升级了15.10后,有时发现笔记本电脑的鼠标不能工作,但触摸板正常,今天测试了下,起动后确实鼠标不能即插即用,而重启后再可以.
诸位同学有木有?
15.10鼠标不能即插即用?(更新内核后已解决)
- 系统: Ubuntu 12.04
上次由 Jacky286 在 2015-11-09 22:27,总共编辑 2 次。
Re: 15.10鼠标不能即插即用?
重启後起动后确实鼠标不能即插即用,而重启后再可以.
把下面指令 複製 貼進終端機 執行
1. sudo journalctl -b -1 -p err --no-pager
2. sudo journalctl -b 0 -p err --no-pager
把結果直接 選取/複製 貼上來
- 系统: Ubuntu 12.04
Re: 15.10鼠标不能即插即用?
UX31E:~$ sudo journalctl -b -l -p err --no-pagerpoloshiao 写了:重启後起动后确实鼠标不能即插即用,而重启后再可以.
把下面指令 複製 貼進終端機 執行
把結果直接 選取/複製 貼上來
-- Logs begin at 日 2015-11-08 16:45:45 CST, end at 日 2015-11-08 16:50:31 CST. --
11月 08 16:45:46 sjg-UX31E ntpdate[615]: name server cannot be used: Temporary failure in name resolution (-3)
11月 08 16:45:48 sjg-UX31E bluetoothd[845]: Failed to obtain handles for "Service Changed" characteristic
11月 08 16:45:48 sjg-UX31E bluetoothd[845]: Not enough free handles to register service
11月 08 16:45:48 sjg-UX31E bluetoothd[845]: Error adding Link Loss service
11月 08 16:45:48 sjg-UX31E bluetoothd[845]: Current Time Service could not be registered
11月 08 16:45:48 sjg-UX31E bluetoothd[845]: gatt-time-server: Input/output error (5)
11月 08 16:45:48 sjg-UX31E bluetoothd[845]: Sap driver initialization failed.
11月 08 16:45:48 sjg-UX31E bluetoothd[845]: sap-server: Operation not permitted (1)
11月 08 16:45:48 sjg-UX31E NetworkManager[823]: nm_device_get_device_type: assertion 'NM_IS_DEVICE (self)' failed
11月 08 16:45:48 sjg-UX31E wpa_supplicant[959]: dbus: wpa_dbus_get_object_properties: failed to get object properties: (none) none
11月 08 16:45:48 sjg-UX31E wpa_supplicant[959]: dbus: Failed to construct signal
11月 08 16:45:49 sjg-UX31E lightdm[1033]: PAM unable to dlopen(pam_kwallet.so): /lib/security/pam_kwallet.so: cannot open shared object file: No such file or directory
11月 08 16:45:49 sjg-UX31E lightdm[1033]: PAM adding faulty module: pam_kwallet.so
11月 08 16:45:49 sjg-UX31E lightdm[1033]: PAM unable to dlopen(pam_kwallet5.so): /lib/security/pam_kwallet5.so: cannot open shared object file: No such file or directory
11月 08 16:45:49 sjg-UX31E lightdm[1033]: PAM adding faulty module: pam_kwallet5.so
11月 08 16:45:50 sjg-UX31E lightdm[1286]: PAM unable to dlopen(pam_kwallet.so): /lib/security/pam_kwallet.so: cannot open shared object file: No such file or directory
11月 08 16:45:50 sjg-UX31E lightdm[1286]: PAM adding faulty module: pam_kwallet.so
11月 08 16:45:50 sjg-UX31E lightdm[1286]: PAM unable to dlopen(pam_kwallet5.so): /lib/security/pam_kwallet5.so: cannot open shared object file: No such file or directory
11月 08 16:45:50 sjg-UX31E lightdm[1286]: PAM adding faulty module: pam_kwallet5.so
11月 08 16:45:54 sjg-UX31E NetworkManager[823]: <error> [1446972354.009181] [dns-manager/nm-dns-dnsmasq.c:387] update(): dnsmasq owner not found on bus: Could not get owner of name 'org.freedesktop.NetworkManager.dnsmasq': no such name
11月 08 16:45:56 sjg-UX31E bluetoothd[845]: RFCOMM server failed for Headset Voice gateway: rfcomm_bind: Address already in use (98)
11月 08 16:45:56 sjg-UX31E pulseaudio[1972]: [pulseaudio] pid.c: Daemon already running.
