新装18.04,设置开机启动不成,查找方案如下:
来自:https://www.centos.bz/2018/05/ubuntu-18 ... %E7%BD%AE/
以下为内容:
ubuntu18.04不再使用initd管理系统,改用systemd。
然而systemd很难用,改变太大,跟之前的完全不同。
使用systemd设置开机启动
为了像以前一样,在/etc/rc.local中设置开机启动程序,需要以下几步:
1、systemd默认读取/etc/systemd/system下的配置文件,该目录下的文件会链接/lib/systemd/system/下的文件。一般系统安装完/lib/systemd/system/下会有rc-local.service文件,即我们需要的配置文件。
链接过来:
ln -fs /lib/systemd/system/rc-local.service /etc/systemd/system/rc-local.service
cd /etc/systemd/system/
cat rc-local.service
rc-local.service内容
# SPDX-License-Identifier: LGPL-2.1+
# This file is part of systemd.
# systemd is free software; you can redistribute it and/or modify it
# under the terms of the GNU Lesser General Public License as published by
# the Free Software Foundation; either version 2.1 of the License, or
# (at your option) any later version.
# This unit gets pulled automatically into multi-user.target by
# systemd-rc-local-generator if /etc/rc.local is executable.
[Unit]
Description=/etc/rc.local Compatibility
Documentation=man:systemd-rc-local-generator(8)
ConditionFileIsExecutable=/etc/rc.local
After=network.target
[Service]
Type=forking
ExecStart=/etc/rc.local start
TimeoutSec=0
RemainAfterExit=yes
GuessMainPID=no
[Install]
WantedBy=multi-user.target
Alias=rc-local.service
1) [Unit] 区块:启动顺序与依赖关系。
2) [Service] 区块:启动行为,如何启动,启动类型。
3) [Install] 区块,定义如何安装这个配置文件,即怎样做到开机启动。
2、创建/etc/rc.local文件
touch /etc/rc.local
3、赋可执行权限
chmod 755 /etc/rc.local
4、编辑rc.local,添加需要开机启动的任务
#!/bin/bash
echo "test rc " > /var/test.log
5、执行reboot重启系统,然后查看test.log
以下为rc.local 内容
#!/bin/sh -e
# rc.local
# This script is executed at the end of each multiuser runlevel.
# Make sure that the script will "exit 0" on success or any other
# value on error.
# In order to enable or disable this script just change the execution
# bits.
# By default this script does nothing.
sudo miredo
sudo /home/han/xx-net/xx_net.sh start
#sudo /home/han/xx-net/start
exit 0
18.04 开机启动(xx-net)解决方案
Re: 18.04 开机启动(xx-net)解决方案
你在18.04上怎么安装XX-net成功,我安装不成功,能否说下安装方法?
