我尝试自己修改vmx文件,但是没有成功,所以尝试新建一个虚拟机,使用现有的虚拟磁盘文件,发现可以开机,但是打开之后一直卡在recovering journal的页面,无法再进一步
里面的数据对我至关重要,如果能提供有效的解决方法,我愿意付费
vmx文件和vmdk文件似乎是不允许上传的,我就在这里贴出来吧
SatLab.vmx文件
.encoding = "GBK"
config.version = "8"
virtualHW.version = "12"
numvcpus = "4"
cpuid.coresPerSocket = "4"
vcpu.hotadd = "TRUE"
scsi0.present = "TRUE"
scsi0.virtualDev = "lsilogic"
sata0.present = "TRUE"
memsize = "6208"
mem.hotadd = "TRUE"
scsi0:0.present = "TRUE"
scsi0:0.fileName = "SatLab.vmdk"
sata0:0.present = "FALSE"
sata0:0.fileName = "auto detect"
sata0:0.deviceType = "cdrom-raw"
sata0:1.present = "TRUE"
sata0:1.fileName = "auto detect"
sata0:1.deviceType = "cdrom-raw"
floppy0.fileType = "device"
floppy0.fileName = ""
floppy0.clientDevice = "FALSE"
ethernet0.present = "TRUE"
ethernet0.connectionType = "bridged"
ethernet0.virtualDev = "e1000"
ethernet0.wakeOnPcktRcv = "FALSE"
ethernet0.addressType = "generated"
usb.present = "TRUE"
ehci.present = "TRUE"
ehci.pciSlotNumber = "35"
sound.present = "TRUE"
sound.fileName = "-1"
sound.autodetect = "TRUE"
mks.enable3d = "TRUE"
svga.graphicsMemoryKB = "786432"
serial0.present = "TRUE"
serial0.fileType = "thinprint"
pciBridge0.present = "TRUE"
pciBridge4.present = "TRUE"
pciBridge4.virtualDev = "pcieRootPort"
pciBridge4.functions = "8"
pciBridge5.present = "TRUE"
pciBridge5.virtualDev = "pcieRootPort"
pciBridge5.functions = "8"
pciBridge6.present = "TRUE"
pciBridge6.virtualDev = "pcieRootPort"
pciBridge6.functions = "8"
pciBridge7.present = "TRUE"
pciBridge7.virtualDev = "pcieRootPort"
pciBridge7.functions = "8"
vmci0.present = "TRUE"
hpet0.present = "TRUE"
usb.vbluetooth.startConnected = "TRUE"
displayName = "SatLab"
guestOS = "ubuntu-64"
nvram = "SatLab.nvram"
virtualHW.productCompatibility = "hosted"
powerType.powerOff = "soft"
powerType.powerOn = "soft"
powerType.suspend = "soft"
powerType.reset = "soft"
extendedConfigFile = "SatLab.vmxf"
uuid.bios = ""
uuid.location = ""
migrate.hostlog = ".\SatLab-aeacc47a.hlog"
scsi0:0.redo = ""
pciBridge0.pciSlotNumber = "17"
pciBridge4.pciSlotNumber = "21"
pciBridge5.pciSlotNumber = "22"
pciBridge6.pciSlotNumber = "23"
pciBridge7.pciSlotNumber = "24"
scsi0.pciSlotNumber = "16"
usb.pciSlotNumber = "32"
ethernet0.pciSlotNumber = "33"
sound.pciSlotNumber = "34"
vmci0.pciSlotNumber = "36"
sata0.pciSlotNumber = "37"
ethernet0.generatedAddress = "00:0C:29:F1:44:47"
ethernet0.generatedAddressOffset = "0"
vmci0.id = "49366087"
monitor.phys_bits_used = "42"
vmotion.checkpointFBSize = "4194304"
vmotion.checkpointSVGAPrimarySize = "33554432"
cleanShutdown = "TRUE"
