安装ubuntu16.10后 内置扬声器没有声音
- 系统: Ubuntu
安装ubuntu16.10后 内置扬声器没有声音 但插入耳机后 耳机有声音
求好心大神帮忙指点一下, 如何解决 ?
已经折腾了很久~
求好心大神帮忙指点一下, 如何解决 ?
已经折腾了很久~
- 系统: Ubuntu
Re: 安装ubuntu16.10后 内置扬声器没有声音
自己先顶一下啦
參閱
viewtopic.php?p=3188258#p3188258
2. 安裝 pavucontrol 套件
2-1. 從 終端機 執行 pavucontrol
把 Playback / Output Devices / Configuration 三個標籤畫面 擷圖貼上來
- 系统: Ubuntu
感谢你的帮忙,之前有事情,所以现在才来回复您~poloshiao 写了:參閱
再麻烦您帮忙看一看
- 系统: Ubuntu
- 系统: Ubuntu
$ aplay -L
default
Playback/recording through the PulseAudio sound server
null
Discard all samples (playback) or generate zero samples (capture)
pulse
PulseAudio Sound Server
sysdefault:CARD=MID
HDA Intel MID, ALC269VB Analog
Default Audio Device
front:CARD=MID,DEV=0
Front speakers
surround21:CARD=MID,DEV=0
2.1 Surround output to Front and Subwoofer speakers
surround40:CARD=MID,DEV=0
4.0 Surround output to Front and Rear speakers
surround41:CARD=MID,DEV=0
4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=MID,DEV=0
5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=MID,DEV=0
5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=MID,DEV=0
7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
dmix:CARD=MID,DEV=0
Direct sample mixing device
dsnoop:CARD=MID,DEV=0
Direct sample snooping device
hw:CARD=MID,DEV=0
Direct hardware device without any conversions
plughw:CARD=MID,DEV=0
Hardware device with all software conversions
hdmi:CARD=HDMI,DEV=0
HDA ATI HDMI, HDMI 0
HDMI Audio Output
dmix:CARD=HDMI,DEV=3
dsnoop:CARD=HDMI,DEV=3
hw:CARD=HDMI,DEV=3
plughw:CARD=HDMI,DEV=3
default
null
pulse
sysdefault:CARD=MID
Front speakers
dmix:CARD=MID,DEV=0
hw:CARD=MID,DEV=0
HDMI Audio Output
hw:CARD=HDMI,DEV=3
- 系统: Ubuntu
$ aplay -l
**** PLAYBACK 硬體裝置清單 ****
card 0: MID [HDA Intel MID], device 0: ALC269VB Analog [ALC269VB Analog]
子设备: 1/1
子设备 #0: subdevice #0
card 1: HDMI [HDA ATI HDMI], device 3: HDMI 0 [HDMI 0]
子设备: 1/1
子设备: 1/1
子设备: 1/1
- 系统: Ubuntu
$ sudo lshw -numeric -class multimedia
[sudo] tml 的密码:
*-multimedia
description: Audio device
product: Redwood HDMI Audio [Radeon HD 5000 Series] [1002:AA60]
vendor: Advanced Micro Devices, Inc. [AMD/ATI] [1002]
physical id: 0.1
bus info: pci@0000:02:00.1
version: 00
width: 64 bits
clock: 33MHz
capabilities: pm pciexpress msi bus_master cap_list
configuration: driver=snd_hda_intel latency=0
resources: irq:30 memory:cfedc000-cfedffff
*-multimedia
product: 5 Series/3400 Series Chipset High Definition Audio [8086:3B56]
physical id: 1b
bus info: pci@0000:00:1b.0
version: 06
width: 64 bits
clock: 33MHz
resources: irq:29 memory:f0400000-f0403fff
[sudo] tml 的密码:
*-multimedia
physical id: 0.1
version: 00
width: 64 bits
clock: 33MHz
*-multimedia
physical id: 1b
version: 06
width: 64 bits
clock: 33MHz
- 系统: Ubuntu
有试过, 扬声器还是没有声音。不过耳机声音一直都是正常poloshiao 写了:先試試内置扬声器
1. 一般是立體聲 雙聲道内置扬声器
2. 測試内置扬声器aplay -L
sysdefault:CARD=MID
把下面指令 複製 貼進終端機 執行
2-1. speaker-test -Dsysdefault:MID -c 2
或
2-2. sudo speaker-test -Dsysdefault:MID -c 2
靜聽看看 喇吧音效 是否 左右喇吧輪流有音響
調整音量調整桿 看看是否能調整音量
2-3. 按下 ctrl + C 中止測試
3. 看看 下面資料 有沒有 幫助
3-1. https://wiki.archlinux.org/index.php/Laptop/Dellcard 0: MID [HDA Intel MID], device 0: ALC269VB Analog [ALC269VB Analog]
子设备: 1/1
HDA Intel MID, works with ALSA after adding options snd-hda-intel index=0 model=dell-m6-dmic to /etc/modprobe.d/alsa-base.conf. HDMI audio has some issues.
3-2. 在 /etc/modprobe.d/alsa-base.conf
加上
- 系统: Ubuntu
$ sudo speaker-test -Dsysdefault:MID -c 2poloshiao 写了:1. 一般是立體聲 雙聲道内置扬声器2. 測試内置扬声器aplay -L
sysdefault:CARD=MID
把下面指令 複製 貼進終端機 執行
或
調整音量調整桿 看看是否能調整音量
[sudo] tml 的密码:
speaker-test 1.1.2
重播设备是sysdefault:MID
流参数是 48000Hz,S16_LE,2 频道
正使用朋克噪声16个8音度
ALSA lib pcm_dmix.c:1041:(snd_pcm_dmix_open) unable to open slave
重播打开错误: -16,设备或资源忙
viewtopic.php?p=3189191#p3189191
3. 看看 下面資料 有沒有 幫助
3. 看看 下面資料 有沒有 幫助
- 系统: Ubuntu
按照这个方法尝试之后:poloshiao 写了:viewtopic.php?p=3189191#p3189191
3. 看看 下面資料 有沒有 幫助
第一次重启机器,发现启动失败,电脑黑屏(可能和这个设置有关), 再次强按关机键,从新开机后,
执行 ~$ sudo speaker-test -Dsysdefault:MID -c 2 确实有变化,如下:(但还是没有声音)
speaker-test 1.1.2
重播设备是sysdefault:MID
正使用朋克噪声16个8音度
频率被设为 48000Hz(被要求为48000Hz)
缓冲大小在范围2048到8192
时间段大小从1024到1024
使用最大缓冲大小 8192
时间段=4
时间段大小被设为=1024
缓冲大小被设为=8192
0 - Front Left
1 - Front Right
每时间段时间=5.823211
0 - Front Left
1 - Front Right
每时间段时间=5.973200
0 - Front Left
1 - Front Right
上次由 leslietuang 在 2017-04-21 19:47,总共编辑 1 次。
- 系统: Ubuntu
上次由 leslietuang 在 2017-04-21 19:50,总共编辑 2 次。
