.304373] AVX2 version of gcm_enc/dec engaged.
[ 9.304380] AES CTR mode by8 optimization enabled
[ 9.443482] usbcore: registered new interface driver btusb
[ 9.458529] Bluetooth: hci0: read Intel version: 370810011003110e00
[ 9.462567] Bluetooth: hci0: Intel Bluetooth firmware file: intel/ibt-hw-37.8.10-fw-1.10.3.11.e.bseq
[ 9.762575] Bluetooth: hci0: unexpected event for opcode 0xfc2f
[ 9.780744] Bluetooth: hci0: Intel BT fw patch 0x32 completed & activated
[ 9.902407] Intel(R) Wireless WiFi driver for Linux
[ 9.902607] iwlwifi 0000:05:00.0: enabling device (0000 -> 0002)
[ 9.987776] iwlwifi 0000:05:00.0: Found debug destination: EXTERNAL_DRAM
[ 9.987785] iwlwifi 0000:05:00.0: Found debug configuration: 0
[ 9.988292] iwlwifi 0000:05:00.0: loaded firmware version 29.4063824552.0 7265D-29.ucode op_mode iwlmvm
[ 10.225442] scsi 2:0:0:1: Wrong diagnostic page; asked for 1 got 8
[ 10.225517] scsi 2:0:0:1: Failed to get diagnostic page 0x1
[ 10.225576] scsi 2:0:0:1: Failed to bind enclosure -19
[ 10.225645] ses 2:0:0:1: Attached Enclosure device
[ 10.361985] uvcvideo: Found UVC 1.00 device Integrated_Webcam_HD (1bcf:2b8a)
[ 10.378875] iwlwifi 0000:05:00.0: Detected Intel(R) Dual Band Wireless AC 3165, REV=0x210
[ 10.383317] input: Integrated_Webcam_HD: Integrate as /devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.0/input/input14
durongze
帖子
由 durongze » 2021-09-04 2:41
73.811889] rfkill: input handler enabled
[ 74.696149] Bluetooth: RFCOMM TTY layer initialized
[ 74.696168] Bluetooth: RFCOMM socket layer initialized
[ 74.696181] Bluetooth: RFCOMM ver 1.11
[ 77.107817] i915 0000:00:02.0: [drm] *ERROR* Failed to write source OUI
[ 403.777125] i915 0000:00:02.0: [drm] *ERROR* Failed to write source OUI
[ 404.056154] i915 0000:00:02.0: [drm] HPD interrupt storm detected on connector eDP-1: switching from hotplug detection to polling
[ 406.224322] rfkill: input handler disabled
[ 410.548324] rfkill: input handler enabled
durongze
帖子
[ 696.760535] sd 2:0:0:0: [sdb] Spinning up disk...
[ 696.760677] ses 2:0:0:1: Wrong diagnostic page; asked for 1 got 8
[ 696.760688] ses 2:0:0:1: Failed to get diagnostic page 0x1
[ 696.760695] ses 2:0:0:1: Failed to bind enclosure -19
[ 697.780895] ..ready
[ 698.805167] sd 2:0:0:0: [sdb] Very big device. Trying to use READ CAPACITY(16).
[ 698.805288] sd 2:0:0:0: [sdb] 7813969920 512-byte logical blocks: (4.00 TB/3.64 TiB)
[ 698.805291] sd 2:0:0:0: [sdb] 4096-byte physical blocks
[ 698.805484] sd 2:0:0:0: [sdb] Write Protect is off
[ 698.805487] sd 2:0:0:0: [sdb] Mode Sense: 47 00 10 08
[ 698.805705] sd 2:0:0:0: [sdb] No Caching mode page found
[ 698.805710] sd 2:0:0:0: [sdb] Assuming drive cache: write through
[ 698.986525] sdb: sdb1 sdb2 sdb3
[ 698.988368] sd 2:0:0:0: [sdb] Attached SCSI disk
[ 871.595923] usb 2-2: USB disconnect, device number 3
[ 871.617525] Buffer I/O error on dev sdb1, logical block 176238718, async page read
[ 871.618010] Buffer I/O error on dev sdb1, logical block 176238718, async page read
