python:2.7
先前更换过3.5后来又换了回来,在安装scrapy框架时一直报这个错误,之前也有这种情况,百度无果,请各位看一下
小弟不胜感激,一下是部分报错信息。
Processing triggers for libc-bin (2.23-0ubuntu3) ...
Setting up python-decorator (4.0.6-1) ...
File "/usr/bin/pycompile", line 35, in <module>
from debpython.version import SUPPORTED, debsorted, vrepr, \
File "/usr/share/python/debpython/version.py", line 24, in <module>
from ConfigParser import SafeConfigParser
ImportError: No module named 'ConfigParser'
dpkg: error processing package python-decorator (--configure):
subprocess installed post-installation script returned error exit status 1
Setting up python-ptyprocess (0.5-1) ...
dpkg: error processing package python-ptyprocess (--configure):
No apport report written because the error message indicates its a followup error from a previous failure.
dpkg: dependency problems prevent configuration of python-pexpect:
python-pexpect depends on python-ptyprocess; however:
Package python-ptyprocess is not configured yet.
dpkg: error processing package python-pexpect (--configure):
Setting up python-simplegeneric (0.8.1-1) ...
dpkg: error processing package python-simplegeneric (--configure):
No apport report written because MaxReports is reached already
安装scrapy遇到的错误,请大神指点给个思路
- 系统: ubuntu/win10
Re: 安装scrapy遇到的错误,请大神指点给个思路
许多系统组件仍然使用 python2,所以不要将默认 python -> python3shark0119 写了:python:2.7 先前更换过3.5后来又换了回来
可能原因 默认 python -> python3shark0119 写了:ImportError: No module named 'ConfigParser'
执行以下指令将结果全部复制贴上来
which python | xargs ls -l
ls -l /usr/bin/ | grep " python"
- 系统: ubuntu/win10
用的是win10双系统,昨天引导坏了,win10的修复后,Ubuntu又进不去了,弄到现在,看来只能从装了,不过还是要多谢您了vickycq 写了:许多系统组件仍然使用 python2,所以不要将默认 python -> python3shark0119 写了:python:2.7 先前更换过3.5后来又换了回来
执行以下指令将结果全部复制贴上来代码: 全选
which python | xargs ls -l ls -l /usr/bin/ | grep " python"
- 系统: ubuntu/win10
从装系统后就好了,是python版本的问题,真是多谢了vickycq 写了:许多系统组件仍然使用 python2,所以不要将默认 python -> python3shark0119 写了:python:2.7 先前更换过3.5后来又换了回来
