sudo apt-get install virtual-box后
virtual-box 安装debian 显示no bootable mideum found
我用的是debian-8.5.0-amd64-DVD-3.iso
apt下载virtualbox-dbg 显示:有一些软件包无法被安装。如果您用的是 unstable 发行版,这也许是
包尚未被创建或是它们已被从新到(Incoming)目录移出。
下列信息可能会对解决问题有所帮助:
下列软件包有未满足的依赖关系:
virtualbox-dbg : 依赖: virtualbox (= 5.0.18-dfsg-2ubuntu1) 但是 5.0.24-dfsg-0ubuntu1.16.04.1 正要被安装 或virtualbox-guest-utils (= 5.0.18-dfsg-2ubuntu1) 但是它将不会被安装
E: 无法修正错误,因为您要求某些软件包保持现状,就是它们破坏了软件包间的依赖关系
执行dpkg -l | grep virtualbox
结果是:
ii unity-scope-virtualbox 0.1+13.10.20130723-0ubuntu1 all VirtualBox scope for Unity
ii virtualbox 5.0.24-dfsg-0ubuntu1.16.04.1 amd64 x86 virtualization solution - base binaries
ii virtualbox-dkms 5.0.24-dfsg-0ubuntu1.16.04.1 all x86 virtualization solution - kernel module sources for dkms
ii virtualbox-qt 5.0.24-dfsg-0ubuntu1.16.04.1 amd64 x86 virtualization solution - Qt based user interface
virtualbox无法启动debian,apt无法下载virtualbox-dbg????????
上次由 hanis_ghost 在 2016-07-25 9:56,总共编辑 2 次。
Re: virtualbox无法启动debian,apt无法下载virtualbox-dbg????????
详细描述需求 打算在 vbox 中安装 debian / 使用已有的 debian 镜像?hanis_ghost 写了:virtual-box显示no bootable mideum found
什么原因 要使用 virtualbox-dbghanis_ghost 写了:apt下载virtualbox-dbg
参考 https://wiki.ubuntu.com/Debug%20Symbol%20Packages
详细描述 当初如何安装的 vbox?hanis_ghost 写了:virtualbox-dbg : 依赖: virtualbox (= 5.0.18-dfsg-2ubuntu1) 但是 5.0.24-dfsg-0ubuntu1.16.04.1 正要被安装
执行以下指令将结果全部复制贴上来
真搞笑,你下载时都不看说明的么?
http://cdimage.debian.org/debian-cd/8.5 ... 4/iso-dvd/
Initially, you will only need to download and use the first image of a set (labelled as debian-something-1 to be able to start the Debian installer and set up Debian on your computer. If there are more images available here (labelled debian-something-2, debian-something-3, etc.), they contain the extra packages that can be installed on a Debian system (as mentioned previously). They will not be bootable and are entirely optional. If you have a fast Internet connection, you're most likely better off installing any desired extra packages directly from the Debian mirrors on the Internet instead of by using these extra images.
增加新信息时建议跟帖说明,否则先前回复过的网友不易发现。hanis_ghost 写了:最后由 hanis_ghost 编辑于 2016-07-25 9:56,总共编辑了 2 次
仅 *DVD-1.iso, *CD-1.iso 可引导。后面的不可引导。hanis_ghost 写了:我用的是debian-8.5.0-amd64-DVD-3.iso
可能原因 系统无法达到您要求的状态。该版本中可能会有一些您需要的软件包(virtualbox-dbg 5.0.24)尚未被创建。hanis_ghost 写了:这也许是因为系统无法达到您要求的状态造成的。该版本中可能会有一些您需要的软件
xenial-updates 中 virtualbox 版本已经为 5.0.24,尚没有对应的 virtualbox-dbg
若的确要使用 virtualbox-dbg,只能将 virtualbox 降级回 5.0.18 以求得与 virtualbox-dbg 的匹配
或从 https://launchpad.net/ubuntu/+source/virtualbox 获取对应的 virtualbox-dbg 5.0.24
