12.04找不到python-dev
- 系统: 64bit-ubuntu-12.04
- YeLee
- 系统: Fundu i64
- 来自: 东海硇州,一双管钥。
Re: 12.04找不到python-dev
还是检查一下源列表吧。
- qy117121
- 系统: Winbuntu
- 来自: 志虚国乌由市
as python-dev
* libboost-mpi-python-dev -> C++ interface to the Message Passing Interface (MPI), Python Bindings (default version)
(<无>/1.49.0.1)
* libboost-python-dev -> Boost.Python Library development files (default version)
(<无>/1.49.0.1)
* libroot-bindings-python-dev -> Python extension for ROOT - development files
(<无>/5.34.00-1ubuntu1)
* python-dev -> header files and a static library for Python (default)
(<无>/2.7.3-0ubuntu7)
12.10
(<无>/1.49.0.1)
(<无>/1.49.0.1)
12.10
邮箱 chuan@ubuntu.org.cn
- qy117121
- 系统: Winbuntu
- 来自: 志虚国乌由市
YeLee 写了:还是检查一下源列表吧。
- amazingp35
- qy117121
- 系统: Winbuntu
- 来自: 志虚国乌由市
lengxx@hexiuzou:~$ aptitude search python-dev
p libboost-mpi-python-dev - Python interface to the Message Passing I
p libboost-python-dev - Boost.Python Library development files (d
p python-dev
12.04
p python-dev
12.04
本人新手,不明白大侠的意思....
我用apt-cache search python-dev,什么也没有,系统是12.04.2-64bit,跟这个有没有关系?qy117121 写了:lengxx@hexiuzou:~$ aptitude search python-dev
p python-dev
12.04
- qy117121
- 系统: Winbuntu
- 来自: 志虚国乌由市
换个源,apt-get update 下
- oneleaf
- 论坛管理员
- 系统: Ubuntu 12.04
源里应该有的,把安装命令的结果贴上来。
$ apt-cache show python-dev
Package: python-dev
Priority: optional
Section: python
Installed-Size: 41
Maintainer: Ubuntu Developers <ubuntu-devel-discuss@lists.ubuntu.com>
Original-Maintainer: Matthias Klose <doko@debian.org>
Architecture: amd64
Source: python-defaults
Version: 2.7.3-0ubuntu7
Replaces: python2.7 (<< 2.7.3)
Depends: python (= 2.7.3-0ubuntu7), python2.7-dev (>= 2.7.3)
Filename: pool/main/p/python-defaults/python-dev_2.7.3-0ubuntu7_amd64.deb
MD5sum: 1059326d9d7436874b430992ef56c5b3
SHA1: 586a10451996ab5699a05476e86210a3bc495373
SHA256: 2891f6bf48be66e98b930628464bd762158bbd5570ce9d102f6ba36c2ed1c7b5
Description-en: header files and a static library for Python (default)
Header files, a static library and development tools for building
Python modules, extending the Python interpreter or embedding Python
in applications.
This package is a dependency package, which depends on Debian's default
Python version (currently v2.7).
Homepage: http://www.python.org/
Description-md5: 93a1917c3f17606b40377d0b737c6c92
Bugs: https://bugs.launchpad.net/ubuntu/+filebug
Origin: Ubuntu
Supported: 18m
按楼上:
好像是被替换了,谢谢各位
Package: python
Status: install ok installed
Priority: important
Section: python
Installed-Size: 658
Architecture: amd64
Version: 2.7.3-0ubuntu2
Replaces: python-dev (<< 2.6.5-2)
Provides: python-ctypes, python-email, python-importlib, python-profiler, python-wsgiref
Depends: python2.7 (>= 2.7.3), python-minimal (= 2.7.3-0ubuntu2)
Suggests: python-doc (= 2.7.3-0ubuntu2), python-tk (= 2.7.3-0ubuntu2)
Breaks: python-bz2 (<< 1.1-8), python-csv (<< 1.0-4), python-email (<< 2.5.5-3), update-manager-core (<< 0.200.5-2)
Conflicts: python-central (<< 0.5.5)
Description: interactive high-level object-oriented language (default version)
Python, the high-level, interactive object oriented language,
includes an extensive class library with lots of goodies for
network programming, system administration, sounds and graphics.
