检查您的网络连接。
细节:
W:The repository 'cdrom://Ubuntu 16.04.1 LTS _Xenial Xerus_ - Release amd64 (20160719) xenial Release' does not have a Release file., W:Data from such a repository can't be authenticated and is therefore potentially dangerous to use., W:See apt-secure(8) manpage for repository creation and user configuration details., W:Failed to fetch http://archive.canonical.com/ubuntu/dis ... /InRelease Cannot initiate the connection to archive.canonical.com:80 (2001:67c:1562::1c). - connect (101: Network is unreachable) [IP: 2001:67c:1562::1c 80], E:Failed to fetch cdrom://Ubuntu 16.04.1 LTS _Xenial Xerus_ - Release amd64 (20160719)/dists/xenial/main/binary-amd64/Packages Please use apt-cdrom to make this CD-ROM recognized by APT. apt-get update cannot be used to add new CD-ROMs, W:Some index files failed to download. They have been ignored, or old ones used instead.
看了网上有些需要修改文件的方法,不太敢尝试ORZ。。。。。
新手小白求助:下载软件仓库信息失败
- 系统: ubuntu16.04+win7
- 九天星
Re: 新手小白求助:下载软件仓库信息失败
看不懂你复制的一些什么东东。
分析:你应该是从VPS主机上复制下来的,将/etc/apt/sources.list关于CDROM的这一行,应该是第一行最前面加个#号注释掉就OK了。
九天星 写了:看不懂你复制的一些什么东东。
谢谢,我找到解决方法了,就是将
其他软件中所有的勾选都去掉就可以了。
