- 监听器状态
[oracle@Fedora-Server root]$ lsnrctl status
LSNRCTL for Linux: Version 12.2.0.1.0 - Production on 24-NOV-2018 12:31:12
Copyright (c) 1991, 2016, Oracle. All rights reserved.
Connecting to (DESCRIPTION=(ADDRESS=(PROTOCOL=TCP)(HOST=192.168.1.200)(PORT=1521)))
STATUS of the LISTENER
Alias LISTENER
Version TNSLSNR for Linux: Version 12.2.0.1.0 - Production
Start Date 24-NOV-2018 12:20:22
Uptime 0 days 0 hr. 10 min. 50 sec
Trace Level off
Security ON: Local OS Authentication
SNMP OFF
Listener Parameter File /opt/oracle/app/product/12.2.0/network/admin/listener.ora
Listener Log File /opt/oracle/app/diag/tnslsnr/Fedora-Server/listener/alert/log.xml
Listening Endpoints Summary...
(DESCRIPTION=(ADDRESS=(PROTOCOL=tcp)(HOST=192.168.1.200)(PORT=1521)))
(DESCRIPTION=(ADDRESS=(PROTOCOL=ipc)(KEY=EXTPROC1521)))
Services Summary...
Service "7b4faaa996841fdce053c801a8c0b6f5" has 1 instance(s).
Instance "orcl", status READY, has 1 handler(s) for this service...
Service "orcl" has 1 instance(s).
Service "orclXDB" has 1 instance(s).
Service "pdborcl" has 1 instance(s).
The command completed successfully
- Oracle运行状态
[oracle@Fedora-Server root]$ sqlplus / as sysdba
SQL*Plus: Release 12.2.0.1.0 Production on Sat Nov 24 12:37:40 2018
Copyright (c) 1982, 2016, Oracle. All rights reserved.
Connected to:
Oracle Database 12c Enterprise Edition Release 12.2.0.1.0 - 64bit Production
SQL>
- listener配置
[root@Fedora-Server admin]# vi listener.ora
# listener.ora Network Configuration File: /opt/oracle/app/product/12.2.0/network/admin/listener.ora
# Generated by Oracle configuration tools.
LISTENER =
(DESCRIPTION_LIST =
(DESCRIPTION =
(ADDRESS = (PROTOCOL = TCP)(HOST = 192.168.1.200)(PORT = 1521))
(ADDRESS = (PROTOCOL = IPC)(KEY = EXTPROC1521))
- tnsnames配置
[root@Fedora-Server admin]# vi tnsnames.ora
# tnsnames.ora Network Configuration File: /opt/oracle/app/product/12.2.0/network/admin/tnsnames.ora
LISTENER_ORCL =
ORCL =
(DESCRIPTION =
(ADDRESS = (PROTOCOL = TCP)(HOST = 0.0.0.0)(PORT = 1521))
(CONNECT_DATA =
(SERVER = DEDICATED)
(SERVICE_NAME = orcl)
tns:connect timeout occurred
笔记本IP 192.168.1.104
怎么配置这俩个文件才能连上Oracle
