执行错误情况如下:
root@ubuntu:/mnt/hgfs/NXP/ASC884xA_5xA_SDK6.2_wk1420/ASC88xx_SDK/Driver_Source_Codes/VideoServer/TW2866_v3.0.0.3# make
make -C M=/mnt/hgfs/NXP/ASC884xA_5xA_SDK6.2_wk1420/ASC88xx_SDK/Driver_Source_Codes/VideoServer/TW2866_v3.0.0.3 modules
make: *** M=/mnt/hgfs/NXP/ASC884xA_5xA_SDK6.2_wk1420/ASC88xx_SDK/Driver_Source_Codes/VideoServer/TW2866_v3.0.0.3: No such file or directory. Stop.
make: *** [default] Error 2
文件夹如下:
root@ubuntu:/mnt/hgfs/NXP/ASC884xA_5xA_SDK6.2_wk1420/ASC88xx_SDK/Driver_Source_Codes/VideoServer/TW2866_v3.0.0.3# ../../SystemDevices/IICCtrl_v1.0.0.2/
makefile文件如下:
# Generated by Code Generator Version 4.2.0.6 #
DEBUG = n
MODULE := TW2866.ko
HEADERFILE := TW2866.h TW2866_locals.h
IICCTRL_DIR = ../../SystemDevices/IICCtrl_v1.0.0.2
# You normally should not need to change the following
ifeq ($(DEBUG),y)
EXTRA_CFLAGS += -O -g -D_DEBUG
else
EXTRA_CFLAGS += -O2 -DNO_DP -DNDEBUG
endif
ifneq ($(KERNELRELEASE),)
ifeq ($(findstring .., $(IICCTRL_DIR)),)
ROOTLOOT = $(IICCTRL_DIR)
else
ROOTLOOT = $(PWD)/$(IICCTRL_DIR)
endif
EXTRA_CFLAGS += -I$(ROOTLOOT)
obj-m := TW2866.o
else
PWD := $(shell pwd)
KERNELDIR := $(KERNELSRC)
default:
$(MAKE) -C $(KERNELDIR) M=$(PWD) modules
clean:
@ rm -rf *.o *.ko .*.cmd *.mod.c .tmp_versions *.order *symvers
endif
makefile编译时,明明那个文件夹存在,为啥提示找不到
- 系统: ubuntu10.04
Re: makefile编译时,明明那个文件夹存在,为啥提示找不到
你看仔细一点
报的错是找不到 M=/mnt/hgfs/NXP/ASC884xA_5xA_SDK6.2_wk1420/ASC88xx_SDK/Driver_Source_Codes/VideoServer/TW2866_v3.0.0.3 这个目录
而不是找不到/mnt/hgfs/NXP/ASC884xA_5xA_SDK6.2_wk1420/ASC88xx_SDK/Driver_Source_Codes/VideoServer/TW2866_v3.0.0.3 这个目录
makefile里写的是
实际执行的是
说明没有设置KERNELDIR变量,把后面的M=XXX当成了-C的参数
makefile里写的是
实际执行的是
- 系统: ubuntu10.04
应该是这个问题,感谢你,周一回公司再看看astolia 写了:你看仔细一点
makefile里写的是
实际执行的是
- 系统: win7
你好! 请问你手里面还有官方的ASC884xA_5xA_SDK6.2_wk1420.tar.bz2吗?项目需要,不知道方便分享一下吗?
