我的安装不成功拉!!!!!!!!!1
帮忙看看
$ ./runInstaller -jreLoc $JAVA_HOME/jre
正在启动 Oracle Universal Installer...
正在检查安装程序要求...
检查操作系统版本: 必须是redhat-3, SuSE-9, redhat-4, UnitedLinux-1.0, asianux-1 or asianux-2
通过
所有安装程序要求均已满足。
准备从以下地址启动 Oracle Universal Installer /tmp/OraInstall2011-01-07_01-06-35PM. 请稍候...UnZip 5.50 of 17 February 2002, by Info-ZIP. Maintained by C. Spieler. Send
bug reports to the authors at
Zip-Bugs@lists.wku.edu; see README for details.
Usage: unzip [-Z] [-opts[modifiers]] file[.zip]
- [-x xlist] [-d exdir]
Default action is to extract files in list, except those in xlist, to exdir;
file[.zip] may be a wildcard. -Z => ZipInfo mode ("unzip -Z" for usage).
-p extract files to pipe, no messages -l list files (short format)
-f freshen existing files, create none -t test compressed archive data
-u update files, create if necessary -z display archive comment
-x exclude files that follow (in xlist) -d extract files into exdir
modifiers: -q quiet mode (-qq => quieter)
-n never overwrite existing files -a auto-convert any text files
-o overwrite files WITHOUT prompting -aa treat ALL files as text
-j junk paths (do not make directories) -v be verbose/print version info
-C match filenames case-insensitively -L make (some) names lowercase
-X restore UID/GID info -V retain VMS version numbers
-M pipe through "more" pager
Examples (see unzip.txt for more info):
unzip data1 -x joe => extract all files except joe from zipfile data1.zip
unzip -p foo | more => send contents of foo.zip via pipe into program more
unzip -fo foo ReadMe => quietly replace existing ReadMe if archive file newer
写入目录 /tmp/OraInstall2011-01-07_01-06-35PM 时出错。请确保此目录是可写的, 并且至少有 60 MB 的磁盘空间。无法继续安装。
: 成功
