使用valgrind检测程序,发现始终有内存泄露的问题,在网上找了很久没有找到向相关的资料,这里求助一下各位大大,先向各位说声谢谢
详细内容如下:
root@ubuntu:/home/ubuntu/temp# cat main.cpp
#include "iostream"
using namespace std;
int main()
cout <<"hello world" << endl;
return 0;
root@ubuntu:/home/ubuntu/temp# g++ -g main.cpp -o qwe
root@ubuntu:/home/ubuntu/temp# ls
main.cpp qwe
root@ubuntu:/home/ubuntu/temp# ./qwe
hello world
root@ubuntu:/home/ubuntu/temp# valgrind ./qwe
==15976== Memcheck, a memory error detector
==15976== Copyright (C) 2002-2017, and GNU GPL'd, by Julian Seward et al.
==15976== Using Valgrind-3.13.0 and LibVEX; rerun with -h for copyright info
==15976== Command: ./qwe
==15976==
hello world
==15976==
==15976== HEAP SUMMARY:
==15976== in use at exit: 72,704 bytes in 1 blocks
==15976== total heap usage: 2 allocs, 1 frees, 73,728 bytes allocated
==15976==
==15976== LEAK SUMMARY:
==15976== definitely lost: 0 bytes in 0 blocks
==15976== indirectly lost: 0 bytes in 0 blocks
==15976== possibly lost: 0 bytes in 0 blocks
==15976== still reachable: 72,704 bytes in 1 blocks
==15976== suppressed: 0 bytes in 0 blocks
==15976== Rerun with --leak-check=full to see details of leaked memory
==15976==
==15976== For counts of detected and suppressed errors, rerun with: -v
==15976== ERROR SUMMARY: 0 errors from 0 contexts (suppressed: 0 from 0)
ubuntu使用valgrind检查C++的helloworld程序出错
- 系统: win10
Re: ubuntu使用valgrind检查C++的helloworld程序出错
找资料要用google,编程问题用英文
我用关键字 valgrind c++ hello world leak 去搜,第一条就是
https://stackoverflow.com/questions/358 ... ello-world
里面就回答了这个问题
里面就回答了这个问题
- 系统: win10
感谢指导astolia 写了:找资料要用google,编程问题用英文
<!-- m --><a class="postlink" href="https://stackoverflow.com/questions/358 ... stions/358 ... ello-world</a><!-- m -->
里面就回答了这个问题
