insserv: Starting vmware-USBArbitrator depends on grub-common and therefore on system facility `$all' which can not be true!
insserv: Max recursions depth 99 reached
insserv: loop involving service vmware at depth 2
insserv: loop involving service mountkernfs at depth 1
insserv: loop involving service vmware-USBArbitrator at depth 1
insserv: There is a loop between service vmware-USBArbitrator and dns-clean if started
insserv: loop involving service dns-clean at depth 1
insserv: exiting now without changing boot order!
update-rc.d: error: insserv rejected the script header
dpkg: error processing package mysql-server-5.6 (--configure):
subprocess installed post-installation script returned error exit status 1
dpkg: dependency problems prevent configuration of mysql-server:
mysql-server depends on mysql-server-5.6; however:
Package mysql-server-5.6 is not configured yet.
dpkg: error processing package mysql-server (--configure):
No apport report written because the error message indicates its a followup error from a previous failure.
mysql-server-5.6
mysql-server
这个该怎样解决?
ubuntu 15.10 安装 mysql-server 时出现如下错误:
