2ch browser for linux
- 系统: debian11 mate
https://github.com/yama-natuki/JD/tree/test
jin@1:~$ git clone -b test --depth 1 https://github.com/yama-natuki/JD.git jd
Cloning into 'jd'...
remote: Counting objects: 568, done.
remote: Compressing objects: 100% (549/549), done.
remote: Total 568 (delta 49), reused 349 (delta 18), pack-reused 0
Receiving objects: 100% (568/568), 935.61 KiB | 398.00 KiB/s, done.
Resolving deltas: 100% (49/49), done.
Checking connectivity... done.
jin@1:~$ cd jd
錯誤使用下面的命令:
jin@1:~/jd$ autoreconf -i
configure.ac:15: error: possibly undefined macro: AC_PROG_LIBTOOL
If this token and others are legitimate, please use m4_pattern_allow.
See the Autoconf documentation.
autoreconf: /usr/bin/autoconf failed with exit status: 1
謝謝!
jin@1:~$ cd jd
錯誤使用下面的命令:
謝謝!
上次由 寺島聰子 在 2017-08-02 20:11,总共编辑 1 次。
- 系统: debian11 mate
Re: configure.ac:15: error: possibly undefined macro
jin@1:~$ sudo apt-get build-dep jd
[sudo] password for jin:
Reading package lists... Done
E: Unable to find a source package for jd
jin@1:~$ sudo apt-get install build-essential automake autoconf-archive git
Building dependency tree
automake is already the newest version (1:1.15-4ubuntu1).
automake set to manually installed.
build-essential is already the newest version (12.1ubuntu2).
git is already the newest version (1:2.7.4-0ubuntu1.1).
The following packages were automatically installed and are no longer required:
cmigemo-common libmigemo1 linux-headers-4.4.0-66
linux-headers-4.4.0-66-generic linux-headers-4.4.0-75
linux-headers-4.4.0-75-generic linux-image-4.4.0-66-generic
linux-image-4.4.0-75-generic linux-image-extra-4.4.0-66-generic
linux-image-extra-4.4.0-75-generic nkf snap-confine
Use 'sudo apt autoremove' to remove them.
autoconf-archive
0 upgraded, 1 newly installed, 0 to remove and 112 not upgraded.
Need to get 637 kB of archives.
After this operation, 6,030 kB of additional disk space will be used.
Get:1 http://jp.archive.ubuntu.com/ubuntu xenial/universe amd64 autoconf-archive all 20150925-1 [637 kB]
Fetched 637 kB in 0s (813 kB/s)
Selecting previously unselected package autoconf-archive.
(Reading database ... 290378 files and directories currently installed.)
Preparing to unpack .../autoconf-archive_20150925-1_all.deb ...
Unpacking autoconf-archive (20150925-1) ...
Processing triggers for install-info (6.1.0.dfsg.1-5) ...
Setting up autoconf-archive (20150925-1) ...
autoconf-archive
sudo apt install libtool
- 系统: debian11 mate
2channel(日語:2ちゃんねる,可譯為二頻道、第二頻道、第二台等等),一般簡稱2ch,是一個大型的日本網路論壇,擁有超過1170萬用戶(2009年統計)[3]。2ch基本上是一個非常巨大的留言板集合體
jin@1:~$ sudo apt install libtool
The following additional packages will be installed:
libltdl-dev
Suggested packages:
libtool-doc gfortran | fortran95-compiler gcj-jdk
libltdl-dev libtool
0 upgraded, 2 newly installed, 0 to remove and 112 not upgraded.
Need to get 355 kB of archives.
After this operation, 1,857 kB of additional disk space will be used.
Get:1 http://jp.archive.ubuntu.com/ubuntu xenial/main amd64 libltdl-dev amd64 2.4.6-0.1 [162 kB]
Get:2 http://jp.archive.ubuntu.com/ubuntu xenial/main amd64 libtool all 2.4.6-0.1 [193 kB]
Fetched 355 kB in 0s (967 kB/s)
Selecting previously unselected package libltdl-dev:amd64.
(Reading database ... 291486 files and directories currently installed.)
Preparing to unpack .../libltdl-dev_2.4.6-0.1_amd64.deb ...
Unpacking libltdl-dev:amd64 (2.4.6-0.1) ...
Selecting previously unselected package libtool.
Preparing to unpack .../libtool_2.4.6-0.1_all.deb ...
Unpacking libtool (2.4.6-0.1) ...
Processing triggers for man-db (2.7.5-1) ...
