frost@frost-virtual-machine:~$ sudo apt-get install build-essential bison flex perl tcl-dev \ tk-dev libxml2-dev zlib1g-dev default-jre doxygen graphviz \ libwebkitgtk-1.0-0 qt4-qmake libqt4-dev libqt4-opengl-dev openmpi-bin \ libopenmpi-dev openjdk-7-jre cmake scons swig m4 python \ python-dev \ libgoogle-perftools-dev
Reading package lists... Done
Building dependency tree
Package openjdk-7-jre is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Unable to locate package
E: Unable to locate package libwebkitgtk-1.0-0
E: Couldn't find any package by glob ' libwebkitgtk-1.0-0'
E: Couldn't find any package by regex ' libwebkitgtk-1.0-0'
E: Unable to locate package libopenmpi-dev
E: Package 'openjdk-7-jre' has no installation candidate
E: Unable to locate package python-dev
E: Unable to locate package libgoogle-perftools-dev
求问这种情况咋整的,更新啥的也试过,没用
Re: 求问这种情况咋整的,更新啥的也试过,没用
把命令里所有的\都删掉。不知道你是从哪里抄的,本来\后面该是换行的,你把换行去掉了也要把\去掉
openjdk-7-jre都是14.04时期的东西了,没有特殊理由的话换openjdk-8-jre
ok,感谢,做cossim的,这个确实有点过时了
