打包PPA问题
- 系统: win10
打包PPA问题
以前没接触过linux打包,最近工作原因需要把一个项目打包上传到launchpad,照着教程来是成功了,但是有个问题 用户下载安装的时候默认是装在/build 目录下的,这是launchpad编译时默认的安装目录,我想把安装目录改成/usr/local,usr/lib这种,试过make install 设置路径和mkdir都没有权限,因为launchpad编译时不给root权限,但我看其他PPA 都可以安装到/usr/local啊.... 。难道是需要联系lanuchpad官方,让他们审核代码才给权限嘛?有大佬知道怎么操作不?
Re: 打包PPA问题
绝对是你自己的安装脚本问题,十有八九是你的安装位置弄错了。你又不说你的包debian目录是怎么弄的,我没法给你具体的建议
- 系统: win10
Re: 打包PPA问题
我的debian/rules 文件没改,只改了项目的makefile...
# Copyright 2018 Slightech Co., Ltd. All rights reserved.
# Licensed under the Apache License, Version 2.0 (the "License");
# you may not use this file except in compliance with the License.
# You may obtain a copy of the License at
# http://www.apache.org/licenses/LICENSE-2.0
# Unless required by applicable law or agreed to in writing, software
# distributed under the License is distributed on an "AS IS" BASIS,
# WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
# See the License for the specific language governing permissions and
# limitations under the License.
include CommonDefs.mk
MKFILE_PATH := $(abspath $(lastword $(MAKEFILE_LIST)))
MKFILE_DIR := $(patsubst %/,%,$(dir $(MKFILE_PATH)))
.DEFAULT_GOAL := help
help:
@echo "Usage:"
@echo " make help show help message"
@echo " make apidoc make api doc"
@echo " make opendoc open api doc (html)"
@echo " make init init project"
@echo " make build build project"
@echo " make test build test and run"
@echo " make install install project"
@echo " make samples build samples"
@echo " make tools build tools"
@echo " make ros build ros wrapper"
@echo " make py build python wrapper"
@echo " make clean|cleanall clean generated or useless things"
.PHONY: help
all: test tools samples
.PHONY: all
# doc
apidoc:
@$(call echo,Make $@)
@[ -e ./_install/include ] || $(MAKE) install
@$(SH) ./doc/build.sh
opendoc: apidoc
@$(shell $(SH) ./doc/langs.sh 1); \
for lang in "$${LANGS[@]}"; do \
html=./doc/_output/$$lang/html/index.html; \
[ -f "$$html" ] && $(SH) ./scripts/open.sh $$html; \
done
cleandoc:
@$(call rm,./doc/_output/)
.PHONY: apidoc opendoc cleandoc
# deps
submodules:
#@git submodule update --init
third_party: submodules
@$(call echo,Make glog,33)
@$(call cmake_build,./third_party/glog/_build)
.PHONY: submodules third_party
# init
init: submodules
@$(SH) ./scripts/init.sh
.PHONY: init
# build
build: third_party
@$(call cmake_build,./_build,..,-DCMAKE_INSTALL_PREFIX=/usr/local/mynteye)
.PHONY: build
# test
test: install
@$(call echo,Make gtest,33)
ifeq ($(HOST_OS),Win)
@$(call cmake_build,./test/gtest/_build,..,-Dgtest_force_shared_crt=ON)
else
@$(call cmake_build,./test/gtest/_build)
endif
@$(call echo,Make test,33)
@$(call cmake_build,./test/_build)
@.\\\test\\\_output\\\bin\\\mynteye_test.bat
else
@./test/_output/bin/mynteye_test
endif
.PHONY: test
# install
install: build
ifneq ($(HOST_NAME),MinGW)
