18.04,意外卡死
躺在桌子上
18.04,意外卡死
帖子 躺在桌子上 » 2018-06-13 21:53
用了几天18.04,感觉非常好,但是今天看视频意外反复死机。下载的电影,昨晚看了一半,今天继续,动不动就死机,reisub大法也没用,只能按重启键。
查看日志(虽然也看不懂)发现错误信息如下:
20:28:25 kernel: nouveau 0000:01:00.0: msvld: init failed, -19
20:23:32 pulseaudio: [pulseaudio] bluez5-util.c: GetManagedObjects() failed: org.freedesktop.DBus.Error.NoReply: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
20:23:15 spice-vdagent: Cannot access vdagent virtio channel /dev/virtio-ports/com.redhat.spice.0
20:22:58 kernel: nouveau 0000:01:00.0: fifo: read fault at 0000207000 engine 05 [BAR3] client 07 [BAR_READ] reason 02 [PAGE_NOT_PRESENT] on channel -1 [003fe36000 unknown]
20:22:41 colord-sane: io/hpmud/pp.c 627: unable to read device-id ret=-1
20:22:36 hpfax: io/hpmud/pp.c 627: unable to read device-id ret=-1
20:22:35 hp: io/hpmud/pp.c 627: unable to read device-id ret=-1
20:22:35 systemd: Failed to start Teredo IPv6 tunneling.
20:22:11 systemd-udevd: Error calling EVIOCSKEYCODE on device node '/dev/input/event3' (scan code 0xc104c, key code 162): Invalid argument
20:22:11 systemd-udevd: Error calling EVIOCSKEYCODE on device node '/dev/input/event3' (scan code 0xc104a, key code 136): Invalid argument
20:22:11 systemd-udevd: Error calling EVIOCSKEYCODE on device node '/dev/input/event3' (scan code 0xc1048, key code 430): Invalid argument
20:22:11 systemd-udevd: Error calling EVIOCSKEYCODE on device node '/dev/input/event3' (scan code 0xc1046, key code 203): Invalid argument
20:22:11 systemd-udevd: Error calling EVIOCSKEYCODE on device node '/dev/input/event3' (scan code 0xc1045, key code 202): Invalid argument
20:22:11 systemd-udevd: Error calling EVIOCSKEYCODE on device node '/dev/input/event3' (scan code 0xc1044, key code 149): Invalid argument
20:22:11 systemd-udevd: Error calling EVIOCSKEYCODE on device node '/dev/input/event3' (scan code 0xc1043, key code 397): Invalid argument
20:22:11 systemd-udevd: Error calling EVIOCSKEYCODE on device node '/dev/input/event3' (scan code 0xc1042, key code 423): Invalid argument
20:22:11 systemd-udevd: Error calling EVIOCSKEYCODE on device node '/dev/input/event3' (scan code 0xc1041, key code 421): Invalid argument
20:22:11 systemd-udevd: Error calling EVIOCSKEYCODE on device node '/dev/input/event3' (scan code 0xc1020, key code 103): Invalid argument
20:22:11 systemd-udevd: Error calling EVIOCSKEYCODE on device node '/dev/input/event3' (scan code 0xc101f, key code 108): Invalid argument
20:22:11 systemd-udevd: Error calling EVIOCSKEYCODE on device node '/dev/input/event3' (scan code 0xc1005, key code 212): Invalid argument
20:22:11 systemd-udevd: Error calling EVIOCSKEYCODE on device node '/dev/input/event3' (scan code 0xc0183, key code 226): Invalid argument
20:22:09 kernel: nouveau 0000:01:00.0: fifo: read fault at 000018b000 engine 05 [BAR3] client 07 [BAR_READ] reason 02 [PAGE_NOT_PRESENT] on channel -1 [003fe36000 unknown]
Re: 18.04,意外卡死
帖子 poloshiao » 2018-06-14 10:50
1. 把下面指令 複製 貼進終端機 執行
1-1. sudo cat /etc/os-release
1-2. sudo lshw -numeric -class video
1-3. echo $DESKTOP_SESSION
1-4. echo $XDG_SESSION_TYPE
把指令及結果直接複製貼上來
躺在桌子上
Re: 18.04,意外卡死
帖子 躺在桌子上 » 2018-06-14 20:20
poloshiao 写了:1. 把下面指令 複製 貼進終端機 執行
把指令及結果直接複製貼上來
1.han@han-home:~$ sudo cat /etc/os-release
NAME="Ubuntu"
VERSION="18.04 LTS (Bionic Beaver)"
ID=ubuntu
ID_LIKE=debian
PRETTY_NAME="Ubuntu 18.04 LTS"
VERSION_ID="18.04"
HOME_URL="https://www.ubuntu.com/"
SUPPORT_URL="https://help.ubuntu.com/"
BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and- ... acy-policy"
VERSION_CODENAME=bionic
UBUNTU_CODENAME=bionic
2.han@han-home:~$ sudo lshw -numeric -class video
*-display
product: GF108 [GeForce GT 630] [10DE:F00]
physical id: 0
bus info: pci@0000:01:00.0
version: a1
width: 64 bits
clock: 33MHz
configuration: driver=nouveau latency=0
resources: irq:25 memory:fb000000-fbffffff memory:d0000000-dfffffff memory:ee000000-efffffff ioport:ef00(size=128) memory:c0000-dffff
3.han@han-home:~$ echo $DESKTOP_SESSION
ubuntu
4.han@han-home:~$ echo $XDG_SESSION_TYPE
x11
谢谢!
Re: 18.04,意外卡死
帖子 poloshiao » 2018-06-16 14:13
1. https://nouveau.freedesktop.org/wiki/CodeNames/
1-1. GF108 沒有 GeForce GT 630
NVC1 (GF108) GeForce GT (415M, 420, 420M, 425M, 430, 435M, 520M, 525M, 530, 540M, 550M, 555M, 620, 630M, 635M, 640M LE)
Quadro 600, 1000M
1-2. GK208 才有 GeForce GT 630
NV108 (GK208) GeForce GT 630, 635, 640, 710M, 720M, 730M, 735M, 740M, 920M
Quadro K510M, K610M
1-3. 1-1, 1-2 都在 nouveau 支援名單內 但是 支援功能 不儘相同
sdzzg
Re: 18.04,意外卡死
帖子 sdzzg » 2018-07-09 16:06
我的也是这样,从16.04就开始了,原以为是机器太老的问题。现象是图像不动,声音持续咔咔的声音。
然后只能按reset键启动或强制关机。一直怀疑是机器硬件或声卡驱动的问题。
而且有几次无法启动机器了。
