安装好的ubuntu18.04出现内部错误如何解决?
linfkkk
系统: Ubuntu16.04
帖子 linfkkk » 2018-05-21 8:42
尝鲜新版本的Ubuntu,今天开机出现了内部错误。我是U盘启动在单个硬盘上安装的,使用全盘新装,LVM模式。看看高人解答下:具体见图片。
onlylove
Re: 安装好的ubuntu18.04出现内部错误如何解决?
帖子 onlylove » 2018-05-21 8:51
内部错误不是ubuntu的日常么
linfkkk
系统: Ubuntu16.04
帖子 linfkkk » 2018-05-21 9:29
onlylove 写了:内部错误不是ubuntu的日常么
开机到桌面出现一个错误报告对话框,本想着发送报告,失败。查看了详细情况,就出现这个内容了。
linfkkk
系统: Ubuntu16.04
帖子 linfkkk » 2018-05-21 9:32
linfkkk 写了:
08:10:03 kernel: rfkill: input handler disabled
08:09:35 kernel: IPv6: ADDRCONF(NETDEV_CHANGE): enp3s0: link becomes ready
08:09:35 kernel: r8169 0000:03:00.0 enp3s0: link up
08:09:35 kernel: usblp 3-2:1.0: usblp0: USB Bidirectional printer dev 3 if 0 alt 0 proto 2 vid 0x17EF pid 0x5425
08:09:35 kernel: usblp0: removed
08:09:33 kernel: IPv6: ADDRCONF(NETDEV_UP): enp3s0: link is not ready
08:09:33 kernel: r8169 0000:03:00.0 enp3s0: link down
08:09:29 kernel: audit: type=1400 audit(1526861369.034:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-soffice" pid=807 comm="apparmor_parser"
08:09:28 kernel: EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
08:09:27 kernel: Adding 999420k swap on /dev/mapper/ubuntu--vg-swap_1. Priority:-2 extents:1 across:999420k FS
08:09:27 kernel: input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input11
08:09:27 kernel: usbcore: registered new interface driver usblp
08:09:27 kernel: usblp 3-2:1.0: usblp0: USB Bidirectional printer dev 3 if 0 alt 0 proto 2 vid 0x17EF pid 0x5425
08:09:27 kernel: intel_rapl: RAPL package 0 domain dram locked by BIOS
08:09:27 kernel: kvm: disabled by bios
08:09:27 kernel: input: HDA Intel PCH Front Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input9
08:09:27 kernel: snd_hda_codec_realtek hdaudioC0D0: Line=0x1a
08:09:27 kernel: snd_hda_intel 0000:01:00.1: Handle vga_switcheroo audio client
08:09:27 kernel: RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
08:09:27 kernel: lpc_ich: Resource conflict(s) found affecting gpio_ich
08:09:27 kernel: ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
08:09:27 kernel: ACPI Warning: SystemIO range 0x0000000000001C00-0x0000000000001C2F conflicts with OpRegion 0x0000000000001C00-0x0000000000001FFF (\GPR) (20170831/utaddress-247)
08:09:27 kernel: ACPI Warning: SystemIO range 0x0000000000001C30-0x0000000000001C3F conflicts with OpRegion 0x0000000000001C00-0x0000000000001FFF (\GPR) (20170831/utaddress-247)
08:09:27 kernel: ACPI Warning: SystemIO range 0x0000000000001C40-0x0000000000001C4F conflicts with OpRegion 0x0000000000001C00-0x0000000000001FFF (\GPR) (20170831/utaddress-247)
08:09:27 kernel: ACPI Warning: SystemIO range 0x0000000000001828-0x000000000000182F conflicts with OpRegion 0x0000000000001800-0x000000000000187F (\PMIO) (20170831/utaddress-247)
08:09:27 kernel: shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
08:09:17 kernel: EXT4-fs (dm-1): re-mounted. Opts: errors=remount-ro
08:09:17 kernel: ppdev: user-space parallel port driver
08:09:17 kernel: lp: driver loaded but no devices found
08:09:17 kernel: Set up automount Arbitrary Executable File Formats File System Automount Point.
08:09:17 kernel: Listening on udev Kernel Socket.
08:09:17 kernel: Created slice system-systemd\x2dcryptsetup.slice.
08:09:17 kernel: Listening on LVM2 metadata daemon socket.
08:09:17 kernel: Created slice System Slice.
08:09:17 kernel: Set hostname to <linfox-Lenovo>.
08:09:17 kernel: Detected architecture x86-64.
08:09:17 kernel: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
08:09:17 kernel: ip_tables: (C) 2000-2006 Netfilter Core Team
08:09:17 kernel: EXT4-fs (dm-1): mounted filesystem with ordered data mode. Opts: (null)
08:09:17 kernel: NET: Registered protocol family 38
08:09:17 kernel: random: crng init done
08:09:17 kernel: clocksource: Switched to clocksource tsc
08:09:17 kernel: [drm] Initialized nouveau 1.3.1 20120801 for 0000:01:00.0 on minor 0
08:09:17 kernel: nouveau 0000:01:00.0: fb0: nouveaufb frame buffer device
08:09:17 kernel: Console: switching to colour frame buffer device 240x67
08:09:17 kernel: fbcon: nouveaufb (fb0) is primary device
08:09:17 kernel: nouveau 0000:01:00.0: DRM: allocated 1920x1080 fb: 0x60000, bo 0000000070f8bc05
帖子 poloshiao » 2018-05-21 9:57
今天开机出现了内部错误
1. 如果你說的內部錯誤是指 apport
這是 Ubuntu 預設的 抓錯機制 正常現象
目的 讓你及 Ubuntu 開發人員 知道你的系統 還有哪些錯誤存在
而這些錯誤 許多是小問題 不會立刻影響你的系統運作
有些錯誤 會隨著套件更新 迅速減少
當然 有時 也有大錯誤 影響你的系統正常運作
但是 新安裝時 太多錯誤報告 會讓新手 不明究理
把他的顯示功能暫時關閉 可以避免新手感到困擾
但是 關閉錯誤報告 並不代表錯誤消失了
你心裡準備好了 想看看 你的系統 還有沒有錯誤 你還是可以啟用錯誤報告
sudo cat /etc/default/apport | grep enabled
# enabled=1
# enabled=n n=0或1 表示僅供備忘 不起作用
enabled=0 表示 關閉錯誤報告
enabled=1 表示 啟用錯誤報告
enabled=0 或 enabled=1 只能設定一個
CharlesLee
系统: Ubuntu18.04
帖子 CharlesLee » 2018-05-31 12:54
:Adore 太正常了好吧~ 提交就行~
