循环登录问题,参考了论坛的相关帖子未解决,求帮助
- 系统: ubuntu kylin
原来是gdm,启动后出现了ubutu kylin logo后,就黑屏,可以进tty,切换到lightdm后重启,出现登录界面了,但陷入了登录循环,安装gnome fallback后,megacity可以进桌面环境,但问题很多,貌似问题出在了libGL上,怎么解决?
FYI :
root@k-E400:/home/k/下载# glxinfo | grep OpenGL
glxinfo: error while loading shared libraries: libGL.so.1: cannot open shared object file: No such file or directory
root@k-E400:/home/k/下载# locate libglx.so
/usr/lib/xorg/modules/extensions/libglx.so
root@k-E400:/home/k/下载# locate libGL.so.1
/usr/lib/i386-linux-gnu/mesa/libGL.so.1
/usr/lib/i386-linux-gnu/mesa/libGL.so.1.2.0
/usr/lib/x86_64-linux-gnu/mesa/libGL.so.1
/usr/lib/x86_64-linux-gnu/mesa/libGL.so.1.2.0
root@k-E400:/home/k/下载# ls -la /usr/lib/xorg/modules/extensions/
总用量 284
drwxr-xr-x 2 root root 4096 6月 6 21:57 .
drwxr-xr-x 6 root root 4096 6月 6 16:33 ..
-rw-r--r-- 1 root root 281928 10月 13 2017 libglx.so
root@k-E400:/home/k/下载# ls -l /usr/lib/x86_64-linux-gnu/libGLU.so.1
lrwxrwxrwx 1 root root 15 10月 20 2014 /usr/lib/x86_64-linux-gnu/libGLU.so.1 -> libGLU.so.1.3.1
root@k-E400:/home/k/下载# dpkg -S libGL.so.1
libgl1-mesa-glx:i386: /usr/lib/i386-linux-gnu/mesa/libGL.so.1
libgl1-mesa-glx:amd64: /usr/lib/x86_64-linux-gnu/mesa/libGL.so.1
libgl1-mesa-glx:i386: /usr/lib/i386-linux-gnu/mesa/libGL.so.1.2.0
libgl1-mesa-glx:amd64: /usr/lib/x86_64-linux-gnu/mesa/libGL.so.1.2.0
诊断信息:
root@k-E400:/home/k/下载# uname -r
3.13.0-149-generic
root@k-E400:/home/k/下载# cat /etc/os-release
NAME="Ubuntu"
VERSION="14.04.5 LTS, Trusty Tahr"
ID=ubuntu
ID_LIKE=debian
PRETTY_NAME="Ubuntu 14.04.5 LTS"
VERSION_ID="14.04"
HOME_URL="http://www.ubuntu.com/"
SUPPORT_URL="http://help.ubuntu.com/"
BUG_REPORT_URL="http://bugs.launchpad.net/ubuntu/"
root@k-E400:/home/k/下载# lshw -numeric -class video
*-display
product: 4th Gen Core Processor Integrated Graphics Controller [8086:416]
physical id: 2
bus info: pci@0000:00:02.0
version: 06
width: 64 bits
clock: 33MHz
capabilities: msi pm vga_controller bus_master cap_list rom
resources: irq:47 memory:f7800000-f7bfffff memory:e0000000-efffffff ioport:f000(size=64)
root@k-E400:/home/k/下载# lsmod | grep -P "(video|drm)"
drm_kms_helper 55071 1 i915
drm 303102 3 i915,drm_kms_helper
video 19476 1 i915
root@k-E400:/home/k/下载# echo $DESKTOP_SESSION
(空)
求赐教,拜谢!
FYI :
总用量 284
诊断信息:
3.13.0-149-generic
NAME="Ubuntu"
ID=ubuntu
ID_LIKE=debian
VERSION_ID="14.04"
*-display
physical id: 2
version: 06
width: 64 bits
clock: 33MHz
video 19476 1 i915
(空)
求赐教,拜谢!
