输入中文就会出现两个候选框,一个是 kimpanel 的,另一个应当是 sogou-qimpanel。如附图。
非常感谢!!
stephen@Optiplex390:~$ fcitx-diagnose
# System Info:
1. `uname -a`:
Linux Optiplex390 4.12.8-2-ARCH #1 SMP PREEMPT Fri Aug 18 14:08:02 UTC 2017 x86_64 GNU/Linux
2. `lsb_release -a`:
LSB Version: 1.4
Distributor ID: Arch
Description: Arch Linux
Release: rolling
Codename: n/a
3. `lsb_release -d`:
4. `/etc/lsb-release`:
LSB_VERSION=1.4
DISTRIB_ID=Arch
DISTRIB_RELEASE=rolling
DISTRIB_DESCRIPTION="Arch Linux"
5. `/etc/os-release`:
NAME="Arch Linux"
PRETTY_NAME="Arch Linux"
ID=arch
ID_LIKE=archlinux
ANSI_COLOR="0;36"
HOME_URL="https://www.archlinux.org/"
SUPPORT_URL="https://bbs.archlinux.org/"
BUG_REPORT_URL="https://bugs.archlinux.org/"
6. Desktop Environment:
Desktop environment is `gnome3`.
7. Bash Version:
BASH_VERSION='4.4.12(1)-release'
# Environment:
1. DISPLAY:
DISPLAY=':0'
2. Keyboard Layout:
1. `setxkbmap`:
xkb_keymap {
xkb_keycodes { include "evdev+aliases(qwerty)" };
xkb_types { include "complete" };
xkb_compat { include "complete" };
xkb_symbols { include "pc+us+cn:2+inet(evdev)" };
xkb_geometry { include "pc(pc105)" };
2. `xprop`:
_XKB_RULES_NAMES(STRING) = "evdev", "pc105", "us,cn", "", ""
3. Locale:
1. All locale:
C
en_US.utf8
POSIX
zh_CN
zh_CN.gb18030
zh_CN.gb2312
zh_CN.gbk
zh_CN.utf8
zh_HK
zh_HK.big5hkscs
zh_HK.utf8
zh_TW
zh_TW.big5
zh_TW.utf8
2. Current locale:
LANG=en_US.UTF-8
LC_CTYPE="en_US.UTF-8"
LC_NUMERIC=zh_CN.UTF-8
LC_TIME=zh_CN.UTF-8
LC_COLLATE="en_US.UTF-8"
LC_MONETARY=zh_CN.UTF-8
LC_MESSAGES="en_US.UTF-8"
LC_PAPER=zh_CN.UTF-8
LC_NAME="en_US.UTF-8"
LC_ADDRESS="en_US.UTF-8"
LC_TELEPHONE="en_US.UTF-8"
LC_MEASUREMENT=zh_CN.UTF-8
LC_IDENTIFICATION="en_US.UTF-8"
LC_ALL=
4. Directories:
1. Home:
/home/stephen
2. `${XDG_CONFIG_HOME}`:
Environment variable `XDG_CONFIG_HOME` is not set.
Current value of `XDG_CONFIG_HOME` is `~/.config` (`/home/stephen/.config`).
3. Fcitx Settings Directory:
Current fcitx settings directory is `~/.config/fcitx` (`/home/stephen/.config/fcitx`).
5. Current user:
The script is run as stephen (1000).
# Fcitx State:
1. executable:
Found fcitx at `/usr/bin/fcitx`.
2. version:
Fcitx version: `4.2.9.1`
3. process:
Found 2 fcitx processes:
969 fcitx
31421 fcitx-dbus-watc
4. `fcitx-remote`:
`fcitx-remote` works properly.
# Fcitx Configure UI:
1. Config Tool Wrapper:
Found fcitx-configtool at `/usr/bin/fcitx-configtool`.
2. Config GUI for gtk2:
**Config GUI for gtk2 not found.**
3. Config GUI for gtk3:
Found `fcitx-config-gtk3` at `/usr/bin/fcitx-config-gtk3`.
4. Config GUI for kde:
**`kcmshell4` not found.**
# Frontends setup:
## Xim:
1. `${XMODIFIERS}`:
Environment variable XMODIFIERS is set to "@im=fcitx" correctly.
Xim Server Name from Environment variable is fcitx.
2. XIM_SERVERS on root window:
Xim server name is the same with that set in the environment variable.
## Qt:
1. qt4 - `${QT4_IM_MODULE}`:
Environment variable QT_IM_MODULE is set to "fcitx" correctly.
