在ubuntu系统中,无论是apt更新或升级,或者使用GUI界面的更新管理器或者新立得,都需要sudo或者root权限。
但是,唯独这个do-release-upgrade却不需要sudo,直接在命令行输入,就会升级到下一个版本,最要命的是,-d参数可以升级到开发版,这可是极具破坏性啊
为什么会这样?难道是个bug!
do-release-upgrade为嘛不要管理员权限
- 百草谷居士
- 系统: Mint21.1/Deepin20.8
Re: do-release-upgrade为嘛不要管理员权限
它是用sudo来提权的。你肯定是运行do-release-upgrade之前用sudo运行过其他命令
1. 需要加 sudo 而且需要從 tty 界面執行 (如果圖形界面已啟用 最好先關閉圖形界面)唯独这个do-release-upgrade却不需要sudo
1-1. 參見
https://wiki.ubuntu.com/BionicBeaver/Re ... S_or_17.10
To upgrade on a server system:
Install update-manager-core if it is not already installed.
Make sure the Prompt line in /etc/update-manager/release-upgrades is set to 'normal' if you want non-LTS upgrades, or 'lts' if you only want LTS upgrades.
Launch the upgrade tool with the command sudo do-release-upgrade
Follow the on-screen instructions.
Note that the server upgrade will use GNU screen and automatically re-attach in case of dropped connection problems.
