kashu
- 系统: Xubuntu 14.04.5 64位
帖子
由 kashu » 2016-04-24 20:11
每次升级完VirtualBox后,都得手动下载更新新的Extention,好麻烦……
VirtualBox中,这两个软件包有什么区别?
http://download.virtualbox.org/virtualbox/5.0.18
Oracle_VM_VirtualBox_Extension_Pack-5.0.18-106667.vbox-extpack 18-Apr-2016 15:47 16M
Oracle_VM_VirtualBox_Extension_Pack-5.0.18.vbox-extpack 18-Apr-2016 15:47 16M
[/size]
vickycq
帖子
由 vickycq » 2016-04-24 20:25
内部人士的解释:
https://forums.virtualbox.org/viewtopic ... 13#p301435
是符号链接
klaus 写了:loukingjr 写了:
It's a little late for me to ask this since I've been using VirtualBox for 5+ years but, what is the difference, if any, between Oracle_VM_VirtualBox_Extension_Pack-4.3.18.vbox-extpack and Oracle_VM_VirtualBox_Extension_Pack-4.3.18-46516.vbox-extpack? There are always two Extension Pack files and they both are the same size and both work. Just curious why there is always two.
Rather easy to explain: we started with a version-revision combination like we always used for package naming. Then it turned out that it's not terribly clever in this case, as the GUI can download extpack updates, and if it's a build from the public repository it uses different revisions. So such builds couldn't know the revision. So we introduced
a symlink on the download server which doesn't have the revision part... the two are always identical.
kashu
帖子
由 kashu » 2016-04-24 20:26
谢谢,原来是这样……