@cd ./_build; msbuild.exe INSTALL.vcxproj /property:Configuration=Release
else
@cd ./_build; make install
endif
else
endif
@make samples
@make tools
.PHONY: install
# samples
samples:
@$(call cmake_build,./samples/_build)
.PHONY: samples
# tools
tools:
@$(call cmake_build,./tools/_build)
.PHONY: tools
# ros
ros: install
$(error "Can't make ros on win")
else
@cd ./wrappers/ros && catkin_make
endif
.PHONY: ros
cleanros:
@$(call rm,./wrappers/ros/build/)
@$(call rm,./wrappers/ros/devel/)
@$(call rm,./wrappers/ros/install/)
@$(call rm,./wrappers/ros/.catkin_workspace)
@$(call rm,./wrappers/ros/src/CMakeLists.txt)
@$(call rm_f,*INFO*,$(HOME)/.ros/)
@$(call rm_f,*WARNING*,$(HOME)/.ros/)
@$(call rm_f,*ERROR*,$(HOME)/.ros/)
@$(call rm_f,*FATAL*,$(HOME)/.ros/)
.PHONY: cleanros
# python
PBCVT_DIR := wrappers/python/third_party/pyboostcvconverter
$(PBCVT_DIR):
@git clone https://github.com/Algomorph/pyboostcvconverter.git $@
pbcvt: $(PBCVT_DIR)
@$(call cmake_build,$(PBCVT_DIR)/_build,.., \
-DCMAKE_INSTALL_PREFIX=$(MKFILE_DIR)/wrappers/python/_install \
-DPYTHON_DESIRED_VERSION=2.X)
@cd $(PBCVT_DIR)/_build; make install
.PHONY: pbcvt
NPCV_DIR := wrappers/python/third_party/numpy-opencv-converter
$(NPCV_DIR):
@git clone https://github.com/GarrickLin/numpy-opencv-converter.git $@
py: python
python: install $(NPCV_DIR)
@$(call cmake_build,./wrappers/python/_build)
@cd ./wrappers/python/_build; make install
.PHONY: py python
cleanpy:
@$(call rm,./wrappers/python/_build/)
@$(call rm,./wrappers/python/_output/)
@$(call rm,./wrappers/python/_install/)
@$(call rm,./$(PBCVT_DIR)/_build/)
.PHONY: cleanpy
# clean
clean:
@$(call rm,./_build/)
@$(call rm,./_output/)
@$(call rm,./_install/)
@$(call rm,./samples/_build/)
@$(call rm,./samples/_output/)
@$(call rm,./tools/_build/)
@$(call rm,./tools/_output/)
@$(call rm,./test/_build/)
@$(call rm,./test/_output/)
@$(MAKE) cleanlog
ifeq ($(HOST_OS),Linux)
@$(MAKE) cleanros
endif
@$(MAKE) cleanpy
cleanlog:
@$(call rm_f,*INFO*)
@$(call rm_f,*WARNING*)
@$(call rm_f,*ERROR*)
@$(call rm_f,*FATAL*)
cleanall: clean cleandoc
@$(call rm,./test/gtest/_build/)
@$(call rm,./third_party/glog/_build/)
@$(FIND) . -type f -name ".DS_Store" -print0 | xargs -0 rm -f
@$(call rm,./$(PBCVT_DIR)/)
@$(call rm,./$(NPCV_DIR)/)
.PHONY: clean cleanlog cleanall
# others
host:
@echo MKFILE_PATH: $(MKFILE_PATH)
@echo MKFILE_DIR: $(MKFILE_DIR)
@echo HOST_OS: $(HOST_OS)
@echo HOST_ARCH: $(HOST_ARCH)
@echo HOST_NAME: $(HOST_NAME)
@echo SH: $(SH)
@echo ECHO: $(ECHO)
@echo FIND: $(FIND)
@echo CC: $(CC)
@echo CXX: $(CXX)
@echo MAKE: $(MAKE)
@echo BUILD: $(BUILD)
@echo LDD: $(LDD)
@echo CMAKE: $(CMAKE)
.PHONY: host
cpplint: submodules
@$(SH) ./scripts/$@.sh
.PHONY: cpplint
Re: 打包PPA问题
就是这种写法惹的祸
安装目标目录不能这么写。因为安装默认是由dh_auto_install来处理的,自己去读它的manpage:http://manpages.ubuntu.com/manpages/bio ... all.1.html