Setting up libltdl-dev:amd64 (2.4.6-0.1) ...
Setting up libtool (2.4.6-0.1) ...
jin@1:~$
感謝
libltdl-dev
Suggested packages:
libltdl-dev libtool
jin@1:~$
感謝
なぜsudo apt-get build-dep jd命令を使う?
直接、autoreconf -iをしよう!
- 系统: debian11 mate
Receiving objects: 100% (568/568), 935.61 KiB | 257.00 KiB/s, done.
jin@1:~$ cd jd
libtoolize: putting auxiliary files in '.'.
libtoolize: copying file './ltmain.sh'
libtoolize: Consider adding 'AC_CONFIG_MACRO_DIRS([m4])' to configure.ac,
libtoolize: and rerunning libtoolize and aclocal.
libtoolize: Consider adding '-I m4' to ACLOCAL_AMFLAGS in Makefile.am.
configure.ac:9: installing './compile'
configure.ac:15: installing './config.guess'
configure.ac:15: installing './config.sub'
configure.ac:6: installing './install-sh'
configure.ac:6: installing './missing'
src/Makefile.am: installing './depcomp'
jin@1:~/jd$
コマンドが通りました!
The command passed! 太谢谢你了!
日本語で書いてくれてありがとうございます
jin@1:~$ cd jd
jin@1:~/jd$
コマンドが通りました!
- 系统: debian11 mate
文章主題を「如何使用GitHub的不理解」に変更したいけど、やり方がわかりません。
我想改變句子主語的“如何使用GitHub的特定非的理解”,不認識路。
- 系统: debian11 mate
jin@1:~/jd$ ./configure
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking whether make supports nested variables... yes
checking for style of include used by make... GNU
checking for gcc... gcc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking whether gcc understands -c and -o together... yes
checking dependency style of gcc... gcc3
checking for library containing strerror... none required
checking for gcc... (cached) gcc
checking whether we are using the GNU C compiler... (cached) yes
checking whether gcc accepts -g... (cached) yes
checking for gcc option to accept ISO C89... (cached) none needed
checking whether gcc understands -c and -o together... (cached) yes
checking dependency style of gcc... (cached) gcc3
checking how to run the C preprocessor... gcc -E
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for ANSI C header files... yes
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking dependency style of g++... gcc3
checking how to run the C++ preprocessor... g++ -E
checking build system type... x86_64-pc-linux-gnu
checking host system type... x86_64-pc-linux-gnu
checking how to print strings... printf
checking for a sed that does not truncate output... /bin/sed
checking for fgrep... /bin/grep -F
checking for ld used by gcc... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for BSD- or MS-compatible name lister (nm)... /usr/bin/nm -B
checking the name lister (/usr/bin/nm -B) interface... BSD nm
checking whether ln -s works... yes
checking the maximum length of command line arguments... 1572864
checking how to convert x86_64-pc-linux-gnu file names to x86_64-pc-linux-gnu format... func_convert_file_noop
checking how to convert x86_64-pc-linux-gnu file names to toolchain format... func_convert_file_noop
checking for /usr/bin/ld option to reload object files... -r
checking for objdump... objdump
checking how to recognize dependent libraries... pass_all
checking for dlltool... no
checking how to associate runtime and link libraries... printf %s\n
checking for ar... ar
checking for archiver @FILE support... @
checking for strip... strip
checking for ranlib... ranlib
checking command to parse /usr/bin/nm -B output from gcc object... ok
checking for sysroot... no
checking for a working dd... /bin/dd
checking how to truncate binary pipes... /bin/dd bs=4096 count=1
checking for mt... mt
checking if mt is a manifest tool... no
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking for dlfcn.h... yes
checking for objdir... .libs
checking if gcc supports -fno-rtti -fno-exceptions... no
checking for gcc option to produce PIC... -fPIC -DPIC
checking if gcc PIC flag -fPIC -DPIC works... yes
checking if gcc static flag -static works... yes
checking if gcc supports -c -o file.o... yes
checking if gcc supports -c -o file.o... (cached) yes
checking whether the gcc linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
checking whether -lc should be explicitly linked in... no
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... yes
checking for ld used by g++... /usr/bin/ld -m elf_x86_64
checking if the linker (/usr/bin/ld -m elf_x86_64) is GNU ld... yes
checking whether the g++ linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
checking for g++ option to produce PIC... -fPIC -DPIC
checking if g++ PIC flag -fPIC -DPIC works... yes
checking if g++ static flag -static works... yes
checking if g++ supports -c -o file.o... yes
checking if g++ supports -c -o file.o... (cached) yes
checking dynamic linker characteristics... (cached) GNU/Linux ld.so
checking whether g++ supports C++11 features by default... no
checking whether g++ supports C++11 features with -std=gnu++11... yes
checking for svn... no
checking for svnversion... no
checking for md5sum... /usr/bin/md5sum
os = linux-gnu
checking for pkg-config... /usr/bin/pkg-config
checking pkg-config is at least version 0.9.0... yes
checking for GTKMM... no
configure: error: Package requirements (gtkmm-2.4 >= 2.4.0) were not met:
No package 'gtkmm-2.4' found
Consider adjusting the PKG_CONFIG_PATH environment variable if you
installed software in a non-standard prefix.