2. qt5 - `${QT_IM_MODULE}`:
3. Qt IM module files:
Found fcitx im module for Qt5: `/usr/lib/qt/plugins/platforminputcontexts/libfcitxplatforminputcontextplugin.so`.
Found fcitx qt module: `/usr/lib/fcitx/qt/libfcitx-quickphrase-editor.so`.
Found fcitx im module for Qt4: `/usr/lib/qt4/plugins/inputmethods/qtim-fcitx.so`.
## Gtk:
1. gtk - `${GTK_IM_MODULE}`:
Environment variable GTK_IM_MODULE is set to "fcitx" correctly.
2. `gtk-query-immodules`:
1. gtk 2:
Found `gtk-query-immodules` for gtk `2.24.31` at `/usr/bin/gtk-query-immodules-2.0`.
Version Line:
# Created by /usr/bin/gtk-query-immodules-2.0 from gtk+-2.24.31
Found fcitx im modules for gtk `2.24.31`.
"/usr/lib/gtk-2.0/2.10.0/immodules/im-fcitx.so"
"fcitx" "Fcitx (Flexible Input Method Framework)" "fcitx" "/usr/share/locale" "ja:ko:zh:*"
Found `gtk-query-immodules` for gtk `2.24.31` at `/usr/bin/gtk-query-immodules-2.0-32`.
Version Line:
# Created by /usr/bin/gtk-query-immodules-2.0-32 from gtk+-2.24.31
**Failed to find fcitx in the output of `/usr/bin/gtk-query-immodules-2.0-32`**
2. gtk 3:
Found `gtk-query-immodules` for gtk `3.22.19` at `/usr/bin/gtk-query-immodules-3.0`.
Version Line:
# Created by /usr/bin/gtk-query-immodules-3.0 from gtk+-3.22.19
Found fcitx im modules for gtk `3.22.19`.
"/usr/lib/gtk-3.0/3.0.0/immodules/im-fcitx.so"
3. Gtk IM module cache:
1. gtk 2:
Found immodules cache for gtk `2.24.31` at `/usr/lib/gtk-2.0/2.10.0/immodules.cache`.
Version Line:
Found immodules cache for gtk `2.24.31` at `/usr/lib32/gtk-2.0/2.10.0/immodules.cache`.
Version Line:
# Created by usr/bin/gtk-query-immodules-2.0-32 from gtk+-2.24.31
**Failed to find fcitx in immodule cache at `/usr/lib32/gtk-2.0/2.10.0/immodules.cache`**
2. gtk 3:
Found immodules cache for gtk `3.22.19` at `/usr/lib/gtk-3.0/3.0.0/immodules.cache`.
Version Line:
4. Gtk IM module files:
1. gtk 2:
All found Gtk 2 immodule files exist.
2. gtk 3:
All found Gtk 3 immodule files exist.
# Configuration:
## Fcitx Addons:
1. Addon Config Dir:
Found fcitx addon config directory: `/usr/share/fcitx/addon`.
2. Addon List:
1. Found 30 enabled addons:
fcitx-autoeng
fcitx-autoeng-ng
fcitx-chttrans
fcitx-classic-ui
fcitx-clipboard
fcitx-dbus
fcitx-freedesktop-notify
fcitx-fullwidth-char
fcitx-fullwidth-char-enhance
fcitx-imselector
fcitx-ipc
fcitx-keyboard
fcitx-kimpanel-ui
fcitx-notificationitem
fcitx-pinyin
fcitx-pinyin-enhance
fcitx-punc
fcitx-punc-ng
fcitx-quickphrase
fcitx-remote
fcitx-sogoucloudpinyin
fcitx-sogoupinyin
fcitx-spell
fcitx-table
fcitx-unicode
fcitx-vk
fcitx-x11
fcitx-xim
fcitx-xkb
fcitx-xkbdbus
2. Found 1 disabled addons:
fcitx-qw
3. Addon Libraries:
All libraries for all addons are found.
4. User Interface:
Found 2 enabled user interface addons:
fcitx-classic-ui
fcitx-kimpanel-ui
Kimpanel process:
668 /usr/bin/gnome-shell
## Input Methods:
1. Found 3 enabled input methods:
fcitx-keyboard-us
sogoupinyin
quwei
2. Default input methods:
You have a keyboard input method "fcitx-keyboard-us" correctly added as your default input method.
# Log:
1. `date`:
2017年 09月 04日 星期一 09:07:19 CST
2. `~/.config/fcitx/log/`:
total 0
3. `~/.config/fcitx/log/crash.log`:
`~/.config/fcitx/log/crash.log` not found.