Re: 循环登录问题,参考了论坛的相关帖子未解决,求帮助
能说下你参考了哪些帖子么, 因为除了安装各种桌面环境,没发现你其他尝试,另外,我想看一条命令的结果 ls $HOME -al|grep .X
Ubuntu 雖然也是 Linux 但是 預設關閉 root 登入root@k-E400:/home/k/下载# glxinfo | grep OpenGL
新手 不建議使用 root 登入
請重新開機 使用安裝 Ubuntu 時 新創的 非 root 使用者登入
重新提供一次相同的指令及回應
- 系统: ubuntu kylin
参考了很多,照着瞎改,只是安装其他桌面环境才有了点作用,进入了桌面。。onlylove 写了:能说下你参考了哪些帖子么, 因为除了安装各种桌面环境,没发现你其他尝试,另外,我想看一条命令的结果 ls $HOME -al|grep .X
k@k-E400:~$ ls $HOME -al|grep .X
-rw------- 1 k k 51 6月 7 10:02 .Xauthority
-rw------- 1 k k 51 6月 6 00:19 .Xauthority.backup
- 系统: ubuntu kylin
感谢回复!poloshiao 写了:Ubuntu 雖然也是 Linux 但是 預設關閉 root 登入root@k-E400:/home/k/下载# glxinfo | grep OpenGL
新手 不建議使用 root 登入
重新提供一次相同的指令及回應
登录的用户就是安装时创立的账户:k,只是sudo su获得了root权限
照着你说的再做了一遍:
k@k-E400:~$ uname -r
3.13.0-149-generic
k@k-E400:~$ sudo cat /etc/os-release
[sudo] password for k:
NAME="Ubuntu"
ID=ubuntu
ID_LIKE=debian
VERSION_ID="14.04"
k@k-E400:~$ sudo lshw -numeric -class video
*-display
physical id: 2
version: 06
width: 64 bits
clock: 33MHz
k@k-E400:~$ lsmod | grep -P "(video|drm)"
video 19476 1 i915
k@k-E400:~$ echo $DESKTOP_SESSION
gnome-fallback
- 系统: ubuntu kylin
k@k-E400:~/下载$ ls $HOME -al|grep .Xonlylove 写了:能说下你参考了哪些帖子么, 因为除了安装各种桌面环境,没发现你其他尝试,另外,我想看一条命令的结果 ls $HOME -al|grep .X
以前,這種問題是因為無法正常啟動Compiz造成的,現在就不曉得了,
Ubuntu 18.04 還有在用 Compiz ?
能进桌面看起来不是.Xauthority权限的问题,其他问题……就不清楚了
- 系统: ubuntu kylin
大神,求帮助~poloshiao 写了:Ubuntu 雖然也是 Linux 但是 預設關閉 root 登入root@k-E400:/home/k/下载# glxinfo | grep OpenGL
新手 不建議使用 root 登入
重新提供一次相同的指令及回應
- Ping-Wu
- 系统: Debian 12
看起来LZ装的是 UbuntuKylin 16.04 14.04。本来说是5年保固期,后来改成4年。已经过期了,我们在这里讨论,只是浪费时间。(也许有人时间不值钱,不过再讨论下去并没有任何实质上的意义。)xenomorph0525 写了:以前,這種問題是因為無法正常啟動Compiz造成的,現在就不曉得了,
建议LZ重新装 Ubuntu 18.04。如果机器较旧的话,可以加装 gnome flashback (而不是 gnome fallback)。
上次由 Ping-Wu 在 2018-06-09 17:08,总共编辑 1 次。
1. 你需要什麼幫助 ?大神,求帮助~
2. 新手 特別是登入桌面進程登录的用户就是安装时创立的账户:k,只是sudo su获得了root权限
在 Ubuntu 避免使用 root 登入
也避免切換成 root 身份 執行指令
3. 如果一定需要 root 權限執行 console 指令 請加 sudo
4. 如果一定需要 root 權限執行 graphic 指令 請先提供 你是登入什麼 graphic session
