vickycq 写了:科学之子 写了:卡死的完美解决方法我仍没找到
目前这个问题无法稳定重现 或未找到稳定重现的方法
例如同样是 openbox,我这里 xfce4 + openbox 或纯 openbox 都会出问题,但在 lxde + openbox 中就无法重现
而在您那里,lxde + openbox 可以稳定重现此问题
又在虚拟机中装了个 jessie,再装好 openbox, fcitx 测试,也无法重现此问题。
但在已有的两套带有 openbox 的系统中测试,都是一抓一个准
aptitude install --without-recommends lxde-core
aptitude install lightdm
我是这么装上lxde的,您无重现的openbox和fcitx版本是?
我的openbox版本:
root@debian:~# openbox --version
Openbox 3.5.2
Copyright (c) 2004 Mikael Magnusson
Copyright (c) 2002 Dana Jansens
This program comes with ABSOLUTELY NO WARRANTY.
This is free software, and you are welcome to redistribute it
under certain conditions. See the file COPYING for details.
root@debian:~# aptitude show openbox
Package: openbox
State: installed
Automatically installed: yes
Version: 3.5.2-8
Priority: optional
Section: x11
Maintainer: Mateusz Łukasik <mati75@linuxmint.pl>
Architecture: i386
Uncompressed Size: 1,030 k
Depends: libc6 (>= 2.4), libglib2.0-0 (>= 2.35.9), libice6 (>= 1:1.0.0), libobrender29 (>= 3.5.2), libobt2 (>= 3.5.2), libsm6, libstartup-notification0 (>= 0.7), libx11-6,
libxau6, libxext6, libxi6 (>= 2:1.2.99.4), libxinerama1, libxrandr2
Recommends: obconf, python-xdg, scrot
Suggests: menu, fonts-dejavu, python, libxml2-dev, tint2, openbox-menu, openbox-gnome-session (= 3.5.2-8), openbox-kde-session (= 3.5.2-8)
Breaks: menu (< 2.1.12)
Provides: x-session-manager, x-window-manager
Description: standards-compliant, fast, light-weight and extensible window manager
Openbox works with your applications, and makes your desktop easier to manage. This is because the approach to its development was the opposite of what seems to be the general
case for window managers. Openbox was written first to comply with standards and to work properly. Only when that was in place did the team turn to the visual interface.
Openbox is fully functional as a stand-alone working environment, or can be used as a drop-in replacement for the default window manager in the GNOME or KDE desktop
environments.
Openbox 3 is a completely new breed of window manager. It is not based upon any existing code base, although the visual appearance has been based upon that of Blackbox. Openbox
2 was based on the Blackbox 0.65.0 codebase.
Some of the things to look for in Openbox are:
* ICCCM and EWMH compliance!
* Very fast
* Chainable key bindings
* Customizable mouse actions
* Window resistance
* Multi-head Xinerama support!
* Pipe menus
Homepage: http://www.openbox.org
Tags: implemented-in::c, interface::x11, role::program, scope::utility, uitoolkit::xlib, x11::window-manager
我的fcitx版本:
root@debian:~# fcitx -v
fcitx version: 4.2.8.5
root@debian:~# aptitude show fcitx
Package: fcitx
State: installed
Version: 1:4.2.8.5-2
Priority: optional
Section: utils
Maintainer: IME Packaging Team <pkg-ime-devel@lists.alioth.debian.org>
Architecture: all
Uncompressed Size: 32.8 k
Depends: fcitx-bin, fcitx-data, fcitx-modules
Recommends: fcitx-config-gtk | kde-config-fcitx, fcitx-frontend-all | fcitx-frontend-fbterm, fcitx-ui-classic | fcitx-ui-light, im-config (>= 0.5) | im-switch
Suggests: fcitx-tools, fcitx-m17n
Description: Flexible Input Method Framework
Fcitx is a input method framework with extension support, which provides an interface for entering characters of different scripts in applications using a variety of mapping
systems.
It offers a pleasant and modern experience, with intuitive graphical configuration tools and customizable skins and mapping tables. It is highly modularized and extensible,
with GTK+ 2/3 and Qt4 IM Modules, support for UIs based on Fbterm, pure Xlib, GTK+, or KDE, and a developer-friendly API.
This metapackage pulls in a set of components recommended for most desktop users.
Homepage: http://code.google.com/p/fcitx/
Tags: accessibility::input, culture::chinese, implemented-in::c, interface::x11, role::metapackage, uitoolkit::xlib, use::typesetting, x11::application
