apt-mirror 同步源后,再次同步不更新问题!
zhangjint5
帖子 zhangjint5 » 2017-01-31 21:00
第一次使用 apt-mirror 同步了官方源,没有问题!
第二次运行 apt-mirror 的时候,总是显示有多少 (例如图中 5.7 GiB)将要被下载。
运行完毕一次后,再次重复运行,还总是这么多要下载,也就是说更新下载的时候实际上就没有下载。
这个问题怎么解?
附 mirror.list 配置
############# config ##################
# set base_path    /var/spool/apt-mirror
# set mirror_path  $base_path/mirror
set mirror_path  /mnt/data/apt-mirror/mirror
# set skel_path    $base_path/skel
# set var_path     $base_path/var
# set cleanscript $var_path/clean.sh
# set defaultarch  <running host architecture>
# set postmirror_script $var_path/postmirror.sh
# set run_postmirror 0
set nthreads     20
set _tilde 0
############# end config ##############
deb-i386 http://archive.ubuntu.com/ubuntu xenial main restricted universe multiverse
deb-i386 http://archive.ubuntu.com/ubuntu xenial-security main restricted universe multiverse
deb-i386 http://archive.ubuntu.com/ubuntu xenial-updates main restricted universe multiverse
#deb http://archive.ubuntu.com/ubuntu xenial-proposed main restricted universe multiverse
#deb http://archive.ubuntu.com/ubuntu xenial-backports main restricted universe multiverse
#deb-src http://archive.ubuntu.com/ubuntu xenial main restricted universe multiverse
#deb-src http://archive.ubuntu.com/ubuntu xenial-security main restricted universe multiverse
#deb-src http://archive.ubuntu.com/ubuntu xenial-updates main restricted universe multiverse
#deb-src http://archive.ubuntu.com/ubuntu xenial-proposed main restricted universe multiverse
#deb-src http://archive.ubuntu.com/ubuntu xenial-backports main restricted universe multiverse
deb-amd64 http://archive.ubuntu.com/ubuntu xenial main restricted universe multiverse
deb-amd64 http://archive.ubuntu.com/ubuntu xenial-security main restricted universe multiverse
deb-amd64 http://archive.ubuntu.com/ubuntu xenial-updates main restricted universe multiverse
deb-armhf http://mirrors.aliyun.com/raspbian/raspbian jessie main rpi contrib
clean http://archive.ubuntu.com/ubuntu
clean http://mirrors.aliyun.com/raspbian/raspbian
Re: apt-mirror 同步源后,再次同步不更新问题!
帖子 poloshiao » 2017-01-31 21:45
1. 第一次 下載了嗎 ?
2. 參閱
https://ubuntuforums.org/showthread.php ... ost3684361
HOWTO: Setup Local Repository Mirror
zhangjint5
帖子 zhangjint5 » 2017-02-01 9:01
第一次肯定下载了,跑了一天多。产生了190GB左右文件。
我将下载的所有数据删除了,重新运行一次,又开始完整下载,没问题。
就是更新现有下载的时候不走~!
帖子 poloshiao » 2017-02-01 9:13
把下面的指令 複製 貼進終端機 執行
1. sudo cat /etc/apt/sources.list
2. sudo apt-get update
3. sudo apt update
把結果全部直接 選取/複製/貼上來
不要摘要 以免遺漏重要資訊
zhangjint5
帖子 zhangjint5 » 2017-02-01 10:17
如图
本机软件我用的阿里源
apt-mirror 我用的官方源
不过一个配置文件是 sources.list 另一个是 mirror.list ,应该相互没有干扰吧?
帖子 poloshiao » 2017-02-01 10:49
1. 終端機指令及文字回應
請直接複製貼上來 不必擷圖
2. 下載/安裝/更新 套件 sources.list 才有效
2-1. 參閱
Step 5: Setup links
Step 6: Set apt to use local mirror
