新买的VPS,安装mysql时,老是出现这样的错误,安装前已经运行apt-get update了。我同学以前帮我解决过一次,说是少了bsdutils,但是我google了好久,没找到,现在联系不上他,请帮帮忙,谢谢了。
root@ceshivps:~# apt-get install mysql-server
Reading package lists... Done
Building dependency tree
mysql-server is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 34 not upgraded.
2 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Setting up mysql-server-5.5 (5.5.46-0ubuntu0.14.04.2) ...
/var/lib/dpkg/info/mysql-server-5.5.postinst: line 146: logger: command not found
ATTENTION: An error has occured. More info is in the syslog!
/var/lib/dpkg/info/mysql-server-5.5.postinst: line 236: logger: command not found
dpkg: error processing package mysql-server-5.5 (--configure):
subprocess installed post-installation script returned error exit status 127
dpkg: dependency problems prevent configuration of mysql-server:
mysql-server depends on mysql-server-5.5; however:
Package mysql-server-5.5 is not configured yet.
dpkg: error processing package mysql-server (--configure):
mysql-server-5.5
mysql-server
root@ceshivps:~#
求助,安装mysql失败
- 系统: ubuntu14.04
Re: 求助,安装mysql失败
这样不行么?说是少了bsdutils,但是我google了好久,没找到
sudo apt-get install --reinstall bsdutils
sudo apt-get install --reinstall mysql-server
http://askubuntu.com/questions/506243/m ... -not-found
http://ubuntuforums.org/showthread.php?t=2246433
- 系统: ubuntu14.04
Re: 求助,安装mysql失败
OK了,谢谢啦、vickycq 写了:这样不行么?说是少了bsdutils,但是我google了好久,没找到参考代码: 全选
sudo apt-get install --reinstall bsdutils sudo apt-get install --reinstall mysql-server
- 系统: ubuntu14.04
Re: 求助,安装mysql失败
搞定了,谢谢啦。vickycq 写了:这样不行么?说是少了bsdutils,但是我google了好久,没找到参考代码: 全选
- 系统: ubuntu14.04
Re: 求助,安装mysql失败
搞定了,谢谢楼上啦
