故障:vlc无法打开任何类型的video,选择视频文件后,软件自动退出。
使用smplayer打开,这样报错
/usr/bin/mplayer -noquiet -nofs -nomouseinput -sub-fuzziness 1 -identify -slave -vo xv -ao pulse -nokeepaspect -nodr -double -input nodefault-bindings:conf=/dev/null -stop-xscreensaver -wid 67108899 -monitorpixelaspect 1 -ass -embeddedfonts -ass-line-spacing 0 -ass-font-scale 1 -ass-styles /home/debian8/.config/smplayer/styles.ass -subfont-autoscale 0 -subfont-text-scale 20 -subcp ISO-8859-1 -subpos 100 -volume 50 -cache 2048 -osdlevel 0 -noslices -channels 2 -af scaletempo,equalizer=0:0:0:0:0:0:0:0:0:0 -softvol -softvol-max 110 /home/debian8/test.mp4
MPlayer2 2.0-728-g2c378c7-4+b1 (C) 2000-2012 MPlayer Team
Terminal type `unknown' is not defined.
Playing /home/debian8/test.mp4.
Cache size set to 2048 KiB
Cache fill: 0.00% (0 bytes)
Detected file format: QuickTime / MOV (libavformat)
MPlayer interrupted by signal 11 in module: demux_open
ID_SIGNAL=11
- MPlayer crashed by bad usage of CPU/FPU/RAM.
Recompile MPlayer with --enable-debug and make a 'gdb' backtrace and
disassembly. Details in DOCS/HTML/en/bugreports_what.html#bugreports_crash.
- MPlayer crashed. This shouldn't happen.
It can be a bug in the MPlayer code _or_ in your drivers _or_ in your
gcc version. If you think it's MPlayer's fault, please read
DOCS/HTML/en/bugreports.html and follow the instructions there. We can't and
won't help unless you provide this information when reporting a possible bug.
ffplay test.mp4 没有任何问题。
我的x11相关模块出了问题?
- 系统: debian8
Re: 我的x11相关模块出了问题?
以前用smplayer的时候,它设置的参数有时候会出这种问题。你不用参数直接跑mplayer试试。如果没问题的话,再慢慢找是哪些参数的锅
Re: 我的x11相关模块出了问题?
应该是升级后,vlc/mplayer 和 ffmpeg 版本不匹配之类的原因。重新升级 vlc/mplayer 试试
