連 synaptic 也不能用,一启动synaptic就报告adobe-flashplugin有问题,然后就退出.
总是提示重新安装该软件包才能remove, 疯了.
sudo apt-get install remove --purge adobe-flashplugin
Reading package lists... Done
Building dependency tree
E: The package adobe-flashplugin needs to be reinstalled, but I can't find an archive for it.
sudo dpkg -i adobe-flashplugin_10.0.12.36-1hardy1_i386.deb
(Reading database ... 123136 files and directories currently installed.)
Preparing to replace adobe-flashplugin 10.0.12.36-1hardy1 (using adobe-flashplugin_10.0.12.36-1hardy1_i386.deb) ...
update-alternatives: error: no alternatives for iceape-flashplugin.
dpkg: warning: old pre-removal script returned error exit status 2
dpkg - trying script from the new package instead ...
dpkg: error processing adobe-flashplugin_10.0.12.36-1hardy1_i386.deb (--install):
subprocess new pre-removal script returned error exit status 2
postinst called with argument `abort-upgrade'
dpkg: error while cleaning up:
subprocess installed post-installation script returned error exit status 1
sudo dpkg -r --force-all adobe-flashplugin
dpkg: warning: overriding problem because --force enabled:
Package is in a very bad inconsistent state - you should
reinstall it before attempting a removal.
(Reading database ... 123135 files and directories currently installed.)
Removing adobe-flashplugin ...
dpkg: error processing adobe-flashplugin (--remove):
subprocess installed pre-removal script returned error exit status 2
postinst called with argument `abort-remove'
adobe-flashplugin
sudo apt-get -f install
