#include <stdio.h>
#include <unistd.h>
#define MAX_LINE 80 /* 80 chars per line, per command, should be enough. */
* setup() reads in the next command line, separating it into distinct tokens
* using whitespace as delimiters. setup() sets the args parameter as a
* null-terminated string.
void setup(char inputBuffer[], char *args[],int *background)
int length, /* # of characters in the command line */
i, /* loop index for accessing inputBuffer array */
start, /* index where beginning of next command parameter is */
ct; /* index of where to place the next parameter into args[] */
ct = 0;
/* read what the user enters on the command line */
length = read(STDIN_FILENO, inputBuffer, MAX_LINE);
start = -1;
if (length == 0)
exit(0); /* ^d was entered, end of user command stream */
if (length < 0){
perror("error reading the command");
exit(-1); /* terminate with error code of -1 */
/* examine every character in the inputBuffer */
for (i=0;i<length;i++) {
switch (inputBuffer[i]){
case ' ':
case '\t' : /* argument separators */
if(start != -1){
args[ct] = &inputBuffer[start]; /* set up pointer */
ct++;
inputBuffer[i] = '\0'; /* add a null char; make a C string */
start = -1;
break;
case '\n': /* should be the final char examined */
if (start != -1){
ct++;
args[ct] = NULL; /* no more arguments to this command */
break;
default : /* some other character */
if (start == -1)
start = i;
if (inputBuffer[i] == '&'){
*background = 1;
args[ct] = NULL; /* just in case the input line was > 80 */
int main(void)
char inputBuffer[MAX_LINE]; /* buffer to hold the command entered */
int background; /* equals 1 if a command is followed by '&' */
char *args[MAX_LINE/2+1];/* command line (of 80) has max of 40 arguments */
while (1){ /* Program terminates normally inside setup */
background = 0;
printf("COMMAND->\n");
// printf("COMMAND->");
// cout<<"COMMAND->";
setup(inputBuffer,args,&background); /* get next command */
int pid = fork();
if(pid == 0){
execvp(args[0], args);
else{
if(!background)
waitpid(pid, NULL, 0)
else{
setup(args[0], args, background);
/* the steps are:
(1) fork a child process using fork()
(2) the child process will invoke execvp()
(3) if background == 0, the parent will wait,
otherwise returns to the setup() function. */
g++ -o shell shell_my.c
./shell
发现只有在printf("COMMAND->\n")时,屏幕上才会每次打出COMMAND,然后另起一行输入命令;如果是被注释掉的另外两种写法,就什么也不显示,直接输入指令,只在退出时(即按ctrl+d时)会连续打印出与之前输入指令相同数目的COMMAND,请问这是为什么?本人新手。