softPowerOff = "TRUE"
usb:1.speed = "2"
usb:1.present = "TRUE"
usb:1.deviceType = "hub"
usb:1.port = "1"
usb:1.parent = "-1"
svga.guestBackedPrimaryAware = "TRUE"
tools.syncTime = "FALSE"
floppy0.autodetect = "TRUE"
sata0:0.autodetect = "TRUE"
sata0:1.autodetect = "TRUE"
tools.remindInstall = "FALSE"
toolsInstallManager.updateCounter = "1"
toolsInstallManager.lastInstallError = "0"
ethernet0.linkStatePropagation.enable = "TRUE"
gui.exitOnCLIHLT = "TRUE"
gui.lastPoweredViewMode = "fullscreen"
floppy0.present = "FALSE"
usb:0.present = "TRUE"
usb:0.deviceType = "hid"
usb:0.port = "0"
usb:0.parent = "-1"
sata0:1.startConnected = "FALSE"
vc.uuid = ""
policy.vm.mvmtid = ""
inVMTeam = "FALSE"
SatLab.vmdk文件
# Disk DescriptorFile
version=1
encoding="GBK"
CID=4447dc0f
parentCID=ffffffff
isNativeSnapshot="no"
createType="twoGbMaxExtentSparse"
# Extent description
RW 8323072 SPARSE "SatLab-000001-s001.vmdk"
RW 8323072 SPARSE "SatLab-000001-s002.vmdk"
RW 8323072 SPARSE "SatLab-000001-s003.vmdk"
RW 8323072 SPARSE "SatLab-000001-s004.vmdk"
RW 8323072 SPARSE "SatLab-000001-s005.vmdk"
RW 8323072 SPARSE "SatLab-000001-s006.vmdk"
RW 8323072 SPARSE "SatLab-000001-s007.vmdk"
RW 8323072 SPARSE "SatLab-000001-s008.vmdk"
RW 8323072 SPARSE "SatLab-000001-s009.vmdk"
RW 8323072 SPARSE "SatLab-000001-s010.vmdk"
RW 8323072 SPARSE "SatLab-000001-s011.vmdk"
RW 8323072 SPARSE "SatLab-000001-s012.vmdk"
RW 8323072 SPARSE "SatLab-000001-s013.vmdk"
RW 8323072 SPARSE "SatLab-000001-s014.vmdk"
RW 8323072 SPARSE "SatLab-000001-s015.vmdk"
RW 8323072 SPARSE "SatLab-000001-s016.vmdk"
RW 8323072 SPARSE "SatLab-000001-s017.vmdk"
RW 8323072 SPARSE "SatLab-000001-s018.vmdk"
RW 8323072 SPARSE "SatLab-000001-s019.vmdk"
RW 8323072 SPARSE "SatLab-000001-s020.vmdk"
RW 8323072 SPARSE "SatLab-000001-s021.vmdk"
RW 8323072 SPARSE "SatLab-000001-s022.vmdk"
RW 8323072 SPARSE "SatLab-000001-s023.vmdk"
RW 8323072 SPARSE "SatLab-000001-s024.vmdk"
RW 8323072 SPARSE "SatLab-000001-s025.vmdk"
RW 1638400 SPARSE "SatLab-000001-s026.vmdk"
# The Disk Data Base
#DDB
ddb.adapterType = "lsilogic"
ddb.deletable = "true"
ddb.geometry.cylinders = "13054"
ddb.geometry.heads = "255"
ddb.geometry.sectors = "63"
ddb.longContentID = "0ae4a03c77d7e31edcedd3ca941c6b94"
ddb.toolsInstallType = "4"
ddb.toolsVersion = "10247"
ddb.uuid = "60 00 C2 9d 49 8e d7 da-c6 6a 4a 7e 5f ea b4 a4"
ddb.virtualHWVersion = "12"
version=1
encoding="GBK"
CID=1fd89250
parentCID=4447dc0f
parentFileNameHint="G:\huifu\Recovered1\SatLab\SatLab.vmdk"
#DDB
ddb.longContentID = "94b615280e58fb0698624b161fd89250"
