ADFilter 1.1 发布
- 20sanguo
127.0.0.1 - - [Sun Jul 27 17:49:51 CST 2008] "GET http://adgeo.163.com/ad_cookies HTTP/1.0" - - "http://www.163.com/" "Opera/9.51 (X11; SunOS i86pc; U; zh-cn)" "req:0.0020" Drop url http://adgeo.163.com/ad_cookies by ^http://adgeo\.163\.com/
127.0.0.1 - - [Sun Jul 27 17:49:51 CST 2008] "GET http://secure-cn.imrworldwide.com/v52.js HTTP/1.0" - - "http://www.163.com/" "Opera/9.51 (X11; SunOS i86pc; U; zh-cn)" "req:0.0010" Drop url http://secure-cn.imrworldwide.com/v52.js by \.imrworldwide\.
127.0.0.1 - - [Sun Jul 27 17:49:52 CST 2008] "GET http://www.torproject.org/documentation.html.en HTTP/1.0" 200 16840 "http://www.torproject.org/docs/囗囗囗-doc-osx.html" "Opera/9.51 (X11; SunOS i86pc; U; zh-cn)" "pay:6.935 req:0.0010 con:1.683 resH:2.066 resD:3.176"
差不多就是上面这样了,每次退出都是。好像是没什么错误信息。会不会和我内存太小有关?512兆的
刚安了个netbeans,嘿嘿,编译通过了,虽然看不太懂。
- oneleaf
- 论坛管理员
- 系统: Ubuntu 12.04
- 20sanguo
明白,就是这样了
java -jar ADFilter1.1.jar DEBUG=true >123.txt
java.net.SocketTimeoutException: connect timed out
at java.net.PlainSocketImpl.socketConnect(Native Method)
at java.net.PlainSocketImpl.doConnect(PlainSocketImpl.java:333)
at java.net.PlainSocketImpl.connectToAddress(PlainSocketImpl.java:195)
at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:182)
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:366)
at java.net.Socket.connect(Socket.java:519)
at adfilter.Handle.process(Handle.java:262)
at adfilter.Handle.run(Handle.java:455)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:885)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:907)
at java.lang.Thread.run(Thread.java:619)
- 附件
- 123.txt.tar
- (20 KiB) 已下载 116 次
- 20sanguo
又试了一次这样的命令
这回持续的时间长些,最后显示的是这些
当前并发数: 5
GET /forum/templates/Conundrum/images/favicon.ico HTTP/1.1
Host: www.ideasemu.org
User-Agent: Mozilla/5.0 (X11; U; SunOS i86pc; en-US; rv:1.8.1.14) Gecko/20080421 Firefox/2.0.0.14
Accept: image/png,*/*;q=0.5
Accept-Language: en-us,en;q=0.5
Accept-Encoding: gzip,deflate
Accept-Charset: x-gbk,utf-8;q=0.7,*;q=0.7
Cookie: phpbb2mysql_data=a%3A2%3A%7Bs%3A11%3A%22autologinid%22%3Bs%3A0%3A%22%22%3Bs%3A6%3A%22userid%22%3Bi%3A-1%3B%7D; phpbb2mysql_sid=954668b9adbbd1135d55d776ca6607b6
HTTP/1.1 200 OK
Date: Sun, 27 Jul 2008 12:07:54 GMT
Server: Apache/2.2.3 (Unix) mod_ssl/2.2.3 OpenSSL/0.9.8b DAV/2 PHP/5.1.2
Last-Modified: Sun, 30 Sep 2007 08:59:44 GMT
ETag: "55630d6-cbe-8a846000"
Accept-Ranges: bytes
Content-Length: 3262
Connection: close
Content-Type: image/x-icon
Content-Language: it
这回持续的时间长些,最后显示的是这些
当前并发数: 5
HTTP/1.1 200 OK
Connection: close
- 附件
- nbde.txt.tar
- 在netbeans里用他那个调试走一次,程序也选中了调试。主要是也不会用,看看有没有帮助吧。
- (60 KiB) 已下载 129 次
- oneleaf
- 论坛管理员
- 系统: Ubuntu 12.04
- 20sanguo
OpenSolaris 2008.5 i386
java version "1.6.0_04"
Java(TM) SE Runtime Environment (build 1.6.0_04-b12)
Java HotSpot(TM) Client VM (build 10.0-b19, mixed mode)
测试都是需要代理才能访问的叶面
同台机XP下测试正常。
接下面xubuntu的,在win下看了下,葱头的端口也是9051,但adf里设为9050、且必须为9050才能访问
xubuntu
java version "1.6.0"
OpenJDK Runtime Environment (build 1.6.0-b10)
OpenJDK Client VM (build 1.6.0-b10, mixed mode, sharing)
葱头 v0.1.2.19 源里的
发现个问题:由于9050端口被占用,我使用的是9051。但在ADFilter里设定127.0.0.1:9051,就会出现
囗囗囗 is not an HTTP Proxy
It appears you have configured your web browser to use 囗囗囗 as an HTTP proxy. This is not correct: 囗囗囗 is a SOCKS proxy, not an HTTP proxy. Please configure your client accordingly.
See http://囗囗囗.eff.org/documentation.html for more information.
葱头改配置为9050,ADF设9050则正常
测试都是需要代理才能访问的叶面
同台机XP下测试正常。
xubuntu
葱头 v0.1.2.19 源里的
- 20sanguo
- 20sanguo
- 20sanguo
- oneleaf
- 论坛管理员
- 系统: Ubuntu 12.04
