系统:win10
处理器:Intel i7-6700
台式机:DELL DESKTOP-13ORR7C
遇到的问题是这样的,想安装ubuntu 16.04桌面版,在F盘下压缩出来了100G的【未分配】空间。用U盘安装。
但是安装过程中的【新建分区表】按钮不能点,是灰色,而且除了U盘的空间以外,没有识别到硬盘。求大神指教!
我的分区是这样的:
[img]file:///F:/fen.htm[/img]
在try ubuntu下输入sudo fdisk -l和sudo parted -l,结果如下:
ubuntu@ubuntu:~$ sudo fdisk -l
Disk /dev/ram0: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram1: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram2: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram3: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram4: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram5: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram6: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram7: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram8: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram9: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram10: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram11: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram12: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram13: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram14: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram15: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/loop0: 1.4 GiB, 1497772032 bytes, 2925336 sectors
Disk /dev/sda: 1.8 TiB, 2000398934016 bytes, 3907029168 sectors
Disklabel type: dos
Disk identifier: 0x65628abb
/dev/sda1 1 4294967295 4294967295 2T ee GPT
Partition 1 does not start on physical sector boundary.
Disk /dev/sdb: 29.8 GiB, 32017047552 bytes, 62533296 sectors
Disk /dev/sdc: 57.8 GiB, 62008590336 bytes, 121110528 sectors
Disklabel type: dos
Disk identifier: 0x15e2543d
/dev/sdc1 * 0 3035519 3035520 1.5G 0 Empty
/dev/sdc2 14432 19295 4864 2.4M ef EFI (FAT-12/16/32)
ubuntu@ubuntu:~$ sudo parted /dev/sda print
Error: /dev/sda: unrecognised disk label
Model: ATA TOSHIBA DT01ACA2 (scsi)
Disk /dev/sda: 2000GB
Partition Table: unknown
Disk Flags:
ubuntu@ubuntu:~$ sudo parted -l
Disk Flags:
Error: /dev/sdb: unrecognised disk label
Model: ATA TOSHIBA THNSNX03 (scsi)
Disk /dev/sdb: 32.0GB
Disk Flags:
Warning: The driver descriptor says the physical block size is 2048 bytes, but
Linux says it is 512 bytes.
Ignore/Cancel? ^C
Model: Kingston DataTraveler 3.0 (scsi)
Disk /dev/sdc: 62.0GB
Disk Flags:
【求助】win10下安装ubuntu,无法新建新建分区表,不识别硬盘空间,只能识别U盘
- 系统: ubuntu 16.04
Re: 【求助】win10下安装ubuntu,无法新建新建分区表,不识别硬盘空间,只能识别U盘
你在windows下面的磁盘管理工具里看一下,是不是弄成动态磁盘了。如果是的话,那是安装不了的。必须先用第三方工具转换回基本磁盘才行
- 系统: win10
楼主安装好了吗?我也是一样的问题,不知道该怎么解决了,想请教一下楼主呀
