ddrescue使用后,无法访问下载文件夹等
最大的社区版本,Ubuntu的发源地
寺島聰子
系统: debian11 mate
帖子 寺島聰子 » 2020-07-15 2:31
それまで使っていたhdd がカランカランと嫌な音を出して破損しました。それで新規購入したノート用hdd にUbuntu的LiveCD上から
ddrescue
之前一直使用的hdd发出了讨厌的声音,破损了。然后在新买的笔记本用hdd上从Ubuntu的LiveCD上
ddrescue
ubuntu@ubuntu:~$ sudo ddrescue -f -r3 -v /dev/disk/by-id/ata-ST3160815AS_6RX65VV6 /dev/disk/by-id/ata-HGST_HTS545032A7E680_RB240EMP06TZHH logfile.log
GNU ddrescue 1.22
About to copy 160041 MBytes from '/dev/disk/by-id/ata-ST3160815AS_6RX65VV6' to '/dev/disk/by-id/ata-HGST_HTS545032A7E680_RB240EMP06TZHH'
Starting positions: infile = 0 B, outfile = 0 B
Copy block size: 128 sectors Initial skip size: 3200 sectors
Sector size: 512 Bytes
ipos: 116997 MB, non-trimmed: 0 B, current rate: 0 B/s
opos: 116997 MB, non-scraped: 0 B, average rate: 51344 kB/s
non-tried: 0 B, bad-sector: 4096 B, error rate: 170 B/s
rescued: 160041 MB, bad areas: 1, run time: 51m 57s
pct rescued: 99.99%, read errors: 33, remaining time: n/a
time since last successful read: 1m 26s
Finished
ubuntu@ubuntu:~$
HGST320GB は起動して、ブラウザなども使えるのですが、home の一部のフォルダが見えません。
HGST320GB启动,浏览器等也能使用,不过,home的一部分的文件夹看不见。
jin@kyo:~$ sudo zpool status
pool: home
state: DEGRADED
status: One or more devices has experienced an error resulting in data
corruption. Applications may be affected.
action: Restore the file in question if possible. Otherwise restore the
entire pool from backup.
see: http://zfsonlinux.org/msg/ZFS-8000-8A
scan: scrub repaired 0B in 0 days 00:07:07 with 0 errors on Sun Jun 14 00:31:08 2020
config:
NAME STATE READ WRITE CKSUM
home DEGRADED 0 0 0
sda3 DEGRADED 0 0 40 too many errors
errors: 4 data errors, use '-v' for a list
jin@kyo:~$
寺島聰子
系统: debian11 mate
Re: ddrescue使用后,无法访问下载文件夹等
帖子 寺島聰子 » 2020-07-15 19:26
jin@kyo:~$ sudo zpool clear home
jin@kyo:~$ sudo zpool scrub home
pool: home
state: ONLINE
scan: scrub repaired 0B in 0 days 00:13:27 with 15 errors on Wed Jul 15 20:06:50 2020
config:
home ONLINE 0 0 0
sda3 ONLINE 0 0 0
errors: Permanent errors have been detected in the following files:
<metadata>:<0xc>
home:<0x0>
home:<0x10901>
home:<0x10902>
/home/jin/.cache/qutebrowser/webengine/old_Cache_000
home:<0x40718>
home:<0x40719>
home:<0x4071b>
/home/jin/.local/share/qutebrowser/webengine
无法显示文件夹内容。无法显示“下载”的所有内容:Error when getting.个information for file“/home/jin/下载/sign.Powerword osXI86.deb力输出错误
没有改善。
寺島聰子
系统: debian11 mate
帖子 寺島聰子 » 2020-07-15 20:15
jin@kyo:~/Downloads$ ls -al
ls: 'sign.Powerword_uos_x86.deb' にアクセスできません: 入力/出力エラーです
合計 94749
drwxr-xr-x 3 jin jin 20 7月 12 04:17 .
drwxr-xr-x 32 jin jin 59 7月 15 20:55 ..