11月 08 16:46:58 sjg-UX31E pkexec[2521]: pam_ck_connector(polkit-1:session): cannot determine display-device
UX31E:~$ sudo journalctl -b 0 -p err --no-pager
-- Logs begin at 日 2015-11-08 16:45:45 CST, end at 日 2015-11-08 16:53:51 CST. --
Re: 15.10鼠标不能即插即用?
... 中間省略
前後兩次開機 錯誤訊息 時間點都一樣2. sudo journalctl -b 0 -p err --no-pager
... 中間省略
應該是同一次開機 不是前後兩次開機 ?
- 系统: Ubuntu 12.04
Re: 15.10鼠标不能即插即用?
第二个命令要重新开机后再运行吗?如下:poloshiao 写了:1. sudo journalctl -b -1 -p err --no-pager
... 中間省略
11月 08 16:46:58 sjg-UX31E pkexec[2521]: pam_ck_connector(polkit-1:session): cannot determine display-device前後兩次開機 錯誤訊息 時間點都一樣2. sudo journalctl -b 0 -p err --no-pager
... 中間省略
應該是同一次開機 不是前後兩次開機 ?
sjg@sjg-UX31E:~$ sudo journalctl -b 0 -p err --no-pager
[sudo] sjg 的密码:
-- Logs begin at 一 2015-11-09 10:00:26 CST, end at 一 2015-11-09 10:00:51 CST. --
11月 09 10:00:27 sjg-UX31E ntpdate[639]: name server cannot be used: Temporary failure in name resolution (-3)
11月 09 10:00:28 sjg-UX31E NetworkManager[712]: nm_device_get_device_type: assertion 'NM_IS_DEVICE (self)' failed
11月 09 10:00:28 sjg-UX31E wpa_supplicant[906]: dbus: wpa_dbus_get_object_properties: failed to get object properties: (none) none
11月 09 10:00:28 sjg-UX31E wpa_supplicant[906]: dbus: Failed to construct signal
11月 09 10:00:28 sjg-UX31E bluetoothd[1016]: Failed to obtain handles for "Service Changed" characteristic
11月 09 10:00:28 sjg-UX31E bluetoothd[1016]: Not enough free handles to register service
11月 09 10:00:28 sjg-UX31E bluetoothd[1016]: Error adding Link Loss service
11月 09 10:00:28 sjg-UX31E bluetoothd[1016]: Current Time Service could not be registered
11月 09 10:00:28 sjg-UX31E bluetoothd[1016]: gatt-time-server: Input/output error (5)
11月 09 10:00:28 sjg-UX31E bluetoothd[1016]: Sap driver initialization failed.
11月 09 10:00:28 sjg-UX31E bluetoothd[1016]: sap-server: Operation not permitted (1)
11月 09 10:00:30 sjg-UX31E lightdm[1122]: PAM unable to dlopen(pam_kwallet.so): /lib/security/pam_kwallet.so: cannot open shared object file: No such file or directory
11月 09 10:00:30 sjg-UX31E lightdm[1122]: PAM adding faulty module: pam_kwallet.so
11月 09 10:00:30 sjg-UX31E lightdm[1122]: PAM unable to dlopen(pam_kwallet5.so): /lib/security/pam_kwallet5.so: cannot open shared object file: No such file or directory
11月 09 10:00:30 sjg-UX31E lightdm[1122]: PAM adding faulty module: pam_kwallet5.so
11月 09 10:00:30 sjg-UX31E lightdm[1322]: PAM unable to dlopen(pam_kwallet.so): /lib/security/pam_kwallet.so: cannot open shared object file: No such file or directory
11月 09 10:00:30 sjg-UX31E lightdm[1322]: PAM adding faulty module: pam_kwallet.so
11月 09 10:00:30 sjg-UX31E lightdm[1322]: PAM unable to dlopen(pam_kwallet5.so): /lib/security/pam_kwallet5.so: cannot open shared object file: No such file or directory
11月 09 10:00:30 sjg-UX31E lightdm[1322]: PAM adding faulty module: pam_kwallet5.so
11月 09 10:00:32 sjg-UX31E NetworkManager[712]: <error> [1447034432.751525] [dns-manager/nm-dns-dnsmasq.c:387] update(): dnsmasq owner not found on bus: Could not get owner of name 'org.freedesktop.NetworkManager.dnsmasq': no such name
11月 09 10:00:35 sjg-UX31E bluetoothd[1016]: RFCOMM server failed for Headset Voice gateway: rfcomm_bind: Address already in use (98)
11月 09 10:00:36 sjg-UX31E pulseaudio[2014]: [pulseaudio] pid.c: Daemon already running.
