下面是安装过程。。
参考资料
http://edin.no-ip.com/blog/hswong3i/ora ... 2-04-howto
1.首先,将系统更新到最新
sudo apt-get update
sudo apt-get dist-upgrade
sudo apt-get install alien binutils build-essential cpp-4.4 debhelper g++-4.4 gawk gcc-4.4 gcc-4.4-base gettext html2text ia32-libs intltool-debian ksh lesstif2 lib32bz2-dev lib32z1-dev libaio-dev libaio1 libbeecrypt7 libc6 libc6-dev libc6-dev-i386 libdb4.8 libelf-dev libelf1 libltdl-dev libltdl7 libmotif4 libodbcinstq4-1 libodbcinstq4-1:i386 libqt4-core libqt4-gui libsqlite3-0 libstdc++5 libstdc++6 libstdc++6-4.4-dev lsb lsb-core lsb-cxx lsb-desktop lsb-graphics lsb-qt4 make odbcinst pax po-debconf rpm rpm-common sysstat unixodbc unixodbc-dev unzip
4.检查系统变量
/sbin/sysctl -a | grep sem
/sbin/sysctl -a | grep shm
/sbin/sysctl -a | grep file-max
/sbin/sysctl -a | grep aio-max
/sbin/sysctl -a | grep ip_local_port_range
/sbin/sysctl -a | grep rmem_default
/sbin/sysctl -a | grep rmem_max
/sbin/sysctl -a | grep wmem_default
/sbin/sysctl -a | grep wmem_max
fs.aio-max-nr = 1048576
fs.file-max = 6815744
kernel.shmall = 2097152
kernel.shmmax = 536870912
kernel.shmmni = 4096
kernel.sem = 250 32000 100 128
net.ipv4.ip_local_port_range = 9000 65500
net.core.rmem_default = 262144
net.core.rmem_max = 4194304
net.core.wmem_default = 262144
net.core.wmem_max = 1048586
sysctl -p
在 /etc/security/limits.conf 文件中增加以下数据
oracle soft nproc 2047
oracle hard nproc 16384
oracle soft nofile 1024
oracle hard nofile 65536
oracle soft stack 10240
查看/etc/pam.d/login,增加以下行(有了就不用增加了)
session required pam_limits.so
mkdir ~/Oracle/oracle11g
mkdir ~/Oracle/oradata
7.配置环境变量
在~/.bashrc中增加以下环境变量(最好把~替换成绝对路径)
#这个写刚刚创建的文件夹
export ORACLE_BASE=~/Oracle/oracle11g
#这个后面(貌似)可以随便填写
export ORACLE_HOME=$ORACLE_BASE/product/11.2.0/dbhome_1
#数据库的sid
export ORACLE_SID="orcl"
#默认字符集
export NLS_LANG=.AL32UTF8
mkdir /usr/lib64
ln -s /etc /etc/rc.d
ln -s /lib/x86_64-linux-gnu/libgcc_s.so.1 /lib64/
ln -s /usr/bin/awk /bin/awk
ln -s /usr/bin/basename /bin/basename
ln -s /usr/bin/rpm /bin/rpm
ln -s /usr/lib/x86_64-linux-gnu/libc_nonshared.a /usr/lib64/
ln -s /usr/lib/x86_64-linux-gnu/libpthread_nonshared.a /usr/lib64/
ln -s /usr/lib/x86_64-linux-gnu/libstdc++.so.6 /lib64/
ln -s /usr/lib/x86_64-linux-gnu/libstdc++.so.6 /usr/lib64/
echo 'Red Hat Linux release 5' > /etc/redhat-release
10.运行安装程序
cd /XXX/XXX/XXX
./runInstaller
a)有路径设置的地方请多加注意,理论上我们前面已经配置了环境变量,不会有大问题,但是为了以防万一还请多加注意。
b)字符集最好选择utf8
c)在执行'链接二进制文件'时如果遇到错误请在不关闭安装程序的情况下打开一个新终端,输入以下命令
sed -i 's/^\(\s*\$(MK_EMAGENT_NMECTL)\)\s*$/\1 -lnnz11/g' $ORACLE_HOME/sysman/lib/ins_emagent.mk
sed -i 's/^\(\$LD \$LD_RUNTIME\) \(\$LD_OPT\)/\1 -Wl,--no-as-needed \2/g' $ORACLE_HOME/bin/genorasdksh
sed -i 's/^\(\s*\)\(\$(OCRLIBS_DEFAULT)\)/\1 -Wl,--no-as-needed \2/g' $ORACLE_HOME/srvm/lib/ins_srvm.mk
sed -i 's/^\(TNSLSNR_LINKLINE.*\$(TNSLSNR_OFILES)\) \(\$(LINKTTLIBS)\)/\1 -Wl,--no-as-needed \2/g' $ORACLE_HOME/network/lib/env_network.mk
sed -i 's/^\(ORACLE_LINKLINE.*\$(ORACLE_LINKER)\) \(\$(PL_FLAGS)\)/\1 -Wl,--no-as-needed \2/g' $ORACLE_HOME/rdbms/lib/env_rdbms.mk
d)最后一步需要让我们手动执行两个文件,第一个应该没啥问题。第二个会提示无法创建目录,根据提示手动创建就好了。
e)安装过程中最好别点不需要的按钮。避免不必要的错误
f)good luck