-rw-r--r-- 1 jin jin 79582 6月 26 20:39 NEW
-rw-r--r-- 1 jin jin 390468 5月 21 14:49 ambient-icon.txz
-rw-r--r-- 1 jin jin 636808 5月 21 14:15 ambient.txz
-rw-r--r-- 1 jin jin 5780 6月 4 16:22 folder-color-caja_0.0.88_all.deb
-rw-r--r-- 1 jin jin 77336 6月 4 16:22 folder-color-common_0.0.88_all.deb
drwxr-xr-x 2 jin jin 4 5月 31 17:26 jd
-rw-r--r-- 1 jin jin 20302960 5月 17 19:09 jdim-set.txz
-rw-r--r-- 1 jin jin 66693792 6月 9 01:37 kindle-for-pc-1-17-44183.exe
-rw-r--r-- 1 jin jin 134108 6月 8 20:58 libfaudio0_20.04-2_amd64.deb
-rw-r--r-- 1 jin jin 7041 5月 16 12:55 lightdm.conf
-rw-r--r-- 1 jin jin 1375 5月 16 20:10 matelist
-rw-r--r-- 1 jin jin 676 5月 13 21:13 oyainput-build.sh
-rw-r--r-- 1 jin jin 5598706 5月 16 20:47 panel-custom.mp4
-rw-r--r-- 1 jin jin 1073741824 5月 26 19:25 practice.img
-rw-r--r-- 1 jin jin 68770 6月 14 00:14 r8auvbrb7f09c38lq2bg1ghqi1.pdf
-????????? ? ? ? ? ? sign.Powerword_uos_x86.deb
-rw-r--r-- 1 jin jin 3220 6月 11 01:24 winehq.key
-rw-r--r-- 1 jin jin 2527392 5月 28 21:25 サンダーバードをオフラインにしてから同期設定する手順.mp4
寺島聰子
系统: debian11 mate
帖子 寺島聰子 » 2020-07-17 0:21
jin@kyo:~$ ls -lh $HOME/Downloads
ls: '/home/jin/Downloads/sign.Powerword_uos_x86.deb' にアクセスできません:
入力/出力エラーです
合計 93M
-rw-r--r-- 1 jin jin 78K 6月 26 20:39 NEW
-rw-r--r-- 1 jin jin 382K 5月 21 14:49 ambient-icon.txz
-rw-r--r-- 1 jin jin 622K 5月 21 14:15 ambient.txz
-rw-r--r-- 1 jin jin 5.7K 6月 4 16:22 folder-color-caja_0.0.88_all.deb
-rw-r--r-- 1 jin jin 76K 6月 4 16:22 folder-color-common_0.0.88_all.deb
-rw-r--r-- 1 jin jin 20M 5月 17 19:09 jdim-set.txz
-rw-r--r-- 1 jin jin 64M 6月 9 01:37 kindle-for-pc-1-17-44183.exe
-rw-r--r-- 1 jin jin 131K 6月 8 20:58 libfaudio0_20.04-2_amd64.deb
-rw-r--r-- 1 jin jin 6.9K 5月 16 12:55 lightdm.conf
-rw-r--r-- 1 jin jin 1.4K 5月 16 20:10 matelist
-rw-r--r-- 1 jin jin 5.4M 5月 16 20:47 panel-custom.mp4
-rw-r--r-- 1 jin jin 1.0G 5月 26 19:25 practice.img
-rw-r--r-- 1 jin jin 68K 6月 14 00:14 r8auvbrb7f09c38lq2bg1ghqi1.pdf
-rw-r--r-- 1 jin jin 3.2K 6月 11 01:24 winehq.key
-rw-r--r-- 1 jin jin 2.5M 5月 28 21:25
jin@kyo:~$
この赤字のファイルがハードディスク障害で変になったファイル。
这个赤字的文件因为硬盘故障而变了的文件。
$ ls | grep -v Powerword_uos > $HOME/salvage-list 救出するファイルリストを作る。制作救出的文件列表。
$ mkdir $HOME/salvage
$ cd $HOME/Downloads
$ mv -v `cat $HOME/salvage-list` $HOME/salvage/