Re: 15.10鼠标不能即插即用?
對第二个命令要重新开机后再运行吗?如下:
你現在貼上來的 沒有比對值
請重新來一次
當出現上述情況時今天测试了下,起动后确实鼠标不能即插即用,而重启后再可以.
把下面指令 複製 貼進終端機 執行
把結果直接 選取/複製 貼上來
- 系统: Ubuntu 12.04
Re: 15.10鼠标不能即插即用?
sjg@sjg-UX31E:~$ sudo journalctl -b -l -p err --no-pagerpoloshiao 写了:對第二个命令要重新开机后再运行吗?如下:
你現在貼上來的 沒有比對值
請重新來一次當出現上述情況時今天测试了下,起动后确实鼠标不能即插即用,而重启后再可以.
把下面指令 複製 貼進終端機 執行
把結果直接 選取/複製 貼上來
[sudo] sjg 的密码:
-- Logs begin at 一 2015-11-09 20:58:26 CST, end at 一 2015-11-09 20:58:58 CST. --
11月 09 20:58:27 sjg-UX31E ntpdate[622]: name server cannot be used: Temporary failure in name resolution (-3)
11月 09 20:58:28 sjg-UX31E NetworkManager[729]: nm_device_get_device_type: assertion 'NM_IS_DEVICE (self)' failed
11月 09 20:58:28 sjg-UX31E wpa_supplicant[871]: dbus: wpa_dbus_get_object_properties: failed to get object properties: (none) none
11月 09 20:58:28 sjg-UX31E wpa_supplicant[871]: dbus: Failed to construct signal
11月 09 20:58:30 sjg-UX31E lightdm[1081]: PAM unable to dlopen(pam_kwallet.so): /lib/security/pam_kwallet.so: cannot open shared object file: No such file or directory
11月 09 20:58:30 sjg-UX31E lightdm[1081]: PAM adding faulty module: pam_kwallet.so
11月 09 20:58:30 sjg-UX31E lightdm[1081]: PAM unable to dlopen(pam_kwallet5.so): /lib/security/pam_kwallet5.so: cannot open shared object file: No such file or directory
11月 09 20:58:30 sjg-UX31E lightdm[1081]: PAM adding faulty module: pam_kwallet5.so
11月 09 20:58:31 sjg-UX31E lightdm[1288]: PAM unable to dlopen(pam_kwallet.so): /lib/security/pam_kwallet.so: cannot open shared object file: No such file or directory
11月 09 20:58:31 sjg-UX31E lightdm[1288]: PAM adding faulty module: pam_kwallet.so
11月 09 20:58:31 sjg-UX31E lightdm[1288]: PAM unable to dlopen(pam_kwallet5.so): /lib/security/pam_kwallet5.so: cannot open shared object file: No such file or directory
11月 09 20:58:31 sjg-UX31E lightdm[1288]: PAM adding faulty module: pam_kwallet5.so
11月 09 20:58:32 sjg-UX31E NetworkManager[729]: <error> [1447073912.618309] [dns-manager/nm-dns-dnsmasq.c:387] update(): dnsmasq owner not found on bus: Could not get owner of name 'org.freedesktop.NetworkManager.dnsmasq': no such name
11月 09 20:58:34 sjg-UX31E bluetoothd[1253]: Failed to obtain handles for "Service Changed" characteristic
11月 09 20:58:34 sjg-UX31E bluetoothd[1253]: Not enough free handles to register service
11月 09 20:58:34 sjg-UX31E bluetoothd[1253]: Error adding Link Loss service
11月 09 20:58:34 sjg-UX31E bluetoothd[1253]: Current Time Service could not be registered
11月 09 20:58:34 sjg-UX31E bluetoothd[1253]: gatt-time-server: Input/output error (5)
11月 09 20:58:34 sjg-UX31E bluetoothd[1253]: Sap driver initialization failed.
