求助ubuntu14.10升级成15.04后vmware不能启动
sli99213
帖子 sli99213 » 2015-05-05 10:24
提示“several modules must be complied and loaded into the running kernel"
按照提示升级后报错“Unable to start services" "see log file"
以下为log
2015-05-05T10:10:07.390+08:00| vthread-3| I120: Log for VMware Workstation pid=3946 version=10.0.5 build=build-2443746 option=Release
2015-05-05T10:10:07.390+08:00| vthread-3| I120: The process is 32-bit.
2015-05-05T10:10:07.390+08:00| vthread-3| I120: Host codepage=UTF-8 encoding=UTF-8
2015-05-05T10:10:07.390+08:00| vthread-3| I120: Host is Linux 3.19.0-15-generic Ubuntu 15.04
2015-05-05T10:10:07.390+08:00| vthread-3| I120: Msg_Reset:
2015-05-05T10:10:07.390+08:00| vthread-3| I120: [msg.dictionary.load.openFailed] Cannot open file "/usr/lib/vmware/settings": 没有那个文件或目录.
2015-05-05T10:10:07.390+08:00| vthread-3| I120: ----------------------------------------
2015-05-05T10:10:07.390+08:00| vthread-3| I120: PREF Optional preferences file not found at /usr/lib/vmware/settings. Using default values.
2015-05-05T10:10:07.390+08:00| vthread-3| I120: [msg.dictionary.load.openFailed] Cannot open file "/root/.vmware/config": 没有那个文件或目录.
2015-05-05T10:10:07.390+08:00| vthread-3| I120: PREF Optional preferences file not found at /root/.vmware/config. Using default values.
2015-05-05T10:10:07.390+08:00| vthread-3| I120: PREF Unable to check permissions for preferences file.
2015-05-05T10:10:07.390+08:00| vthread-3| I120: [msg.dictionary.load.openFailed] Cannot open file "/root/.vmware/preferences": 没有那个文件或目录.
2015-05-05T10:10:07.390+08:00| vthread-3| I120: PREF Failed to load user preferences.
2015-05-05T10:10:07.391+08:00| vthread-3| W110: Logging to /tmp/vmware-root/vmware-modconfig-3946.log
2015-05-05T10:10:07.407+08:00| vthread-3| I120: Obtaining info using the running kernel.
2015-05-05T10:10:07.407+08:00| vthread-3| I120: Created new pathsHash.
2015-05-05T10:10:07.408+08:00| vthread-3| I120: Setting header path for 3.19.0-15-generic to "/lib/modules/3.19.0-15-generic/build/include".
2015-05-05T10:10:07.408+08:00| vthread-3| I120: Validating path "/lib/modules/3.19.0-15-generic/build/include" for kernel release "3.19.0-15-generic".
2015-05-05T10:10:07.408+08:00| vthread-3| I120: Failed to find /lib/modules/3.19.0-15-generic/build/include/linux/version.h
2015-05-05T10:10:07.408+08:00| vthread-3| I120: /lib/modules/3.19.0-15-generic/build/include/linux/version.h not found, looking for generated/uapi/linux/version.h instead.
2015-05-05T10:10:07.408+08:00| vthread-3| I120: using /usr/bin/gcc-4.9 for preprocess check
2015-05-05T10:10:07.419+08:00| vthread-3| I120: Preprocessed UTS_RELEASE, got value "3.19.0-15-generic".
2015-05-05T10:10:07.419+08:00| vthread-3| I120: The header path "/lib/modules/3.19.0-15-generic/build/include" for the kernel "3.19.0-15-generic" is valid. Whoohoo!
2015-05-05T10:10:07.560+08:00| vthread-3| I120: found symbol version file /lib/modules/3.19.0-15-generic/build/Module.symvers
2015-05-05T10:10:07.560+08:00| vthread-3| I120: Reading symbol versions from /lib/modules/3.19.0-15-generic/build/Module.symvers.
2015-05-05T10:10:07.605+08:00| vthread-3| I120: Read 18827 symbol versions
2015-05-05T10:10:07.606+08:00| vthread-3| I120: Reading in info for the vmmon module.
2015-05-05T10:10:07.606+08:00| vthread-3| I120: Reading in info for the vmnet module.
2015-05-05T10:10:07.606+08:00| vthread-3| I120: Reading in info for the vmblock module.
2015-05-05T10:10:07.606+08:00| vthread-3| I120: Reading in info for the vmci module.
2015-05-05T10:10:07.606+08:00| vthread-3| I120: Reading in info for the vsock module.
2015-05-05T10:10:07.606+08:00| vthread-3| I120: Setting vsock to depend on vmci.
2015-05-05T10:10:07.606+08:00| vthread-3| I120: Invoking modinfo on "vmmon".
2015-05-05T10:10:07.609+08:00| vthread-3| I120: "/sbin/modinfo" exited with status 0.
2015-05-05T10:10:07.609+08:00| vthread-3| I120: Invoking modinfo on "vmnet".
2015-05-05T10:10:07.612+08:00| vthread-3| I120: "/sbin/modinfo" exited with status 256.