これでDownloads内のデータにアクセスできるようになりました。
这样就可以访问Downloads内的数据了。
寺島聰子
系统: debian11 mate
帖子 寺島聰子 » 2020-07-17 0:42
但是用同样的方法
参考对象
https://docs.oracle.com/cd/E19683-01/81 ... index.html
使用grep作为过滤器
如果在其他命令中使用grep命令作为过滤器,则可以从命令的输出结果中删除不需要的信息。要将grep作为过滤器使用,必须通过grep将其他命令的输出结果进行管道。管道符号是|。
jin@kyo:~/Desktop$ ls | grep -v Powerword
karama yonekwa.pdf
おとなしい女校正中.txt へのリンク
jin@kyo:~/Desktop$
jin@kyo:~$ cd $HOME/Desktop
jin@kyo:~/Desktop$ ls | grep -v Powerword > $HOME/salvage-list
jin@kyo:~/Desktop$
jin@kyo:~/Desktop$ mv -v `cat $HOME/salvage-list` $HOME/salvage/
mv: 'Screenshot' を stat できません: 没有这样的文件或目录
mv: 'at' を stat できません: そのようなファイルやディレクトリはありません
mv: '2020-06-01' を stat できません: そのようなファイルやディレクトリはありません
mv: '09-22-53.png' を stat できません: そのようなファイルやディレクトリはありません
mv: 'Screenshot' を stat できません: そのようなファイルやディレクトリはありません
mv: '2020-07-15' を stat できません: そのようなファイルやディレクトリはありません
mv: '02-29-09.png' を stat できません: そのようなファイルやディレクトリはありません
mv: 'karama' を stat できません: そのようなファイルやディレクトリはありません
mv: 'yonekwa.pdf' を stat できません: そのようなファイルやディレクトリはありません
mv: 'おとなしい女校正中.txt' を stat できません: そのようなファイルやディレクトリはありません
mv: 'へのリンク' を stat できません: そのようなファイルやディレクトリはありません
jin@kyo:~/Desktop$
まったくmv されませんでした。なにが問題なのでしょう?
完全没有被mv。有什么问题吗? :Faint
帖子 astolia » 2020-07-17 11:45
あなたにZFSを使用することはお勧めしません。 ハードドライブにハードウェア障害が発生した場合、複数のハードドライブ/ RAIDがないと、データの回復に明らかな利点がありません。あなたができることは破損したファイルを削除する
寺島聰子
系统: debian11 mate
帖子 寺島聰子 » 2020-07-18 10:55
https://gihyo.jp/admin/serial/01/ubuntu ... 597?page=1
ZFSの強みはファイルシステムとしてRAIDやスクラビングによる故障検知,そして障害発生時のホットスワップなど,「⁠複数のストレージデバイス」が前提になっている機能が大半です。
ZFS的优势是作为文件系统,大多数功能都是以RAID、垃圾处理检测故障,以及故障发生时的热交换等“多个存储设备”为前提的。
よってデスクトップやノートPCで「ZFS」と言われても,一般的なユーザー(※4)には機能の使い道がなく,オーバーキル気味な印象を受けます。
因此,即使在桌面或笔记本电脑上被称为“ZFS”,一般用户(※4)也不会使用功能,会给人一种过度吉尔的感觉。
とは言えスナップショット・リストアや暗号化など個人でも使いやすい機能もたくさん存在する
虽说如此,也有很多像快照、重启和加密等个人也能轻松使用的功能
(我)このうちoverkillには目をつむり、ひとまずスナップショット・リストアを体験するためにZFSを採用しました。
(我)其中对overkill闭上眼睛,首先为了体验快照·list而采用了ZFS。
それと近いうちに「⁠複数のストレージデバイス」を獲得の予定で、その際はRAIDにする予定です。まだzfs がちんぷんかんぷんで、自分にとってどうなのか?評価すらできてない段階です。メリット少ないと確信したら、やめます。
近期计划获得“多个存储设备”,届时将采用RAID。还对zfs一窍不通,对自己来说怎么样?是连评价都没有的阶段。如果确信好处少的话,我就不做了。
astoliaさん、そして前回質問時にきちんとした返信ができなかった"帅de没人要"さん(ちんぷんかんぷんのため、どう返信すればよいかわからなかった)
astolia先生,还有上次提问时没能好好回复的“帅de没人要”先生(莫名其妙,不知道该怎么回复)
お二人とも「そもそもいるのか?」という本質的問題についてご指摘下さってありがとうございます!
两位都说“本来就有吗?”非常感谢您指出了这样的本质问题!   :Smile