11月 09 20:58:34 sjg-UX31E bluetoothd[1253]: sap-server: Operation not permitted (1)
11月 09 20:58:38 sjg-UX31E bluetoothd[1253]: RFCOMM server failed for Headset Voice gateway: rfcomm_bind: Address already in use (98)
11月 09 20:58:38 sjg-UX31E pulseaudio[2006]: [pulseaudio] pid.c: Daemon already running.
11月 09 20:58:38 sjg-UX31E pulseaudio[2008]: [pulseaudio] pid.c: Daemon already running.
[sudo] sjg 的密码:
-- Logs begin at 一 2015-11-09 21:04:34 CST, end at 一 2015-11-09 21:05:03 CST. --
11月 09 21:04:35 sjg-UX31E ntpdate[623]: name server cannot be used: Temporary failure in name resolution (-3)
11月 09 21:04:36 sjg-UX31E NetworkManager[799]: nm_device_get_device_type: assertion 'NM_IS_DEVICE (self)' failed
11月 09 21:04:36 sjg-UX31E wpa_supplicant[891]: dbus: wpa_dbus_get_object_properties: failed to get object properties: (none) none
11月 09 21:04:36 sjg-UX31E wpa_supplicant[891]: dbus: Failed to construct signal
11月 09 21:04:38 sjg-UX31E lightdm[1101]: PAM unable to dlopen(pam_kwallet.so): /lib/security/pam_kwallet.so: cannot open shared object file: No such file or directory
11月 09 21:04:38 sjg-UX31E lightdm[1101]: PAM adding faulty module: pam_kwallet.so
11月 09 21:04:38 sjg-UX31E lightdm[1101]: PAM unable to dlopen(pam_kwallet5.so): /lib/security/pam_kwallet5.so: cannot open shared object file: No such file or directory
11月 09 21:04:38 sjg-UX31E lightdm[1101]: PAM adding faulty module: pam_kwallet5.so
11月 09 21:04:38 sjg-UX31E lightdm[1308]: PAM unable to dlopen(pam_kwallet.so): /lib/security/pam_kwallet.so: cannot open shared object file: No such file or directory
11月 09 21:04:38 sjg-UX31E lightdm[1308]: PAM adding faulty module: pam_kwallet.so
11月 09 21:04:38 sjg-UX31E lightdm[1308]: PAM unable to dlopen(pam_kwallet5.so): /lib/security/pam_kwallet5.so: cannot open shared object file: No such file or directory
11月 09 21:04:38 sjg-UX31E lightdm[1308]: PAM adding faulty module: pam_kwallet5.so
11月 09 21:04:40 sjg-UX31E NetworkManager[799]: <error> [1447074280.254064] [dns-manager/nm-dns-dnsmasq.c:387] update(): dnsmasq owner not found on bus: Could not get owner of name 'org.freedesktop.NetworkManager.dnsmasq': no such name
11月 09 21:04:42 sjg-UX31E bluetoothd[1260]: Failed to obtain handles for "Service Changed" characteristic
11月 09 21:04:42 sjg-UX31E bluetoothd[1260]: Not enough free handles to register service
11月 09 21:04:42 sjg-UX31E bluetoothd[1260]: Error adding Link Loss service
11月 09 21:04:42 sjg-UX31E bluetoothd[1260]: Current Time Service could not be registered
11月 09 21:04:42 sjg-UX31E bluetoothd[1260]: gatt-time-server: Input/output error (5)
11月 09 21:04:42 sjg-UX31E bluetoothd[1260]: Sap driver initialization failed.
11月 09 21:04:42 sjg-UX31E bluetoothd[1260]: sap-server: Operation not permitted (1)
11月 09 21:04:44 sjg-UX31E bluetoothd[1260]: RFCOMM server failed for Headset Voice gateway: rfcomm_bind: Address already in use (98)
11月 09 21:04:44 sjg-UX31E pulseaudio[2031]: [pulseaudio] pid.c: Daemon already running.
Re: 15.10鼠标不能即插即用?
1. 間隔 6 分鐘 ?sudo journalctl -b -l -p err --no-pager
2. 兩者記錄 除了時間點不一樣以外 其它訊息幾乎一樣
3. 其它待查
- 系统: Ubuntu 12.04
Re: 15.10鼠标不能即插即用?
亲,更新内核后,问题已解决,谢谢!poloshiao 写了:1. 間隔 6 分鐘 ?sudo journalctl -b -l -p err --no-pager
3. 其它待查
