我在Ubuntu下装了两个MySQL实例,一个在3306端口,另一个在3307端口。
第一个实例可以用mysql -u root -p 来连接, 没问题。
第二个实例只能用mysql --protocol=tcp --port=3307, -h127.0.0.1 -u root -p 来连接。如果我用mysql -u root -p --socket=/var/lib/mysql2/mysqld2.sock 来连接,就会报错:ERROR 2002 (HY000): Can't connect to local MySQL server through socket '/var/lib/mysql2/mysqld2.sock' (13)
我查了一下,我其实有这个socket文件,为什么系统还要报错呢?
sudo ls -l /var/lib/mysql2/mysqld2.sock
srwxrwxrwx 1 mysql mysql 0 Nov 4 16:30 /var/lib/mysql2/mysqld2.sock
以下是我的my.cnf 文件的一部分,请指点哪个地方出问题了。 谢谢。
[mysqld_safe]
socket = /var/lib/mysql2/mysqld2.sock
nice = 0
[mysqld_multi]
mysqld = /usr/bin/mysqld_safe
mysqladmin = /usr/bin/mysqladmin
user = boss
password = boss
[mysqld1]
# * Basic Settings
user = mysql
pid-file = /var/run/mysqld/mysqld.pid
socket = /var/run/mysqld/mysqld.sock
port = 3306
basedir = /usr
datadir = /var/lib/mysql
tmpdir = /tmp
lc-messages-dir = /usr/share/mysql
skip-external-locking
[mysqld2]
pid-file = /var/lib/mysql2/mysqld2.pid
port = 3307
datadir = /var/lib/mysql2
user = mysql
tmpdir = /tmp
log-error = /var/log/mysql2.err
MySQL的第二个实例客户端连接问题
- 系统: Windows 7