Alternatively, you may set the environment variables GTKMM_CFLAGS
and GTKMM_LIBS to avoid the need to call pkg-config.
See the pkg-config man page for more details.
os = linux-gnu
- 系统: debian11 mate
https://ja.osdn.net/projects/jd4linux/w ... 9%E6%B3%95
を入れるのであろうと
端末から
jin@1:~$ sudo apt-get -y install libgtkmm-2.4-dev
エラーが出たので、慌てて閉じて、
libgtkmm-2.4-dev を Synaptic からインストール。今度はSynapticが応答停止。
sudo apt-get -y install libgtkmm-2.4-devUbuntu
Synaptic からインストール、または端末を開いて
sudo apt-get install jd
ubuntu11.04日本語版でsvn版をビルドする方法
sudo apt-get -y install subversion
sudo apt-get -y install autoconf
sudo apt-get -y install libtool
sudo apt-get -y install libgnutls-dev
sudo apt-get -y install ttf-ipamonafont
を入れるのであろうと
端末から
エラーが出たので、慌てて閉じて、
ここです でも、この問題はGithubと関係なくて、だたシステム設定を変更する必要があります。寺島聰子 写了:文章主題を「如何使用GitHub的不理解」に変更したいけど、やり方がわかりません。
sudo add-apt-repository universe
sudo apt update
ソースコードからのコンパイルする必要はもうありません,直接バイナリパッケージをインストール
sudo apt install jd
- 系统: debian11 mate
jin@1:~$ sudo add-apt-repository universe
'universe' distribution component is already enabled for all sources.
jin@1:~$ sudo apt update
Get:1 http://archive.ubuntulinux.jp/ubuntu xenial InRelease [17.5 kB]
Hit:2 http://jp.archive.ubuntu.com/ubuntu xenial InRelease
Get:3 http://jp.archive.ubuntu.com/ubuntu xenial-updates InRelease [102 kB]
Ign:4 http://archive.ubuntulinux.jp/ubuntu-ja-non-free xenial InRelease
Hit:5 http://archive.ubuntulinux.jp/ubuntu-ja-non-free xenial Release
Get:6 http://jp.archive.ubuntu.com/ubuntu xenial-backports InRelease [102 kB]
Ign:7 http://archive.ubuntulinux.jp/ubuntu xenial/main Sources
Ign:8 http://archive.ubuntulinux.jp/ubuntu xenial/main amd64 Packages
Ign:9 http://archive.ubuntulinux.jp/ubuntu xenial/main i386 Packages
Ign:10 http://archive.ubuntulinux.jp/ubuntu xenial/main Translation-en
Get:7 http://archive.ubuntulinux.jp/ubuntu xenial/main Sources [3,056 B]
Get:8 http://archive.ubuntulinux.jp/ubuntu xenial/main amd64 Packages [3,728 B]
Get:9 http://archive.ubuntulinux.jp/ubuntu xenial/main i386 Packages [3,732 B]
Get:10 http://archive.ubuntulinux.jp/ubuntu xenial/main Translation-en [1,820 B]
Get:12 http://security.ubuntu.com/ubuntu xenial-security InRelease [102 kB]
Get:13 http://jp.archive.ubuntu.com/ubuntu xenial-updates/main amd64 Packages [593 kB]
Get:14 http://jp.archive.ubuntu.com/ubuntu xenial-updates/main i386 Packages [573 kB]
Get:15 http://jp.archive.ubuntu.com/ubuntu xenial-updates/main Translation-en [240 kB]
Get:16 http://jp.archive.ubuntu.com/ubuntu xenial-updates/restricted amd64 Packages [7,804 B]
Get:17 http://jp.archive.ubuntu.com/ubuntu xenial-updates/restricted i386 Packages [7,804 B]
Get:18 http://jp.archive.ubuntu.com/ubuntu xenial-updates/universe amd64 Packages [510 kB]
Get:19 http://jp.archive.ubuntu.com/ubuntu xenial-updates/universe i386 Packages [493 kB]
Get:20 http://jp.archive.ubuntu.com/ubuntu xenial-updates/universe Translation-en [198 kB]
Get:21 http://jp.archive.ubuntu.com/ubuntu xenial-updates/multiverse amd64 Packages [15.5 kB]