再去看看你ppa里的安装日志,https://launchpadlibrarian.net/37511840 ... ING.txt.gz 搜一下dh_auto_install部分
所以最保险的做法是利用它给你的DESTDIR环境变量,把目标目录写成 ${DESTDIR}/mynteye 这种形式
- 系统: win10
Re: 打包PPA问题
谢谢 我试着改成 ${DESTDIR}/usr/lib/mynteye , 下面是launchpad的buildlog 我看它应该还是安装在 /build 下面...astolia 写了: ↑2018-08-09 13:08 就是这种写法惹的祸安装目标目录不能这么写。因为安装默认是由dh_auto_install来处理的,自己去读它的manpage:http://manpages.ubuntu.com/manpages/bio ... all.1.html代码: 全选
drwxr-xr-x root/root 0 2018-08-09 06:36 ./
drwxr-xr-x root/root 0 2018-08-09 06:36 ./build/
drwxr-xr-x root/root 0 2018-08-09 06:36 ./<<BUILDDIR>>/
drwxr-xr-x root/root 0 2018-08-09 06:36 ./<<PKGBUILDDIR>>/
drwxr-xr-x root/root 0 2018-08-09 06:36 ./<<PKGBUILDDIR>>/debian/
drwxr-xr-x root/root 0 2018-08-09 06:36 ./<<PKGBUILDDIR>>/debian/mynteye2-demo/
drwxr-xr-x root/root 0 2018-08-09 06:36 ./<<PKGBUILDDIR>>/debian/mynteye2-demo/usr/
drwxr-xr-x root/root 0 2018-08-09 06:36 ./<<PKGBUILDDIR>>/debian/mynteye2-demo/usr/lib/
drwxr-xr-x root/root 0 2018-08-09 06:36 ./<<PKGBUILDDIR>>/debian/mynteye2-demo/usr/lib/mynteye/
drwxr-xr-x root/root 0 2018-08-09 06:36 ./<<PKGBUILDDIR>>/debian/mynteye2-demo/usr/lib/mynteye/include/
drwxr-xr-x root/root 0 2018-08-09 06:36 ./<<PKGBUILDDIR>>/debian/mynteye2-demo/usr/lib/mynteye/include/mynteye/
-rw-r--r-- root/root 6693 2018-06-19 04:48 ./<<PKGBUILDDIR>>/debian/mynteye2-demo/usr/lib/mynteye/include/mynteye/api.h
-rw-r--r-- root/root 3060 2018-06-19 04:48 ./<<PKGBUILDDIR>>/debian/mynteye2-demo/usr/lib/mynteye/include/mynteye/callbacks.h
-rw-r--r-- root/root 1285 2018-06-19 04:48 ./<<PKGBUILDDIR>>/debian/mynteye2-demo/usr/lib/mynteye/include/mynteye/context.h
-rw-r--r-- root/root 7931 2018-06-19 04:48 ./<<PKGBUILDDIR>>/debian/mynteye2-demo/usr/lib/mynteye/include/mynteye/device.h
-rw-r--r-- root/root 943 2018-06-19 04:48 ./<<PKGBUILDDIR>>/debian/mynteye2-demo/usr/lib/mynteye/include/mynteye/files.h
-rw-r--r-- root/root 2137 2018-06-19 04:48 ./<<PKGBUILDDIR>>/debian/mynteye2-demo/usr/lib/mynteye/include/mynteye/global.h
-rw-r--r-- root/root 1966 2018-07-24 07:36 ./<<PKGBUILDDIR>>/debian/mynteye2-demo/usr/lib/mynteye/include/mynteye/glog_init.h
-rw-r--r-- root/root 2173 2018-08-09 06:35 ./<<PKGBUILDDIR>>/debian/mynteye2-demo/usr/lib/mynteye/include/mynteye/mynteye.h
-rw-r--r-- root/root 2408 2018-07-24 07:36 ./<<PKGBUILDDIR>>/debian/mynteye2-demo/usr/lib/mynteye/include/mynteye/object.h
-rw-r--r-- root/root 3140 2018-06-19 04:48 ./<<PKGBUILDDIR>>/debian/mynteye2-demo/usr/lib/mynteye/include/mynteye/plugin.h
-rw-r--r-- root/root 1818 2018-06-19 04:48 ./<<PKGBUILDDIR>>/debian/mynteye2-demo/usr/lib/mynteye/include/mynteye/strings.h
-rw-r--r-- root/root 5902 2018-06-19 04:48 ./<<PKGBUILDDIR>>/debian/mynteye2-demo/usr/lib/mynteye/include/mynteye/times.h
-rw-r--r-- root/root 11534 2018-06-19 04:48 ./<<PKGBUILDDIR>>/debian/mynteye2-demo/usr/lib/mynteye/include/mynteye/types.h