17.04 及以前常使用的 gksu / gksudo 可能需要修正
但是 尚且處於嘗試研發階段
1. Ubuntu 14.04 預設登入 unity 桌面進程sudo cat /etc/os-release
NAME="Ubuntu"
1-1. unity 桌面 需要足夠的 3D 支援
2. 目前作用中的驅動 開源驅動 i915sudo lshw -numeric -class video
2-1. 開源驅動 i915 無法充分支援 unity 桌面所需要的 3D 支援
2-2. 上述現象 都可以歸類為 無法充分支援 unity 桌面所需要的 3D 支援原来是gdm,启动后出现了ubutu kylin logo后,就黑屏,可以进tty,切换到lightdm后重启,出现登录界面了,但陷入了登录循环
3. 開源驅動 i915 可以充分支援 unity 桌面所需要的 2D 支援只是最后一条结果不一样。。k@k-E400:~$ echo $DESKTOP_SESSION
gnome-fallback
3-1. gnome-fallback, megacity 都只需要 2D 支援
3-2. xubuntu, lubuntu 也都只需要 2D 支援 意思是 你也可以安裝 xfce, lxsession, lxqt-session 應該沒問題
4. 如果你使用 root 登入 或 切換成 root 身份 執行圖形指令
有一些問題 很不容易捉錯 因為那在 Ubuntu 設定範圍以外
1. 建議你試試 ubuntu 18.04sudo lshw -numeric -class video
看看能否登入 Ubuntu on wayland
或者
登入 Ubuntu on xorg 使用 xwayland
2. 也可以試試 開源 vulkan 驅動
3. 歡迎心得分享
- 系统: ubuntu kylin
谢谢详细解答,但为什么之前我可以正常使用呢?这期间并没有更改驱动。在重启前就安装了electron-ssr,这应该没有影响吧?
贴上2个日志文件Xorg.0.log, .xsession-errors,能帮忙分析下原因吗?
我就是怕了windows的升级才用的ubuntu,升级后一堆事。。
- 附件
- Xorg.log.zip
- 2-5是6月4号没有安装fallback桌面的日志
- (20.43 KiB) 已下载 170 次
- xsession-errors.zip
- (923 Bytes) 已下载 186 次
- 系统: ubuntu kylin
这个问题可能跟 usr_lib_x86_64-linux-gnu_ubuntu-geoip-provider.1000.crash有关吗?poloshiao 写了:1. 建議你試試 ubuntu 18.04sudo lshw -numeric -class video
或者
3. 歡迎心得分享
k@k-E400:~$ ls -la /var/crash
总用量 30320
drwxrwsrwt 2 root whoopsie 4096 6月 8 08:14 .
drwxr-xr-x 14 root root 4096 8月 24 2016 ..
-rw-r----- 1 root whoopsie 7486420 6月 7 15:14 _opt_electron-ssr_electron-ssr.0.crash
-rw-r--r-- 1 root whoopsie 0 6月 6 19:08 _opt_electron-ssr_electron-ssr.0.upload
-rw-r----- 1 k whoopsie 8825466 6月 6 17:28 _opt_electron-ssr_electron-ssr.1000.crash
-rw-rw-r-- 1 k whoopsie 0 6月 3 19:12 _opt_electron-ssr_electron-ssr.1000.upload
-rw-r----- 1 k whoopsie 8450291 6月 4 15:14 _usr_bin_gedit.1000.crash
-rw-r----- 1 k whoopsie 5703878 6月 1 17:11 _usr_bin_ss-qt5.1000.crash
-rw-rw-r-- 1 k whoopsie 0 6月 1 17:11 _usr_bin_ss-qt5.1000.upload
-rw-r----- 1 k whoopsie 561976 6月 4 15:15 _usr_lib_x86_64-linux-gnu_ubuntu-geoip-provider.1000.crash