Get:22 http://jp.archive.ubuntu.com/ubuntu xenial-updates/multiverse i386 Packages [14.6 kB]
Get:23 http://jp.archive.ubuntu.com/ubuntu xenial-updates/multiverse Translation-en [7,540 B]
Get:24 http://jp.archive.ubuntu.com/ubuntu xenial-backports/universe amd64 Packages [5,804 B]
Get:25 http://jp.archive.ubuntu.com/ubuntu xenial-backports/universe i386 Packages [5,816 B]
Get:26 http://security.ubuntu.com/ubuntu xenial-security/main amd64 Packages [316 kB]
Get:27 http://security.ubuntu.com/ubuntu xenial-security/main i386 Packages [298 kB]
Get:28 http://security.ubuntu.com/ubuntu xenial-security/main Translation-en [133 kB]
Get:29 http://security.ubuntu.com/ubuntu xenial-security/universe amd64 Packages [149 kB]
Get:30 http://security.ubuntu.com/ubuntu xenial-security/universe i386 Packages [133 kB]
Get:31 http://security.ubuntu.com/ubuntu xenial-security/universe Translation-en [77.0 kB]
Fetched 4,115 kB in 7s (522 kB/s)
173 packages can be upgraded. Run 'apt list --upgradable' to see them.
jin@1:~$ sudo apt install jd
linux-headers-4.4.0-66 linux-headers-4.4.0-66-generic linux-headers-4.4.0-75
linux-image-extra-4.4.0-75-generic snap-confine
Suggested packages:
fonts-konatu | fonts-monapo | fonts-mona
jd
0 upgraded, 1 newly installed, 0 to remove and 173 not upgraded.
Need to get 1,410 kB of archives.
After this operation, 8,217 kB of additional disk space will be used.
Get:1 http://jp.archive.ubuntu.com/ubuntu xenial/universe amd64 jd amd64 1:2.8.9-150226-5build1 [1,410 kB]
Fetched 1,410 kB in 0s (2,128 kB/s)
Selecting previously unselected package jd.
(Reading database ... 291560 files and directories currently installed.)
Preparing to unpack .../jd_1%3a2.8.9-150226-5build1_amd64.deb ...
Unpacking jd (1:2.8.9-150226-5build1) ...
Processing triggers for desktop-file-utils (0.22-1ubuntu5.1) ...
Processing triggers for bamfdaemon (0.5.3~bzr0+16.04.20160824-0ubuntu1) ...
Rebuilding /usr/share/applications/bamf-2.index...
Processing triggers for mime-support (3.59ubuntu1) ...
Setting up jd (1:2.8.9-150226-5build1) ...
jin@1:~$
Suggested packages:
jd
jin@1:~$
Re: 2ch browser for linux
さて、端末で jd を実行する
- 系统: debian11 mate
https://www.hiroom2.com/2016/05/12/ubun ... 4%E6%96%B9
2 Difference between apt upgrade and apt-get upgrade
Apt upgrade may install new packages. Apt-get upgrade will not install new packages.
Apt dist - upgrade / apt In dist - upgrade, you may delete existing packages as well as adding new packages. This is different from apt upgrade / apt - get upgrade.
Basically it is better to use apt upgrade.
Sudo apt update Update package list
(Be sure to execute it when adding / deleting repository)
Sudo apt upgrade Update package
(Use this command when updating normal packages)
- photor
- 系统: debian11 mate
https://www.karelie.net/install-2ch-bro ... or-ubuntu/
于Ubuntu 2ch浏览器“JD”全行施法之介。
易知此页
>2ch浏览器”JD“安装
然,为记述,
sudo apt update
sudo apt install jd
比,“何异”者乎?施JD版者乎?
易知此页
>2ch浏览器”JD“安装
然,为记述,
sudo apt update
sudo apt install jd
比,“何异”者乎?施JD版者乎?