-rw-r--r-- root/root 1566 2018-06-19 04:48 ./<<PKGBUILDDIR>>/debian/mynteye2-demo/usr/lib/mynteye/include/mynteye/utils.h
drwxr-xr-x root/root 0 2018-08-09 06:36 ./<<PKGBUILDDIR>>/debian/mynteye2-demo/usr/lib/mynteye/lib/
drwxr-xr-x root/root 0 2018-08-09 06:36 ./<<PKGBUILDDIR>>/debian/mynteye2-demo/usr/lib/mynteye/lib/cmake/
drwxr-xr-x root/root 0 2018-08-09 06:36 ./<<PKGBUILDDIR>>/debian/mynteye2-demo/usr/lib/mynteye/lib/cmake/mynteye/
-rw-r--r-- root/root 1607 2018-08-09 06:35 ./<<PKGBUILDDIR>>/debian/mynteye2-demo/usr/lib/mynteye/lib/cmake/mynteye/mynteye-config-version.cmake
-rw-r--r-- root/root 1300 2018-08-09 06:35 ./<<PKGBUILDDIR>>/debian/mynteye2-demo/usr/lib/mynteye/lib/cmake/mynteye/mynteye-config.cmake
-rw-r--r-- root/root 936 2018-08-09 06:35 ./<<PKGBUILDDIR>>/debian/mynteye2-demo/usr/lib/mynteye/lib/cmake/mynteye/mynteye-targets-release.cmake
-rw-r--r-- root/root 3508 2018-08-09 06:35 ./<<PKGBUILDDIR>>/debian/mynteye2-demo/usr/lib/mynteye/lib/cmake/mynteye/mynteye-targets.cmake
lrwxrwxrwx root/root 0 2018-08-09 06:36 ./<<PKGBUILDDIR>>/debian/mynteye2-demo/usr/lib/mynteye/lib/libmynteye.so -> libmynteye.so.2
lrwxrwxrwx root/root 0 2018-08-09 06:36 ./<<PKGBUILDDIR>>/debian/mynteye2-demo/usr/lib/mynteye/lib/libmynteye.so.2 -> libmynteye.so.2.0.1
-rw-r--r-- root/root 664288 2018-08-09 06:36 ./<<PKGBUILDDIR>>/debian/mynteye2-demo/usr/lib/mynteye/lib/libmynteye.so.2.0.1
drwxr-xr-x root/root 0 2018-08-09 06:36 ./<<PKGBUILDDIR>>/debian/mynteye2-demo/usr/lib/mynteye/share/
drwxr-xr-x root/root 0 2018-08-09 06:36 ./<<PKGBUILDDIR>>/debian/mynteye2-demo/usr/lib/mynteye/share/mynteye/
-rw-r--r-- root/root 602 2018-08-09 06:35 ./<<PKGBUILDDIR>>/debian/mynteye2-demo/usr/lib/mynteye/share/mynteye/build.info
drwxr-xr-x root/root 0 2018-08-09 06:36 ./usr/
drwxr-xr-x root/root 0 2018-08-09 06:36 ./usr/share/
drwxr-xr-x root/root 0 2018-08-09 06:36 ./usr/share/doc/
drwxr-xr-x root/root 0 2018-08-09 06:36 ./usr/share/doc/mynteye2-demo/
-rw-r--r-- root/root 185 2018-08-09 06:21 ./usr/share/doc/mynteye2-demo/README.Debian
-rw-r--r-- root/root 174 2018-08-09 06:22 ./usr/share/doc/mynteye2-demo/changelog.Debian.gz
-rw-r--r-- root/root 1682 2018-08-09 06:21 ./usr/share/doc/mynteye2-demo/copyright
drwxr-xr-x root/root 0 2015-09-03 09:12 ./
drwxr-xr-x root/root 0 2015-09-03 09:12 ./usr/
drwxr-xr-x root/root 0 2015-09-03 09:12 ./usr/bin/
-rwxr-xr-x root/root 423 2015-09-03 09:12 ./usr/bin/docky
drwxr-xr-x root/root 0 2015-09-03 09:12 ./usr/lib/
drwxr-xr-x root/root 0 2015-09-03 09:12 ./usr/lib/docky/
-rw-r--r-- root/root 13824 2015-09-03 09:12 ./usr/lib/docky/Docky.CairoHelper.dll
-rw-r--r-- root/root 22528 2015-09-03 09:12 ./usr/lib/docky/Docky.DBus.dll
-rw-r--r-- root/root 102400 2015-09-03 09:12 ./usr/lib/docky/Docky.Items.dll
