Manju丶saka
- 系统: Ubuntu15.10
帖子
由 Manju丶saka » 2016-05-25 19:01
官网下载的ubuntu16.04(64位)版本的网易云音乐
sudo dpkg --install netease-cloud-music_0.9.0-2_amd64.deb
Selecting previously unselected package netease-cloud-music.
(Reading database ... 219710 files and directories currently installed.)
Preparing to unpack netease-cloud-music_0.9.0-2_amd64.deb ...
Unpacking netease-cloud-music (0.9.0-1) ...
dpkg: dependency problems prevent configuration of netease-cloud-music:
netease-cloud-music depends on libqt5multimedia5-plugins; however:
Package libqt5multimedia5-plugins is not installed.
netease-cloud-music depends on libqt5libqgtk2; however:
Package libqt5libqgtk2 is not installed.
dpkg: error processing package netease-cloud-music (--install):
Processing triggers for gnome-menus (3.13.3-6ubuntu3) ...
Processing triggers for desktop-file-utils (0.22-1ubuntu5) ...
Processing triggers for bamfdaemon (0.5.3~bzr0+16.04.20160415-0ubuntu1) ...
Rebuilding /usr/share/applications/bamf-2.index...
Processing triggers for mime-support (3.59ubuntu1) ...
Processing triggers for hicolor-icon-theme (0.15-0ubuntu1) ...
netease-cloud-music
按照提示安装 libqt5multimedia5-plugins,然后:
sudo apt-get install libqt5multimedia5-plugins
Reading package lists... Done
Building dependency tree
You might want to run 'apt-get -f install' to correct these:
libqt5multimedia5-plugins : Depends: libqt5multimedia5 (= 5.4.2-1ubuntu3) but 5.5.1-4ubuntu2 is to be installed
Depends: libgstreamer-plugins-base0.10-0 (>= 0.10.32) but it is not going to be installed
Depends: libgstreamer0.10-0 (>= 0.10.33) but it is not going to be installed
Depends: libqgsttools-p1 (>= 5.4.0) but it is not going to be installed
netease-cloud-music : Depends: libqt5libqgtk2 but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
一直在Linux上找不到好用的听歌软件,现在有了却装不上,好郁闷.
跪求大牛指导....
[已解决] 问题出在源上,一开是用的是cn99(网易)的源,后来改成aliyun(阿里)就直接安装成功了.
Manju丶saka
- 系统: Ubuntu15.10
帖子
由 Manju丶saka » 2016-05-25 19:44
试过了,结果就是把相关的配置文件全部删掉了.然后重装依然是这样.
Manju丶saka
- 系统: Ubuntu15.10
帖子
由 Manju丶saka » 2016-05-25 19:51
sudo apt-get -f install
Correcting dependencies... Done
The following packages will be REMOVED:
netease-cloud-music
0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
1 not fully installed or removed.
After this operation, 112 MB disk space will be freed.
(Reading database ... 219781 files and directories currently installed.)
Removing netease-cloud-music (0.9.0-1) ...
- 系统: Winbuntu
- 来自: 志虚国乌由市
帖子
由 qy117121 » 2016-05-25 19:51
二楼命令少了一位
dpkg -i 命令安装deb包不会自动安装依赖,所以要用上面的命令修复依赖
我更推荐用gdebi 安装deb包,会自动安装依赖的软件包
Manju丶saka
- 系统: Ubuntu15.10
帖子
由 Manju丶saka » 2016-05-25 22:06
qy117121 写了:二楼命令少了一位
使用gdebi得到的也是一样的结果.
sudo gdebi netease-cloud-music_0.9.0-2_amd64.deb
netease cloud music player.
Do you want to install the software package? [y/N]:y
(Reading database ... 220641 files and directories currently installed.)
netease-cloud-music
Manju丶saka
- 系统: Ubuntu15.10
帖子
由 Manju丶saka » 2016-05-25 23:45
steley 写了:用apt把
和
安装之后再安装呢
在1楼已经贴出过了,安装不了.