2015-05-05T10:10:07.612+08:00| vthread-3| I120: Invoking modinfo on "vmblock".
2015-05-05T10:10:07.615+08:00| vthread-3| I120: "/sbin/modinfo" exited with status 256.
2015-05-05T10:10:07.615+08:00| vthread-3| I120: Invoking modinfo on "vmci".
2015-05-05T10:10:07.619+08:00| vthread-3| I120: "/sbin/modinfo" exited with status 256.
2015-05-05T10:10:07.619+08:00| vthread-3| I120: Invoking modinfo on "vsock".
2015-05-05T10:10:07.622+08:00| vthread-3| I120: "/sbin/modinfo" exited with status 0.
2015-05-05T10:10:07.652+08:00| vthread-3| I120: to be installed: vmnet status: 0
2015-05-05T10:10:07.680+08:00| vthread-3| I120: Obtaining info using the running kernel.
2015-05-05T10:10:07.681+08:00| vthread-3| I120: Setting header path for 3.19.0-15-generic to "/lib/modules/3.19.0-15-generic/build/include".
2015-05-05T10:10:07.681+08:00| vthread-3| I120: Validating path "/lib/modules/3.19.0-15-generic/build/include" for kernel release "3.19.0-15-generic".
2015-05-05T10:10:07.681+08:00| vthread-3| I120: Failed to find /lib/modules/3.19.0-15-generic/build/include/linux/version.h
2015-05-05T10:10:07.681+08:00| vthread-3| I120: /lib/modules/3.19.0-15-generic/build/include/linux/version.h not found, looking for generated/uapi/linux/version.h instead.
2015-05-05T10:10:07.681+08:00| vthread-3| I120: using /usr/bin/gcc-4.9 for preprocess check
2015-05-05T10:10:07.691+08:00| vthread-3| I120: Preprocessed UTS_RELEASE, got value "3.19.0-15-generic".
2015-05-05T10:10:07.691+08:00| vthread-3| I120: The header path "/lib/modules/3.19.0-15-generic/build/include" for the kernel "3.19.0-15-generic" is valid. Whoohoo!
2015-05-05T10:10:07.832+08:00| vthread-3| I120: found symbol version file /lib/modules/3.19.0-15-generic/build/Module.symvers
2015-05-05T10:10:07.832+08:00| vthread-3| I120: Reading symbol versions from /lib/modules/3.19.0-15-generic/build/Module.symvers.
2015-05-05T10:10:07.877+08:00| vthread-3| I120: Read 18827 symbol versions
2015-05-05T10:10:07.877+08:00| vthread-3| I120: Kernel header path retrieved from FileEntry: /lib/modules/3.19.0-15-generic/build/include
2015-05-05T10:10:07.877+08:00| vthread-3| I120: Update kernel header path to /lib/modules/3.19.0-15-generic/build/include
2015-05-05T10:10:07.877+08:00| vthread-3| I120: Validating path "/lib/modules/3.19.0-15-generic/build/include" for kernel release "3.19.0-15-generic".
2015-05-05T10:10:07.877+08:00| vthread-3| I120: Failed to find /lib/modules/3.19.0-15-generic/build/include/linux/version.h
2015-05-05T10:10:07.877+08:00| vthread-3| I120: /lib/modules/3.19.0-15-generic/build/include/linux/version.h not found, looking for generated/uapi/linux/version.h instead.
2015-05-05T10:10:07.877+08:00| vthread-3| I120: using /usr/bin/gcc-4.9 for preprocess check
2015-05-05T10:10:07.888+08:00| vthread-3| I120: Preprocessed UTS_RELEASE, got value "3.19.0-15-generic".
2015-05-05T10:10:07.888+08:00| vthread-3| I120: The header path "/lib/modules/3.19.0-15-generic/build/include" for the kernel "3.19.0-15-generic" is valid. Whoohoo!
2015-05-05T10:10:07.890+08:00| vthread-3| I120: Found compiler at "/usr/bin/gcc"
2015-05-05T10:10:07.894+08:00| vthread-3| I120: Got gcc version "4.9.2".
2015-05-05T10:10:07.894+08:00| vthread-3| I120: The GCC version matches the kernel GCC minor version like a glove.
2015-05-05T10:10:07.894+08:00| vthread-3| I120: Using user supplied compiler "/usr/bin/gcc".
2015-05-05T10:10:07.898+08:00| vthread-3| I120: Got gcc version "4.9.2".
2015-05-05T10:10:07.898+08:00| vthread-3| I120: The GCC version matches the kernel GCC minor version like a glove.
2015-05-05T10:10:07.905+08:00| vthread-3| I120: Trying to find a suitable PBM set for kernel "3.19.0-15-generic".
2015-05-05T10:10:07.905+08:00| vthread-3| I120: No matching PBM set was found for kernel "3.19.0-15-generic".
2015-05-05T10:10:07.906+08:00| vthread-3| I120: The GCC version matches the kernel GCC minor version like a glove.
