当我输入“sudo lsblk”时,显示:
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
sda 8:0 0 238.5G 0 disk
├─sda1 8:1 0 243M 0 part /boot
├─sda2 8:2 0 1K 0 part
└─sda5 8:5 0 238.2G 0 part
├─ubuntu--vg-root (dm-0) 252:0 0 222.3G 0 lvm /
└─ubuntu--vg-swap_1 (dm-1) 252:1 0 15.9G 0 lvm [SWAP]
sr0 11:0 1 1024M 0 rom
当我输入“sudo fdisk -l”时,它显示:
Disk /dev/sda: 256.1 GB, 256060514304 bytes
255 heads, 63 sectors/track, 31130 cylinders, total 500118192 sectors
Units = sectors of 1 * 512 = 512 bytes
Disk identifier: 0x00093873
Device Boot Start End Blocks Id System
/dev/sda1 * 2048 499711 248832 83 Linux
/dev/sda2 501758 500117503 249807873 5 Extended
Partition 2 does not start on physical sector boundary.
/dev/sda5 501760 500117503 249807872 8e Linux LVM
Disk /dev/mapper/ubuntu--vg-root: 238.7 GB, 238697840640 bytes
255 heads, 63 sectors/track, 29020 cylinders, total 466206720 sectors
Disk identifier: 0x00000000
Disk /dev/mapper/ubuntu--vg-root doesn't contain a valid partition table
Disk /dev/mapper/ubuntu--vg-swap_1: 17.1 GB, 17100177408 bytes
255 heads, 63 sectors/track, 2078 cylinders, total 33398784 sectors
Disk /dev/mapper/ubuntu--vg-swap_1 doesn't contain a valid partition table