其实一开始是显示了好多依赖需要安装的,我一个个都安装了,只剩下这两个没法安装的.
- 系统: Winbuntu
- 来自: 志虚国乌由市
帖子
由 qy117121 » 2016-05-26 9:13
建议楼主先执行下sudo apt update 再安装
- 系统: Winbuntu
- 来自: 志虚国乌由市
帖子
由 qy117121 » 2016-05-26 9:15
我特地卸载了一个依赖,再重装云音乐
需要安装以下软件包: libcue1 libqgsttools-p1 libqt5multimedia5-plugins
您是否想安装这个软件包?[y/N]:y
0% [正在连接 cn.archive.ubuntu.com] 0% [正在连接 cn.archive.ubuntu.com (112.124.140.210)] 0% [正在等待报头] Get:1 http://cn.archive.ubuntu.com/ubuntu xenial/universe amd64 libcue1 amd64 1.4.0-1 [25.2 kB]
9% [正在等待报头] Get:2 http://cn.archive.ubuntu.com/ubuntu xenial/main amd64 libqgsttools-p1 amd64 5.5.1-4ubuntu2 [65.4 kB]
34% [正在等待报头] Get:3 http://cn.archive.ubuntu.com/ubuntu xenial/main amd64 libqt5multimedia5-plugins amd64 5.5.1-4ubuntu2 [175 kB]
Fetched 266 kB in 0s (0 B/s)
正在选中未选择的软件包 libcue1。
(正在读取数据库 ... 系统当前共安装有 245461 个文件和目录。)
正准备解包 .../libcue1_1.4.0-1_amd64.deb ...
正在解包 libcue1 (1.4.0-1) ...
正在选中未选择的软件包 libqgsttools-p1:amd64。
正准备解包 .../libqgsttools-p1_5.5.1-4ubuntu2_amd64.deb ...
正在解包 libqgsttools-p1:amd64 (5.5.1-4ubuntu2) ...
正在选中未选择的软件包 libqt5multimedia5-plugins:amd64。
正准备解包 .../libqt5multimedia5-plugins_5.5.1-4ubuntu2_amd64.deb ...
正在解包 libqt5multimedia5-plugins:amd64 (5.5.1-4ubuntu2) ...
正在处理用于 libc-bin (2.23-0ubuntu3) 的触发器 ...
正在设置 libcue1 (1.4.0-1) ...
正在设置 libqgsttools-p1:amd64 (5.5.1-4ubuntu2) ...
正在设置 libqt5multimedia5-plugins:amd64 (5.5.1-4ubuntu2) ...
正在选中未选择的软件包 netease-cloud-music。
(正在读取数据库 ... 系统当前共安装有 245488 个文件和目录。)
正准备解包 netease-cloud-music_0.9.0-2_amd64.deb ...
正在解包 netease-cloud-music (0.9.0-1) ...
正在设置 netease-cloud-music (0.9.0-1) ...
正在处理用于 bamfdaemon (0.5.3~bzr0+16.04.20160415-0ubuntu1) 的触发器 ...
正在处理用于 desktop-file-utils (0.22-1ubuntu5) 的触发器 ...
正在处理用于 gnome-menus (3.13.3-6ubuntu3) 的触发器 ...
正在处理用于 mime-support (3.59ubuntu1) 的触发器 ...
正在处理用于 hicolor-icon-theme (0.15-0ubuntu1) 的触发器 ...
chole
帖子
由 chole » 2016-05-26 9:33
我也是这个问题
Manju丶saka
- 系统: Ubuntu15.10
帖子
由 Manju丶saka » 2016-05-26 12:25
qy117121 写了:我特地卸载了一个依赖,再重装云音乐
您是否想安装这个软件包?[y/N]:y
之前就执行过 sudo apt-get update了,但是仍然装不上.问题就在于 libqt5multimedia5-plugins 和 libqt5libqgtk2 装不上.