2015-05-05T10:10:07.906+08:00| vthread-3| I120: Validating path "/lib/modules/3.19.0-15-generic/build/include" for kernel release "3.19.0-15-generic".
2015-05-05T10:10:07.906+08:00| vthread-3| I120: Failed to find /lib/modules/3.19.0-15-generic/build/include/linux/version.h
2015-05-05T10:10:07.906+08:00| vthread-3| I120: /lib/modules/3.19.0-15-generic/build/include/linux/version.h not found, looking for generated/uapi/linux/version.h instead.
2015-05-05T10:10:07.906+08:00| vthread-3| I120: using /usr/bin/gcc-4.9 for preprocess check
2015-05-05T10:10:07.916+08:00| vthread-3| I120: Preprocessed UTS_RELEASE, got value "3.19.0-15-generic".
2015-05-05T10:10:07.916+08:00| vthread-3| I120: The header path "/lib/modules/3.19.0-15-generic/build/include" for the kernel "3.19.0-15-generic" is valid. Whoohoo!
2015-05-05T10:10:07.936+08:00| vthread-3| I120: The GCC version matches the kernel GCC minor version like a glove.
2015-05-05T10:10:07.936+08:00| vthread-3| I120: Validating path "/lib/modules/3.19.0-15-generic/build/include" for kernel release "3.19.0-15-generic".
2015-05-05T10:10:07.936+08:00| vthread-3| I120: Failed to find /lib/modules/3.19.0-15-generic/build/include/linux/version.h
2015-05-05T10:10:07.936+08:00| vthread-3| I120: /lib/modules/3.19.0-15-generic/build/include/linux/version.h not found, looking for generated/uapi/linux/version.h instead.
2015-05-05T10:10:07.936+08:00| vthread-3| I120: using /usr/bin/gcc-4.9 for preprocess check
2015-05-05T10:10:07.946+08:00| vthread-3| I120: Preprocessed UTS_RELEASE, got value "3.19.0-15-generic".
2015-05-05T10:10:07.946+08:00| vthread-3| I120: The header path "/lib/modules/3.19.0-15-generic/build/include" for the kernel "3.19.0-15-generic" is valid. Whoohoo!
2015-05-05T10:10:07.946+08:00| vthread-3| I120: Using temp dir "/tmp".
2015-05-05T10:10:07.948+08:00| vthread-3| I120: Obtaining info using the running kernel.
2015-05-05T10:10:07.948+08:00| vthread-3| I120: Setting header path for 3.19.0-15-generic to "/lib/modules/3.19.0-15-generic/build/include".
2015-05-05T10:10:07.948+08:00| vthread-3| I120: Validating path "/lib/modules/3.19.0-15-generic/build/include" for kernel release "3.19.0-15-generic".
2015-05-05T10:10:07.948+08:00| vthread-3| I120: Failed to find /lib/modules/3.19.0-15-generic/build/include/linux/version.h
2015-05-05T10:10:07.948+08:00| vthread-3| I120: /lib/modules/3.19.0-15-generic/build/include/linux/version.h not found, looking for generated/uapi/linux/version.h instead.
2015-05-05T10:10:07.948+08:00| vthread-3| I120: using /usr/bin/gcc-4.9 for preprocess check
2015-05-05T10:10:07.958+08:00| vthread-3| I120: Preprocessed UTS_RELEASE, got value "3.19.0-15-generic".
2015-05-05T10:10:07.958+08:00| vthread-3| I120: The header path "/lib/modules/3.19.0-15-generic/build/include" for the kernel "3.19.0-15-generic" is valid. Whoohoo!
2015-05-05T10:10:08.098+08:00| vthread-3| I120: found symbol version file /lib/modules/3.19.0-15-generic/build/Module.symvers
2015-05-05T10:10:08.098+08:00| vthread-3| I120: Reading symbol versions from /lib/modules/3.19.0-15-generic/build/Module.symvers.
2015-05-05T10:10:08.144+08:00| vthread-3| I120: Read 18827 symbol versions
2015-05-05T10:10:08.144+08:00| vthread-3| I120: Invoking modinfo on "vmnet".
2015-05-05T10:10:08.147+08:00| vthread-3| I120: "/sbin/modinfo" exited with status 256.
2015-05-05T10:10:08.502+08:00| vthread-3| I120: Setting destination path for vmnet to "/lib/modules/3.19.0-15-generic/misc/vmnet.ko".
2015-05-05T10:10:08.502+08:00| vthread-3| I120: Extracting the vmnet source from "/usr/lib/vmware/modules/source/vmnet.tar".
2015-05-05T10:10:08.517+08:00| vthread-3| I120: Successfully extracted the vmnet source.
2015-05-05T10:10:08.517+08:00| vthread-3| I120: Building module with command "/usr/bin/make -j2 -C /tmp/modconfig-SknY5s/vmnet-only auto-build HEADER_DIR=/lib/modules/3.19.0-15-generic/build/include CC=/usr/bin/gcc IS_GCC_3=no"
2015-05-05T10:10:11.333+08:00| vthread-3| W110: Failed to build vmnet. Failed to execute the build command.
