目前这么配置需要ubuntu 登陆后,远程win10使用vnc viewer才能登陆。win10自带远程桌面不能登陆.
现在问题有:
1:ubuntu上面登陆用户a桌面环境后,vnc viewer才能登陆用户a远程桌面
2:多个用户同时远程登陆还不能用
1、sudo apt-get install xrdp vnc4server xbase-clients
2、安装desktop sharing(Ubuntu16.04默认已经安装),可以到应用商店下载。打开desktop sharing,设置如下:
3、安装安装dconf-editor,取消权限限制:
sudo apt-get install dconf-editor
dconf-editor设置:org > gnome > desktop > remote-access,取消 “requlre-encryption”
service xrdp restart
apt-get install libtasn1-3-bin libtasn1-bin
Step 1 – Download TigerVNC Server package
https://bintray.com/tigervnc/stable/tig ... .6.0#files
In this installation process, this is really the tricky part. We need to install the tigervnc software solution but there is no Ubuntu packages available for Ubuntu 16.04. If you look on the official TigerVNC repository, you will see that there is no deb packages for Ubuntu 16.04.
You will need to either compile Tigervnc package on your own or find an existing debian package that can be used with Ubuntu 16.04.
Our Tigervnc deb package available for download
For your convenience, we are providing you a Tigervnc debian package that we have been using for our test. You can try to use this package but we cannot guarantee that this package would work for you. We will also not provide any support if the package is not working for you. You can give it a try and see if it works….(use it at you own risk !)
http://www.c-nergy.be/downloads/tigervn ... _amd64.zip
ubuntu 16.04 多用户同时远程登陆怎么配置?
Re: ubuntu 16.04 多用户同时远程登陆怎么配置?
libpam-smbpass 16.04已经没有这个包了,做密码同步的只能下载源码编译了,个人没有验证这个
这样是分享当前正在运行的 X Session,即基于 x11vnc 的方案,而不是连接时新开一个 X SessionBloodKing 写了:2、安装desktop sharing(Ubuntu16.04默认已经安装),可以到应用商店下载。打开desktop
有新开x server的方法没?vickycq 写了:这样是分享当前正在运行的 X Session,即基于 x11vnc 的方案,而不是连接时新开一个 X SessionBloodKing 写了:2、安装desktop sharing(Ubuntu16.04默认已经安装),可以到应用商店下载。打开desktop