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
E: Unable to correct problems, you have held broken packages.
sudo apt-get install libqt5libqgtk2
libqt5libqgtk2 : Depends: libqt5gui5 (= 5.4.2+dfsg-2ubuntu9) but 5.5.1+dfsg-16ubuntu7 is to be installed
Depends: qtbase-abi-5-4-2
看上面的提示好像是因为libqt5gui5的问题,它需要5.4.2+dfsg-2ubuntu9版本的,但是电脑中已经装了的是5.5.1+dfsg-16ubuntu7版本的.我倒是想把后者卸载了,装前者.但是一来不知道它的作用,担心系统出问题,二来,也不知道怎么安转5.4.2+dfsg-2ubuntu9版本.
- 系统: Winbuntu
- 来自: 志虚国乌由市
帖子
由 qy117121 » 2016-05-26 12:42
把 /etc/apt/sources.list 内容贴上来看下
Manju丶saka
- 系统: Ubuntu15.10
帖子
由 Manju丶saka » 2016-05-26 14:03
qy117121 写了:把 /etc/apt/sources.list 内容贴上来看下
# deb cdrom:[Ubuntu 16.04 LTS _Xenial Xerus_ - Release amd64 (20160420.1)]/ xenial main restricted
# See http://help.ubuntu.com/community/UpgradeNotes for how to upgrade to
# newer versions of the distribution.
deb http://ubuntu.cn99.com/ubuntu/ xenial main restricted
# deb-src http://cn.archive.ubuntu.com/ubuntu/ xenial main restricted
## Major bug fix updates produced after the final release of the
## distribution.
deb http://ubuntu.cn99.com/ubuntu/ xenial-updates main restricted
# deb-src http://cn.archive.ubuntu.com/ubuntu/ xenial-updates main restricted
## N.B. software from this repository is ENTIRELY UNSUPPORTED by the Ubuntu
## team, and may not be under a free licence. Please satisfy yourself as to
## your rights to use the software. Also, please note that software in
## universe WILL NOT receive any review or updates from the Ubuntu security
## team.
deb http://ubuntu.cn99.com/ubuntu/ xenial universe
# deb-src http://cn.archive.ubuntu.com/ubuntu/ xenial universe
deb http://ubuntu.cn99.com/ubuntu/ xenial-updates universe
# deb-src http://cn.archive.ubuntu.com/ubuntu/ xenial-updates universe
## multiverse WILL NOT receive any review or updates from the Ubuntu
## security team.
deb http://ubuntu.cn99.com/ubuntu/ xenial multiverse
# deb-src http://cn.archive.ubuntu.com/ubuntu/ xenial multiverse
deb http://ubuntu.cn99.com/ubuntu/ xenial-updates multiverse
# deb-src http://cn.archive.ubuntu.com/ubuntu/ xenial-updates multiverse
## N.B. software from this repository may not have been tested as
## extensively as that contained in the main release, although it includes
## newer versions of some applications which may provide useful features.
## Also, please note that software in backports WILL NOT receive any review
## or updates from the Ubuntu security team.
deb http://ubuntu.cn99.com/ubuntu/ xenial-backports main restricted universe multiverse
# deb-src http://cn.archive.ubuntu.com/ubuntu/ xenial-backports main restricted universe multiverse
## Uncomment the following two lines to add software from Canonical's
## 'partner' repository.
## This software is not part of Ubuntu, but is offered by Canonical and the
## respective vendors as a service to Ubuntu users.
# deb http://archive.canonical.com/ubuntu xenial partner
# deb-src http://archive.canonical.com/ubuntu xenial partner
deb http://ubuntu.cn99.com/ubuntu/ xenial-security main restricted
# deb-src http://security.ubuntu.com/ubuntu xenial-security main restricted
deb http://ubuntu.cn99.com/ubuntu/ xenial-security universe
# deb-src http://security.ubuntu.com/ubuntu xenial-security universe
deb http://ubuntu.cn99.com/ubuntu/ xenial-security multiverse
# deb-src http://security.ubuntu.com/ubuntu xenial-security multiverse
