如果是在新安装ubuntu1804时,没有划出交换分区,系统会自动启用交换文件来替代交换分区,这也是Ubuntu现在推荐的方式。
可是问题是这样的,我在安装ubuntu1804时,已经存在交换分区了,现在又把交换分区删了,又不想重新安装,那么,如何手工建立交换文件并启用这种模式呢?
怎样手工建立交换文件?
- 百草谷居士
- 系统: Mint21.1/Deepin20.8
怎样手工建立交换文件?
Re: 怎样手工建立交换文件?
又上不了google了? https://help.ubuntu.com/community/SwapF ... ap_file.3F
Create the Swap File:
We will create a 1 GiB file (/mnt/1GiB.swap) to use as swap:
fallocate size suffixes: g = Giga, m = Mega, etc. (See man fallocate).代码: 全选
sudo fallocate -l 1g /mnt/1GiB.swap
If fallocate fails or it not available, you can use dd:
We need to set the swap file permissions to 600 to prevent other users from being able to read potentially sensitive information from the swap file.代码: 全选
sudo dd if=/dev/zero of=/mnt/1GiB.swap bs=1024 count=1048576
Format the file as swap:代码: 全选
sudo chmod 600 /mnt/1GiB.swap
Enable use of Swap File代码: 全选
sudo mkswap /mnt/1GiB.swap
The additional swap is now available and verified with: cat /proc/swaps代码: 全选
sudo swapon /mnt/1GiB.swap
Enable Swap File at Bootup
Add the swap file details to /etc/fstab so it will be available at bootup:
Example of making a swap file代码: 全选
echo '/mnt/1GiB.swap swap swap defaults 0 0' | sudo tee -a /etc/fstab
This is an example of making and using a swap file on a computer with no swap partition.代码: 全选
$ sudo fallocate -l 1g /mnt/1GiB.swap $ sudo chmod 600 /mnt/1GiB.swap $ sudo mkswap /mnt/1GiB.swap Setting up swapspace version 1, size = 1048576 kB $ sudo swapon /mnt/1GiB.swap $ cat /proc/swaps Filename Type Size Used Priority /home/swapfile file 1048576 1048576 -1 $ echo '/mnt/4GiB.swap swap swap defaults 0 0' | sudo tee -a /etc/fstab $ reboot $ free -h total used free shared buff/cache available Mem: 15G 9.3G 454M 4.0G 5.8G 1.9G Swap: 1.0G 1.0G 0B
- 百草谷居士
Re: 怎样手工建立交换文件?
谢谢,我将交换文件设置为4G。好像用不到啊!
free -h
free -h
swapon$ free -h
总计 已用 空闲 共享 缓冲/缓存 可用
内存: 7.7G 760M 6.0G 202M 1.0G 6.5G
交换: 4.0G 0B 4.0G
$ swapon
NAME TYPE SIZE USED PRIO
/home/4G.swap file 4G 0B -2
Re: 怎样手工建立交换文件?
有那么多快速的内存空着,干嘛要用慢的要死的交换文件?
非要玩的话
非要玩的话
sudo sysctl vm.swappiness=100
dd if=/dev/urandom of=/dev/shm/test bs=1M
- 男菜鸟
- 来自: 漂在江湖
Re: 怎样手工建立交换文件?
mark
- 百草谷居士
Re: 怎样手工建立交换文件?
我看了一下如果安装时没有交换分区,系统自设的交换文件在fstab文件的定义,是这样的:
swapfile 位于根节点。后面的选项还是有区别的。swapfile none swap sw 0 0
- tang.zhe
Re: 怎样手工建立交换文件?
- 速腾1994
- 系统: Arch+gnome
Re: 怎样手工建立交换文件?
swap是不需要手动挂载的。只要有swap分区,系统会自动挂载的