-rw-r--r-- root/root 151040 2015-09-03 09:12 ./usr/lib/docky/Docky.Services.dll
-rw-r--r-- root/root 381 2015-09-03 09:12 ./usr/lib/docky/Docky.Services.dll.config
-rw-r--r-- root/root 40960 2015-09-03 09:12 ./usr/lib/docky/Docky.Widgets.dll
-rw-r--r-- root/root 204 2015-09-03 09:12 ./usr/lib/docky/Docky.Widgets.dll.config
-rw-r--r-- root/root 77 2015-09-03 09:12 ./usr/lib/docky/Docky.addins
-rwxr-xr-x root/root 262144 2015-09-03 09:12 ./usr/lib/docky/Docky.exe
-rw-r--r-- root/root 223744 2015-09-03 09:12 ./usr/lib/docky/gio-sharp.dll
-rw-r--r-- root/root 291 2015-09-03 09:12 ./usr/lib/docky/gio-sharp.dll.config
drwxr-xr-x root/root 0 2015-09-03 09:12 ./usr/lib/docky/plugins/
-rw-r--r-- root/root 96768 2015-09-03 09:12 ./usr/lib/docky/plugins/BatteryMonitor.dll
-rw-r--r-- root/root 10752 2015-09-03 09:12 ./usr/lib/docky/plugins/Bookmarks.dll
-rw-r--r-- root/root 9216 2015-09-03 09:12 ./usr/lib/docky/plugins/CPUMonitor.dll
-rw-r--r-- root/root 7168 2015-09-03 09:12 ./usr/lib/docky/plugins/Clippy.dll
-rw-r--r-- root/root 20992 2015-09-03 09:12 ./usr/lib/docky/plugins/Clock.dll
-rw-r--r-- root/root 88576 2015-09-03 09:12 ./usr/lib/docky/plugins/Desktop.dll
-rw-r--r-- root/root 35840 2015-09-03 09:12 ./usr/lib/docky/plugins/GMail.dll
-rw-r--r-- root/root 9728 2015-09-03 09:12 ./usr/lib/docky/plugins/Mounter.dll
-rw-r--r-- root/root 29696 2015-09-03 09:12 ./usr/lib/docky/plugins/NPR.dll
-rw-r--r-- root/root 32256 2015-09-03 09:12 ./usr/lib/docky/plugins/NetworkManager.dll
-rw-r--r-- root/root 9728 2015-09-03 09:12 ./usr/lib/docky/plugins/NetworkMonitor.dll
-rw-r--r-- root/root 10752 2015-09-03 09:12 ./usr/lib/docky/plugins/RecentDocuments.dll
-rw-r--r-- root/root 16384 2015-09-03 09:12 ./usr/lib/docky/plugins/SessionManager.dll
-rw-r--r-- root/root 48640 2015-09-03 09:12 ./usr/lib/docky/plugins/Timer.dll
-rw-r--r-- root/root 11264 2015-09-03 09:12 ./usr/lib/docky/plugins/Trash.dll
-rw-r--r-- root/root 71168 2015-09-03 09:12 ./usr/lib/docky/plugins/Weather.dll
-rw-r--r-- root/root 17408 2015-09-03 09:12 ./usr/lib/docky/plugins/WorkspaceSwitcher.dll
-rw-r--r-- root/root 61440 2015-09-03 09:12 ./usr/lib/docky/wnck-sharp1.dll
-rw-r--r-- root/root 151 2015-09-03 09:12 ./usr/lib/docky/wnck-sharp1.dll.config
drwxr-xr-x root/root 0 2015-09-03 09:12 ./usr/lib/pkgconfig/
-rw-r--r-- root/root 117 2015-09-03 09:12 ./usr/lib/pkgconfig/docky.cairohelper.pc
-rw-r--r-- root/root 98 2015-09-03 09:12 ./usr/lib/pkgconfig/docky.items.pc
-rw-r--r-- root/root 107 2015-09-03 09:12 ./usr/lib/pkgconfig/docky.services.pc
-rw-r--r-- root/root 104 2015-09-03 09:12 ./usr/lib/pkgconfig/docky.widgets.pc
Re: 打包PPA问题
你好像把
打包 package 跟
打包好 package 上傳到 ppa
混為一談了
打包 package 跟
打包好 package 上傳到 ppa
混為一談了
Re: 打包PPA问题
那你就继续检查cmake的那套东西怎么处理安装路径的。你可以在本地用安装dpkg-dev后,用dpkg-buildpackage来打包检查,等本地打包没问题了,再上传launchpad
